Results 1 to 9 of 9
Thread: Heres a strange one
    Mar 2015
    Heres a strange one
    I was driving going home couple of nights ago and this happens; Gearbox malfunction - Safe to drive message came on along with Parking Brake Failure, Steering Assist malfunction and also ABS failure.
    My speedometer RPM has stopped working too and pretty sure its linked with the above.
    I came home and plugged it into VCFS to see pretty much every single module is seeing red. When I try to access the following modules via VCDS, it throws up a message saying no communication:
    Engine
    Transmission
    Airbag
    Parking Brake
    Every other module I access seems to say no communication with those 4 modules.
    The weird thing I have noticed is that whilst ignition is switched on, but engine off I can move the steering wheel as if the car is running.
    Last thing to mention my car is running normal, starts fine and drives fine apart from the above which is strange considering I cannot communicate with the those 4 modules above.
    I am thinking along the lines of CAN network issue however have no idea where to start and hoping someone can share some light
    Find Scan attached:
    Saturday,13,January,2018,12:16:24:05540
    VCDS Version: 17.8.1.0 (x64)
    VIN:    License Plate: AUDI A7
    Mileage: 165566km-102877mi   Repair Order:
    Chassis Type: 4G0
    Scan: 01 02 03 05 08 09 10 15 16 17 19 30 36 3B 42 44 46 47 52 53
              55 56 5F 62 6D 72 82 8F 90
       Mileage: 165566km-102877miles
    01-Engine -- Status: Malfunction 0110
    02-Auto Trans -- Status: Malfunction 0110
    03-ABS Brakes -- Status: Malfunction 0110
    04-Steering Angle -- Status: Malfunction 0110
    15-Airbags -- Status: Malfunction 0110
    53-Parking Brake -- Status: Malfunction 0110
    82-Heads Up Display -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    90-Pretens. Frt Right -- Status: Malfunction 0010
    Address 01: Engine
    Address 02: Auto Trans
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 27A68703E465E1C0DB00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 3462BB999F2ECBE645-8060
    13 Faults Found:
    0044 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:01:49
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 22
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: AA
                        Uz: B4
    0051 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: B3
                        Uz: 98
    0058 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:13:44
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BB
                        Uz: 7E
    0060 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:16:43
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BE
                        Uz: 96
    0067 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:13:44
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: D8
                        Uz: 8B
    0069 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:16:43
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E0
                        Uz: 96
    0073 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:16:43
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F2
                        Uz: 96
    0077 - Function Restricted due to Missing Message(s)
              U1111 00 [129] - -
    0713 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:13:44
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: C2
                        Uz: 82
    0715 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:13:44
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: C5
                        Uz: 82
    0722 - Function Restriction due to Implausible Message(s)
              U1112 00 [137] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:13:44
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 22
                        Uz: 82
    0821 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:13:44
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F9
                        Uz: 82
    0725 - Function Restriction due to Implausible Message(s)
              U1112 00 [137] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:13:44
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 24
                        Uz: 82
       Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
       Component: BCM2 2.0      H31 0330
       Coding: 01BA3000000000000000
       Shop #: WSC 02311 785 00200
       VCID: 76E64191C1D299F6BB-8022
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000115359003
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 45
                        Reset counter: 54
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:35:30
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0056
       Serial number: 15061100040722
       Coding: 3623000830
       ASAM Dataset: EV_AirCondiBasisUDS 002033
       VCID: 24424BD92FCE5B66D5-8070
    0260 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 12
                        Reset counter: 54
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:49:36
                        Voltage terminal 30: 14.77 V
                        Outside air temperature: 11.0 C
    0275 - Development code 1
              B2F01 00 [008] -  -
                        Reset counter: 94
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:44:40
                        Voltage terminal 30: 14.68 V
                        Outside air temperature: 7.5 C
                        Energy management heat output control status: Default
                        Electric auxiliary air heater: stage: 2
    0276 - Engine Off Timer Performance
              P150A 00 [008] - -
                        Reset counter: 94
