Guys I have retro fitted the rain light sensor to my polo and its working and happy but I just cant get the Coming Home/Leaving home to work...Can anyone help with this please?????
I have activated it in the 5F for both options and you can change the time you want it set to but it just doesn't work.
I have done a full scan and Adapmap of 09 BCM/Gateway & 5F
Full Scan!!!
BCM/Gateway!!!
5F Adapmap!!!
Full Scan!!!
Tuesday,16,January,2018,18:29:18:48600
VCDS Version: 17.8.1.0
Dealer/Shop Name: VCDS
Workshop Code: 444 03743 000001
VIN: WVWZZZ6RZFU042052 License Plate: SP15MDO-RAIN LIGHT SENSOR FITTED
Mileage: 112439km-69866mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 47 57 5F
VIN: WVWZZZ6RZFU042052 Mileage: 112439km-69866miles
47-Sound System -- Status: Cannot be reached 0100
57-TV Tuner -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 HW: 04C 907 309 J
Component: R3 1.0l MPI H23 8071
Revision: 31H23000
Coding: 01110052022401080000
Shop #: WSC 34575 001 1048576
ASAM Dataset: EV_ECM10MPI01104C906057 001012
ROD: EV_ECM10MPI_VW26.rod
VCID: 62C0BA9975F26956E7-8036
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 HW: 6R0 907 379 BA
Component: ESP9.0i H03 0002
Serial number: 08510702140901
Coding: 23DD2485492733C20914106E0053C42492CC90080005C7090C00
Shop #: WSC 03743 444 00001
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
VCID: 6CDCD4A187362F265D-8038
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H02 0105
Serial number: 1408251B-0159
Coding: 200000001000100000
Shop #: WSC 31414 790 50316
ROD: EV_ACManueKMMValeoPQ26_VW26.rod
VCID: 1D3AC9650C0C16AE9A-8048
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 A HW: 6C0 937 089
Component: BCM PQ26 Hi4R H06 0047
Serial number: 009458005500
Coding: 0300084042530A730BA44080B10707C800005B0257010000000000000000
ASAM Dataset: EV_BCMA0 004003
ROD: EV_BCMA0_004_VW26.rod
VCID: 2E581EA971AA9D3633-807A
Subsystem 1 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M04D27H13M00S51
Coding: 1238DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 CH HW: 6R0 959 801 CF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 9610
Serial number: KU0KU030011550301321
Coding: 1400A1
Subsystem 3 - Part No SW: 6R0 959 801 CF HW: 6R0 959 802 CH Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 9610
Serial number: KU0KU003031550625640
Coding: 0400A1
Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150640SRX
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000060144761
Subsystem 6 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU015101442885103
Coding: 1400A0
Subsystem 7 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU019091442622788
Coding: 0400A0
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391510504043
Coding: 0031151041
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 3D7A29E5ACCC76AEBA-8068
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag011 001 0330
Revision: -------- Serial number: 003LM004JBD7
Coding: 88C0C000000000005C000000008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 316205D5609482CE2E-8064
Subsystem 1 - Part No SW: ----------- HW: 410 820 808 14
Component: SideSensor_Df 151 0800
Serial number: 3575H009915C41F2101B
Subsystem 2 - Part No SW: ----------- HW: 410 820 808 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00B716376A1930G
Subsystem 3 - Part No SW: ----------- HW: 442 151 508 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A116C1CE473EP
Subsystem 4 - Part No SW: ----------- HW: 442 151 508 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A009B16C1CE5E2D+
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 6C0 920 940 A HW: 6C0 920 940 A
Component: KOMBI 211 0290
Coding: 232D09002180260001087A001000000000000000
VCID: 2240FA9935722956A7-8076
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0047
Revision: -------- Serial number: 009458005500
Coding: 030100046F0A640071000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_VW26.rod
VCID: 65CAA18564DC1E6E02-8030
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 2181614230501676AD1B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 61247F40302821697543
U1101 00 [009] - Active
Reset counter: 42
Mileage: 112439 km
Date: 2018.01.16
Time: 18:25:07
Supply voltage: Terminal 30: 12.2 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3211
Serial number: CE8M0038
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 336E0FDD9A88B0DE5C-8066
Address 47: Sound System
Address 57: TV Tuner
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 021 D HW: 3G0 035 021
Component: MU-H-LND-EU H33 0814
Serial number: A239I0E7507617
Coding: 02730001FF00000011111201008908002F0000D601208100FE
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
VCID: 1932DD7518246A8E76-804C
Subsystem 1 - Part No SW: 6C0 919 603 HW: 6C0 919 603
Component: ABTm_Std2 H41 1017
Serial number: VWZ8Z9PH000VF3
Subsystem 2 - Part No SW: V03 959 800 QS HW: -----------
Component: ECE 2018 --- 0166
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote---- --- 1010
12 Faults Found:
B201A 00 [009] - -
Reset counter: 41
Mileage: 112385 km
Date: 2018.01.14
Time: 16:16:28
Voltage terminal 30: 14.8 V
Status_Software_Version_Management-module_name: MDUV412/DUV
13697024 - Component Protection
U1100 00 [009] - No Basic Setting
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 16:16:23
Voltage terminal 30: 14.9 V
15361024 - Component Protection
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 16:16:23
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 16:16:23
0513 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 19:03:05
Voltage terminal 30: 12.2 V
B1066 13 [009] - Open Circuit
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 19:03:05
7169 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 16:16:25
Voltage terminal 30: 15.0 V
BAP-BAP_Function_ID: 02
7170 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 16:16:25
7175 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 19:09:06
Voltage terminal 30: 11.9 V
7193 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 16:16:25
7201 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 16:16:25
7203 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 37
Mileage: 112385 km
Date: 2018.01.14
Time: 16:16:25
End-------------------------(Elapsed Time: 03:20)--------------------------
BCM/Gateway!!!
;SW:6C0-937-089-A HW:6C0-937-089 --- Cent. Elect.
;Component:BCM PQ26 Hi4R H06 0047, Coding:03000840425300530BA44080B10703880000580257010000000000000000
;EV_BCMA0,004003,EV_BCMA0_004_VW26.rod
;Wednesday,02,August,2017,16:10:44:48600
;VCDS Version: Release 17.1.3 Data version: 20170320 DS267.7
;VCID: 2E581EA971AA9D314B-807A
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
IDE00001-ENG130235-Production mode-Entry_control,not active
IDE00001-ENG130233-Production mode-Exit_lights_Heading_time_15_s,not active
IDE00001-ENG112304-Production mode-Heckwischer,not active
IDE00001-ENG98647-Production mode-Interior lighting,not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
IDE00001-ENG130234-Production mode-Window_regulator_kl_15_nr_2,not active
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active
IDE00002-Transport mode,active
IDE00820-Activating and deactivating all development messages,not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,not active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,not activated
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active
IDE02152-Characteristics in production mode,0 ms
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active
IDE02332-Deactivate production mode,0
IDE02488-DWA Interior monitoring,100 %
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.50 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,180 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,120 °
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,combined
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active
IDE04923-ENG115774-Turn signal control-Komfortblinken,active
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,Not Present
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,0.0
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,not enabled
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,not active
IDE04926-ENG126570-Comfort illumination-lho_zeit,0 s
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,0 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,not active
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0.0 s
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
IDE05142-ENG116621-Access control-automatisches Entriegeln,active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
IDE05142-ENG116706-Access control-Autounlock NAR,not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
IDE05142-ENG115755-Access control-Notschließfunktion,active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
IDE05142-ENG115758-Access control-Valet Parking,not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,00
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,00
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,00
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,00
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,35
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,09
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,19
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,29
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,0A
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,1A
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,00
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,3F
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,00
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,3A
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,44
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100
IDE05145-ENG114999-Light configuration-Dimming_AB_10,0
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100
IDE05145-ENG115212-Light configuration-Dimming_AB_12,0
IDE05145-ENG114958-Light configuration-Dimming_AB_13,0
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100
IDE05145-ENG115404-Light configuration-Dimming_AB_23,60
IDE05145-ENG115423-Light configuration-Dimming_AB_24,60
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100
IDE05145-ENG115556-Light configuration-Dimming_AB_31,0
IDE05145-ENG115575-Light configuration-Dimming_AB_32,0
IDE05145-ENG115594-Light configuration-Dimming_AB_33,0
IDE05145-ENG115613-Light configuration-Dimming_AB_34,0
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0
IDE05145-ENG115060-Light configuration-Dimming_CD_2,0
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0
IDE05145-ENG115408-Light configuration-Dimming_CD_23,0
IDE05145-ENG115427-Light configuration-Dimming_CD_24,0
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0
IDE05145-ENG115079-Light configuration-Dimming_CD_3,0
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0
IDE05145-ENG115617-Light configuration-Dimming_CD_34,0
IDE05145-ENG115098-Light configuration-Dimming_CD_4,0
IDE05145-ENG114981-Light configuration-Dimming_CD_5,0
IDE05145-ENG115119-Light configuration-Dimming_CD_6,0
IDE05145-ENG115138-Light configuration-Dimming_CD_7,0
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,maximize
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,maximize
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0
IDE05145-ENG115064-Light configuration-Dimming_EF_2,0
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0
IDE05145-ENG115083-Light configuration-Dimming_EF_3,0
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,00
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,00
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,00
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,2B
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,2D
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,29
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,2A
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,00
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,Always
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4
IDE05145-ENG114997-Light configuration-Light_Function_A_10,0
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62
IDE05145-ENG115210-Light configuration-Light_Function_A_12,0
IDE05145-ENG114956-Light configuration-Light_Function_A_13,0
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4
IDE05145-ENG115054-Light configuration-Light_Function_A_2,8
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8
IDE05145-ENG115459-Light configuration-Light_Function_A_26,28
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37
IDE05145-ENG115073-Light configuration-Light_Function_A_3,8
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0
IDE05145-ENG115611-Light configuration-Light_Function_A_34,0
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0
IDE05145-ENG115211-Light configuration-Light_Function_B_12,0
IDE05145-ENG114957-Light configuration-Light_Function_B_13,0
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0
IDE05145-ENG115055-Light configuration-Light_Function_B_2,9
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10
IDE05145-ENG115441-Light configuration-Light_Function_B_25,0
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0
IDE05145-ENG115074-Light configuration-Light_Function_B_3,10
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0
IDE05145-ENG115612-Light configuration-Light_Function_B_34,0
IDE05145-ENG115093-Light configuration-Light_Function_B_4,0
IDE05145-ENG114976-Light configuration-Light_Function_B_5,0
IDE05145-ENG115114-Light configuration-Light_Function_B_6,30
IDE05145-ENG115133-Light configuration-Light_Function_B_7,30
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0
IDE05145-ENG115058-Light configuration-Light_Function_C_2,0
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0
IDE05145-ENG115406-Light configuration-Light_Function_C_23,0
IDE05145-ENG115425-Light configuration-Light_Function_C_24,0
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0
IDE05145-ENG115077-Light configuration-Light_Function_C_3,0
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0
IDE05145-ENG115615-Light configuration-Light_Function_C_34,0
IDE05145-ENG115096-Light configuration-Light_Function_C_4,0
IDE05145-ENG114979-Light configuration-Light_Function_C_5,0
IDE05145-ENG115117-Light configuration-Light_Function_C_6,0
IDE05145-ENG115136-Light configuration-Light_Function_C_7,0
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0
IDE05145-ENG115059-Light configuration-Light_Function_D_2,0
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0
IDE05145-ENG115078-Light configuration-Light_Function_D_3,0
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0
IDE05145-ENG115616-Light configuration-Light_Function_D_34,0
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0
IDE05145-ENG115118-Light configuration-Light_Function_D_6,0
IDE05145-ENG115137-Light configuration-Light_Function_D_7,0
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0
IDE05145-ENG115062-Light configuration-Light_Function_E_2,0
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0
IDE05145-ENG115081-Light configuration-Light_Function_E_3,0
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0
IDE05145-ENG115619-Light configuration-Light_Function_E_34,0
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0
IDE05145-ENG115624-Light configuration-Light_Function_H_34,0
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,Blinkleuchten
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,Blinkleuchten
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,not active
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,not active
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,not active
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,LED Blinkleuchten
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,LED Blinkleuchten
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,Blinkleuchten
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,Blinkleuchten
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,Bremsleuchten
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,Bremsleuchten
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,2* 5W
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeineGluehlampe12W
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,allgemeineGluehlampe12W
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active
IDE05145-ENG115608-Light configuration-Type_Of_Load_34,not active
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Low beam
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Low beam
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung
IDE05822-DWA Vehicle inclination sensor,100 %
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 C1 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 24 23 65 42 57 9B 25 44 3F 3A 69 35 95 2C 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 24 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 27 23 65 42 57 9B 25 24 0C FA 0A 34 95 2C 09 A3 21 03 00 02 02 02 02 02 02 91 10 B2 26 B6
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %
IDE06425-Roller test bench mode: functional,not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min
IDE08542-IDE02021-Access control 2-Comfort closing,active
IDE08542-IDE02022-Access control 2-Comfort opening,active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active
IDE08542-ENG115671-Access control 2-Regenschließen,not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm
MAS01490-Energy management,Energy management not active
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed
MAS08233-ENG126575-other-mute_mode_aktiv,not active
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed
ENG124896-Adaptation_theft_protection,not active
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,100.0 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,0 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,0 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,0 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,0 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,0.0 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,0.0
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,0.0
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,0.0
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,0.0
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,0
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,00
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,00
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,not active
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,not active
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,not active
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,0
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,00
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,00
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,not active
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,not active
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,not active
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,18
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,18
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken rechts Hellphase
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not active
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not active
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not active
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not active
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not active
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not active
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not active
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,09
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,19
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,60
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,60
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,00
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,00
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundLinksverkehr
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,35
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Parking light
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parking light left
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not active
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not active
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Parking light
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parking light right
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,not active
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,not active
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.0 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.0 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.0 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %
ENG130141-Patch_Code: Beifahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG130136-Patch_Code: Fahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG117299-Reversing_Threshold_Driver_Side_Rear,0 %
ENG117298-Reversing_Threshold_Passenger_Side_Front,0 %
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
ENG130135-Window_Regulator_Supplier_Settings_Driver_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG130138-Window_Regulator_Supplier_Settings_Passener_Side_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG130139-Window_Regulator_Supplier_Settings_Passener_Side_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG130140-Window_Regulator_Supplier_Settings_Passener_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Elapsed Time: 03:22
;SW:6C0-937-089-A HW:6C0-937-089 --- Cent. Elect.
