Facelift A6 C7.5 (09 Cent Elec) question
Thecherry0121
C?ID=302234
Hi All,
Iv been doing a few tweeks using the readily available guides however when i go to the 09 Cent Elec module it tells me there are no codings availiable (it shows the bytes and codes but no descriptions next to the check boxes)
Now i have this for a pre facelift A6 C7
Enabling the Daytime Running Lights on/off setting in the MMI
[Select]
[09-Cent. Elect.]
[Coding - 07]
[Long Coding Helper]
Click on byte 3 and enable bit 0 (Daytime running lights adjustable via MMI)
[Do It!]
Has anyone tried this on a facelift model ?
Also on the golf platform there is an option to close all windows and sunroof using the rain sensor. Now I'm new to all of this so wondered if anyone with more knowledge could guide me ?
Cheers
Andy
hadez16
C?ID=289891
Rain closing does not work for Audi, only a very few A3 8V models could be capable of this.
Pleae post a full Auto-Scan of your car.
Thecherry0121
C?ID=302234
Wednesday,10,January,2018,16:48:41:43233
VCDS Version: 17.8.1.0 (x64)
VIN: WAUZZZ4G5FN077867   License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 42 44 46 52
          53 55 5F 62 69 6C 6D 72 85 A9 AC C0
VIN: WAUZZZ4G5FN077867   Mileage: 65516km-40709miles
Address 01: Engine (J623-CVUA)       Labels: None
   Part No SW: 4G0 907 589 D    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0002
   Revision: 54H23---
   Coding: 122A4032253603030000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589D 001002
   ROD: EV_ECM30BTD0114G0907589D.rod
   VCID: 3560ACE594E997EE72-8060
11897 - Turbocharger/Supercharger Inlet Pressure Sensor
          P012B 00 [032] - Implausible Signal
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1003
   Revision: --H19---
   VCID: 77FC66EDCE65A5FEA0-8022
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 49B7DE4192ED7B82BB00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3F8CCECDA6D55DBEA8-806A
154624 - Tire Pressure Warning
          C102D 00 [040] -  -
                    Mileage: 64742 km
                    Date: 2017.12.26
                    Time: 11:22:27
                    VzRef: 82
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    Uz: BA
                    Unlearning counter according OBD: 25
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01B9704E000000000000
   VCID: 7AFA7FD9F577B896DF-802E
   Serial number: 3215000030265011
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 10031500041607
   Coding: 362211B82D0000
   VCID: 63C422BD6AFD595EEC-8036
   Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
   Revision: 14020001    Serial number: 00001019896102
   Coding: 0105001440349FE0690140C3A0001800CF9DE7082F08020100000894E100170200400010010000
   VCID: 70EE5DF1A30BF2C661-8024
   Component: WWS57X 150213  H37 0080
   Serial number:         150218212925
   Coding: 0045F7
   Serial number: 23795154
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 03 03 2015  00001500
   Serial number: F8088897000000000001
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56291505903880
   Coding: B91318
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU64X0000.rod
   Revision: --------    Serial number: 003P1003NJMA
   Coding: 30333130313730323738554A305234473053
   VCID: 3B74BADDB2CD419E84-806E
   Serial number: 3575HRB400G52UCI4OO%
   Serial number: 3585HRB404T373K65H46
   Serial number: 3515JRB405T36K44K8SU
   Serial number: 3525JRB404V367OOPH57
   Serial number: 3554VRB405H33EQGB8T7
   Serial number: 3564VRB4010536FQQ1MO
   Revision: --------    Serial number: 90372OC600093
   Coding: 000035
   VCID: 377CA6ED86E565FE60-8062
   Component: E221 - MFL  H08 0009
   Serial number: 20 07 2011  11153056
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 985 L    HW: 4G8 920 985 L
   Component: TDieGb        H08 0043
   Revision: 04001037    Serial number: 658100315596041
   Coding: 33A612009B412600010000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 408ECD31DB2B2246D1-8014
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001758281
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001024
   ROD: EV_GatewPkoUDS_001.rod
   VCID: 75E06CE5D469D7EEB2-8020
   Serial number: 6638126003
   Voltage stabilizer:
          U140B 00 [008] - -
                    Reset counter: 140
                    Mileage: 65384 km
                    Date: 2018.01.06
                    Time: 17:26:27
                    Voltage terminal 30: 11.5 V
