VW Sharan 2017, VCDS error messages.
sfryklund
Sweden
C?ID=323198
When Iám trying to open almost any module and adaptation, these error messages appears...
https://www.dropbox.com/s/x5ceokcvhozdgbc/picture1.PNG?dl=0
https://www.dropbox.com/s/ki78sewkce50v48/picture2.PNG?dl=0
Autoscan in English this time :-)
Saturday,13,January,2018,15:39:00:16178
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4409.4
VIN: WVWZZZ7NZJV008092   License Plate: YPE921
Mileage: 13160km-8177mi   Repair Order: 2
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 25 2B 42 44 46 4C 4F
          52 53 55 5F 61 62 69 6C 72
VIN: WVWZZZ7NZJV008092   Mileage: 13160km-8177miles
Address 01: Engine (J623-DFLA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 HE    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1624
   Revision: 8AH20---
   Coding: 011D001A047411083000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01104L906016HE 001003
   ROD: EV_ECM20TDI01104L906016HE_001.rod
   VCID: 73A633F7DA8A1ADE9C-8026
   Part No SW: 02E 300 066 N    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 5201
   Revision: 06454104    Serial number: 00001706171457
   Shop #: WSC 44551 111 44551
   VCID: 240400ABE7E4CD66D5-8070
Address 03: ABS Brakes (J104)       Labels:. 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CM    HW: 5N0 614 109 CM
   Component: ESC-EBC460iV1 H14 0014
   Serial number: A01J8KZ
   Coding: 12F0449A0920C2740877480922C59043103917F800014884
   VCID: 78BC04DBC3EC7986A9-802C
0763 - Tire Pressure Warning
          C102D 00 [136] -  -
                    Reset counter: 103
                    Mileage: 4855 km
                    Date: 2017.10.18
                    Time: 22:06:08
                    Additional_Codes: 11 73 00 0E C0 7F 00 48 02
                    DTC: 00 02 FB
                    Additional2: 00 0A 01 00 05 22 58 00 58 00
   Part No SW: 5K0 959 434 J    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1403
   Revision: 00092000    Serial number: 0447447312
   Coding: 032C0C
   Shop #: WSC 00020 999 39850
   ROD: EV_KESSYPQ35G.rod
   VCID: 3C34D8CBB75495A68D-8068
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [008] - Open Circuit
                    Reset counter: 37
                    Mileage: 12657 km
                    Date: 2018.01.03
                    Time: 15:03:10
   Part No SW: 7N0 907 044 BB    HW: 7N0 907 044 BB
   Component: Clima-Sharan  H04 0606
   Revision: 00001K06
   Coding: 021010C549
   VCID: 71AA39FFA09628CE6E-8024
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20170710000000124076
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0186
   Revision: BC122001
   Coding: 40180A3F8125E1C0408800C09400097403D50008666D2DB2E4848720A2C1
   Shop #: WSC 00020 790 00000
   VCID: 45C2BD2FCC9ED46EE2-8010
   Subsystem 1 - Part No SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 310517  024 0644
   Serial number: 17052603010461
   Coding: 004DBD
   Component: RLHS  042 0105
   Serial number: S8Y17M07D04H01M04S17
   Coding: 0228BB
   Subsystem 3 - Part No: 7N0 951 172
   Component: Sensor, DWA 0  005 0502
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39361719400912
   Coding: 0031150211
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   VCID: 373EC7E78E72B6FE60-8062
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 3006170466A38E
   Coding: 00001900FE0739
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3620CAE389784FF67B-8062
1130 - Sensor for Automatic Distance Control
                    Fault Priority: 9
                    Reset counter: 19
                    Mileage: 12695 km
                    Date: 2018.01.04
                    Time: 19:57:29
                    Control Module temperature: 5 °C
                    Voltage terminal 15: 12.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1132 - Sensor for Automatic Distance Control
                    Fault Priority: 9
                    Reset counter: 19
                    Mileage: 12694 km
                    Date: 2018.01.04
                    Time: 19:52:39
                    Control Module temperature: 8 °C
                    Voltage terminal 15: 14.6 V
                    Vehicle speed: 5.85 m/s
                    Acceleration: -1.23 m/s²
1131 - Sensor for Automatic Distance Control
                    Fault Priority: 9
                    Reset counter: 19
