Results 1 to 6 of 6
Thread: 2009 1.6tdi EGR fault P0403 P0407
    Oct 2016
    got a fault that wont clear have fitted and aftermarket EGR valve and cooler but codes remain. is there a adaption to carry out and whats the precedure ? any help much appreciated.
    Saturday,13,January,2018,09:24:41:11898
    VCDS Version: 17.8.1.0 (x64)
    Dealer/Shop Name: Sterling Garage Ltd
    VIN: WVWZZZ1KZAW051251   License Plate: VO09UXF
    Mileage: 139910km-86936mi   Repair Order:
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZAW051251   Mileage: 139910km-86936miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 B    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 9970
       Revision: --H23---    Serial number: 00000000000000
       Coding: 00114014032500080000
       ASAM Dataset: EV_ECM16TDI02103L906023B 003010
       ROD: EV_ECM16TDI02103L906023DB.rod
       VCID: 254BC3E924CF7C6EC2-8070
    7461 - EGR Valve (N18)
              P0403 00 [101] - Malfunction
                        Mileage: 139915 km
                        Date: 2018.01.13
                        Time: 09:20:53
                        Engine speed: 802.25 /min
                        Normed load value: 41.6 %
                        Coolant temperature: 56 C
                        Intake air temperature: 17 C
                        Voltage terminal 30: 14.231 V
                        Accelerator position: normalized-Accelerator position: 0.00 %
                        EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 84.253 %
                        EGR Solen.val.: actual value-ANG_EGRV[0]: 99.997 %
                        Air mass: actual value (mg/stroke)-MAF_MES: 373.071 mg/stroke
                        Sensor for engine block temperature: raw value-Coolant temperature: 56 C
    7343 - EGR Sensor 2
              P0407 00 [032] - Signal too Low
                        Mileage: 139915 km
                        Date: 2018.01.12
                        Time: 17:49:14
                        Coolant temperature: 40 C
                        Intake air temperature: 14 C
                        Voltage terminal 30: 11.633 V
                        EGR Solen.val.: actual value-ANG_EGRV[0]: -38.159 %
                        EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                        High pressure EGR actuator: activation-PWM_HBR_EGRV[0]: 0.000 %
                        High press EGR actuator: actual unconditioned volt val-V_EGRV[0]: 0.015 V
                        EGR valve: offset closed-V_EGRV_BOL[0]: 1.006 V
                        EGR valve: offset open-V_EGRV_TOL[0]: 3.999 V
                        Actuator for high pressure EGR: status-LF_STATE_EGRV_DISP[0]: 2
    Readiness: 1110 1000
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Revision: 00H45001
       Coding: 133B200D092700FBC80D04E9901A00803000
       VCID: 7EF9CC85E9D90FB6E3-802A
                        Fault Status: 00101101
                        Reset counter: 207
                        Mileage: 138666 km
                        Date: 2012.05.06
                        Time: 17:42:45
                        Count: 2
                        Count: 4864
                        Count: 8193
                        Count: 40193
                        Count: 64512
       Part No SW: 3C8 907 336 H    HW: 3C8 907 336 H
       Component: Climatic      H13 0203
       Revision: 00006001
       Coding: 0000000000
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 326128B565011BD657-8066
              B10AB F0 [009] - Too Low
                        Reset counter: 136
                        Mileage: 138028 km
                        Date: 2017.12.06
                        Time: 15:36:14
       Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
       Component: BCM PQ35  B   103 0537
       Revision: 00103 AD
       Coding: 48180A3A9025F1C044000080140000E443510088536D8160648000200000
       VCID: 2D5B3BC9743F442E0A-8078
       Component: Wischer 23060  21  0501
       Coding: 009795
       Component: RLS 290609 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
    00984 - Left Tail Light (M4)
                        Fault Status: 00101010
                        Reset counter: 207
                        Mileage: 138871 km
                        Date: 2012.05.13
                        Time: 09:45:45
                        Voltage: 14.35 V
                            Term 50 Off
    01134 - Alarm Horn (H12)
                        Reset counter: 207
                        Mileage: 139335 km
                        Date: 2012.05.20
                        Time: 06:45:13
                        Voltage: 13.75 V
                            Term 50 Off
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    033 0604
       Serial number: 003C2RA0V649
       Coding: 00003230
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 77F7D9A1CEE33EFEA0-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 5C4F6049ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 15354547ZZZZZZZZZZZZ
       Serial number: 1A412E18ZZZZZZZZZZZZ
       Serial number: 2E202F22ZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           053 0111
       Coding: 0000034
       VCID: 030FBD71423B625E8C-8056
    00888 - Wiper Switch for Intermittent Operation (E22)
       Part No SW: 5K0 920 960 J    HW: 5K0 920 960 J
       Component: KOMBI         H06 0206
       Coding: 470B00
       VCID: 346D2EAD9F1515E645-8060
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H07 0081
       Revision:   H07 01    Serial number: 220609F2001068
       Coding: E9807F06000212000003
       VCID: 66C984E55149B7760B-8032
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H06 0206
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0084
       Revision: A1001003    Serial number: 7667478268
       VCID: 2649C4E551C97776CB-8072
       Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
       Component: Tuer-SG         009 2124
       Coding: 0000692
       VCID: 336F2DB1521B12DE5C-8066
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 000    3001
       Revision: 00H15000
       Shop #: WSC 00581 210 71795
       VCID: 316327B9A80720CE2E-8064
       Component: Tuer-SG         009 2110
       Coding: 0000692
       VCID: 326128B5AD011BD657-8066
       Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
       Component: Radio RCD310  042 0082
       Revision: 01000001    Serial number: VWZ1Z2M4004926
       Coding: 0500040004000A
       VCID: 336F2DB1921B12DE5C-8066
    03138 - Input AUX IN
                        Reset counter: 132
                        Mileage: 137930 km
                        Date: 2012.04.26
                        Time: 09:46:12
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 346D2EAD571515E645-8060
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
       VCID: 356B13A95C6F0CEE72-8060
    End-------------------------(Elapsed Time: 02:08)--------------------------
    Oct 2017
    Northwest UK
    Check the wires on the plug and connectors. I changed an EGR then I realised afterwards that a wire was damaged giving me the error code.
    Aug 2016
    Switzerland
    Yes it needs adaptation. Its in basic settings in the engine
  4. Likes Uwe liked this post
    Should be: IDE00785 - Adaptation of EGR valve
    But given the fact that he still has "EGR Valve (N18) - Malfunction" I'm skeptical that it will accomplish much. I think whatever is causing this DTC needs to be fixed first.
    Aug 2016
    Switzerland
    I agree that there are good odds that the error code is still present.
    Oct 2017
    Northwest UK
    Precisely why I suggested checking the loom first as this happened to me. I ended up changing the EGR only to establish it was a damaged wire. I ordered a repair wire from dealers and it sorted the issue.
  8. Likes Uwe liked this post
