Results 1 to 10 of 19
Thread: Activate Coming/Leaving Home on MK 7.5
    Pirate
    Jan 2018
    Italy
    Hi everyone guys, I'm looking for the VCDS code to enable the Coming/Leaving Home on MK 7.5 without the light and rain sensor and without the led pack. When I open and close the car I would like to turn on the front fog lights and rear position lights. I tried the following code but the internal rear leds (those on the hatchback) don't light up. It seems that only the external leds light up:
    Left Rear Right
    Leuchte23SL HLC10-Lichtfunktion F 23: Interior light
    Leuchte23SL HLC10-Dimmwert EF 23: 28
    Leuchte23SL HLC10-Direzione dimming EF 23: maximize
    Right Rear Right
    Leuchte24SL HRA65-Lichtfunktion F 24:
    Leuchte24SL HRA65-Dimmwert EF 24: 28
    Leuchte24SL HRA65-Direzione dimming EF 24: maximize
    Front Left Fog Lamp
    Leuchte12NL LB45 lichtfunktion C12: Interior light
    Leuchte12NL LB45 dimmingwert CD12: 126
    Leuchte12NL LB45 dimming-direction CD12: maximize
    Front Right Fog Lamp
    Leuchte13NL RB5 lichtfunktion C13: Interior light
    Leuchte13NL RB5 dimmingwert CD13: 126
    Leuchte13NL RB5 dimming-direction CD13: maximize
    Thank you to everybody.
    Aug 2016
    Switzerland
    Please show us a full autoscan
    http://forums.ross-tech.com/showthre...t-an-Auto-Scan
    Grazie
  3. Likes Uwe liked this post
    ^^^^ Roberto: hi. I'm not sure that I know what the "rear position lights" are, but your instructions look like they were intended for a mk7 (not for a mk7.5).
    You can find the correct Leutch-set for any lamp on your car if you access the wiring diagram for your mk7.5. VW's standard nomenclature for Leuchte-sets identifies the pin number of the BCM in the naming convention.
    For example - in your Leuchte-set Leuchte24SL HRA65 which you call "Right Rear [Lamp] Right", the term "A65" refers to pin #65 on the A socket of the BCM.
    So, to find the Leuchte-set for the "rear position light" on your mk7.5, look at the WD and identify the socket/pin number - then use the search box for this combo in the adaptation list for the module @ address hex09
    Simples!!
    PS: I'm also not sure that applying the Leuchte-command "internal light" is the same as Coming/Leaving Home - but I agree that it's a kind-of rough surrogate!
    VW Golf MkVII (103TSI) my13
    Pirate
    Jan 2018
    Italy
    Hi guys,
    thank you very much for your replies.
    I'm not an expert of the VCDS system, I just entered on this new world and I hope you can help me to find the correct Leuchte-set of my Golf MK 7.5. My problem is that I don't know what is the WD and how to find the socket/pin number of my rear ligths. I will need your help to find the correct codification for the Coming/Leaving Home. Below you can find the full autoscan as requested:
    Thank you very much!
    Jun 2017
    Leuchte20BR L
    and
    Leuchte20BR R
    are the ones you are looking for.
    Pirate
    Jan 2018
    Italy
    Thank you @hadez16.
    Can you post the complete codification? Because I will need also the channel and settings to update.
    Jun 2017
    It is the same principle as above. Look for an unused Lichtfunktion channel (not active) where you put in Interior Light.
    Then adjust the dimming direction for that Lichtfunktion (A to G) to maximize and set the dimming value accordingly like the others ("Standlicht").
  9. #8
    Quote Originally Posted by RobertoVW View Post
    Hover your mouse over WD (which you can see is bold green) and a popup will appear telling you it means Wiring Diagram.
    You can get this for you car from erWin for a 1 hour download fee.
  10. #9
    Pirate
    Jan 2018
    Italy
    Unfortunately I'm not an expert of the VCDS system so I think that I will need the complete codification for both rear lights with the channel and settings for MK 7.5. Can you or someone kindly send me this codification? Thank you!
  11. #10
    Jun 2017
    ...and you do not want to become one?
  12. Likes iichel liked this post