;Component:BCM PQ26 Hi4R H06 0047, Coding:03000840425300530BA44080B107038800005B0257010000000000000000
;EV_BCMA0,004003,EV_BCMA0_004_VW26.rod
;Friday,04,August,2017,13:52:50:48600
;VCDS Version: Release 17.8.0 Data version: 20170721 DS276.2
;VCID: 2E581EA971AA9D3628-807A
IDE00001-ENG130235-Production mode-Entry_control,not active ,3
IDE00001-ENG130233-Production mode-Exit_lights_Heading_time_15_s,not active ,3
IDE00001-ENG130234-Production mode-Window_regulator_kl_15_nr_2,not active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,9
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,not active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,not activated ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE02152-Characteristics in production mode,0 ms,4
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,32
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,2
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,2
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.50 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,180 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,120 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,separate ,4
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active ,4
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,4
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5 ,4
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS ,4
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled ,4
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active ,4
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active ,4
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %,4
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %,4
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h,14
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active ,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,Not Present ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,0.0 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,not enabled ,5
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,not active ,5
IDE04926-ENG126570-Comfort illumination-lho_zeit,0 s,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,0 s,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,not active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0.0 s,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,not active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,not active ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34 ,560
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E ,560
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00 ,560
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00 ,560
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,00 ,560
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,00 ,560
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00 ,560
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00 ,560
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,00 ,560
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,00 ,560
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08 ,560
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18 ,560
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,35 ,560
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,09 ,560
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,19 ,560
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,29 ,560
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,0A ,560
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,1A ,560
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,00 ,560
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C ,560
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00 ,560
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B ,560
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00 ,560
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,3F ,560
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00 ,560
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00 ,560
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00 ,560
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00 ,560
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,00 ,560
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,3A ,560
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,44 ,560
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36 ,560
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40 ,560
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37 ,560
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41 ,560
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100 ,560
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100 ,560
IDE05145-ENG114999-Light configuration-Dimming_AB_10,0 ,560
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100 ,560
IDE05145-ENG115212-Light configuration-Dimming_AB_12,0 ,560
IDE05145-ENG114958-Light configuration-Dimming_AB_13,0 ,560
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100 ,560
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100 ,560
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100 ,560
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100 ,560
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100 ,560
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100 ,560
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100 ,560
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100 ,560
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100 ,560
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100 ,560
IDE05145-ENG115404-Light configuration-Dimming_AB_23,60 ,560
IDE05145-ENG115423-Light configuration-Dimming_AB_24,60 ,560
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100 ,560
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100 ,560
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100 ,560
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100 ,560
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100 ,560
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100 ,560
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100 ,560
IDE05145-ENG115556-Light configuration-Dimming_AB_31,0 ,560
IDE05145-ENG115575-Light configuration-Dimming_AB_32,0 ,560
IDE05145-ENG115594-Light configuration-Dimming_AB_33,0 ,560
IDE05145-ENG115613-Light configuration-Dimming_AB_34,0 ,560
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100 ,560
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100 ,560
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100 ,560
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100 ,560
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100 ,560
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100 ,560
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0 ,560
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0 ,560
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0 ,560
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0 ,560
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0 ,560
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0 ,560
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0 ,560
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0 ,560
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0 ,560
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0 ,560
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0 ,560
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0 ,560
IDE05145-ENG115060-Light configuration-Dimming_CD_2,0 ,560
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0 ,560
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0 ,560
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0 ,560
IDE05145-ENG115408-Light configuration-Dimming_CD_23,0 ,560
IDE05145-ENG115427-Light configuration-Dimming_CD_24,0 ,560
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0 ,560
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0 ,560
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0 ,560
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0 ,560
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0 ,560
IDE05145-ENG115079-Light configuration-Dimming_CD_3,0 ,560
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0 ,560
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0 ,560
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0 ,560
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0 ,560
IDE05145-ENG115617-Light configuration-Dimming_CD_34,0 ,560
IDE05145-ENG115098-Light configuration-Dimming_CD_4,0 ,560
IDE05145-ENG114981-Light configuration-Dimming_CD_5,0 ,560
IDE05145-ENG115119-Light configuration-Dimming_CD_6,0 ,560
IDE05145-ENG115138-Light configuration-Dimming_CD_7,0 ,560
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0 ,560
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0 ,560
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize ,560
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize ,560
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize ,560
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize ,560
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize ,560
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize ,560
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize ,560
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize ,560
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize ,560
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize ,560
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize ,560
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize ,560
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize ,560
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize ,560
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize ,560
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize ,560
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize ,560
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize ,560
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize ,560
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize ,560
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize ,560
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize ,560
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize ,560
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize ,560
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize ,560
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize ,560
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize ,560
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize ,560
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize ,560
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize ,560
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize ,560
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize ,560
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize ,560
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize ,560
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize ,560
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize ,560
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize ,560
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize ,560
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize ,560
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize ,560
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize ,560
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize ,560
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize ,560
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize ,560
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize ,560
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize ,560
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize ,560
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,maximize ,560
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize ,560
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize ,560
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize ,560
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize ,560
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize ,560
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize ,560
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize ,560
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize ,560
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize ,560
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize ,560
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,maximize ,560
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize ,560
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize ,560
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize ,560
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize ,560
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize ,560
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize ,560
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize ,560
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize ,560
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize ,560
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize ,560
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize ,560
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize ,560
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize ,560
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize ,560
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize ,560
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize ,560
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize ,560
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize ,560
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize ,560
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize ,560
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize ,560
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize ,560
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize ,560
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize ,560
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize ,560
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize ,560
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize ,560
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize ,560
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize ,560
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize ,560
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize ,560
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize ,560
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize ,560
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize ,560
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize ,560
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize ,560
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize ,560
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize ,560
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize ,560
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize ,560
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize ,560
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize ,560
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize ,560
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize ,560
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize ,560
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize ,560
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0 ,560
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0 ,560
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0 ,560
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0 ,560
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0 ,560
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0 ,560
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0 ,560
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0 ,560
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0 ,560
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0 ,560
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0 ,560
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0 ,560
IDE05145-ENG115064-Light configuration-Dimming_EF_2,0 ,560
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0 ,560
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0 ,560
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0 ,560
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0 ,560
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0 ,560
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0 ,560
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0 ,560
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0 ,560
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0 ,560
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0 ,560
IDE05145-ENG115083-Light configuration-Dimming_EF_3,0 ,560
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0 ,560
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0 ,560
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0 ,560
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0 ,560
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0 ,560
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0 ,560
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0 ,560
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0 ,560
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0 ,560
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0 ,560
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0 ,560
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0 ,560
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0 ,560
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0 ,560
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0 ,560
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0 ,560
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0 ,560
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0 ,560
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0 ,560
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0 ,560
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0 ,560
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0 ,560
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0 ,560
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0 ,560
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0 ,560
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0 ,560
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0 ,560
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0 ,560
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0 ,560
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0 ,560
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0 ,560
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0 ,560
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0 ,560
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0 ,560
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0 ,560
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0 ,560
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0 ,560
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0 ,560
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0 ,560
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0 ,560
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0 ,560
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0 ,560
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0 ,560
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0 ,560
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0 ,560
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0 ,560
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14 ,560
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15 ,560
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00 ,560
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00 ,560
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,00 ,560
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,00 ,560
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00 ,560
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00 ,560
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00 ,560
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,00 ,560
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16 ,560
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18 ,560
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26 ,560
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,2B ,560
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,2D ,560
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C ,560
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,29 ,560
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,2A ,560
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,00 ,560
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E ,560
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08 ,560
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32 ,560
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01 ,560
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27 ,560
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07 ,560
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00 ,560
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00 ,560
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00 ,560
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00 ,560
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20 ,560
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21 ,560
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A ,560
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B ,560
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C ,560
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D ,560
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always ,560
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always ,560
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always ,560
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always ,560
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always ,560
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always ,560
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always ,560
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always ,560
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always ,560
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always ,560
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always ,560
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always ,560
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always ,560
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always ,560
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always ,560
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always ,560
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always ,560
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always ,560
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always ,560
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always ,560
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always ,560
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always ,560
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always ,560
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always ,560
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always ,560
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always ,560
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always ,560
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always ,560
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,Always ,560
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always ,560
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always ,560
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always ,560
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always ,560
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always ,560
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always ,560
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2 ,560
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4 ,560
IDE05145-ENG114997-Light configuration-Light_Function_A_10,0 ,560
