Results 1 to 5 of 5
Thread: MK6 2014 GTI, able to set Comfort Blinks to 2, but not 1? (valid range: 1..5)
    Mar 2016
    I've got a 2014 GTI and want to change the "comfort blink" (aka, "Comfort Turn Signal Cycles")
    to a value of 1. It's currently set to 3.
    Using VCDS, I'm able to set it to 2, but not to 1.
    Whenever I enter 1 in the "New Value" box, VCDS grays out (disables) the "Save" button..
    VCDS on my car reports that valid range is 1->5, so it should take 1.
    (This range agrees with other online docs)
    I'm following these instructions: http://www.myturbodiesel.com/1000q/a...-signal-vw.htm
    Any suggestions on how I can get my car to accept a value of 1 for "comfort blink"?
    Thanks in advance!
    VCDS autoscan follows:
    Thursday,11,January,2018,18:18:50:09576
    VCDS Version: 17.8.1.0 (x64)
    VIN: WVWHD7AJ2EW000268   License Plate:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWHD7AJ2EW000268   Mileage: 47400km-29452miles
    Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
       Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
       Revision: E3H26---    Serial number:
       Coding: 040301081C070160
       VCID: 78D111830BF62386A9-802C
       Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 3513
       Revision: 05652104    Serial number: 00001307180293
       VCID: 277302FF96C87C7EF0-8072
       Revision: 00H31001
       Coding: 114B600C492200FA880D06EA92210041B70800
       VCID: 7DDF0097E4D406AEFA-8028
       Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
       Component: AC Manuell    H20 0505
       Revision: 00001019
       Coding: 0010002002
       VCID: 7BDB0E8FF2C0089EC4-802E
       Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
       Component: BCM PQ35  M   111 0709
       Revision: AC111709
       Coding: 6F180A1A90252AC4008800C17000054448010386434D8D60648020200040
       VCID: 41A7BC67D8ACA24EDE-8014
       Component: Wischer 20061  26  0512
       Coding: 009795
    01259 - Fuel Pump Relay (J17)
                        Fault Status: 00101001
                        Reset counter: 231
                        Mileage: 46438 km
                        Date: 2017.12.07
                        Time: 08:31:33
                            Term 15 Off
                        Voltage: 12.40 V
                            Term 50 Off
       Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
       Component: AirbagVW10G   014 0726
       Serial number: 003L4R02933T
       Coding: 00004737
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3C59CD93B74ECFA68D-8068
       Serial number: ---0000R--00008FCN00
       Serial number: 3572MSME68585478ZZZ1
       Serial number: 3582MSME6D585478ZZZ7
       Serial number: 3512QSME66483049ZZZV
       Serial number: 3522QSME4A04321EZZZU
       Serial number: 35527SME5B755C2FZZZ
       Serial number: 35627SME2C6E5C2FZZZ2
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   008 0090
       Revision: --------    Serial number:  90440MGN000BG
       Coding: 189A140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76CD1FBBC9E255F6BB-8022
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0032
       Serial number: 0151632
       Coding: 830000
       Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
       Coding: 270F01
       VCID: 3753D2BF8E68ECFE60-8062
       Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
       Component: J533  Gateway H52 1634
       Revision:   H52       Serial number: 200513F1000362
       Coding: 350002
       VCID: 74C925B3D79E47E685-8020
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         002 0002
       Revision: 00002000    Serial number: 1225223RP3TQ07
       VCID: 7EDD079B29D21DB6E3-802A
       VCID: 6AF53BCB8D5A81162F-803E
       Revision: A1001003    Serial number: 7665021244
       Coding: 010100
       VCID: 2B7BFECF4A20581E14-807E
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2105
       Coding: 0001204
       VCID: 3753D2BF4668ECFE60-8062
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 74     3501
       Revision: 00H22000
       VCID: 3957D487707CFA8E96-806C
       Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
       Coding: 0001204
       VCID: 3851D1834B76E38669-806C
       Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
       Component: LOW NAR SDARS H03 0005
       Revision: -----07S    Serial number: VWZ4Z6N3583861
       Coding: 01000400040005
       VCID: 256F08F72CC46E6EC2-8070
                        Reset counter: 67
                        Mileage: 27348 km
                        Date: 2015.12.21
                        Time: 21:06:08
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 354FD8B75C641EEE72-8060
       Coding: 0001168
       VCID: 364DDFBB416215F67B-8062
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007664987885
       Coding: 0A10040000010100
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A55CB8BBD7AF1969F-806E
    End-------------------------(Elapsed Time: 01:55)--------------------------
    Additional info: I expected my change (switching Comfort Blinks from 3 --> 2) to have
    resulted in a change in the VCDS long coding for Address 09: Cent. Elect. (J519) ",
    however the long coding (before the change, and after the change) is identical:
    Coding: 6F180A1A90252AC4008800C17000054448010386434D8D6064 8020200040
    -Ted
    Comfort blinks changes an Adaptation channel not the Coding string, hence why there is no change to the Coding - the instructions you link to show the is an Adaptation change
  3. Likes Zenerdiode liked this post
    Mar 2016
    Thanks for the quick reply PetrolDave, much appreciated!
    Q#1/2) are Adaptation parms in the VCDS Autoscan output? I did an Autoscan before and after making the change, and the Autoscan output was identical (other than the timestamp in the header).
    Q#2/2) more importantly, do you know of a way I can get VCDS to let me write a value of 1 to the Comfort blink Adaptation channel? When I enter 1 into the "New value" TextEdit box, the "Save" button goes grey, which prevents that value from taking effect.
    Thanks in advance,
    -Ted
    Dec 2016
    DE
    I wish there would be the possibility to automatically save adaption channel maps along the Auto-Scan, but there isn‘t
    When you want to set comfort blinking to 1 you are essentially disabling it. So I would recommend (since value 1 seems implausible) to just disable comfort blinking alltogether. This should be possible via coding in the BCM.
  6. Likes PetrolDave liked this post
    Mar 2016
    Thanks for the info TBAx, much appreciated. Your suggestion gave me something else to google for and eventually I came across a thread which suggested that Comfort blinks might be defeatable via the MFD (ie, by changing the car settings from the console display w/o even using VCDS).
    Lo and behold, it's actually true. In my case, it's under: Settings | Convenience | Lights & Vision | Conv. turn sig.
    There was a checkbox beside "Conv. turn sig.", and when I unchecked it, it accomplished what I wanted: set the "Comfort blink" to 1. Nice! Now I don't look as much like an idiot when I signal, then cancel the signal (due to someone else grabbing the lane, usually). Before (with default settings), there was no way to cancel the turn signal w/o having it signal 3 blinks in the opposite direction.
    Thanks again for all your help folks, I'm a happy camper now.
