Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 2014 VW Jetta MK6 Bi-Xenon Converson
    Jan 2018
    Trinidad and Tobago
    Question 2014 VW Jetta MK6 Bi-Xenon Converson
    Hello Ross-Tech,
    I'm a bit new here but i hope to make some valuable contributions to the forum through the tasks at which i am looking to venture into.
    Vehicle:-
    I am currently the owner of a Euro Spec 2014 VW Jetta MK6. My vehicle is RHD and came with a 1.4 Turbo Supercharged Engine
    What I have:-
    I purchased a Set of OEM VW Jetta Bi-Xenon DRL Headlights for my vehicle.
    Part numbers: 5C7941751.D / 5C7941752.D
    The vehicle came with Factory Installed Halogen Headlamps (Euro Spec).
    Current Position:-
    So I had the lights installed over the weekend and they look great. When i Turn the ignition on, There's no DRL. So i tired the headlights. At first both headlights came on and the High and Low beams of the Bi Xenon came on. The indicator works as well.
    However, when i start the vehicle, the Bi-Xenon's begin to flicker and then turn off. Also the Headlight adjusters do not work and the lights are currently on the ground.
    I purchased these off of eBay and they came with adapters (10pins to 14pins), however, when i took the tape off of it, i noticed that there were wires joined in all different patterns. After doing some research (on Ross Tech Forum), some of the pin arrangements were in the right place (I just did not trust the shabby cut and join work on the harness) but just to be safe I'm considering getting these off kufatec:-
    https://www.kufatec.de/shop/en/volks...c-vw-sharan-7n
    But To Note: The original harness coming from the vehicle (10pins) currently has 9pins in use and one vacant (Just in the event that this may add in the adapter decision)
    Summery of what works and what doesn't:-
    So with the Bi-Xenon's installed, i currently have the following:-
    Loads of Errors on the Dash
    Light Error Indicator on
    No DRL Lights
    Bi-Xenon Flickering and Cuts off
    Height Adjusters not functional
    Left light makes a "Motor Moving type sound" every time the light turns on
    Indicator works
    Turn assist does not function on the headlights
    What I Purchased and Questioning:-
    I today purchased a VCDS HEX-V2 Enthusiast USB Interface from Ross Tech
    I'm thinking about purchasing the Adapter/Converter Cable from kufatec but I'm looking for some advise on this before purchasing.
    This harness Wires into the CECM at terminal 48 & 49. I've read that some persons who did this conversion, stated that they required to do this in order to get the DRLs working.
    Assistance required:-
    At this point, i really need some assistance in the following:-
    Would the 10Pin to 14Pin cable be required for the correct functioning of the Xenon Headlights?
    How can I resolve the Flickering and turning off issue with the Bi-Xenon?
    How can i get the DRL's Working?
    How can i get the Headlight Height adjusters working?
    How do I code the CECM to remove these errors from the dash and have the lights working as they should?
    Tuesday,09,January,2018,21:34:28:42155
    VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4409.4
    VIN: WVWZZZ16ZDM060166
    Mileage: 30000km-18641mi
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72
    77
    VIN: WVWZZZ16ZDM060166 Mileage: 30000km-18641miles
    Address 01: Engine (J623-CTHD) Labels:. 03C-907-309-V1.clb
    Part No SW: 03C 906 026 BG HW: 03C 907 309 Q
    Component: 1.4l R4 TSI H02 3743
    Revision: LMH02--- Serial number: 00000000000000
    Coding: 00250012002400000000
    Shop #: WSC 00066 000 00189
    ASAM Dataset: EV_ECM14TSI01103C906026BG 001002
    ROD: EV_ECM14TSI01103C906026AB.rod
    VCID: 66954BA358ED8787C0D-8032
    4674 - Please Check Fault Codes in Control Module for ABS Brakes
    U1017 00 [036] - -
    Mileage: 30007 km
    Date: 2018.01.09
    Time: 17:16:18
    Engine speed: 1898.00 /min
    Normed load value: 8.2 %
    Vehicle speed: 23 km/h
    Coolant temperature: 51 C
    Intake air temperature: 34 C
    Voltage terminal 30: 14.065 V
    Cruise Control System (CCS): status-Bit 0: 00001011
    Cruise control switch-off: irreversible w. brake intervention-Bit 0: 00000000
