4B: Multifunc. Module (J745) 3Q0-907-338
Guccio
Japan
C?ID=326036
Hi!:):)
I'm a new comer to this forum.
I bought Touran,MY2018 HL and made DLA coding on 4B multifunction module.
AFS error(C107E54) came up as expected and I tried to do basic settings of headlights.
However, Label file wasn't found("NONE") and basic settings(IDE03675) didn't start("Not running...").
Acknowledgement(IDE03676) can delete the AFS error.
Dynamic cornering light doesn't function after this issue,
although it's demonstrated successfully when engine starts.
I think the controler, 3Q0-907-338 is not supported by VCDS at this moment.
When are you planning to support this controler(at leaset basic settings of headlight)?
Thank you in advance.
Saturday,13,January,2018,23:33:18:50204
VCDS Version: 17.12.0.1 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20171213 DS285.1
VIN: WVGZZZ1TZJW0xxxxx   License Plate:
Mileage: 724km-449mi   Repair Order:
Chassis Type: 1T-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 29 2B 39 3C 42 44 4B 52
          57 5F 6D A5 CF D6 D7
VIN: WVGZZZ1TZJW0xxxxx   Mileage: 724km-449miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 AK    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 2465
   Revision: R7H26---
   Coding: 0125003223641D083000
   ASAM Dataset: EV_ECM14TFS01104E906027AK 001002
   ROD: EV_ECM14TFS01104E906027AK.rod
   VCID: 6D8734F52D1DBFA94484-8038
   CAN Converter 01:
   Part No SW: 0CW 300 041 C    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1007
   Revision: 00005026    Serial number: CU501706118506
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 3537DC9505CD37697CD4-8060
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 61517000000755
   Coding: 0CEA92A03421236F4778060680C52930492CC4E2600194753822F078CAA2420000040212121212B235351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036.rod
   VCID: 79AF10A569551309D87C-802C
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0446041767
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E25C3B930FBF431ADAE-806A
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98201711
   Part No SW: 5G0 907 044 CJ    HW: 5G0 907 044 CJ
   Revision: 00001K10
   Coding: 0812000410010000110510401010152A
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   VCID: 71BF288531255B4960AC-8024
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865802061700EA
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B435A6D33C91199FAB0-805E
   Subsystem 1 - Part No SW: 5TC 955 119 A    HW: 5TB 955 119
   Component: WWS    170517  042 0608
   Serial number:         170530121150
   Component: RLHS  042 0105
   Serial number: S5Y17M04D27H05M42S50
   Coding: 008F77
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417617163
   Coding: 0371167851
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 50F98D019A6F72414FE2-8004
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Coding: 320467D351FFC428949C8045
   ROD: EV_ACCBOSCHVW48X.rod
   Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
   Serial number: 003VXR31H6NF
   Coding: 98FCC0C00C0000005C5450CF008800000065
   VCID: 0A4D5F693CB30891C1A6-805E
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 5TC857705E0160R00850
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 5TC857706E0159R01607
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 306 17
   Serial number: 35700000000E929C852X
   Subsystem 4 - Part No SW: -----------    HW: 480 002 306 17
   Serial number: 358000000001829C852K
   Subsystem 5 - Part No SW: -----------    HW: 480 411 906 17
   Component: SideSensor_Dr  003 0189
   Serial number: 351001A094651D834FBD
   Subsystem 6 - Part No SW: -----------    HW: 480 411 906 17
   Component: SideSensor_Pr  003 0189
   Serial number: 352001A094651D949C4B
   Subsystem 7 - Part No SW: -----------    HW: 480 402 206 17
   Serial number: 3550001B925E614195E9
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 306 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 23000019925EAC21356+
   Subsystem 9 - Part No SW: -----------    HW: 480 001 806 17
   Serial number: I0M00000000E768CC52K
   Subsystem 10 - Part No SW: -----------    HW: 480 001 806 17
   Serial number: I0N000000001D38CC52B
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170622400380
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73B3228D4B3969599240-8026
   Part No SW: 5TA 920 650 B    HW: 5TA 920 650 B
   Component: KOMBI         302 1440
   Coding: 27A401186F88000E02886B2B1403000080000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009008
   ROD: EV_DashBoardJCIMQBAB_009.rod
   VCID: 42DDB749440390D1C956-8016
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 10061710521030
   Coding: 030100047F085700FB00025E1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 3333E28D0BB9295952C0-8066
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 1631711251301243AS2B
   Coding: 2D0000
   Serial number: 2725094204
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45D7AC55552DA7E9EC74-8010
   Serial number: 17000149369011
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------
   Coding: 44C002
   VCID: 3A2DCFA92CD3D8119186-806E
   Serial number: 110417EDA26632
   Coding: 003B1320D001048000001000
   VCID: 43D3B24D5B1999D9C260-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000015279086
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 06061710521441
   Coding: 000000050100074E02000F01000000000000000000000000000000000000
   VCID: 72BD27893423605199B6-8026
   Serial number: 310517EEV25524
   Coding: 003B1120DE01048000801000
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000015210822
   Coding: 050000
Address 57: TV Tuner (R78)       Labels:* None
   Part No SW: 8V0 919 129 F    HW: 8V0 919 129 D
   Component: JP-DTV        H12 2110
   Coding: 02041C0000000100000002
   ASAM Dataset: EV_TVMELC 001039
   ROD: EV_TVMELC_VW27.rod
   Part No SW: 5NA 035 050 A    HW: 5NA 035 050
   Component: MU-H-N-JP     053 0829
   Serial number: K5F AW7U80MO6K
   Coding: 02730806FF00000051380001001038001F0100F601200500FE
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW27.rod
   VCID: 323DE789F4A320515936-8066
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZHT1782448
   Subsystem 2 - Part No SW: V03 959 803 EG    HW: -----------
   Component: JPN 2017  --- 7720
   Chip Card Reader Control Module:
   Subsystem 3 - Part No SW: 8V0 919 813 B    HW: 8V0 919 813 B
   Component: DSRC UNIT  H10 0003
   Serial number: 502129464406
   Traffic Data Aerial:
   Subsystem 4 - Part No SW: 8V0 035 504 B    HW: 8V0 035 504 B
   Component: VICS Antenna  H07 0001
   Serial number: 503530012201
   Subsystem 5 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 2014
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31406358100000
   Coding: 0308
   VCID: 41DFB84541058BC9D04C-8014
   Part No SW: 3Q0 980 653 F    HW: 3Q0 980 653
   Component: MQB_B_MFK     H13 0171
   Serial number: 08061711K24166
   Coding: 00030708000005010002234EC140A900840094300000
   ROD: EV_MFKBoschMQBB_VW27.rod
   VCID: 392FD0A529D5D30998FC-806C
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   VCID: 372BD69D1FC1C5796EE8-8062
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 7PP 941 571 AC    HW: 7PP 941 571 A
   Component: LED1L         H09 0008
   VCID: 16753B19780BDC71551E-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H09 0008
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:15, VBatt start/end: 12.1V/12.1V)-----------
AndySwede
Stockholm Sweden
C?ID=172802
There are no errors in your scan?