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62 ,560
IDE05145-ENG115210-Light configuration-Light_Function_A_12,0 ,560
IDE05145-ENG114956-Light configuration-Light_Function_A_13,0 ,560
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63 ,560
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64 ,560
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2 ,560
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4 ,560
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2 ,560
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4 ,560
IDE05145-ENG115054-Light configuration-Light_Function_A_2,8 ,560
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24 ,560
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24 ,560
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24 ,560
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8 ,560
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8 ,560
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8 ,560
IDE05145-ENG115459-Light configuration-Light_Function_A_26,28 ,560
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38 ,560
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25 ,560
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37 ,560
IDE05145-ENG115073-Light configuration-Light_Function_A_3,8 ,560
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41 ,560
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0 ,560
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0 ,560
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0 ,560
IDE05145-ENG115611-Light configuration-Light_Function_A_34,0 ,560
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20 ,560
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20 ,560
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11 ,560
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12 ,560
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13 ,560
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14 ,560
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0 ,560
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0 ,560
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0 ,560
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0 ,560
IDE05145-ENG115211-Light configuration-Light_Function_B_12,0 ,560
IDE05145-ENG114957-Light configuration-Light_Function_B_13,0 ,560
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0 ,560
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0 ,560
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0 ,560
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0 ,560
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0 ,560
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0 ,560
IDE05145-ENG115055-Light configuration-Light_Function_B_2,9 ,560
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0 ,560
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0 ,560
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0 ,560
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9 ,560
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10 ,560
IDE05145-ENG115441-Light configuration-Light_Function_B_25,0 ,560
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0 ,560
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0 ,560
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0 ,560
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0 ,560
IDE05145-ENG115074-Light configuration-Light_Function_B_3,10 ,560
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0 ,560
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0 ,560
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0 ,560
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0 ,560
IDE05145-ENG115612-Light configuration-Light_Function_B_34,0 ,560
IDE05145-ENG115093-Light configuration-Light_Function_B_4,0 ,560
IDE05145-ENG114976-Light configuration-Light_Function_B_5,0 ,560
IDE05145-ENG115114-Light configuration-Light_Function_B_6,30 ,560
IDE05145-ENG115133-Light configuration-Light_Function_B_7,30 ,560
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15 ,560
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15 ,560
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0 ,560
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0 ,560
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0 ,560
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0 ,560
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0 ,560
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0 ,560
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0 ,560
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0 ,560
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0 ,560
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0 ,560
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0 ,560
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0 ,560
IDE05145-ENG115058-Light configuration-Light_Function_C_2,0 ,560
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0 ,560
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0 ,560
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0 ,560
IDE05145-ENG115406-Light configuration-Light_Function_C_23,0 ,560
IDE05145-ENG115425-Light configuration-Light_Function_C_24,0 ,560
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0 ,560
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0 ,560
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0 ,560
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0 ,560
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0 ,560
IDE05145-ENG115077-Light configuration-Light_Function_C_3,0 ,560
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0 ,560
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0 ,560
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0 ,560
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0 ,560
IDE05145-ENG115615-Light configuration-Light_Function_C_34,0 ,560
IDE05145-ENG115096-Light configuration-Light_Function_C_4,0 ,560
IDE05145-ENG114979-Light configuration-Light_Function_C_5,0 ,560
IDE05145-ENG115117-Light configuration-Light_Function_C_6,0 ,560
IDE05145-ENG115136-Light configuration-Light_Function_C_7,0 ,560
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0 ,560
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0 ,560
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0 ,560
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0 ,560
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0 ,560
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0 ,560
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0 ,560
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0 ,560
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0 ,560
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0 ,560
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0 ,560
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0 ,560
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0 ,560
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0 ,560
IDE05145-ENG115059-Light configuration-Light_Function_D_2,0 ,560
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0 ,560
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0 ,560
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0 ,560
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0 ,560
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0 ,560
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0 ,560
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0 ,560
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0 ,560
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0 ,560
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0 ,560
IDE05145-ENG115078-Light configuration-Light_Function_D_3,0 ,560
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0 ,560
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0 ,560
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0 ,560
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0 ,560
IDE05145-ENG115616-Light configuration-Light_Function_D_34,0 ,560
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0 ,560
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0 ,560
IDE05145-ENG115118-Light configuration-Light_Function_D_6,0 ,560
IDE05145-ENG115137-Light configuration-Light_Function_D_7,0 ,560
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0 ,560
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0 ,560
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0 ,560
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0 ,560
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0 ,560
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0 ,560
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0 ,560
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0 ,560
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0 ,560
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0 ,560
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0 ,560
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0 ,560
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0 ,560
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0 ,560
IDE05145-ENG115062-Light configuration-Light_Function_E_2,0 ,560
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0 ,560
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0 ,560
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0 ,560
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0 ,560
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0 ,560
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0 ,560
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0 ,560
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0 ,560
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0 ,560
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0 ,560
IDE05145-ENG115081-Light configuration-Light_Function_E_3,0 ,560
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0 ,560
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0 ,560
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0 ,560
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0 ,560
IDE05145-ENG115619-Light configuration-Light_Function_E_34,0 ,560
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0 ,560
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0 ,560
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0 ,560
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0 ,560
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0 ,560
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0 ,560
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0 ,560
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0 ,560
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0 ,560
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0 ,560
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0 ,560
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0 ,560
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0 ,560
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0 ,560
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0 ,560
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0 ,560
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0 ,560
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0 ,560
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0 ,560
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0 ,560
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0 ,560
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0 ,560
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0 ,560
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0 ,560
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0 ,560
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0 ,560
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0 ,560
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0 ,560
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0 ,560
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0 ,560
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0 ,560
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0 ,560
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0 ,560
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0 ,560
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0 ,560
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0 ,560
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0 ,560
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0 ,560
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0 ,560
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0 ,560
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0 ,560
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0 ,560
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0 ,560
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0 ,560
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0 ,560
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0 ,560
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0 ,560
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0 ,560
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0 ,560
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0 ,560
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0 ,560
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0 ,560
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0 ,560
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0 ,560
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0 ,560
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0 ,560
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0 ,560
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0 ,560
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0 ,560
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0 ,560
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0 ,560
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0 ,560
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0 ,560
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0 ,560
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0 ,560
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0 ,560
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0 ,560
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0 ,560
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0 ,560
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0 ,560
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0 ,560
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0 ,560
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0 ,560
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0 ,560
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0 ,560
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0 ,560
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0 ,560
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0 ,560
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0 ,560
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0 ,560
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0 ,560
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0 ,560
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0 ,560
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0 ,560
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0 ,560
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0 ,560
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0 ,560
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0 ,560
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0 ,560
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0 ,560
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0 ,560
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0 ,560
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0 ,560
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0 ,560
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0 ,560
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0 ,560
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0 ,560
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0 ,560
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0 ,560
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0 ,560
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0 ,560
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0 ,560
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0 ,560
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0 ,560
IDE05145-ENG115624-Light configuration-Light_Function_H_34,0 ,560
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0 ,560
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0 ,560
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0 ,560
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0 ,560
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0 ,560
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0 ,560
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,Blinkleuchten ,560
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,Blinkleuchten ,560
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,not active ,560
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,not active ,560
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,not active ,560
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,LED Blinkleuchten ,560
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,LED Blinkleuchten ,560
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,Blinkleuchten ,560
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,Blinkleuchten ,560
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,Bremsleuchten ,560
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,Bremsleuchten ,560
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte ,560
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,2* 5W ,560
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeineGluehlampe12W ,560
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,allgemeineGluehlampe12W ,560
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active ,560
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active ,560
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active ,560
IDE05145-ENG115608-Light configuration-Type_Of_Load_34,not active ,560
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Low beam ,560
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Low beam ,560
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,560
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 C1 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 24 23 65 42 57 9B 25 44 3F 3A 69 35 95 2C 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 24 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 27 23 65 42 57 9B 25 24 0C FA 0A 34 95 2C 09 A3 21 03 00 02 02 02 02 02 02 91 10 B2 26 B6 ,172
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min,2
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0 ,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active ,4
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36 ,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40 ,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm ,7
MAS01490-Energy management,Energy management not active ,1
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed ,1
MAS08233-ENG126575-other-mute_mode_aktiv,not active ,1
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed ,1
ENG124896-Adaptation_theft_protection,not active ,2
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,100.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,0 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,0 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,0 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,0 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,0.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,0.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,0.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,0.0 ,10
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0 ,16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0 ,16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize ,16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize ,16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize ,16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0 ,16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0 ,16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00 ,16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00 ,16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always ,16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active ,16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active ,16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active ,16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active ,16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active ,16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active ,16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active ,16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active ,16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,0 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,00 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,00 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,not active ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,not active ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,not active ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,0 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,00 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,00 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,not active ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,not active ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,not active ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,18 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,18 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken rechts Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not active ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not active ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not active ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not active ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not active ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not active ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not active ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,09 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,19 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,60 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,60 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,00 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,00 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundLinksverkehr ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,35 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Parking light ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parking light left ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not active ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not active ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Parking light ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parking light right ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,not active ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,not active ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
ENG130141-Patch_Code: Beifahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130136-Patch_Code: Fahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117299-Reversing_Threshold_Driver_Side_Rear,0 %,1
ENG117298-Reversing_Threshold_Passenger_Side_Front,0 %,1
ENG130135-Window_Regulator_Supplier_Settings_Driver_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130138-Window_Regulator_Supplier_Settings_Passener_Side_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-Window_Regulator_Supplier_Settings_Passener_Side_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-Window_Regulator_Supplier_Settings_Passener_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,88
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
Elapsed Time: 03:29
;SW:6C0-937-089-A HW:6C0-937-089 --- Cent. Elect.
