Results 1 to 7 of 7
Thread: Facelift A6 C7.5 (09 Cent Elec) question
    Jan 2018
    Hi All,
    Iv been doing a few tweeks using the readily available guides however when i go to the 09 Cent Elec module it tells me there are no codings availiable (it shows the bytes and codes but no descriptions next to the check boxes)
    Now i have this for a pre facelift A6 C7
    Enabling the Daytime Running Lights on/off setting in the MMI
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    [Long Coding Helper]
    Click on byte 3 and enable bit 0 (Daytime running lights adjustable via MMI)
    [Do It!]
    Has anyone tried this on a facelift model ?
    Also on the golf platform there is an option to close all windows and sunroof using the rain sensor. Now I'm new to all of this so wondered if anyone with more knowledge could guide me ?
    Cheers
    Andy
    Jun 2017
    Rain closing does not work for Audi, only a very few A3 8V models could be capable of this.
    Pleae post a full Auto-Scan of your car.
    Jan 2018
    Wednesday,10,January,2018,16:48:41:43233
    VCDS Version: 17.8.1.0 (x64)
    VIN: WAUZZZ4G5FN077867   License Plate:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 42 44 46 52
              53 55 5F 62 69 6C 6D 72 85 A9 AC C0
    VIN: WAUZZZ4G5FN077867   Mileage: 65516km-40709miles
    Address 01: Engine (J623-CVUA)       Labels: None
       Part No SW: 4G0 907 589 D    HW: 4G0 907 589 B
       Component: 3.0BTD EDC17  H23 0002
       Revision: 54H23---
       Coding: 122A4032253603030000
       ASAM Dataset: EV_ECM30BTD0114G0907589D 001002
       ROD: EV_ECM30BTD0114G0907589D.rod
       VCID: 3560ACE594E997EE72-8060
    11897 - Turbocharger/Supercharger Inlet Pressure Sensor
              P012B 00 [032] - Implausible Signal
       Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H19 1003
       Revision: --H19---
       Coding: 000001
       VCID: 77FC66EDCE65A5FEA0-8022
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 49B7DE4192ED7B82BB00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3F8CCECDA6D55DBEA8-806A
    154624 - Tire Pressure Warning
              C102D 00 [040] -  -
                        Mileage: 64742 km
                        Date: 2017.12.26
                        Time: 11:22:27
                        VzRef: 82
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        Uz: BA
                        Unlearning counter according OBD: 25
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 01B9704E000000000000
       VCID: 7AFA7FD9F577B896DF-802E
       Serial number: 3215000030265011
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 10031500041607
       Coding: 362211B82D0000
       VCID: 63C422BD6AFD595EEC-8036
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
       Revision: 14020001    Serial number: 00001019896102
       Coding: 0105001440349FE0690140C3A0001800CF9DE7082F08020100000894E100170200400010010000
       VCID: 70EE5DF1A30BF2C661-8024
       Component: WWS57X 150213  H37 0080
       Serial number:         150218212925
       Coding: 0045F7
       Serial number: 23795154
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 03 03 2015  00001500
       Serial number: F8088897000000000001
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0070
       Revision: --------    Serial number: 56291505903880
       Coding: B91318
       ASAM Dataset: EV_EPHVA2CAU64X0000 001011
       ROD: EV_EPHVA2CAU64X0000.rod
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P1003NJMA
       Coding: 30333130313730323738554A305234473053
       VCID: 3B74BADDB2CD419E84-806E
       Serial number: 3575HRB400G52UCI4OO%
       Serial number: 3585HRB404T373K65H46
       Serial number: 3515JRB405T36K44K8SU
       Serial number: 3525JRB404V367OOPH57
       Serial number: 3554VRB405H33EQGB8T7
       Serial number: 3564VRB4010536FQQ1MO
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372OC600093
       Coding: 000035
       VCID: 377CA6ED86E565FE60-8062
       Component: E221 - MFL  H08 0009
       Serial number: 20 07 2011  11153056
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 985 L    HW: 4G8 920 985 L
       Component: TDieGb        H08 0043
       Revision: 04001037    Serial number: 658100315596041
       Coding: 33A612009B412600010000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K.rod
       VCID: 408ECD31DB2B2246D1-8014
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001758281
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 001024
       ROD: EV_GatewPkoUDS_001.rod
       VCID: 75E06CE5D469D7EEB2-8020
       Serial number: 6638126003
       Voltage stabilizer:
              U140B 00 [008] - -
                        Reset counter: 140
                        Mileage: 65384 km
                        Date: 2018.01.06
                        Time: 17:26:27
                        Voltage terminal 30: 11.5 V
                        Voltage terminal 15: 11.4 V
                        Control Module temperature: 8 C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 1
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H17 0200
       Serial number: 002801150001042
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       VCID: 285E7591535BFA06F9-807C
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0112
       Serial number: 11031500040345
       Coding: 22
       VCID: 3E72B3C9A1DF54B6A3-806A
    0075 - Button or Switch in Operating Unit
              B10C7 07 [008] - Mechanical Failure
                        Reset counter: 136
                        Mileage: 65264 km
                        Date: 2017.12.28