                    Mileage: 12695 km
                    Date: 2018.01.04
                    Time: 19:57:29
1542 - Sensor for Automatic Distance Control
                    Reset counter: 19
                    Mileage: 12694 km
                    Date: 2018.01.04
                    Time: 19:52:39
1545 - Sensor for Automatic Distance Control
                    Reset counter: 19
                    Mileage: 12694 km
                    Date: 2018.01.04
                    Time: 19:52:39
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag11M H15 0016
   Serial number: 003PWPDWH0CU
   Coding: 00314D
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 40CCAC3BDBBCF146D1-8014
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS6054CF8B1D9DF
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS6084FB791DDDA
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS608191801DDDR
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS6020D3791D9DV
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS6009087A1DDDP
   Part No SW: 5K0 953 501 EL    HW: 5K0 953 569 AN
   Revision: FF010042    Serial number: 20170704200076
   Coding: 111AC40008
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 1791707355600882AE1B
   Coding: 2D0000
   Part No SW: 7N0 920 870 Q    HW: 7N0 920 870 Q
   Component: KOMBI         H03 1107
   Coding: 110F010800
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 E
   Component: Standheizer     044 4941
   Revision: 00044000    Serial number: 09028239000000
   Coding: 0031142
   VCID: 373EC7E74672B6FE60-8062
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 040717F1000517
   Coding: 468022
   VCID: 7BB61BD7FADA529EC4-802E
   Component: IMMO          H03 1107
   Coding: 000007
   VCID: 6A982E938D40DB162F-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Revision: 00000000    Serial number: 17000184209007
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 312AF9FF601668CE2E-8064
   Part No SW: 7N0 959 793 H    HW: 7N0 959 793 F
   Component: TSG FA        H05 0561
   Revision:             Serial number: 0000263870920
   Coding: 011006208000411011
   VCID: 47DEB727F692C67E10-8012
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.325 1501
   Revision: 1BH04741    Serial number: 00171650017801
   Coding: 0000258
   VCID: 42C8A6331DB0E356C7-8016
   Component: EZE_2         H56 1682
   Coding: 050B0500
   VCID: 6FAE3F87BEA23E3E78-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Part No SW: 7N0 959 792 H    HW: 7N0 959 792 F
   Component: TSG BF        H05 0561
   Revision:             Serial number: 0000266484432
   Coding: 011004208000411011
   VCID: 46C0BA23F198DF76EB-8012
   Component: AFS-ECU       H05 0111
   Coding: 058200000B000200
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0011
   Coding: 360000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0011
   Coding: 360000
5275648 - Left/Right Driving Switch-Over Active
          C1080 00 [009] -  -
                    Reset counter: 210
                    Mileage: 11170 km
                    Date: 2017.12.23
                    Time: 15:02:18
   Part No SW: 5K7 035 200 L    HW: 5K7 035 200 L
   Component: MU-S--ER      H41 0449
   Serial number: VWZAZ2T5295603
   Coding: 02240800FF0000001111000100080A001F0100C40020010003
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2D12E58F7C2E0C2E0A-8078
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
   Component: Batt.regelung H56 1682
   Coding: 330F1873
   VCID: 71AA39FFA89628CE6E-8024
   Subsystem 1 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 34184549405831521005
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 K    HW: 7N0 959 794 G
   Component: TSG HL        H06 0561
   Revision:             Serial number: 0000266490058
   Coding: 010004200000411001
   VCID: 4BD68B17EAFA221E34-801E
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383 A    HW: 7N0 907 383
   Component: Anhaenger     H12 0130
   Revision: 3I001001    Serial number: 00000440794465
   Coding: 410C040003000000
   VCID: 3424F0EB97045DE645-8060
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012301000700
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 302CFCFB6B1C61C621-8064
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H06 0561
   Revision:             Serial number: 0000266489894
End----------(Elapsed Time: 01:56, VBatt start/end: 14.9V/14.9V)-----------