;Component:BCM PQ26 Hi4R H06 0047, Coding:03000840425300530BA44080B10703C800005B0257010000000000000000
;EV_BCMA0,004003,EV_BCMA0_004_VW26.rod
;Saturday,28,October,2017,16:24:21:48600
;VCDS Version: Release 17.8.0 Data version: 20170721 DS276.2
;VCID: 2E581EA971AA9D3628-807A
IDE00001-ENG130235-Production mode-Entry_control,not active ,3
IDE00001-ENG130233-Production mode-Exit_lights_Heading_time_15_s,not active ,3
IDE00001-ENG130234-Production mode-Window_regulator_kl_15_nr_2,not active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,9
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,not active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,not activated ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE02152-Characteristics in production mode,0 ms,4
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,32
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,2
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,2
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.50 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,180 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,120 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,separate ,4
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active ,4
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,4
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5 ,4
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS ,4
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled ,4
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active ,4
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active ,4
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %,4
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %,4
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h,14
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active ,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,Not Present ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,0.0 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,not enabled ,5
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,not active ,5
IDE04926-ENG126570-Comfort illumination-lho_zeit,0 s,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,0 s,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,not active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0.0 s,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34 ,560
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E ,560
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00 ,560
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00 ,560
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,00 ,560
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,00 ,560
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00 ,560
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00 ,560
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,00 ,560
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,00 ,560
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08 ,560
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18 ,560
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,35 ,560
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,09 ,560
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,19 ,560
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,29 ,560
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,0A ,560
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,1A ,560
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,00 ,560
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C ,560
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00 ,560
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B ,560
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00 ,560
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,3F ,560
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00 ,560
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00 ,560
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00 ,560
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00 ,560
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,00 ,560
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,3A ,560
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,44 ,560
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36 ,560
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40 ,560
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37 ,560
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41 ,560
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100 ,560
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100 ,560
IDE05145-ENG114999-Light configuration-Dimming_AB_10,0 ,560
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100 ,560
IDE05145-ENG115212-Light configuration-Dimming_AB_12,0 ,560
IDE05145-ENG114958-Light configuration-Dimming_AB_13,0 ,560
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100 ,560
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100 ,560
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100 ,560
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100 ,560
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100 ,560
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100 ,560
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100 ,560
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100 ,560
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100 ,560
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100 ,560
IDE05145-ENG115404-Light configuration-Dimming_AB_23,60 ,560
IDE05145-ENG115423-Light configuration-Dimming_AB_24,60 ,560
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100 ,560
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100 ,560
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100 ,560
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100 ,560
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100 ,560
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100 ,560
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100 ,560
IDE05145-ENG115556-Light configuration-Dimming_AB_31,0 ,560
IDE05145-ENG115575-Light configuration-Dimming_AB_32,0 ,560
IDE05145-ENG115594-Light configuration-Dimming_AB_33,0 ,560
IDE05145-ENG115613-Light configuration-Dimming_AB_34,0 ,560
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100 ,560
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100 ,560
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100 ,560
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100 ,560
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100 ,560
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100 ,560
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0 ,560
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0 ,560
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0 ,560
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0 ,560
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0 ,560
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0 ,560
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0 ,560
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0 ,560
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0 ,560
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0 ,560
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0 ,560
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0 ,560
IDE05145-ENG115060-Light configuration-Dimming_CD_2,0 ,560
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0 ,560
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0 ,560
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0 ,560
IDE05145-ENG115408-Light configuration-Dimming_CD_23,0 ,560
IDE05145-ENG115427-Light configuration-Dimming_CD_24,0 ,560
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0 ,560
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0 ,560
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0 ,560
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0 ,560
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0 ,560
IDE05145-ENG115079-Light configuration-Dimming_CD_3,0 ,560
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0 ,560
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0 ,560
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0 ,560
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0 ,560
IDE05145-ENG115617-Light configuration-Dimming_CD_34,0 ,560
IDE05145-ENG115098-Light configuration-Dimming_CD_4,0 ,560
IDE05145-ENG114981-Light configuration-Dimming_CD_5,0 ,560
IDE05145-ENG115119-Light configuration-Dimming_CD_6,0 ,560
IDE05145-ENG115138-Light configuration-Dimming_CD_7,0 ,560
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0 ,560
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0 ,560
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize ,560
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize ,560
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize ,560
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize ,560
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize ,560
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize ,560
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize ,560
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize ,560
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize ,560
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize ,560
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize ,560
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize ,560
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize ,560
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize ,560
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize ,560
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize ,560
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize ,560
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize ,560
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize ,560
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize ,560
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize ,560
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize ,560
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize ,560
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize ,560
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize ,560
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize ,560
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize ,560
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize ,560
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize ,560
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize ,560
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize ,560
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize ,560
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize ,560
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize ,560
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize ,560
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize ,560
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize ,560
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize ,560
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize ,560
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize ,560
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize ,560
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize ,560
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize ,560
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize ,560
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize ,560
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize ,560
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize ,560
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,maximize ,560
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize ,560
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize ,560
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize ,560
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize ,560
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize ,560
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize ,560
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize ,560
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize ,560
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize ,560
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize ,560
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,maximize ,560
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize ,560
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize ,560
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize ,560
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize ,560
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize ,560
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize ,560
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize ,560
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize ,560
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize ,560
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize ,560
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize ,560
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize ,560
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize ,560
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize ,560
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize ,560
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize ,560
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize ,560
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize ,560
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize ,560
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize ,560
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize ,560
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize ,560
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize ,560
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize ,560
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize ,560
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize ,560
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize ,560
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize ,560
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize ,560
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize ,560
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize ,560
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize ,560
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize ,560
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize ,560
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize ,560
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize ,560
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize ,560
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize ,560
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize ,560
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize ,560
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize ,560
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize ,560
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize ,560
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize ,560
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize ,560
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize ,560
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0 ,560
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0 ,560
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0 ,560
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0 ,560
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0 ,560
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0 ,560
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0 ,560
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0 ,560
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0 ,560
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0 ,560
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0 ,560
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0 ,560
IDE05145-ENG115064-Light configuration-Dimming_EF_2,0 ,560
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0 ,560
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0 ,560
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0 ,560
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0 ,560
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0 ,560
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0 ,560
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0 ,560
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0 ,560
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0 ,560
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0 ,560
IDE05145-ENG115083-Light configuration-Dimming_EF_3,0 ,560
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0 ,560
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0 ,560
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0 ,560
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0 ,560
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0 ,560
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0 ,560
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0 ,560
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0 ,560
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0 ,560
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0 ,560
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0 ,560
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0 ,560
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0 ,560
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0 ,560
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0 ,560
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0 ,560
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0 ,560
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0 ,560
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0 ,560
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0 ,560
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0 ,560
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0 ,560
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0 ,560
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0 ,560
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0 ,560
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0 ,560
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0 ,560
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0 ,560
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0 ,560
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0 ,560
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0 ,560
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0 ,560
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0 ,560
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0 ,560
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0 ,560
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0 ,560
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0 ,560
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0 ,560
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0 ,560
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0 ,560
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0 ,560
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0 ,560
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0 ,560
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0 ,560
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0 ,560
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0 ,560
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14 ,560
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15 ,560
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00 ,560
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00 ,560
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,00 ,560
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,00 ,560
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00 ,560
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00 ,560
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00 ,560
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,00 ,560
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16 ,560
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18 ,560
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26 ,560
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,2B ,560
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,2D ,560
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C ,560
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,29 ,560
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,2A ,560
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,00 ,560
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E ,560
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08 ,560
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32 ,560
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01 ,560
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27 ,560
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07 ,560
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00 ,560
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00 ,560
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00 ,560
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00 ,560
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20 ,560
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21 ,560
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A ,560
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B ,560
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C ,560
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D ,560
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always ,560
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always ,560
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always ,560
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always ,560
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always ,560
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always ,560
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always ,560
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always ,560
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always ,560
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always ,560
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always ,560
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always ,560
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always ,560
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always ,560
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always ,560
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always ,560
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always ,560
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always ,560
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always ,560
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always ,560
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always ,560
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always ,560
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always ,560
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always ,560
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always ,560
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always ,560
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always ,560
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always ,560
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,Always ,560
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always ,560
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always ,560
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always ,560
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always ,560
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always ,560
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always ,560
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2 ,560
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4 ,560
IDE05145-ENG114997-Light configuration-Light_Function_A_10,0 ,560
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62 ,560
IDE05145-ENG115210-Light configuration-Light_Function_A_12,0 ,560
IDE05145-ENG114956-Light configuration-Light_Function_A_13,0 ,560
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63 ,560
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64 ,560
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2 ,560
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4 ,560
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2 ,560
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4 ,560
IDE05145-ENG115054-Light configuration-Light_Function_A_2,8 ,560
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24 ,560
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24 ,560
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24 ,560
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8 ,560
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8 ,560
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8 ,560
IDE05145-ENG115459-Light configuration-Light_Function_A_26,28 ,560
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38 ,560
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25 ,560
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37 ,560
IDE05145-ENG115073-Light configuration-Light_Function_A_3,8 ,560
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41 ,560
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0 ,560
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0 ,560
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0 ,560
IDE05145-ENG115611-Light configuration-Light_Function_A_34,0 ,560
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20 ,560
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20 ,560
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11 ,560
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12 ,560
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13 ,560
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14 ,560
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0 ,560
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0 ,560
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0 ,560
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0 ,560
IDE05145-ENG115211-Light configuration-Light_Function_B_12,0 ,560
IDE05145-ENG114957-Light configuration-Light_Function_B_13,0 ,560
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0 ,560
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0 ,560
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0 ,560
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0 ,560
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0 ,560
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0 ,560
IDE05145-ENG115055-Light configuration-Light_Function_B_2,9 ,560
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0 ,560
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0 ,560
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0 ,560
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9 ,560
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10 ,560
IDE05145-ENG115441-Light configuration-Light_Function_B_25,0 ,560
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0 ,560
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0 ,560
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0 ,560
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0 ,560
IDE05145-ENG115074-Light configuration-Light_Function_B_3,10 ,560
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0 ,560
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0 ,560
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0 ,560
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0 ,560
IDE05145-ENG115612-Light configuration-Light_Function_B_34,0 ,560
IDE05145-ENG115093-Light configuration-Light_Function_B_4,0 ,560
IDE05145-ENG114976-Light configuration-Light_Function_B_5,0 ,560
IDE05145-ENG115114-Light configuration-Light_Function_B_6,30 ,560
IDE05145-ENG115133-Light configuration-Light_Function_B_7,30 ,560
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15 ,560
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15 ,560
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0 ,560
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0 ,560
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0 ,560
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0 ,560
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0 ,560
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0 ,560
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0 ,560
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0 ,560
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0 ,560
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0 ,560
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0 ,560
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0 ,560
IDE05145-ENG115058-Light configuration-Light_Function_C_2,0 ,560
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0 ,560
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0 ,560
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0 ,560
IDE05145-ENG115406-Light configuration-Light_Function_C_23,0 ,560
IDE05145-ENG115425-Light configuration-Light_Function_C_24,0 ,560
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0 ,560
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0 ,560
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0 ,560
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0 ,560
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0 ,560
IDE05145-ENG115077-Light configuration-Light_Function_C_3,0 ,560
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0 ,560
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0 ,560
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0 ,560
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0 ,560
IDE05145-ENG115615-Light configuration-Light_Function_C_34,0 ,560
IDE05145-ENG115096-Light configuration-Light_Function_C_4,0 ,560
IDE05145-ENG114979-Light configuration-Light_Function_C_5,0 ,560
IDE05145-ENG115117-Light configuration-Light_Function_C_6,0 ,560
IDE05145-ENG115136-Light configuration-Light_Function_C_7,0 ,560
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0 ,560
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0 ,560
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0 ,560
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0 ,560
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0 ,560
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0 ,560
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0 ,560
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0 ,560
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0 ,560
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0 ,560
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0 ,560
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0 ,560
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0 ,560
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0 ,560
IDE05145-ENG115059-Light configuration-Light_Function_D_2,0 ,560
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0 ,560
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0 ,560
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0 ,560