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:00:35
                        Voltage terminal 30: 11.59 V
    0331 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 35
                        Reset counter: 54
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:35:30
                        Voltage terminal 30: 14.53 V
                        Outside air temperature: 10.5 C
    0392 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 54
                        Mileage: 163253 km
                        Date: 2017.07.14
                        Time: 08:23:34
                        Voltage terminal 30: 13.15 V
                        Outside air temperature: 17.5 C
                        Interior temperature: 19.99 C
       Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0100
       Revision: 20012002    Serial number: 00000000940391
       Coding: 2600201040349FE08181008380001D0CCF9DC30A27090101000004602100
       VCID: 6DD46EFDB4845A2E4A-8038
       Component: WWS57X 110518  H35 0051
       Serial number:         110523150047
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11486366
       Coding: 02562B
       Subsystem 3 - Part No SW: 4G0 941 531 G    HW: 4G0 941 531 G
       Component: E1 - LDS  H07 0044
       Serial number: 31 05 2011  00000423
       Component: Humidity_Sens  H02 0002
       Serial number: B5588AA5000000000001
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:43:00
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:43:00
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:43:00
                        Reset counter: 94
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:07:00
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:43:00
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:43:00
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4H0 919 475 M    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56231116108267
       Coding: 981304
       ASAM Dataset: EV_EPHVA2CAU57X0000 002008
       ROD: EV_EPHVA2CAU57X0000.rod
       VCID: 3C7293B9B77E03A68D-8068
    12648720 - Databus
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:16:45
    12658704 - Databus
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:49:23
    12648448 - Databus
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:16:46
    12648464 - Databus
                        Fault Frequency: 42
                        Reset counter: 54
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:35:29
    13637413 - Databus
                        Fault Frequency: 7
                        Reset counter: 54
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:34:47
    13679386 - Databus
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:45:15
    Address 15: Airbags
       Revision: 00000000    Serial number: 20110610000026
       Coding: 000034
       VCID: 306AB7896336F7C621-8064
       Component: E221 - MFL  H07 0009
    01312 - Powertrain Data Bus
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:04:03
                        Fault Status: 01100101
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:04:03
                        Voltage: 11.80 V
                        Hex Value: 0x0000
                        Steering Angle: -1.97
    01316 - ABS Control Module
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:04:03
    02085 - Incorrect Control Module Installed
                000 -  -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:04:03
                        Voltage: 11.80 V
                        Hex Value: 0x0000
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:04:03
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 981 S    HW: 4G8 920 981 S
       Component: TDieGb        H71 0375
       Revision: 26181114    Serial number: 658170611593007
       Coding: 33A600020B032600010100
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K.rod
       VCID: 4380E845CA807C5ECC-8016
    16776962 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:03:20
    16776967 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:03:20
    16776970 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 94
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:07:48
    16776971 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:03:20
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000169292
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 326EBD81653AC5D657-8066
       Component: J367-BDM  H07 0141
       Serial number: 40262M36331051046269
       Voltage stabilizer:
    5013 - Headlight Range Control Module
              U101E 00 [008] - No Communication
                        Reset counter: 94
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:07:49
                        Voltage terminal 30: 11.7 V
                        Voltage terminal 15: 11.7 V
                        Control Module temperature: 17 C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    0257 - Powertrain Databus
              U0002 00 [009] - No Communications
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:46:48
                        Voltage terminal 30: 11.8 V
                        Voltage terminal 15: 11.8 V
                        Control Module temperature: 14 C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    0264 - Powertrain Databus (VAG Wingle-Wire Mode) (SAE  L Shorted H)
              U0009 00 [009] - -
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:46:47
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000016389
       Coding: 01010101000000000001000202
       VCID: 64C20BD9674E1B6615-8030
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00000006174939
       Coding: 0078130000006001000001010101102030303232203232
       VCID: 77F84C95C6D8E0FEA0-8022
                        Fault Frequency: 29