I had the same issue coding DLA on the new Areton. But eventhough the basic setting stated "not running" it was possible to clear the fault afterwards.
Try the latest BETA, it may solve the basic setting issue.
Guccio
Japan
C?ID=326036
No errors in my scan because I cleared it by basic settings acknowledgement.
I have already tried the latest beta, 17.12, however basic settings wouldn’t run as mentioned above.
Output test of moving headlights also failed.
Guccio
Japan
C?ID=326036
Thank you for your suggestion, Andy!
Did you solve this issue after all?
hadez16
C?ID=289891
What steps did you follow in order to retrofit DLA by coding?
hadez16
C?ID=289891
Are your headlights DLA capable?
AndySwede
Stockholm Sweden
C?ID=172802
I followed following steps.:cry:
https://www.vcdsschweiz.ch/en/activating-dynamic-light-assist-dla/
After these steps, I set codings and adaptations to the original value to see whether the issue could be fixed, and it couldn’t...
I’m thinking of trying it again.
I used the exact same instructions. I actually did not test the dynamic cornering light after coding DLA because it was dayligt. But so far (after two weeks) the customer has not yet reported any issues with the car.
Look in your debug file and try to find anything in your settings that could be made wrong. Some adaption channels have very similar names so they could easily be mixed up. Take a look in your Media Discover system, car and settings and check for the tick box. Maybe it´s deactivated?
Guccio
Japan
C?ID=326036
Yes, I think so.
LED headlights and camera are equipped.
TBAx
C?ID=287144
As far as I know there are different version of the LED headlights.
hadez16
C?ID=289891
I read more and more often that people try to retrofit DLA / ALS by coding on Tiguan / Touran / Whatever. Who told you that your headlights are DLA capable? The only car I know it is possible yet is Passat B8.
Guccio
Japan
C?ID=326036
Thank you, hadez.
I didn’t know touran isn’t capable of DLA..
The instruction says car with MQB platform is required for retrofitting DLA,
and I mistook it for that touran MY2018 could be retrofitted.
The only thing I wish is to retrieve dynamic cornering light....
AndySwede
Stockholm Sweden
C?ID=172802
And Arteon. But... I didn´t actually test DCL on that car but as said earlier - the owner has (not yet...) filed any complaints. And I can tell you it´s dark hours in Sweden between 3PM and 8AM this time of year, and sometimes around the clock when it´s cloudy.
Guccio
Japan
C?ID=326036
I found a coding shop in Japan which says it can retrofit DAL on new Touran.
I think new Touran might be capable of DAL if basic settings for AFS could be implemented...
hadez16
C?ID=289891
This only depends on the mounted headlights, not on the control units. Afaik.
So Touran is over-equipped with DLA capable headlights? Perhaps only on the international market, who knows.
Guccio
Japan
C?ID=326036
I found possible reason why dynamic AFS won't work.
It seems that the adaptation for mdf_activation initialized the value of lighting specified position.
Can I modify "IDE03727 Variable left front lighting specified position 204.70 %" by VCDS?
Do I need VCP or dealer's help?
                Address 4B: Multifunc. Module  (3Q0 907 338 )
00:13:08
  IDE03622   Left headlight beam adjusting motor: status no error
  IDE03624   Left dynamic AFS light motor: specified value 0.000000 ー
  IDE03626   Left dynamic AFS light motor: status Fault position run started
  IDE03640   Dynamic AFS light On
  IDE08706-MAS06932   Actual angle of ref. segments-Horizontal angle reference segment left -500.0 '
  IDE08706-MAS06934   Actual angle of ref. segments-Vertical angle reference segment left -120.0 '
  ENG101323   Headlight leveling control state static
  ENG107365   Left dynamic cornering light value Initializing
MasterTommy
Amsterdam
C?ID=295586
Are you talking about NAR car's? Or specifically retrofitting? Because almost every MQB car has DLA available from the factory in ROW.
I'm probably misunderstanding you.