    Cruise control switch-off: reversible-Bit 0: 11111111
    Cruise control switch-off: irreversible-Bit 0: 11111111
    Acceleration: 0.000 m/s
    4675 - Please Check Fault Codes in Control Module for ABS Brakes
    U1017 00 [047] - -
    Fault Frequency: 15
    Mileage: 29760 km
    Date: 2018.01.02
    Time: 16:07:04
    Engine speed: 811.00 /min
    Normed load value: 18.8 %
    Coolant temperature: 89 C
    Intake air temperature: 58 C
    Voltage terminal 30: 13.428 V
    Cruise Control System (CCS): status-Bit 0: 00001100
    4629 - ECM Power Relay Load Circuit
    P068A 00 [032] - Opens Too Early
    5523 - Engine Start Blocked by Immobilizer
    P1570 00 [032] - -
    Address 02: Auto Trans Labels: 0AM-927-769.clb
    Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
    Component: GSG DSG AG7 431 3652
    Revision: 00043014 Serial number: CU501211266331
    VCID: 3E25C3C36C7DFF4768D-806A
    006279 - Wheel-Speed Signal from ABS Control Module
    P1887 - 000 - Implausible Signal - Intermittent
    Fault Frequency: 25
    Reset counter: 10
    Mileage: 29733 km
    Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152
    Revision: 00H31001
    Coding: A63B60F8212800FA650C06EA841F0080211800
    VCID: 7DA704CF2DFB245F317-8028
    03841 - RPM Sensor Rear Left: Incorrect Signal
    Reset counter: 14
    Mileage: 29829 km
    Date: 2018.01.05
    Time: 13:02:24
    Count: 16384
    Count: 14
    Count: 12800
    Count: 71
    Count: 49408
    Count: 65027
    Count: 18749
    Reset counter: 17
    Mileage: 29836 km
    Date: 2018.01.06
    Time: 12:13:27
    Count: 3
    Count: 14
    Count: 28672
    Count: 128
    Count: 43264
    Count: 1
    Count: 51
    Fault Status: 00100011
    Reset counter: 233
    Mileage: 30007 km
    Count: 12288
    Count: 67
    Count: 51201
    Count: 64757
    Count: 63488
    Count: 59
    Fault Status: 00101100
    Reset counter: 229
    Mileage: 29729 km
    Date: 2018.01.01
    Time: 06:29:28
    Count: 16391
    Count: 12
    Count: 16896
    Count: 64
    Count: 45056
    Count: 65280
    Count: 52
    Part No SW: 3AA 907 044 AF HW: 3AA 907 044 AF
    Component: Climatronic H03 0303
    Revision: 00001K02
    Coding: 0010004002
    Shop #: WSC 00066 000 00119
    ROD: EV_ClimaAutoBasis_VW32.rod
    VCID: 74B121EB1E3165174E9-8020
    Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
    Component: BCM PQ35 M 021 0068
    Revision: BC021001
    Coding: 08000A3A802DE1C0408800801000816403000088508089605C 8000000040
    VCID: 3E25C3C3607DFF4768D-806A
    Subsystem 1 - Part No: 1K8 951 171
    12 Faults Found:
    Fault Status: 00100111
    Fault Frequency: 252
    Reset counter: 15
    Mileage: 29586 km
    Date: 2017.12.23
    Time: 10:03:38
    Voltage: 13.70 V
    Fault Status: 00101010
    Reset counter: 10
    Mileage: 29586 km
    Date: 2017.12.26
    Time: 17:43:02
    Voltage: 13.90 V
    Fault Frequency: 191
    Reset counter: 15
    Mileage: 29586 km
    Date: 2017.12.23
    Time: 10:03:38
    Voltage: 13.70 V
    Fault Frequency: 24
    Reset counter: 10
    Mileage: 29586 km
    Date: 2017.12.23
    Time: 10:03:46
    Voltage: 13.75 V
    Reset counter: 4
    Mileage: 29595 km
    Date: 2017.12.26
    Time: 22:58:02
    Voltage: 11.90 V
    Fault Status: 01101010
    Reset counter: 218
    Mileage: 29586 km
    Date: 2017.12.23
    Time: 09:18:40
    Voltage: 11.60 V
    Reset counter: 4
    Mileage: 29595 km
    Date: 2017.12.26
    Time: 22:59:57
    Voltage: 12.15 V
    Reset counter: 218
    Mileage: 29586 km
    Date: 2017.12.23
    Time: 09:50:23
    Voltage: 11.85 V
    Reset counter: 218
    Mileage: 29586 km
    Date: 2017.12.23
    Time: 09:18:42
    Voltage: 11.65 V
    Reset counter: 218
    Mileage: 29586 km
    Date: 2017.12.23
    Time: 09:50:24
    Voltage: 11.85 V
    Fault Frequency: 50
    Reset counter: 233
    Mileage: 29586 km
    Date: 2017.12.23
    Time: 09:20:13
    Voltage: 12.10 V
    Fault Frequency: 51
    Reset counter: 233
    Mileage: 29586 km
    Date: 2017.12.23
    Time: 09:50:29
    Voltage: 11.90 V
    Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
    Part No SW: 5C6 919 475 HW: 7E0 919 475 A
    Component: PARKHILFE 8K H10 0005
    Revision: -------- Serial number: 07381302100884
    Coding: 108101
