Hi, Just did scan and got 2 problem, one on A/C and one on ABS,
1. On A/C, Front A/C blower does't work, rear blower work occasionally, what is the possible fix to this?
2. ABS issue, I don't know if this is related, in up-hill situation, stopping at traffic light (engine stop as the auto-start is on), when release the foot brake, the car roll back (engine start is not fast enough), I apply the foot brake again to stop it from rolling back, then the Traction Control warning is on.
What is the possible fix to this?
Alex
Alex
Saturday,20,January,2018,10:39:49:46832
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4401.4
VIN: WAUZZZ4L1ED031082 License Plate: MT1107
Mileage: 40270km-25022mi Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 18 19 28 36 42 46 4F 52 55
56 5F 62 6C 6D 6F 72
VIN: WAUZZZ4L1ED031082 Mileage: 40270km-25022miles
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 2196593
Shop #: WSC 31414 790 00001
VCID: 3432141F423000A78E9-8060
Reset counter: 203
Mileage: 39310 km
Date: 2017.12.18
Time: 15:49:56
Count: 2049
Count: 128
Count: 30470
00814 - Solenoid for Brake Pressure (N247)
Fault Status: 00101100
Reset counter: 208
Mileage: 38475 km
Date: 2017.11.23
Time: 09:01:44
Count: 2049
Count: 111
Count: 30982
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AN
Revision: 00---031 Serial number: 00000030324489
Coding: 01029456
VCID: 2514F95BF5EA692F097-8070
01273 - Fresh Air Blower (V2)
Fault Status: 00101010
Fault Frequency: 139
Reset counter: 224
Mileage: 39858 km
Date: 2018.01.06
Time: 09:53:43
Temperature: 30.0°C
Speed: 49.0 km/h
(no units): 72.0
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AD
Revision: 00---011 Serial number: 00000000418978
Coding: 0000006
VCID: 688AB06F4E78B447F21-803C
00003 - Control Module
Fault Status: 00100011
Mileage: 36665 km
Date: 2017.09.03
Time: 12:59:22
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 173
Mileage: 39858 km
Date: 2018.01.06
Time: 09:53:48