                    Voltage terminal 15: 11.4 V
                    Control Module temperature: 8 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 002801150001042
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
   VCID: 285E7591535BFA06F9-807C
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0112
   Serial number: 11031500040345
   Coding: 22
   VCID: 3E72B3C9A1DF54B6A3-806A
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 136
                    Mileage: 65264 km
                    Date: 2017.12.28
                    Time: 17:25:49
                    Outside air temperature: 2.5 °C
                    Left rear vent temperature: 41.2 °C
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Coding: 008001
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F6C9E8D76B5AD3E38-807A
403200 - Function Shut-Off Active
          C10C8 00 [008] -  -
                    Reset counter: 110
                    Time: 00:00:00
   Revision: AA000000    Serial number: 00000138980418
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77FC66EDC665A5FEA0-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E01EMFO
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 377CA6ED8EE565FE60-8062
   Coding: 011F16015E01620002080002
   VCID: 479CD62DF605157E10-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0021539714
   Coding: 101100010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 3978A0D5B8F1738E96-806C
   Revision: 00002001    Serial number: 0362785969
   Coding: 013B0622A0B93094C320098420010F470000000000000000000000000000
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST0006CCHB00000
   Coding: 901E00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00011888356
   Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST0006CCNH00000
   Coding: 801E00
   VCID: 4682DB29F10F0C76EB-8012
   Revision: --------    Serial number: 00000001397238
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2D5084857CB9DF2E0A-8078
   Coding: 04FE02202A130200
   VCID: 346691E19F938EE645-8060
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 D    HW: 4G1 035 021
   Component: MU-H-LND-EU   041 0389
   Serial number: A588C0F7507254
   Coding: 017502010000000013111102000A00132F0006E7F1700100DF
   VCID: 1B345A5D120D219E64-804E
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9EY800JEE
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349OBK00061
   Component: Gracenote2  --- 1012
3086 - Antenna for Telephone Mount
          B1564 01 [009] - Electrical Failure
                    Reset counter: 108
                    Mileage: 63711 km
                    Date: 2017.12.04
                    Time: 15:11:46
                    Voltage terminal 30: 14.5 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
   Coding: 010F14004001620002080002
   VCID: 4998D015E011E30E06-801C
                    Fault Status: 00101100
                    Reset counter: 140
                    Mileage: 65384 km
                    Date: 2018.01.05
                    Time: 13:20:51
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001001    Serial number: 0363209295
   Coding: 0100000202000000
   VCID: 336492FD9A9D89DE5C-8066
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027502010301000700
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 326A97F9658780D657-8066
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 059500647
   Coding: 093205C011
   ROD: EV_HDSGAu571.rod
   VCID: 3662ABE989EF9CF67B-8062
Address 85: On Board Cam. (J852)       Labels:* None
   Component: DPC-SG        H27 0081
   Coding: E0140000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C56898147A3D6261D-8078
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 150228200311
   VCID: 2E52838971BFA43633-807A
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150131144
   ROD: EV_RDCMA00100_008.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 150302201281
   ROD: EV_ActuaForExterNoiseUDS_VW12.rod
   VCID: 275C76AD5E45F57EF0-8072
End-------------------------(Elapsed Time: 06:01)--------------------------
hadez16
C?ID=289891
Does Byte 3 Bit 0 not work? It should
hadez16
C?ID=289891
DJAlix
London, United Kingdom
C?ID=238277
Only when there is the correct RLFS sensor mounted...and that is hardly the case.
Actually, for the vehicles I mentioned, XXX XXX 559 B and C are used. The OP has 8U0 955 559 B however the feature is based on 09 having the parameter to activate.
