- Oct 3, 2016
- 94
- 36
- Stockholm Sweden
- C?ID=172802
Hi!
The G450 is changed to a brand new. Does it need to be adapted and calibrated? The car runs much better, but still not perfect.
Scan before the change. No scan after available right now.
2.0 TDI 103kW Multivan MY 2010 DSG
Wednesday,10,January,2018,16:35:49:08489
VCDS Version: 17.8.1.0 (x64) HEX-NET CB: 0.4411.4
VIN: WV2ZZZ7HZAH22xxxx License Plate: DCF677
Mileage: 199910km-124218mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 56 69 0B
VIN: WV2ZZZ7HZAH22xxxx Mileage: 199910km-124218miles
Address 01: Engine (J623-CCHA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 022 GF HW: 03L 907 309 K
Component: R4 2,0L EDC H32 9130
Revision: 26H32--- Serial number: 00000000000000
Coding: 0125401A233400080000
Shop #: WSC 40760 222 999999
ASAM Dataset: EV_ECM20TDI01103L906022GF 002008
ROD: EV_ECM20TDI01103L906019DG.rod
VCID: 6FAE0AC8B6BC253E78-803A
12002 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [237] - Implausible Signal
Mileage: 196116 km
Date: 2017.12.13
Time: 17:43:52
Coolant temperature: 73 °C
Intake air temperature: 17 °C
Voltage terminal 30: 12.620 V
Sensor for particle filter differential press: raw value: -168 hPa
Particle filter: difference pressure: -18 hPa
Particle filter: offset for differential press.: -74 hPa
Particle filter: differential pressure: dynamic offset: -150 hPa
Outside air temperature: 2.5 °C
Particle filter: soot mass measured: 0.00 g
Particle filter: soot mass calculated: 1.64 g
5175 - Fuel Pressure Regulation
P1065 00 [104] - Regulation Discrepancy
Mileage: 197216 km
Date: 2017.12.22
Time: 11:53:38
Engine speed: 1462.50 /min
Normed load value: 56.1 %
Vehicle speed: 78 km/h
Coolant temperature: 60 °C
Intake air temperature: 10 °C
Voltage terminal 30: 14.420 V
Engine status: COENG_RUNNING
Fuel temperature: 13.8 °C
Mean injection quantity: 30.57 mg/stroke
Pressure control valve adaptation factor: 0.7000
Fuel pressure regulator valve: specified value rail pressure: 1.1142e+006 hPa
High fuel pressure: specified value: 847300 hPa
Fuel high pressure: actual value: 891100 hPa
Readiness: 1 1 0 0 0
Part No SW: 0BT 300 045 P HW: 0BH 927 711 C
Component: DSG DQ500-7F H08 1801
Revision: 00H08V01
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 42C8937CD5AEF856C7-8016
Address 03: ABS Brakes (-----) Labels:. 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 E HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0103
Revision: 00H43001
Coding: 208764AD09A6049C26A390766A5F16
Shop #: WSC 02756 000 49167
VCID: 3424C5A4971A46E645-8060
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 E HW: 7E5 907 040 E
Component: ClimatronicT5 H10 0101
Coding: 0004000102
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_ClimatronicT5 A01002
ROD: EV_ClimaAutoT5Basis.rod
VCID: 2A18DBDC4DDE0016EF-807E
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 A HW: 7E5 907 049 A
Component: Heckbedienung H10 0101
Serial number: BHB-0010412090010071
9481748 - High Pressure Sensor
B10AE 14 [008] - Open or Short to Ground
Reset counter: 84
Mileage: 199830 km
Date: 2018.01.10
Time: 08:00:55
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 B HW: 7H0 937 087 B
Component: BCM T5GP H+4 H46 0207
Revision: BO046001 Serial number: 0156 343090809
Coding: A0A0293A0E212002002800003C2B8DD40080410F60040000300000000000
Shop #: WSC 02756 790 00000
VCID: 3326C6B8921441DE5C-8066
Subsystem 1 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3310
Subsystem 2 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3310
Subsystem 3 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 50000000000000041839
Coding: E20000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 A HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0008
Revision: -------- Serial number: 32730932804121
Coding: 110101
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_VW75XParkAssis8K A01003
ROD: EV_VW75XParkAssis8K_A01.rod
VCID: 302CC9B46B027AC621-8064
Part No SW: 7E0 959 655 HW: 7E0 959 655
Component: VW10Airbag01L H05 0011
Revision: -------- Serial number: 003E40007YM+
Coding: 00000000000000000000000000000000314C
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 73A606B8DA9401DE9C-8026
Serial number: 3495ZRB40616DUG6H8H3
Serial number: 3505ZRB40616DUG628MS
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 7E0 920 870 A HW: 7E0 920 870 A
Component: KOMBI H16 0111
Coding: 160F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
VCID: 271E22E85ECC3D7EF0-8072
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 A
Component: J737__Standheizung 0404
Revision: 00085000 Serial number: 09019275D00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 230636F8E2F4D15EAC-8076
00664 - Fuel gauge
Fault Frequency: 78
Mileage: 195657 km
Date: 2012.05.01
Time: 18:26:03
Temperature: 15.0°C
Voltage: 14.21 V
Temperature: -1.0°C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087 B
Component: GW-K-CAN TP20 0207
Coding: 042200
VCID: 70AC09B4A3823AC661-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H16 0111
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
Part No SW: 7H0 035 186 A HW: 7H0 035 186 A
Component: Radio RCD310 006 0049
Revision: 00000001 Serial number: VWZ1Z2K3761902
Coding: 0500040004
VCID: 271E22E856CC3D7EF0-8072
03138 - Input AUX IN
Fault Status: 01101011
Reset counter: 168
Mileage: 195434 km
Date: 2012.04.30
Time: 10:13:31
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H08 0080
Revision: 3A002002 Serial number: 00000123984217
Coding: 4100000100000000
VCID: 2F2ECAC87E3C653E38-807A
End----(Elapsed Time: 01:31, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
Address 01: DTCs cleared
Address 08: DTCs cleared
Address 18: DTCs cleared
