Results 1 to 10 of 10
Thread: 2009 passat red light steering
    Verified VCDS User mecjp2216's Avatar
    Jan 2015
    Canada
    2009 passat 3c 2.0l red light steering
    Passat from Canada/Québec After battery low voltage the steering red light always on the steering assist does't work ....I post for my friend he make a steering angle g85 procedure it is ok but after when he make a steering stop limit procedure it does't work ....Any ideas
    Code steering assist module are
    0003 and 02546
    Please post a complete Auto-Scan for context.
    Jan 2015
    Canada
    I can not I do not have the vehicle
    Jan 2015
    Canada
    Maybe afternoon auto scan
    Jan 2015
    Canada
    Friday,12,January,2018,12:16:18:24102
    VCDS Version: 17.8.1.0
    VIN: WVWLK73C59E051807   License Plate:
    Mileage: 142450km-88514mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 6D 72
    VIN: WVWLK73C59E051807   Mileage: 142450km-88514miles
       Part No SW: 06J 906 026 AG    HW: 06J 906 026 AF
       Component: MED17.5 TFSI 2,0    3319
       Revision: AAH03---    Serial number: VWZCZ000000000
       Coding: 0404010A19070160
       Shop #: WSC 05314 000 00000
       VCID: 6FEDE5327EC32A3E78-803A
    Readiness: 0110 0101
       Part No SW: 09G 927 750 GP    HW: 09G 927 750 GP
       Component: AQ 250 6F           1391
       Revision: 00H76000    Serial number:
       Coding: 0000840
       Shop #: WSC 05311 000 00000
       VCID: 0501A79A4C7F006EA2-8050
       Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
       Component: J104    C4 440 V2   0011
       Revision: --025---    Serial number: 00000786172180
       Coding: 0000376
       VCID: 2B5531228A5B161E14-807E
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 77FDDD52069362FEA0-8022
       Revision: 00H54000    Serial number: 00000008859461
       Coding: 178C8F0340041A00470000000F000000002A5D435C000100000000000000
       Shop #: WSC 05124 000 00000
       VCID: 33652942526B4EDE5C-8066
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 070708 003  0205
       Coding: 00046997
       Shop #: WSC 05124
       Part No SW: 5N0 959 655     HW: 5N0 959 655
       Component: J234__003 VW10 HI   1815
       Revision: 19013000    Serial number: 0039BPKCFJJ4
       Coding: 0012339
       VCID: 7AFBC46635817F96DF-802E
       Subsystem 1 - Serial number: 6333FTS678922418
       Subsystem 2 - Serial number: 6343FTS637052068
       Subsystem 3 - Serial number: 6353ETS67Q94VVNJ
       Subsystem 4 - Serial number: 6363ETS6T0J3VVNJ
       Subsystem 5 - Serial number: 6374CTS68O44VVNJ
       Subsystem 6 - Serial number: 6384CTS6RE64VVNR
       Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C9953507AR
       Coding: 0001112
       VCID: 6DD1FF3A74CFD82E4A-8038
       Part No SW: 3C0 920 871 F    HW: 3C0 920 871 F
       Component: KOMBIINSTRUMENT VD1 2416
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0006305
       VCID: 275DCD1296B3327EF0-8072
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P089170540
       Coding: FD817F06020202002002
       VCID: 2A5B342685A10F16EF-807E
       Part No SW: 3C0 959 433 S    HW: 3C0 959 433 S
       Component:    IMMO         041 0383
       Revision: 00041000    Serial number: VWZCZ000000000
       Shop #: WSC 94770 999 91338
       VCID: 3A7B04667501BF969F-806E
       Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
       Component: J386  TUER-SG FT    1517
       Revision: 72009005    Serial number: 00000752188824
       Coding: 0001205
       Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.082 0401
       Revision: 1AH02234    Serial number: 00081640514802
       Coding: 0000258
       VCID: 3663105641195BF67B-8062
    00003 - Control Module
                        Fault Status: 11101100
                        Reset counter: 116
                            Term 15 On
                        (no units): 14.0
                        Voltage: 11.60 V
    02546 - Steering Limit Stop
                        Fault Status: 11100101
                        Reset counter: 116
                            Term 15 On
                        (no units): 14.0
                        Voltage: 12.40 V
       Component:    KSG PQ46 ELV 041 0472
       Coding: 13900E80D1032E521004141FF08A0F0E087801
       Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
       Component: J387  TUER-SG BT    1517
       Revision: 72009005    Serial number: 00000030788822
       Coding: 0001204
       VCID: 70EFE64E63FD35C661-8024
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000140196
       Coding: 0000057
       VCID: 285FCE2E9BAD3D06F9-807C
       Component: AFS-Steuergeraet    0133
       Coding: 2323457
       VCID: 34672A5E576549E645-8060
       Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Coding: 00000035
       Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Coding: 00000035
       Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
       Component: Radio PM6       019 0037
       Revision: 00019000    Serial number: VWZ5Z7H2257614
       Coding: 0040401
       Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
       Component: J388   TUER-SG HL   0307
       Revision: 42004101    Serial number: 00000000519121
       Coding: 0001168
       VCID: 72EBEC466DF107D697-8026
       Part No SW: 3C9 827 383 B    HW: 3C9 827 383 E
       Component: J605  HECKDECKEL    0600
       Revision: 00H27001
       Shop #: WSC 23250 384 715754
       VCID: 306F264EA37D75C621-8064
       Subsystem 1 - Part No: 3C9 827 384 B
       Component: J756  HECKDECKEL    0600
       Subsystem 2 - Serial number: 0800H27001001C0183ÿ
       Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
       Component: J389   TUER-SG HR   0307
       Revision: 42004101    Serial number: 00000000543850
       Coding: 0001168
       VCID: 73E5E94212EB0EDE9C-8026
    End-------------------------(Elapsed Time: 02:04)--------------------------
    Address 44: DTCs cleared
    Adaptation Channel 003:
    Stored value
      ERROR:
      Security
      access
      required
    Learning, helping, sharing !!
    Greeting all from Québec, Canada
  6. Likes Uwe liked this post
    I think you are going to need to find and fix whatever is causing "00003 - Control Module -- Electrical Fault in Circuit". I suspect that this fault is inside the control module itself.
    Probably a bad ground or feed cable down to the rack to module for load of pump + voltage is too low.
    Correct it......
  9. #8
    Fuse SA2, make sure the connections there look good.
    Ground point 672 is located at "left front longitudinal member". This looks to be a few inches behind where the left front bumper mounts up, top side.
    If the electrical paths for the power/ground of the J500 are good, I would suspect this is a bad rack. Since voltage drop might be of concern, a Load Pro would be handy here:
    https://www.amazon.com/Electronic-Sp.../dp/B004IKPUL2
    Jef
  10. Likes Uwe liked this post
  11. #9
    Jan 2015
    Canada
    I replace the rack and the problem is solved .......thank you to all of you
  12. Likes Uwe, Jef liked this post
  13. #10
    Feedback!
    Jef