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0 ,560
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0 ,560
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0 ,560
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0 ,560
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0 ,560
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0 ,560
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0 ,560
IDE05145-ENG115078-Light configuration-Light_Function_D_3,0 ,560
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0 ,560
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0 ,560
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0 ,560
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0 ,560
IDE05145-ENG115616-Light configuration-Light_Function_D_34,0 ,560
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0 ,560
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0 ,560
IDE05145-ENG115118-Light configuration-Light_Function_D_6,0 ,560
IDE05145-ENG115137-Light configuration-Light_Function_D_7,0 ,560
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0 ,560
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0 ,560
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0 ,560
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0 ,560
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0 ,560
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0 ,560
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0 ,560
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0 ,560
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0 ,560
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0 ,560
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0 ,560
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0 ,560
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0 ,560
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0 ,560
IDE05145-ENG115062-Light configuration-Light_Function_E_2,0 ,560
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0 ,560
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0 ,560
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0 ,560
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0 ,560
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0 ,560
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0 ,560
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0 ,560
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0 ,560
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0 ,560
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0 ,560
IDE05145-ENG115081-Light configuration-Light_Function_E_3,0 ,560
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0 ,560
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0 ,560
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0 ,560
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0 ,560
IDE05145-ENG115619-Light configuration-Light_Function_E_34,0 ,560
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0 ,560
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0 ,560
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0 ,560
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0 ,560
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0 ,560
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0 ,560
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0 ,560
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0 ,560
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0 ,560
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0 ,560
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0 ,560
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0 ,560
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0 ,560
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0 ,560
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0 ,560
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0 ,560
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0 ,560
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0 ,560
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0 ,560
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0 ,560
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0 ,560
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0 ,560
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0 ,560
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0 ,560
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0 ,560
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0 ,560
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0 ,560
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0 ,560
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0 ,560
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0 ,560
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0 ,560
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0 ,560
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0 ,560
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0 ,560
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0 ,560
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0 ,560
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0 ,560
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0 ,560
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0 ,560
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0 ,560
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0 ,560
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0 ,560
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0 ,560
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0 ,560
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0 ,560
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0 ,560
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0 ,560
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0 ,560
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0 ,560
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0 ,560
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0 ,560
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0 ,560
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0 ,560
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0 ,560
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0 ,560
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0 ,560
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0 ,560
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0 ,560
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0 ,560
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0 ,560
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0 ,560
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0 ,560
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0 ,560
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0 ,560
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0 ,560
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0 ,560
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0 ,560
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0 ,560
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0 ,560
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0 ,560
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0 ,560
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0 ,560
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0 ,560
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0 ,560
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0 ,560
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0 ,560
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0 ,560
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0 ,560
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0 ,560
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0 ,560
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0 ,560
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0 ,560
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0 ,560
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0 ,560
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0 ,560
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0 ,560
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0 ,560
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0 ,560
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0 ,560
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0 ,560
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0 ,560
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0 ,560
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0 ,560
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0 ,560
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0 ,560
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0 ,560
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0 ,560
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0 ,560
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0 ,560
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0 ,560
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0 ,560
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0 ,560
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0 ,560
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0 ,560
IDE05145-ENG115624-Light configuration-Light_Function_H_34,0 ,560
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0 ,560
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0 ,560
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0 ,560
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0 ,560
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0 ,560
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0 ,560
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,Blinkleuchten ,560
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,Blinkleuchten ,560
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,not active ,560
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,not active ,560
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,not active ,560
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,LED Blinkleuchten ,560
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,LED Blinkleuchten ,560
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,Blinkleuchten ,560
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,Blinkleuchten ,560
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,Bremsleuchten ,560
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,Bremsleuchten ,560
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte ,560
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,2* 5W ,560
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeineGluehlampe12W ,560
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,allgemeineGluehlampe12W ,560
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active ,560
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active ,560
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active ,560
IDE05145-ENG115608-Light configuration-Type_Of_Load_34,not active ,560
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Low beam ,560
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Low beam ,560
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,560
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 C1 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 24 23 65 42 57 9B 25 44 3F 3A 69 35 95 2C 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 24 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 27 23 65 42 57 9B 25 24 0C FA 0A 34 95 2C 09 A3 21 03 00 02 02 02 02 02 02 91 10 A1 26 A5 ,172
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min,2
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0 ,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active ,4
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36 ,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40 ,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm ,7
MAS01490-Energy management,Energy management not active ,1
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed ,1
MAS08233-ENG126575-other-mute_mode_aktiv,not active ,1
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed ,1
ENG124896-Adaptation_theft_protection,not active ,2
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,100.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,0 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,0 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,0 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,0 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,0.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,0.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,0.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,0.0 ,10
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0 ,16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0 ,16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize ,16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize ,16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize ,16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0 ,16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0 ,16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00 ,16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00 ,16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always ,16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active ,16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active ,16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active ,16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active ,16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active ,16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active ,16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active ,16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active ,16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,0 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,00 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,00 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,not active ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,not active ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,not active ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,0 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,00 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,00 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,not active ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,not active ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,not active ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,18 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,18 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken rechts Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not active ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not active ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not active ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not active ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not active ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not active ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not active ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,09 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,19 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,60 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,60 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,00 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,00 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundLinksverkehr ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,35 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Parking light ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parking light left ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not active ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not active ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Parking light ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parking light right ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,not active ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,not active ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
ENG130141-Patch_Code: Beifahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130136-Patch_Code: Fahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117299-Reversing_Threshold_Driver_Side_Rear,0 %,1
ENG117298-Reversing_Threshold_Passenger_Side_Front,0 %,1
ENG130135-Window_Regulator_Supplier_Settings_Driver_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130138-Window_Regulator_Supplier_Settings_Passener_Side_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-Window_Regulator_Supplier_Settings_Passener_Side_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-Window_Regulator_Supplier_Settings_Passener_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,88
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
Elapsed Time: 03:24
;SW:6C0-937-089-A HW:6C0-937-089 --- Cent. Elect. --- SA: 31347
;Component:BCM PQ26 Hi4R H06 0047, Coding:03000840425300530BA44080B10703C800005B0257010000000000000000
;EV_BCMA0,004003,EV_BCMA0_004_VW26.rod
;Saturday,28,October,2017,16:38:54:48600
;VCDS Version: Release 17.8.0 Data version: 20170721 DS276.2
;VCID: 2E581EA971AA9D3628-807A
IDE00001-ENG130235-Production mode-Entry_control,not active ,3
IDE00001-ENG130233-Production mode-Exit_lights_Heading_time_15_s,not active ,3
IDE00001-ENG130234-Production mode-Window_regulator_kl_15_nr_2,not active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,9
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,not active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,not activated ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE02152-Characteristics in production mode,0 ms,4
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,32
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,2
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,2
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.50 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,180 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,120 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,separate ,4
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active ,4
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,4
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5 ,4
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS ,4
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled ,4
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active ,4
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active ,4
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %,4
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %,4
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h,14
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active ,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,Not Present ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,0.0 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,not enabled ,5
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,not active ,5
IDE04926-ENG126570-Comfort illumination-lho_zeit,0 s,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,0 s,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,not active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0.0 s,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34 ,560
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E ,560
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00 ,560
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00 ,560
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,00 ,560
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,00 ,560
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00 ,560
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00 ,560
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,00 ,560
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,00 ,560
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08 ,560
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18 ,560
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,35 ,560
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,09 ,560
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,19 ,560
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,29 ,560
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,0A ,560
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,1A ,560
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,00 ,560
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C ,560
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00 ,560
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B ,560
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00 ,560
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,3F ,560
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00 ,560
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00 ,560
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00 ,560
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00 ,560
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,00 ,560
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,3A ,560
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,44 ,560
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36 ,560
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40 ,560
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37 ,560
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41 ,560
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100 ,560
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100 ,560
IDE05145-ENG114999-Light configuration-Dimming_AB_10,0 ,560
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100 ,560
IDE05145-ENG115212-Light configuration-Dimming_AB_12,0 ,560
IDE05145-ENG114958-Light configuration-Dimming_AB_13,0 ,560
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100 ,560
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100 ,560
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100 ,560
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100 ,560
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100 ,560
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100 ,560
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100 ,560
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100 ,560
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100 ,560
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100 ,560
IDE05145-ENG115404-Light configuration-Dimming_AB_23,60 ,560
IDE05145-ENG115423-Light configuration-Dimming_AB_24,60 ,560
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100 ,560
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100 ,560
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100 ,560
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100 ,560
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100 ,560
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100 ,560
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100 ,560
IDE05145-ENG115556-Light configuration-Dimming_AB_31,0 ,560
IDE05145-ENG115575-Light configuration-Dimming_AB_32,0 ,560
IDE05145-ENG115594-Light configuration-Dimming_AB_33,0 ,560
IDE05145-ENG115613-Light configuration-Dimming_AB_34,0 ,560
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100 ,560
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100 ,560
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100 ,560
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100 ,560
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100 ,560
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100 ,560
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0 ,560
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0 ,560
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0 ,560
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0 ,560
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0 ,560
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0 ,560
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0 ,560
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0 ,560
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0 ,560
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0 ,560
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0 ,560
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0 ,560
IDE05145-ENG115060-Light configuration-Dimming_CD_2,0 ,560
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0 ,560
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0 ,560
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0 ,560
IDE05145-ENG115408-Light configuration-Dimming_CD_23,0 ,560
IDE05145-ENG115427-Light configuration-Dimming_CD_24,0 ,560
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0 ,560
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0 ,560
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0 ,560
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0 ,560
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0 ,560
IDE05145-ENG115079-Light configuration-Dimming_CD_3,0 ,560
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0 ,560
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0 ,560
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0 ,560
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0 ,560
IDE05145-ENG115617-Light configuration-Dimming_CD_34,0 ,560
IDE05145-ENG115098-Light configuration-Dimming_CD_4,0 ,560
IDE05145-ENG114981-Light configuration-Dimming_CD_5,0 ,560
IDE05145-ENG115119-Light configuration-Dimming_CD_6,0 ,560
IDE05145-ENG115138-Light configuration-Dimming_CD_7,0 ,560
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0 ,560
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0 ,560
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize ,560
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize ,560
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize ,560
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize ,560
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize ,560
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize ,560
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize ,560
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize ,560
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize ,560
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize ,560
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize ,560
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize ,560
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize ,560
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize ,560
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize ,560
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize ,560
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize ,560
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize ,560
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize ,560
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize ,560
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize ,560
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize ,560
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize ,560
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize ,560
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize ,560
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize ,560
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize ,560
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize ,560
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize ,560
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize ,560
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize ,560
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize ,560
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize ,560
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize ,560
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize ,560
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize ,560
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize ,560
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize ,560
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize ,560
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize ,560
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize ,560
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize ,560
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize ,560
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize ,560
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize ,560
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize ,560
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize ,560
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,maximize ,560
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize ,560
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize ,560
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize ,560
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize ,560
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize ,560
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize ,560
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize ,560
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize ,560
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize ,560
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize ,560
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,maximize ,560
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize ,560
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize ,560
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize ,560
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize ,560
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize ,560
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize ,560
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize ,560
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize ,560
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize ,560
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize ,560
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize ,560
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize ,560
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize ,560
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize ,560
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize ,560
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize ,560
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize ,560
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize ,560
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize ,560
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize ,560
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize ,560
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize ,560
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize ,560
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize ,560
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize ,560
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize ,560
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize ,560
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize ,560
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize ,560
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize ,560
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize ,560