                        Reset counter: 54
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:35:30
                        Fault Frequency: 33
                        Reset counter: 54
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:49:23
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA42013VLD0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D54AEFD7C049A2E0A-8078
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011F46225E21628002080402
       Shop #: WSC 02312 785 00200
       VCID: 428EED41DD9A7556C7-8016
                        Fault Frequency: 18
                        Reset counter: 54
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:49:35
                        Fault Frequency: 10
                        Reset counter: 54
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:49:52
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0009399269
       Coding: 000000000000
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       VCID: 3360B8859A20CCDE5C-8066
    3158274 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 49
                        Reset counter: 54
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:35:30
                        valid
    3158276 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 43
                        Reset counter: 54
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:49:26
                        valid
    4205828 - Steering angle sensor
              B1168 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 94
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:00:48
                        valid
    4208000 - Steering Angle Sensor
              B1168 F1 [137] - Synchronization Failed
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:45:14
                        valid
    5258753 - Steering End Stops Not Learned
              C10AC F0 [137] - Unknown Error Elaboration
                        Fault Frequency: 15
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 02:45:31
                        valid
    3150596 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Fault Frequency: 200
                        Reset counter: 94
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:41:48
                        valid
       Revision: 00002001    Serial number: 0151854802
       Coding: 013B062220B9BC8083200A04080100000000000000000000000000000000
       Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H09 0027
       Serial number: WA102622000000315231
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:48:45
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:48:45
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:48:45
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:48:45
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:48:45
    00218 - Humidity Sensor (G355)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:48:49
       Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0130
       Revision: CJ007000    Serial number: 00000000004200
       VCID: 1C3273391FBE63A66D-8048
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 418CE24DD89C6E4EDE-8014
                        Fault Frequency: 18
                        Reset counter: 54
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:49:35
                        Fault Frequency: 10
                        Reset counter: 54
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:49:52
    Address 53: Parking Brake
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Serial number: 110612-0004-013
       Coding: 1123A6101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C52A3F9471E93261D-8078
    0095 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Fault Frequency: 63
                        Reset counter: 54
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:35:30
    336388 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Fault Frequency: 42
                        Reset counter: 54
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:35:30
       Part No SW: 4G0 035 061 G    HW: 4G0 035 061
       Component: Radio U DAB   H52 0097
       Revision: AB001007    Serial number: 109F 0B7524287
       Coding: 010103010000000001
       VCID: 214C42CD38DC4E4EBE-8074
                000 -  -
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:39:45
                        Bin. Bits: 00000000 00001000
       Part No SW: 4G0 035 670 C    HW: 4G0 035 670
       Component: H-BNT-EU      H47 0406
       Revision: --------    Serial number: 428FZ0B7516802
       Coding: 090101040003E5ED45108B3E00000003000001000000000000
       VCID: 234048C522C05C5EAC-8076
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDB1300VEAT
       Subsystem 3 - Part No SW: 4G2 919 610 A    HW: 4G2 919 610 A
       Component: E380 BDT C7  H08 0203
       Serial number: 90349KEU000AJ
       Subsystem 4 - Part No: 8R0 060 961 B
       Component: CD-Database  3371
                000 -  -
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:39:51
                        Bin. Bits: 00010000 00000000
                        Bin. Bits: 00000000 00010000
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F04224021628002080002
       VCID: 4482EB59C78E7B66F5-8010
       Part No SW: 4G8 959 107 L    HW: 4G8 959 107 F
       Component: HDSG-Modul    H13 0039
       Revision: 11013001    Serial number: 137100061
       Coding: 0A3305C002
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       VCID: 3E7699B1A16211B6A3-806A
       Component: TSG HR        H04 0212
    Address 82: Heads Up Display (J898)       Labels:* None
       Part No SW: 4G8 919 604 E    HW: 4G8 919 604 E
       Component: HeadUpDisplay 006 0103
       Coding: AA0000
       ASAM Dataset: EV_HUDContiC7 001020