                        Time: 17:25:49
                        Outside air temperature: 2.5 C
                        Left rear vent temperature: 41.2 C
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Coding: 008001
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F6C9E8D76B5AD3E38-807A
              C10C8 00 [008] -  -
                        Reset counter: 110
                        Time: 00:00:00
       Revision: AA000000    Serial number: 00000138980418
       VCID: 77FC66EDC665A5FEA0-8022
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E01EMFO
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 377CA6ED8EE565FE60-8062
       Coding: 011F16015E01620002080002
       VCID: 479CD62DF605157E10-8012
       Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
       Component: RCEPS         H43 0012
       Revision: 00001000    Serial number: 0021539714
       Coding: 101100010001
       ASAM Dataset: EV_RCEPS 009013
       ROD: EV_RCEPS_009.rod
       VCID: 3978A0D5B8F1738E96-806C
       Revision: 00002001    Serial number: 0362785969
       Coding: 013B0622A0B93094C320098420010F470000000000000000000000000000
       Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS20.403  H03 0004
       Serial number: 0000FST0006CCHB00000
       Coding: 901E00
       Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
       Serial number: 0000000AP00011888356
       Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS20.403  H03 0004
       Serial number: 0000FST0006CCNH00000
       Coding: 801E00
       VCID: 4682DB29F10F0C76EB-8012
       Revision: --------    Serial number: 00000001397238
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 2D5084857CB9DF2E0A-8078
       Coding: 04FE02202A130200
       VCID: 346691E19F938EE645-8060
       Coding: E01F00
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 021 D    HW: 4G1 035 021
       Component: MU-H-LND-EU   041 0389
       Serial number: A588C0F7507254
       Coding: 017502010000000013111102000A00132F0006E7F1700100DF
       VCID: 1B345A5D120D219E64-804E
       Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
       Component: ECE 2017  --- 0157
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9EY800JEE
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
       Serial number: 90349OBK00061
       Component: Gracenote2  --- 1012
    3086 - Antenna for Telephone Mount
              B1564 01 [009] - Electrical Failure
                        Reset counter: 108
                        Mileage: 63711 km
                        Date: 2017.12.04
                        Time: 15:11:46
                        Voltage terminal 30: 14.5 V
                        Status of telephone-Antenna diagnostic: OK
                        Status of telephone-Telephone baseplate diagnostic: not connected
                        Status of telephone-Handset in handset holder (cradle): not selected
                        Status of telephone-Handset holder (cradle): not connected
       Coding: 010F14004001620002080002
       VCID: 4998D015E011E30E06-801C
    02123 - Door Warning Light / Entry Light
                        Fault Status: 00101100
                        Reset counter: 140
                        Mileage: 65384 km
                        Date: 2018.01.05
                        Time: 13:20:51
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
       Component: Anhaenger     H14 0137
       Revision: 7B001001    Serial number: 0363209295
       Coding: 0100000202000000
       VCID: 336492FD9A9D89DE5C-8066
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
       Component: D4-PA RVC Mid H07 0050
       Coding: 027502010301000700
       ASAM Dataset: EV_CamSysRearPANAAU914 002002
       ROD: EV_CamSysRearPANAAU914.rod
       VCID: 326A97F9658780D657-8066
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0150
       Revision: 14005001    Serial number: 059500647
       Coding: 093205C011
       ROD: EV_HDSGAu571.rod
       VCID: 3662ABE989EF9CF67B-8062
    Address 85: On Board Cam. (J852)       Labels:* None
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: E0140000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C56898147A3D6261D-8078
       Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0007
       Serial number: 150228200311
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       VCID: 2E52838971BFA43633-807A
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 150131144
       ROD: EV_RDCMA00100_008.rod
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0011
       Serial number: 150302201281
       ROD: EV_ActuaForExterNoiseUDS_VW12.rod
       VCID: 275C76AD5E45F57EF0-8072
    End-------------------------(Elapsed Time: 06:01)--------------------------
    Jun 2017
    Does Byte 3 Bit 0 not work? It should
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    Audi A1 8X, Q3 8U, A3 8V and Q2 GA will all perform rain closing if configured correctly, however only the A1 and Q3 will include the sunroof. MQB Audi cars are windows only:
    https://www.instagram.com/p/BZLUGk9g...y=vagcarcoding
    https://www.instagram.com/p/BYyDTemg...y=vagcarcoding
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
    Jun 2017
    Quote Originally Posted by DJAlix View Post
    Only when there is the correct RLFS sensor mounted...and that is hardly the case.
  7. #7
    Apr 2015
    Actually, for the vehicles I mentioned, XXX XXX 559 B and C are used. The OP has 8U0 955 559 B however the feature is based on 09 having the parameter to activate.
    VAG Car Coding
    @vagcarcoding