    ASAM Dataset: EV_EPHVA18VW3610000 001003
    ROD: EV_EPHVA18VW3610000.rod
    VCID: 71BF28FF6123503FA5F-8024
    Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
    Component: AirbagVW10 013 0613
    Serial number: 003G6M085PSR
    Coding: 00003241
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 323DE7F3A4A52B279C5-8066
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Serial number: 3572MSME560E1376ZZZZ
    Serial number: 3582MSME040C1376ZZZR
    Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Serial number: 3516KSME6C726420ZZZS
    Serial number: 3526KSME0A096520ZZZM
    Part No SW: 1K5 953 507 T HW: 5K0 953 549 B
    Component: Lenks.Modul 008 0090
    Revision: -------- Serial number: 90422LKU0004X
    Coding: 088A140000
    Shop #: WSC 00066 000 00187
    ROD: EV_SMLSNGKUDS_A05.rod
    VCID: 42DDB73314059BA70C5-8016
    Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H31 0037
    Serial number: 0053220 FLE 20130103
    Coding: 820000
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
    Part No SW: 5C6 920 872 HW: 5C6 920 872
    Component: KOMBI H07 0705
    Coding: 171B00
    VCID: 6A8D3F934CF5A3E7E45-803E
    Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
    Component: J533 Gateway H50 1634
    Revision: H50 Serial number: 04011303290002
    Coding: 351003
    VCID: 76B51BE308CD770770D-8022
    Component: IMMO H07 0705
    Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
    Component: SG EXT.PLAYER H19 0550
    Revision: A1001003 Serial number: 7664004002
    Coding: 010100
    VCID: 2A0DFF938CF563E7245-807E
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0515
    Revision: 13110009 Serial number: 0006013436
    Coding: 0002B5
    Shop #: WSC 01383 790 50316
    VCID: 5BE36A5793AFCA6F6F3-800E
    Slave Driver:
    Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 008 1508
    Serial number: 00000007488986
    Coding: 000290
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 69 3305
    Revision: 00H22000
    VCID: 372BD6E74347CE0FABB-8062
    Fault Status: 00101101
    Fault Frequency: 18
    Reset counter: 18
    Mileage: 30008 km
    Date: 2018.01.09
    Time: 17:46:04
    Voltage: 14.00 V
    DU
    Temperature: 37.0C
    RPM: 1606 /min
    Speed: 38.0 km/h
    Speed: 38.0 km/h
    Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
    Component: EZE_2 H50 1634
    Coding: 01030100
    VCID: 6FBB2E87779746CFB3B-803A
    Subsystem 1 - Part No SW: 5K0 959 591 HW: 5K0 959 591
    Component: J245 PS41.022 H10 0007
    Serial number: WRH0007POUD
    Coding: 180000
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0515
    Revision: 15110009 Serial number: 0006158935
    Coding: 0002B4
    VCID: 5CE1694B96A1CD57669-8008
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 008 1508
    Serial number: 00000007522919
    Coding: 000290
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
    Component: Radio RCD510 005 0236
    Revision: 00000001 Serial number: VWZ1Z3M9873940
    Coding: 01000400040006
    VCID: 241111ABEED1B5971E9-8070
    Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
    Component: TELEFON H15 3200
    Revision: 1B001001 Serial number: 00007663943662
    Coding: 0A00000000010100
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_002.rod
    VCID: 3A2DCFD37CD5D367545-806E
    End----------(Elapsed Time: 01:23, VBatt start/end: 12.3V/12.3V)-----------
    __________________________________________________ __________________________________________________ __________________________________________________ _______________________________________________
    I haven't received the Bi-Xenon 10pin to 14pin Adapter Cable yet. (The shipping has been rescheduled....sigh)
    I did perform two changes and the headlight are not flickering anymore...
    I Enabled "Bi-Xenon Headlights (with Shutter) Installed", in the Byte 14 - (This stopped the Flickering)
    AND
    I Enabled "High Beam via Shutter active/installed", in the Byte 25 (Tried this, but the high beam only works when the lights are on, but i cant flash the lights when the headlights are off.
    Will install and try some more coding then. don't want to try much with these Adapters since they maybe wired incorrectly.
    Any advise would be appreciated.
    Thanks in advance everyone!
