This question is concerning the new Seat Leon with automatic high/low beam control
The owner is asking if it is possible to change the time it takes to change between high and low beam.
The problem is that from a car is coming against this car it is so slow to change to low beam that it is annoying the other car.
If I remember right this is possible in the Skoda Octavia 3 via the menu.
Can I access and change the time via the VCDS. ?
I have the log file from the car. A bit old but nothing have changed except that the error on auto distance has been reset.
Thursday,20,July,2017,17:56:44:57576
VCDS Version: 17.1.3.0 (x64)
VIN: VSSZZZ5FZHR068486 License Plate: SEAT LEON XCELLENCE
Mileage: 4155km-2581mi Repair Order:
Chassis Type 5F (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 69 A5
VIN: VSSZZZ5FZHR068486 Mileage: 4155km-2581miles
Address 01: Engine (J623-CZEA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 HF HW: 04E 907 309 BJ
Component: R4 1.4l TFS H24 3545
Revision: R6H24---
Coding: 01250032246419083000
Shop #: WSC 00049 770 00124
ASAM Dataset: EV_ECM14TFS01104E906027HF 001006
ROD: EV_ECM14TFS01104E906027HF_AU37.rod
VCID: 6FEDB609B67DE43900-803A
CAN Converter 01:
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0CW 300 041 B HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1009
Revision: 00005026 Serial number: CU501704065665
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021.rod
VCID: 346779659FDB87E13D-8060
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 60927000000156
Coding: 19EE6A9224262174877B060840C92498562484E1600224731822F074C222430000000012121212B835351919323200
Shop #: WSC 00049 770 00103
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 77FD8E69CE2DACF9D8-8022
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0438402770
Coding: 032C0C
VCID: 3B755259B2854899FC-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 AL HW: 5F0 907 044 AL
Component: Climatronic H05 1801
Revision: 00001K09
Coding: 02000004200110011105000000101020
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 70EFB575AB43FBC119-8024
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001710100833
Shop #: WSC 00049 770 00199
ROD: EV_BCMBOSCH_017.rod
VCID: 7F0D6649E61D94B990-802A
Subsystem 1 - Part No SW: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 170311 041 0574
Serial number: 170331041803
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S9Y17M04D07H00M58S38
Coding: 00095D
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-283.clb
Part No SW: 5QA 919 283 A HW: 5QA 919 283
Component: PDC 4 KanalH07 0038
Serial number: 000308419617095
Coding: 0600140111
ASAM Dataset: EV_EPHVA14AU3700000 009029
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 489F3D95F353130161-801C
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Component: ACC BOSCH MQB H10 0620
Coding: 3500674955FFC728949C814580400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002005
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3C775145B78B4FA1F5-8068
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Reset counter: 127
Mileage: 4095 km
Date: 2017.07.20
Time: 13:31:34
Control Module temperature: 35 °C
Voltage terminal 15: 13.3 V
Velocity_vehicle_reference: 27.04 m/s
Longitudinal_acceleration_vehicle_reference: 0.16 m/s²
0836 - Databus
Reset counter: 163
Mileage: 3971 km
Date: 2017.07.19
Time: 10:44:27
Control Module temperature: 21 °C
Voltage terminal 15: 13.1 V
Velocity_vehicle_reference: -0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.09 m/s²
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQP6Q9J2F
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F2DD689D6BD843960-805A
Subsystem 1 - Part No SW: ----------- HW: 454 002 203 17
Serial number: 3576U00000069CD8332L
Subsystem 2 - Part No SW: ----------- HW: 454 002 703 17
Serial number: 3586U000000F53118324
Subsystem 3 - Part No SW: ----------- HW: 454 802 803 17
Component: SideSensor_Dr 301 0148
Serial number: 3516R45A3CF0F000000K
Subsystem 4 - Part No SW: ----------- HW: 454 802 703 17
Component: SideSensor_Pr 301 0148
Serial number: 3526RE809800F000000B
Subsystem 5 - Part No SW: ----------- HW: 454 801 903 17
Component: FrontSensor_D 304 0149
Serial number: 3556V8AABC10E000000U
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 JA HW: 5Q0 953 549 E
Revision: -------- Serial number: 01041704401659
Coding: 6C10
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 7EF39B4DE1179DB19B-802A
Part No SW: 5F0 920 750 D HW: 5F0 920 750 D
Component: KOMBI 306 8311
Coding: 07A43A186F84000800886A031000000000000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 2643932D5907E571B3-8072
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0006244732
Coding: 030100F42F085700EA000250140F00010001050000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 2F6D760976FDA43940-807A
Subsystem 2 - Part No SW: 5F0 959 537 A HW: 5F0 959 537 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G0498310317
Coding: 012000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 758860000017033006D0
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000092991006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0032
Serial number: 0000250103618
Coding: 00101320DC00040000001000
VCID: 479D3EA9FE4D1C7968-8012
Serial number: 00000000000014215432
Coding: 310000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 1107
ROD: EV_SteerAssisMQB_013.rod
VCID: 458134A1C4410E699A-8010
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0032
Serial number: 0000250221486
Coding: 00101320DE00040000001000
VCID: 468333ADF947057193-8012
Serial number: 00000000000014274150
Coding: 290000
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5QA 035 846 A HW: 5QA 035 846 A
Component: MU-S-N-ER H30 0359
Serial number: SEZAZ2T1079882
Coding: 04738201D70A00001111000100080A002F0100D40120010086
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE26.rod
VCID: 428B2FBDD56F3951BF-8016
Subsystem 1 - Part No SW: 5F0 919 606 HW: 5F0 919 606
Component: ABTm-2_8-CR H41 1041
Serial number: SEZ8Z9TJH01D6F
Subsystem 2 - Part No SW: 6P0 919 866 M HW: -----------
Component: ECE1 2017 --- 0730
Address 69: Trailer (J345) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 J HW: 5Q0 907 383 B
Component: Anhaenger H21 0204
Revision: 8C001003 Serial number: 0436577726
Coding: 0100000202000000
VCID: 3E735B4DA1975DB1DB-806A
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 03041711K20061
Coding: 0303070300000400002213458040A90098000E200020
ROD: EV_MFKBoschMQBB.rod
End-------------------------(Elapsed Time: 04:28)--------------------------