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize ,560
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize ,560
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize ,560
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize ,560
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize ,560
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize ,560
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize ,560
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize ,560
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize ,560
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize ,560
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize ,560
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize ,560
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize ,560
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize ,560
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize ,560
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0 ,560
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0 ,560
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0 ,560
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0 ,560
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0 ,560
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0 ,560
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0 ,560
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0 ,560
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0 ,560
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0 ,560
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0 ,560
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0 ,560
IDE05145-ENG115064-Light configuration-Dimming_EF_2,0 ,560
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0 ,560
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0 ,560
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0 ,560
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0 ,560
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0 ,560
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0 ,560
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0 ,560
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0 ,560
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0 ,560
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0 ,560
IDE05145-ENG115083-Light configuration-Dimming_EF_3,0 ,560
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0 ,560
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0 ,560
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0 ,560
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0 ,560
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0 ,560
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0 ,560
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0 ,560
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0 ,560
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0 ,560
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0 ,560
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0 ,560
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0 ,560
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0 ,560
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0 ,560
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0 ,560
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0 ,560
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0 ,560
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0 ,560
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0 ,560
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0 ,560
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0 ,560
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0 ,560
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0 ,560
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0 ,560
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0 ,560
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0 ,560
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0 ,560
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0 ,560
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0 ,560
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0 ,560
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0 ,560
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0 ,560
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0 ,560
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0 ,560
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0 ,560
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0 ,560
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0 ,560
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0 ,560
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0 ,560
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0 ,560
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0 ,560
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0 ,560
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0 ,560
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0 ,560
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0 ,560
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0 ,560
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14 ,560
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15 ,560
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00 ,560
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00 ,560
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,00 ,560
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,00 ,560
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00 ,560
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00 ,560
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00 ,560
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,00 ,560
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16 ,560
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18 ,560
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26 ,560
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,2B ,560
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,2D ,560
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C ,560
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,29 ,560
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,2A ,560
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,00 ,560
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E ,560
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08 ,560
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32 ,560
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01 ,560
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27 ,560
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07 ,560
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00 ,560
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00 ,560
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00 ,560
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00 ,560
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20 ,560
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21 ,560
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A ,560
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B ,560
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C ,560
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D ,560
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always ,560
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always ,560
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always ,560
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always ,560
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always ,560
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always ,560
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always ,560
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always ,560
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always ,560
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always ,560
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always ,560
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always ,560
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always ,560
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always ,560
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always ,560
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always ,560
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always ,560
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always ,560
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always ,560
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always ,560
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always ,560
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always ,560
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always ,560
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always ,560
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always ,560
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always ,560
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always ,560
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always ,560
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,Always ,560
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always ,560
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always ,560
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always ,560
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always ,560
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always ,560
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always ,560
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2 ,560
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4 ,560
IDE05145-ENG114997-Light configuration-Light_Function_A_10,0 ,560
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62 ,560
IDE05145-ENG115210-Light configuration-Light_Function_A_12,0 ,560
IDE05145-ENG114956-Light configuration-Light_Function_A_13,0 ,560
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63 ,560
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64 ,560
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2 ,560
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4 ,560
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2 ,560
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4 ,560
IDE05145-ENG115054-Light configuration-Light_Function_A_2,8 ,560
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24 ,560
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24 ,560
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24 ,560
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8 ,560
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8 ,560
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8 ,560
IDE05145-ENG115459-Light configuration-Light_Function_A_26,28 ,560
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38 ,560
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25 ,560
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37 ,560
IDE05145-ENG115073-Light configuration-Light_Function_A_3,8 ,560
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41 ,560
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0 ,560
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0 ,560
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0 ,560
IDE05145-ENG115611-Light configuration-Light_Function_A_34,0 ,560
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20 ,560
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20 ,560
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11 ,560
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12 ,560
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13 ,560
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14 ,560
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0 ,560
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0 ,560
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0 ,560
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0 ,560
IDE05145-ENG115211-Light configuration-Light_Function_B_12,0 ,560
IDE05145-ENG114957-Light configuration-Light_Function_B_13,0 ,560
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0 ,560
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0 ,560
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0 ,560
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0 ,560
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0 ,560
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0 ,560
IDE05145-ENG115055-Light configuration-Light_Function_B_2,9 ,560
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0 ,560
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0 ,560
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0 ,560
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9 ,560
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10 ,560
IDE05145-ENG115441-Light configuration-Light_Function_B_25,0 ,560
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0 ,560
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0 ,560
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0 ,560
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0 ,560
IDE05145-ENG115074-Light configuration-Light_Function_B_3,10 ,560
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0 ,560
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0 ,560
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0 ,560
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0 ,560
IDE05145-ENG115612-Light configuration-Light_Function_B_34,0 ,560
IDE05145-ENG115093-Light configuration-Light_Function_B_4,0 ,560
IDE05145-ENG114976-Light configuration-Light_Function_B_5,0 ,560
IDE05145-ENG115114-Light configuration-Light_Function_B_6,30 ,560
IDE05145-ENG115133-Light configuration-Light_Function_B_7,30 ,560
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15 ,560
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15 ,560
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0 ,560
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0 ,560
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0 ,560
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0 ,560
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0 ,560
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0 ,560
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0 ,560
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0 ,560
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0 ,560
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0 ,560
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0 ,560
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0 ,560
IDE05145-ENG115058-Light configuration-Light_Function_C_2,0 ,560
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0 ,560
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0 ,560
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0 ,560
IDE05145-ENG115406-Light configuration-Light_Function_C_23,0 ,560
IDE05145-ENG115425-Light configuration-Light_Function_C_24,0 ,560
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0 ,560
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0 ,560
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0 ,560
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0 ,560
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0 ,560
IDE05145-ENG115077-Light configuration-Light_Function_C_3,0 ,560
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0 ,560
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0 ,560
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0 ,560
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0 ,560
IDE05145-ENG115615-Light configuration-Light_Function_C_34,0 ,560
IDE05145-ENG115096-Light configuration-Light_Function_C_4,0 ,560
IDE05145-ENG114979-Light configuration-Light_Function_C_5,0 ,560
IDE05145-ENG115117-Light configuration-Light_Function_C_6,0 ,560
IDE05145-ENG115136-Light configuration-Light_Function_C_7,0 ,560
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0 ,560
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0 ,560
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0 ,560
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0 ,560
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0 ,560
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0 ,560
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0 ,560
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0 ,560
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0 ,560
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0 ,560
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0 ,560
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0 ,560
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0 ,560
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0 ,560
IDE05145-ENG115059-Light configuration-Light_Function_D_2,0 ,560
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0 ,560
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0 ,560
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0 ,560
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0 ,560
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0 ,560
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0 ,560
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0 ,560
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0 ,560
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0 ,560
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0 ,560
IDE05145-ENG115078-Light configuration-Light_Function_D_3,0 ,560
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0 ,560
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0 ,560
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0 ,560
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0 ,560
IDE05145-ENG115616-Light configuration-Light_Function_D_34,0 ,560
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0 ,560
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0 ,560
IDE05145-ENG115118-Light configuration-Light_Function_D_6,0 ,560
IDE05145-ENG115137-Light configuration-Light_Function_D_7,0 ,560
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0 ,560
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0 ,560
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0 ,560
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0 ,560
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0 ,560
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0 ,560
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0 ,560
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0 ,560
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0 ,560
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0 ,560
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0 ,560
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0 ,560
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0 ,560
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0 ,560
IDE05145-ENG115062-Light configuration-Light_Function_E_2,0 ,560
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0 ,560
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0 ,560
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0 ,560
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0 ,560
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0 ,560
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0 ,560
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0 ,560
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0 ,560
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0 ,560
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0 ,560
IDE05145-ENG115081-Light configuration-Light_Function_E_3,0 ,560
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0 ,560
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0 ,560
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0 ,560
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0 ,560
IDE05145-ENG115619-Light configuration-Light_Function_E_34,0 ,560
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0 ,560
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0 ,560
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0 ,560
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0 ,560
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0 ,560
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0 ,560
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0 ,560
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0 ,560
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0 ,560
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0 ,560
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0 ,560
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0 ,560
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0 ,560
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0 ,560
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0 ,560
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0 ,560
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0 ,560
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0 ,560
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0 ,560
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0 ,560
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0 ,560
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0 ,560
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0 ,560
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0 ,560
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0 ,560
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0 ,560
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0 ,560
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0 ,560
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0 ,560
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0 ,560
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0 ,560
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0 ,560
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0 ,560
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0 ,560
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0 ,560
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0 ,560
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0 ,560
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0 ,560
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0 ,560
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0 ,560
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0 ,560
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0 ,560
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0 ,560
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0 ,560
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0 ,560
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0 ,560
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0 ,560
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0 ,560
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0 ,560
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0 ,560
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0 ,560
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0 ,560
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0 ,560
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0 ,560
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0 ,560
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0 ,560
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0 ,560
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0 ,560
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0 ,560
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0 ,560
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0 ,560
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0 ,560
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0 ,560
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0 ,560
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0 ,560
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0 ,560
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0 ,560
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0 ,560
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0 ,560
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0 ,560
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0 ,560
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0 ,560
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0 ,560
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0 ,560
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0 ,560
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0 ,560
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0 ,560
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0 ,560
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0 ,560
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0 ,560
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0 ,560
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0 ,560
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0 ,560
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0 ,560
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0 ,560
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0 ,560
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0 ,560
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0 ,560
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0 ,560
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0 ,560
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0 ,560
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0 ,560
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0 ,560
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0 ,560
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0 ,560
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0 ,560
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0 ,560
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0 ,560
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0 ,560
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0 ,560
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0 ,560
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0 ,560
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0 ,560
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0 ,560
IDE05145-ENG115624-Light configuration-Light_Function_H_34,0 ,560
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0 ,560
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0 ,560
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0 ,560
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0 ,560
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0 ,560
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0 ,560
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,Blinkleuchten ,560
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,Blinkleuchten ,560
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,not active ,560
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,not active ,560
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,not active ,560
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,LED Blinkleuchten ,560
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,LED Blinkleuchten ,560
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,Blinkleuchten ,560
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,Blinkleuchten ,560
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,Bremsleuchten ,560
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,Bremsleuchten ,560
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte ,560
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,2* 5W ,560
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeineGluehlampe12W ,560
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,allgemeineGluehlampe12W ,560
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active ,560
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active ,560
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active ,560
IDE05145-ENG115608-Light configuration-Type_Of_Load_34,not active ,560
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Low beam ,560
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Low beam ,560
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,560
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 C1 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 24 23 65 42 57 9B 25 44 3F 3A 69 35 95 2C 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 24 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 27 23 65 42 57 9B 25 24 0C FA 0A 34 95 2C 09 A3 21 03 00 02 02 02 02 02 02 91 10 A1 26 A5 ,172
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min,2
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0 ,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active ,4
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36 ,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40 ,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm ,7
MAS01490-Energy management,Energy management not active ,1
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed ,1
MAS08233-ENG126575-other-mute_mode_aktiv,not active ,1
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed ,1
ENG124896-Adaptation_theft_protection,not active ,2
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,100.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,0 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,0 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,0 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,0 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,0.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,0.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,0.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,0.0 ,10