    Kind regards,
    Vapor.Rob
    Aug 2016
    Switzerland
    >> yes
    >> correct coding combined with correct BCM
    >> Install module 55 Xenon Range and wire it all up
    Byte 11 --> bit 2 = 0, bit 7 = 1
    Byte 15 --> bit 3, 6, 7 = 1
    Byte 18 --> HEX 04
    Byte 24 --> bit 7 = 1 / Value set for DRL brightness to 100%
    Byte 25 --> bit 6 = 0
    Byte 26 --> bit 3 = 1
    Byte 27 --> bit 2 = 1
    Xenon range: install and wire module, install and wire AFS sensor, enable address 55 in gateway, go to 55, basic settings, enter 1446940.
    Leveling headlights: go to 55, basic settings, adaptation, select ON/Off, wait for the calibration
  3. Likes Dana liked this post
    Jan 2018
    Trinidad and Tobago
    Talking
    >> yes
    Byte 18 --> HEX 04
    Hey iichel,
    Thanks soo much for responding. This some useful information. Ok so i will try these and provide feedback. But can i use the lights without the automatic leveling system?
    Aug 2016
    Switzerland
    i suppose you could, but a better question maybe whether you should.
    often it's required simply by regulation. and it's better not to blind people with HID headlights.
  6. Likes Uwe liked this post
    Jan 2018
    Trinidad and Tobago
    Honestly i would prefer the automatic leveling but at the moment the cost is a bit high. So i wanted to get these lights working and then retro fit the auto leveling afterwards. Once i can use the leveling adjuster inside the car from the halogens i should be ok for the while. as for the regulations, were i live, there's currently no regulations on HIDs. its so bad, that you would not get a ticket for driving with hids but you would get a ticket for driving with your foglamps on
    Aug 2016
    Switzerland
    it's not possible to use the manual headlight adjuster in the car with original HID headlights.
    I'm not sure how expensive OEM HID's are and if you're going through the effort and expense of fitting OEM HID's, the AFS system is only a small in relation, both in cost and in effort.
    and driving with your fogs on, in bright daylight makes you look like a 16 year old.
    and driving with your fogs on, in darkness, makes you an idiot. i'm quite OK with people getting fines for this.
  9. Likes Eric liked this post
  10. #7
    Jan 2018
    Trinidad and Tobago
    well it is what it is, but tell me, the lights would not raise to the correct level unless i install the automatic leveling? because at the moment they're on the ground....
  11. #8
    Jan 2018
    Trinidad and Tobago
    Hey everyone,
    so I got the Adapter from kufatec today, and i'm in a little more trouble. So i installed them, the light were exactly as they were before, (beams on the ground, no drl, or high beam flash with control).
    I tired the byte adjustments above and it didnt change the behavour of the lights, however, my rear lights are really dim and the reverse light turns on when i turn the switch on.
    I put the Byte 18 back to the original setting which is "00 Lighting: Standard/Parameter Settings (EEPROM) which did not help.
    I also revert all the other setting back to its original settings and i am still having the problem with the reverse light being on and the dim rear park lights.
    Any assistance on how i can get this fixed? seems like im grounded for the evening....
  12. #9
    Jan 2018
    Trinidad and Tobago
    Update: so I went back into the byte18 and changed the value to "Jetta - RoW" and I was able to get things back to normal.
    But I still can't get the DRLs working, headlight height adjuster or the high beam flash. Any suggestions....
  13. Likes Dana liked this post
  14. #10
    Per a PM from the OP: Hex 8C Jetta (162/VW361) Rest if Word (ROW) fixed up the Byte 18 problem. That may be valuable to someone with a RoW 162 chassis sedan that needs to get factory functions re-enabled.
    I agree with iichel here. Installing a 55-Xenon range module is a requirement for assistance from us directly .. but more importantly having a fully functional AFS system is a much better driving experience and safer for all oncoming traffic. The conventional short coding he provided (1446940) would apply to the older CAN protocol 55 type. We have that Software Part Numbers 5M0-907-357 through 5M0-907-357-D split shown on this page: VW Golf (1K) Headlight Aim Control (Xenon with AFS)
    Software Part Numbers 5M0-907-357-E and above are the newer UDS type. What we see frequently is new UDS modules sourced from 3rd party suppliers that have No End of Line Programming DTCs which prevent coding and Basic Settings. For that reason I would try to retrofit the complete system from an older CAN setup if possible.
    Next, factory installed BCMs with part numbers other than ?K0-937-087-?? (i.e.087) rarely have the terminals inside the controller for proper high beam shutter activation. There are some exceptions to that rule .. but they are rare.
    This may not be the most up to date revision but PL24 shows this BCM as the direct replacement by VIN: 5K0-937-087-R/ZHB
    So, if you wanted to install a BCM that was guaranteed compatible with this vehicle and install all of the components required for a factory-like AFS system I would double check to make sure that number is the latest version and install the higher end BCM. You would still have to iron out the AFS details after a 55 module is installed and communicating.
  15. Likes Uwe, iichel, Eric liked this post