       ROD: EV_HUDContiC7_VW51.rod
       VCID: 3564869D9454D2EE72-8060
              U1111 00 [009] - -
                        Fault Frequency: 45
                        Reset counter: 54
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:34:54
    16777212 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Fault Frequency: 22
                        Reset counter: 94
                        Mileage: 165567 km
                        Date: 2018.01.12
                        Time: 14:45:00
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 00060000031F030000030800424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FE874F5B688A83E78-803A
    8 Faults Found:
    12583681 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:00:47
    12583691 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:39:40
    12583692 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:39:40
    12583940 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Reset counter: 94
                        Mileage: 165562 km
                        Date: 2018.01.05
                        Time: 16:45:10
    12583961 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Fault Frequency: 124
                        Reset counter: 94
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:38:14
    12583964 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Fault Frequency: 18
                        Reset counter: 94
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:44:39
    12583967 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Fault Frequency: 16
                        Reset counter: 93
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:44:46
    12588800 - Internal Control Module Memory Check Sum Error
              B2000 98 [137] - Component or system over temperature
                        Mileage: 148959 km
                        Date: 2016.09.14
                        Time: 15:12:38
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70EA7789ABB6B7C661-8024
    8 Faults Found:
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:00:47
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165567 km
                        Date: 2018.01.13
                        Time: 11:39:40
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 165566 km
                        Date: 2018.01.13
                        Time: 00:00:47
              U1112 00 [008] - -
                        Reset counter: 94
                        Mileage: 165562 km
                        Date: 2018.01.05
                        Time: 16:45:10
              U1112 00 [008] - -
                        Fault Frequency: 109
                        Reset counter: 94
                        Mileage: 165555 km
                        Date: 2018.01.05
                        Time: 14:38:14
              U1112 00 [008] - -
                        Fault Frequency: 20
                        Reset counter: 94
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:42:44
              U1112 00 [008] - -
                        Fault Frequency: 16
                        Reset counter: 93
                        Mileage: 165556 km
                        Date: 2018.01.05
                        Time: 14:44:46
                        Mileage: 148959 km
                        Date: 2016.09.14
                        Time: 15:11:39
    End-------------------------(Elapsed Time: 05:24)--------------------------
    Oct 2017
    Northwest UK
    Hi Hassan, it sounds like you've either got a flat battery, insufficient voltage, loose terminal, etc. This is the most likely issue, being power related.
    Failing in that it could be an issue with the BCM. I'd check power related issues firstly before thinking along those lines.
    Mar 2015
    Quote Originally Posted by myounus View Post
    Battery seems to be fine although I have not checked it. It starts instantly and always has, so not sure if this is the case.
    I did open the terminal on the battery hoping everything would reset, but unfortunately this did not work.
    Mar 2015
    I think I am in the right track as I've just looked at how all the modules are linked up on the Self Study Program for the A7.
    The diagram confirms my suspicion of it being CAN issue as all the modules I have that are not communicating share the Powertrain CAN bus line
    Oct 2017
    Northwest UK
    I would get the battery tested and check the cables properly, then try clearing all DTC's.
  6. #6
    Aug 2016
    Switzerland
    Here is the cause:
    Reset counter: 54
    Mileage: 165567 km
    Date: 2018.01.13
    Time: 11:46:48
    Engine running: On
    IN ZAS_Te_X: On
    Datenfeld: 0
    U0009 00 [009] - -
    Reset counter: 54
    Mileage: 165567 km
    Date: 2018.01.13
    Time: 11:46:47
    Engine running: On
    IN ZAS_Te_X: On
    Datenfeld: 0
    So somewhere there is likely a short or break in the powertrain can wires. Bring out the multimeter, time to check wiring. Maybe Google for the usual suspects, i.e. corrosion on a module or a sharp edge near a wiring loom.
  7. Likes Uwe, Jack@European_Parts, Hassan, downtime liked this post
    Here is the cause:
    I concur.
  9. Likes Jack@European_Parts, Hassan, downtime liked this post
  10. #8
    Jun 2014
    Newcastle, England
    Here is the cause:
    Wingle-Wire Eric?
    I think that should be Single-Wire. Or maybe Wiggle-Wire. Yep, you've entered VAG Wiggle-Wire Mode and need to wiggle the wire to test it.
  11. Likes Eric liked this post
  12. #9
    Wingle-Wire Eric Uwe?
    Fixed that for you -- that's almost certainly a typo that I made. I've already corrected it in the "Source" data, which will make its way into an updated CODES.DAT file at some point.
  13. Likes Eric, Zenerdiode liked this post