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0 ,16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0 ,16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize ,16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize ,16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize ,16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0 ,16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0 ,16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00 ,16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00 ,16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always ,16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active ,16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active ,16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active ,16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active ,16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active ,16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active ,16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active ,16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active ,16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,0 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,00 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,00 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,not active ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,not active ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,not active ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,0 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,00 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,00 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,not active ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,not active ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,not active ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,18 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,18 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken rechts Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not active ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not active ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not active ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not active ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not active ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not active ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not active ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,09 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,19 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,60 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,60 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,00 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,00 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundLinksverkehr ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,35 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Parking light ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parking light left ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not active ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not active ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Parking light ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parking light right ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,not active ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,not active ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
ENG130141-Patch_Code: Beifahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130136-Patch_Code: Fahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117299-Reversing_Threshold_Driver_Side_Rear,0 %,1
ENG117298-Reversing_Threshold_Passenger_Side_Front,0 %,1
ENG130135-Window_Regulator_Supplier_Settings_Driver_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130138-Window_Regulator_Supplier_Settings_Passener_Side_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-Window_Regulator_Supplier_Settings_Passener_Side_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-Window_Regulator_Supplier_Settings_Passener_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,88
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
Elapsed Time: 02:57
;SW:6C0-937-089-A HW:6C0-937-089 --- Cent. Elect. --- SA: 31347
;Component:BCM PQ26 Hi4R H06 0047, Coding:0300084042530A730BA44080B10707C800005B0257010000000000000000
;EV_BCMA0,004003,EV_BCMA0_004_VW26.rod
;Tuesday,16,January,2018,18:32:07:48600
;VCDS Version: Release 17.8.1 Data version: 20171130 DS276.6
;VCID: 2E581EA971AA9D3633-807A
IDE00001-ENG130235-Production mode-Entry_control,not active ,3
IDE00001-ENG130233-Production mode-Exit_lights_Heading_time_15_s,not active ,3
IDE00001-ENG130234-Production mode-Window_regulator_kl_15_nr_2,not active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,9
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,not active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,not activated ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE02152-Characteristics in production mode,0 ms,4
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,32
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,2
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,2
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.50 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,180 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,120 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,separate ,4
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active ,4
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,4
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5 ,4
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS ,4
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled ,4
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active ,4
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active ,4
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %,4
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %,4
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h,14
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active ,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,0.0 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,5
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,not active ,5
IDE04926-ENG126570-Comfort illumination-lho_zeit,0 s,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,30 s,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0.0 s,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34 ,560
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E ,560
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00 ,560
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00 ,560
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,00 ,560
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,00 ,560
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00 ,560
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00 ,560
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,00 ,560
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,00 ,560
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08 ,560
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18 ,560
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,35 ,560
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,09 ,560
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,19 ,560
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,29 ,560
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,0A ,560
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,1A ,560
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,00 ,560
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C ,560
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00 ,560
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B ,560
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00 ,560
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,3F ,560
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00 ,560
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00 ,560
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00 ,560
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00 ,560
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,00 ,560
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,3A ,560
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,44 ,560
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36 ,560
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40 ,560
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37 ,560
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41 ,560
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100 ,560
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100 ,560
IDE05145-ENG114999-Light configuration-Dimming_AB_10,0 ,560
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100 ,560
IDE05145-ENG115212-Light configuration-Dimming_AB_12,0 ,560
IDE05145-ENG114958-Light configuration-Dimming_AB_13,0 ,560
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100 ,560
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100 ,560
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100 ,560
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100 ,560
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100 ,560
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100 ,560
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100 ,560
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100 ,560
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100 ,560
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100 ,560
IDE05145-ENG115404-Light configuration-Dimming_AB_23,60 ,560
IDE05145-ENG115423-Light configuration-Dimming_AB_24,60 ,560
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100 ,560
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100 ,560
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100 ,560
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100 ,560
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100 ,560
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100 ,560
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100 ,560
IDE05145-ENG115556-Light configuration-Dimming_AB_31,0 ,560
IDE05145-ENG115575-Light configuration-Dimming_AB_32,0 ,560
IDE05145-ENG115594-Light configuration-Dimming_AB_33,0 ,560
IDE05145-ENG115613-Light configuration-Dimming_AB_34,0 ,560
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100 ,560
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100 ,560
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100 ,560
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100 ,560
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100 ,560
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100 ,560
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0 ,560
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0 ,560
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0 ,560
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0 ,560
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0 ,560
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0 ,560
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0 ,560
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0 ,560
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0 ,560
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0 ,560
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0 ,560
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0 ,560
IDE05145-ENG115060-Light configuration-Dimming_CD_2,0 ,560
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0 ,560
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0 ,560
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0 ,560
IDE05145-ENG115408-Light configuration-Dimming_CD_23,0 ,560
IDE05145-ENG115427-Light configuration-Dimming_CD_24,0 ,560
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0 ,560
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0 ,560
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0 ,560
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0 ,560
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0 ,560
IDE05145-ENG115079-Light configuration-Dimming_CD_3,0 ,560
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0 ,560
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0 ,560
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0 ,560
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0 ,560
IDE05145-ENG115617-Light configuration-Dimming_CD_34,0 ,560
IDE05145-ENG115098-Light configuration-Dimming_CD_4,0 ,560
IDE05145-ENG114981-Light configuration-Dimming_CD_5,0 ,560
IDE05145-ENG115119-Light configuration-Dimming_CD_6,0 ,560
IDE05145-ENG115138-Light configuration-Dimming_CD_7,0 ,560
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0 ,560
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0 ,560
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize ,560
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize ,560
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize ,560
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize ,560
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize ,560
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize ,560
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize ,560
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize ,560
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize ,560
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize ,560
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize ,560
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize ,560
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize ,560
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize ,560
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize ,560
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize ,560
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize ,560
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize ,560
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize ,560
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize ,560
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize ,560
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize ,560
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize ,560
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize ,560
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize ,560
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize ,560
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize ,560
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize ,560
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize ,560
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize ,560
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize ,560
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize ,560
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize ,560
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize ,560
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize ,560
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize ,560
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize ,560
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize ,560
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize ,560
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize ,560
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize ,560
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize ,560
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize ,560
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize ,560
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize ,560
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize ,560
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize ,560
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,maximize ,560
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize ,560
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize ,560
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize ,560
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize ,560
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize ,560
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize ,560
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize ,560
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize ,560
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize ,560
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize ,560
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,maximize ,560
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize ,560
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize ,560
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize ,560
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize ,560
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize ,560
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize ,560
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize ,560
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize ,560
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize ,560
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize ,560
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize ,560
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize ,560
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize ,560
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize ,560
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize ,560
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize ,560
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize ,560
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize ,560
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize ,560
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize ,560
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize ,560
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize ,560
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize ,560
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize ,560
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize ,560
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize ,560
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize ,560
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize ,560
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize ,560
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize ,560
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize ,560
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize ,560
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize ,560
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize ,560
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize ,560
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize ,560
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize ,560
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize ,560
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize ,560
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize ,560
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize ,560
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize ,560
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize ,560
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize ,560
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize ,560
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize ,560
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0 ,560
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0 ,560
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0 ,560
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0 ,560
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0 ,560
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0 ,560
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0 ,560
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0 ,560
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0 ,560
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0 ,560
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0 ,560
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0 ,560
IDE05145-ENG115064-Light configuration-Dimming_EF_2,0 ,560
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0 ,560
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0 ,560
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0 ,560
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0 ,560
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0 ,560
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0 ,560
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0 ,560
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0 ,560
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0 ,560
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0 ,560
IDE05145-ENG115083-Light configuration-Dimming_EF_3,0 ,560
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0 ,560
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0 ,560
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0 ,560
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0 ,560
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0 ,560
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0 ,560
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0 ,560
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0 ,560
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0 ,560
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0 ,560
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0 ,560
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0 ,560
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0 ,560
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0 ,560
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0 ,560
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0 ,560
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0 ,560
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0 ,560
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0 ,560
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0 ,560
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0 ,560
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0 ,560
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0 ,560
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0 ,560
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0 ,560
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0 ,560
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0 ,560
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0 ,560
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0 ,560
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0 ,560
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0 ,560
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0 ,560
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0 ,560
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0 ,560
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0 ,560
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0 ,560
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0 ,560
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0 ,560
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0 ,560
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0 ,560
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0 ,560
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0 ,560
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0 ,560
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0 ,560
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0 ,560
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0 ,560
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14 ,560
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15 ,560
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00 ,560
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00 ,560
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,00 ,560
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,00 ,560
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00 ,560
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00 ,560
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00 ,560
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,00 ,560
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16 ,560
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18 ,560
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26 ,560
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,2B ,560
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,2D ,560
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C ,560
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,29 ,560
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,2A ,560
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,00 ,560
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E ,560
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08 ,560
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32 ,560
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01 ,560
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27 ,560
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07 ,560
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00 ,560
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00 ,560
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00 ,560
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00 ,560
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20 ,560
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21 ,560
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A ,560
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B ,560
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C ,560
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D ,560
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always ,560
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always ,560
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always ,560
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always ,560
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always ,560
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always ,560
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always ,560
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always ,560
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always ,560
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always ,560
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always ,560
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always ,560
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always ,560
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always ,560
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always ,560
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always ,560
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always ,560
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always ,560
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always ,560
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always ,560
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always ,560
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always ,560
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always ,560
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always ,560
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always ,560
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always ,560
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always ,560
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always ,560
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,Always ,560
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always ,560
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always ,560
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always ,560
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always ,560
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always ,560
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always ,560
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2 ,560
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4 ,560
IDE05145-ENG114997-Light configuration-Light_Function_A_10,0 ,560
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62 ,560
IDE05145-ENG115210-Light configuration-Light_Function_A_12,0 ,560
IDE05145-ENG114956-Light configuration-Light_Function_A_13,0 ,560
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63 ,560
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64 ,560
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2 ,560
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4 ,560
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2 ,560
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4 ,560
IDE05145-ENG115054-Light configuration-Light_Function_A_2,8 ,560
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24 ,560
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24 ,560
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24 ,560
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8 ,560
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8 ,560
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8 ,560
IDE05145-ENG115459-Light configuration-Light_Function_A_26,28 ,560
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38 ,560
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25 ,560
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37 ,560
IDE05145-ENG115073-Light configuration-Light_Function_A_3,8 ,560
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41 ,560
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0 ,560
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0 ,560
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0 ,560
IDE05145-ENG115611-Light configuration-Light_Function_A_34,0 ,560
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20 ,560
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20 ,560
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11 ,560
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12 ,560
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13 ,560
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14 ,560
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0 ,560
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0 ,560
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0 ,560
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0 ,560
IDE05145-ENG115211-Light configuration-Light_Function_B_12,0 ,560
IDE05145-ENG114957-Light configuration-Light_Function_B_13,0 ,560
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0 ,560
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0 ,560
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0 ,560
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0 ,560
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0 ,560
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0 ,560
IDE05145-ENG115055-Light configuration-Light_Function_B_2,9 ,560
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0 ,560
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0 ,560
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0 ,560
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9 ,560
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10 ,560
IDE05145-ENG115441-Light configuration-Light_Function_B_25,0 ,560
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0 ,560
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0 ,560
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0 ,560
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0 ,560
IDE05145-ENG115074-Light configuration-Light_Function_B_3,10 ,560
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0 ,560
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0 ,560
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0 ,560
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0 ,560
IDE05145-ENG115612-Light configuration-Light_Function_B_34,0 ,560
IDE05145-ENG115093-Light configuration-Light_Function_B_4,0 ,560
IDE05145-ENG114976-Light configuration-Light_Function_B_5,0 ,560
IDE05145-ENG115114-Light configuration-Light_Function_B_6,30 ,560
IDE05145-ENG115133-Light configuration-Light_Function_B_7,30 ,560
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15 ,560
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15 ,560
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0 ,560
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0 ,560
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0 ,560
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0 ,560
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0 ,560
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0 ,560
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0 ,560
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0 ,560
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0 ,560
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0 ,560
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0 ,560
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0 ,560
IDE05145-ENG115058-Light configuration-Light_Function_C_2,0 ,560
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0 ,560
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0 ,560
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0 ,560
IDE05145-ENG115406-Light configuration-Light_Function_C_23,0 ,560
IDE05145-ENG115425-Light configuration-Light_Function_C_24,0 ,560
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0 ,560
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0 ,560
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0 ,560
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0 ,560
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0 ,560
IDE05145-ENG115077-Light configuration-Light_Function_C_3,0 ,560
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0 ,560
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0 ,560
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0 ,560
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0 ,560
IDE05145-ENG115615-Light configuration-Light_Function_C_34,0 ,560
IDE05145-ENG115096-Light configuration-Light_Function_C_4,0 ,560
IDE05145-ENG114979-Light configuration-Light_Function_C_5,0 ,560
IDE05145-ENG115117-Light configuration-Light_Function_C_6,0 ,560
IDE05145-ENG115136-Light configuration-Light_Function_C_7,0 ,560
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0 ,560
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0 ,560
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0 ,560
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0 ,560
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0 ,560
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0 ,560
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0 ,560
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0 ,560
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0 ,560
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0 ,560
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0 ,560
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0 ,560
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0 ,560
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0 ,560
IDE05145-ENG115059-Light configuration-Light_Function_D_2,0 ,560
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0 ,560
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0 ,560
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0 ,560
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0 ,560
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0 ,560
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0 ,560
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0 ,560
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0 ,560
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0 ,560
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0 ,560
IDE05145-ENG115078-Light configuration-Light_Function_D_3,0 ,560
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0 ,560
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0 ,560
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0 ,560
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0 ,560
IDE05145-ENG115616-Light configuration-Light_Function_D_34,0 ,560
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0 ,560
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0 ,560
IDE05145-ENG115118-Light configuration-Light_Function_D_6,0 ,560
IDE05145-ENG115137-Light configuration-Light_Function_D_7,0 ,560
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0 ,560
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0 ,560
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0 ,560
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0 ,560
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0 ,560
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0 ,560
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0 ,560
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0 ,560
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0 ,560
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0 ,560
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0 ,560
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0 ,560
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0 ,560
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0 ,560
IDE05145-ENG115062-Light configuration-Light_Function_E_2,0 ,560
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0 ,560
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0 ,560
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0 ,560
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0 ,560
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0 ,560
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0 ,560
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0 ,560
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0 ,560
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0 ,560
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0 ,560
IDE05145-ENG115081-Light configuration-Light_Function_E_3,0 ,560
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0 ,560
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0 ,560
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0 ,560
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0 ,560
IDE05145-ENG115619-Light configuration-Light_Function_E_34,0 ,560
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0 ,560
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0 ,560
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0 ,560
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0 ,560
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0 ,560
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0 ,560
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0 ,560
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0 ,560
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0 ,560
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0 ,560
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0 ,560
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0 ,560
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0 ,560
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0 ,560
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0 ,560
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0 ,560
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0 ,560
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0 ,560
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0 ,560
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0 ,560
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0 ,560
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0 ,560
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0 ,560
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0 ,560
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0 ,560
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0 ,560
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0 ,560
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0 ,560
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0 ,560
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0 ,560
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0 ,560
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0 ,560
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0 ,560
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0 ,560
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0 ,560
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0 ,560
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0 ,560
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0 ,560
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0 ,560
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0 ,560
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0 ,560
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0 ,560
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0 ,560
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0 ,560
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0 ,560
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0 ,560
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0 ,560
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0 ,560
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0 ,560
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0 ,560
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0 ,560
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0 ,560
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0 ,560
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0 ,560
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0 ,560
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0 ,560
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0 ,560
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0 ,560
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0 ,560
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0 ,560
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0 ,560
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0 ,560
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0 ,560
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0 ,560
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0 ,560
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0 ,560
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0 ,560
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0 ,560
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0 ,560
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0 ,560
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0 ,560
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0 ,560
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0 ,560
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0 ,560
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0 ,560
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0 ,560
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0 ,560
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0 ,560
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0 ,560
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0 ,560
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0 ,560
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0 ,560
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0 ,560
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0 ,560
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0 ,560
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0 ,560
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0 ,560
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0 ,560
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0 ,560
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0 ,560
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0 ,560
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0 ,560
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0 ,560
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0 ,560
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0 ,560
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0 ,560
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0 ,560
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0 ,560
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0 ,560
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0 ,560
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0 ,560
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0 ,560
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0 ,560
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0 ,560
IDE05145-ENG115624-Light configuration-Light_Function_H_34,0 ,560
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0 ,560
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0 ,560
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0 ,560
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0 ,560
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0 ,560
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0 ,560
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,Blinkleuchten ,560
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,Blinkleuchten ,560
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,not active ,560
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,not active ,560
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,not active ,560
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,LED Blinkleuchten ,560
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,LED Blinkleuchten ,560
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,Blinkleuchten ,560
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,Blinkleuchten ,560
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,Bremsleuchten ,560
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,Bremsleuchten ,560
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte ,560
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,2* 5W ,560
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeineGluehlampe12W ,560
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,allgemeineGluehlampe12W ,560
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active ,560
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active ,560
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active ,560
IDE05145-ENG115608-Light configuration-Type_Of_Load_34,not active ,560
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Low beam ,560
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Low beam ,560
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,560
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 C1 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 24 23 65 42 57 9B 25 44 3F 3A 69 35 95 2C 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 24 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 27 23 65 42 57 9B 25 24 0C FA 0A 34 95 2C 09 A3 21 03 00 02 02 02 02 02 02 91 10 A1 26 A5 ,172
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min,2
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0 ,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active ,4
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36 ,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40 ,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm ,7
MAS01490-Energy management,Energy management not active ,1
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed ,1
MAS08233-ENG126575-other-mute_mode_aktiv,not active ,1
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed ,1
ENG124896-Adaptation_theft_protection,not active ,2
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,100.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,0 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,0 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,0 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,0 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,0.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,0.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,0.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,0.0 ,10
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0 ,16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0 ,16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize ,16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize ,16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize ,16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0 ,16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0 ,16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00 ,16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00 ,16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always ,16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active ,16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active ,16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active ,16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active ,16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active ,16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active ,16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active ,16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active ,16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,0 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,00 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,00 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,not active ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,not active ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,not active ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,0 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,00 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,00 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,not active ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,not active ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,not active ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,18 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,18 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken rechts Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not active ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not active ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not active ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not active ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not active ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not active ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not active ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,09 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,19 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,60 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,60 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,00 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,00 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundLinksverkehr ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,35 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Parking light ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parking light left ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not active ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not active ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Parking light ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parking light right ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,not active ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,not active ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
ENG130141-Patch_Code: Beifahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130136-Patch_Code: Fahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117299-Reversing_Threshold_Driver_Side_Rear,0 %,1
ENG117298-Reversing_Threshold_Passenger_Side_Front,0 %,1
ENG122935-RLS_Washer_Front,15 s,1
ENG130135-Window_Regulator_Supplier_Settings_Driver_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130138-Window_Regulator_Supplier_Settings_Passener_Side_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-Window_Regulator_Supplier_Settings_Passener_Side_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-Window_Regulator_Supplier_Settings_Passener_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,88
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
Elapsed Time: 03:03
5F Adapmap!!!
;SW:3G0-035-021-D HW:3G0-035-021 --- Information Electr. --- SA: 20103
;Component:MU-H-LND-EU H33 0814, Coding:02730001FF00000011111201008908002F0000C601208100FE
;EV_MUHig4CGen2HBAS,001115,EV_MUHig4CGen2HBAS_VW37.rod
;Sunday,19,November,2017,16:04:41:48600
;VCDS Version: Release 17.8.0 Data version: 20170721 DS276.2
;VCID: 1932DD7518246A8E6D-804C
IDE00346-Summertime-automatic,manual ,1
IDE00768-Country identification: country of sale,DE ,2
IDE00769-Number 1 for Info call,5E 06 A1 80 00 44 42 42 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 06 A1 80 00 44 42 42 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00845-Wheel circ.,0 mm,2
IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes ,3
IDE01996-ENG99724-Installation list: specified installations-ECU coded,No ,3
IDE01996-ENG137645-Installation list: specified installations-ECU coded 2,No ,3
IDE02122-Developer mode,activated ,1
IDE02330-Number 2 for Info call,5E 07 91 94 16 05 45 84 55 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 07 91 94 16 05 45 84 55 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22 ,49
IDE02502-Confirmation of installation change,1E 4B ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,function_off_hmi_off ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,On ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.4 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_EU ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,On ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03580-Country code for mobile network,0 ,2
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04549-Telephone data services,On ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE05111-Fee-based traffic information (TMC),32771 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Petrol ,1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2,Petrol ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 ,16
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 ,16
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10604-Menu entries for mobile online services,not activated ,1
IDE10668-Internal SIM card: use,automatic ,1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,37 dBµV,3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,32 dB,3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,15.0 s,3
IDE11105-Brand-specific display of connect application,de.audi.mmiconnect ,19
IDE11122-Country identification: country of sale HMI,-- ,2
IDE11153-Surroundings display: virtual camera positions-,32767 ,330
IDE11153-Surroundings display: virtual camera positions-,65535 ,330
IDE11153-Surroundings display: virtual camera positions-,4294967295 ,330
IDE11153-Surroundings display: virtual camera positions-,0 ,330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11638-Bluetooth Audio Codec,FF ,1
MAS00951-Bluetooth,On ,1
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,OFF ,12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,0.00 ms,12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,OFF ,12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,0.00 ms,12
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9 ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Comfort data bus ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Databus Infotainment ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Databus extended ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,CAB_9 ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9 ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Databus Infotainment ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Terminal 15 ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay,0 ms,3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic,On ,3
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 96 00 A4 01 C8 00 82 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 05 ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 01:11
;SW:3G0-035-021-D HW:3G0-035-021 --- Information Electr. --- SA: S12345
;Component:MU-H-LND-EU H33 0814, Coding:02730001FF00000011111201008908002F0000C601208100FE
;EV_MUHig4CGen2HBAS,001115,EV_MUHig4CGen2HBAS_VW37.rod
;Wednesday,29,November,2017,20:28:07:48600
;VCDS Version: Release 17.8.0 Data version: 20170721 DS276.2
;VCID: 1932DD7518246A8E6D-804C
IDE00346-Summertime-automatic,manual ,1
IDE00768-Country identification: country of sale,DE ,2
IDE00769-Number 1 for Info call,5E 06 A1 80 00 44 42 42 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 06 A1 80 00 44 42 42 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00845-Wheel circ.,0 mm,2
IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes ,3
IDE01996-ENG99724-Installation list: specified installations-ECU coded,No ,3
IDE01996-ENG137645-Installation list: specified installations-ECU coded 2,No ,3
IDE02122-Developer mode,activated ,1
IDE02330-Number 2 for Info call,5E 07 91 94 16 05 45 84 55 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 07 91 94 16 05 45 84 55 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22 ,49
IDE02502-Confirmation of installation change,1E 4B ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,function_off_hmi_off ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,On ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.4 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_EU ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,On ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03580-Country code for mobile network,0 ,2
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04549-Telephone data services,On ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE05111-Fee-based traffic information (TMC),32771 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Petrol ,1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2,Petrol ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 ,16
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 ,16
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10604-Menu entries for mobile online services,not activated ,1
IDE10668-Internal SIM card: use,automatic ,1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,37 dBµV,3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,32 dB,3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,15.0 s,3
IDE11105-Brand-specific display of connect application,de.audi.mmiconnect ,19
IDE11122-Country identification: country of sale HMI,-- ,2
IDE11153-Surroundings display: virtual camera positions-,32767 ,330
IDE11153-Surroundings display: virtual camera positions-,65535 ,330
IDE11153-Surroundings display: virtual camera positions-,4294967295 ,330
IDE11153-Surroundings display: virtual camera positions-,0 ,330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11638-Bluetooth Audio Codec,FF ,1
MAS00951-Bluetooth,On ,1
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,OFF ,12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,0.00 ms,12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,OFF ,12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,0.00 ms,12
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9 ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Databus drivetrain ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Databus Infotainment ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9 ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9 ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Databus Infotainment ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Terminal 15 ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay,0 ms,3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic,On ,3
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 96 00 A4 01 C8 00 82 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 05 ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 01:08
;SW:3G0-035-021-D HW:3G0-035-021 --- Information Electr.
;Component:MU-H-LND-EU H33 0814, Coding:02730001FF00000011111201008908002F0000D601208100FE
;EV_MUHig4CGen2HBAS,001115,EV_MUHig4CGen2HBAS_VW37.rod
;Tuesday,16,January,2018,18:35:44:48600
;VCDS Version: Release 17.8.1 Data version: 20171130 DS276.6
;VCID: 1932DD7518246A8E76-804C
IDE00346-Summertime-automatic,manual ,1
IDE00768-Country identification: country of sale,GB ,2
IDE00769-Number 1 for Info call,5E 06 A1 80 00 44 42 42 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 06 A1 80 00 44 42 42 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00845-Wheel circ.,0 mm,2
IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes ,3
IDE01996-ENG99724-Installation list: specified installations-ECU coded,No ,3
IDE01996-ENG137645-Installation list: specified installations-ECU coded 2,No ,3
IDE02122-Developer mode,activated ,1
IDE02330-Number 2 for Info call,5E 07 91 94 16 05 45 84 55 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 07 91 94 16 05 45 84 55 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22 ,49
IDE02502-Confirmation of installation change,36 ED ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,function_off_hmi_off ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,On ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.4 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_EU ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,On ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03580-Country code for mobile network,0 ,2
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04549-Telephone data services,On ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE05111-Fee-based traffic information (TMC),32771 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Petrol ,1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2,Petrol ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 ,16
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 ,16
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10604-Menu entries for mobile online services,not activated ,1
IDE10668-Internal SIM card: use,automatic ,1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,37 dBµV,3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,32 dB,3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,15.0 s,3
IDE11105-Brand-specific display of connect application,de.audi.mmiconnect ,19
IDE11122-Country identification: country of sale HMI,-- ,2
IDE11153-Surroundings display: virtual camera positions-,32767 ,330
IDE11153-Surroundings display: virtual camera positions-,65535 ,330
IDE11153-Surroundings display: virtual camera positions-,4294967295 ,330
IDE11153-Surroundings display: virtual camera positions-,0 ,330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11638-Bluetooth Audio Codec,FF ,1
MAS00951-Bluetooth,On ,1
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,OFF ,12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,0.00 ms,12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,OFF ,12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,0.00 ms,12
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9 ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Databus drivetrain ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Databus Infotainment ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,CAB_9 ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9 ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9 ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Databus Infotainment ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus drivetrain ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Terminal 15 ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay,0 ms,3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic,On ,3
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 96 00 A4 01 C8 00 82 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 05 ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 01:07
