2009 passat red light steering
mecjp2216
Canada
C?ID=236885
2009 passat 3c 2.0l red light steering
Passat from Canada/Québec After battery low voltage the steering red light always on the steering assist does't work ....I post for my friend he make a steering angle g85 procedure it is ok but after when he make a steering stop limit procedure it does't work ....Any ideas
Code steering assist module are
0003 and 02546
mecjp2216
Canada
C?ID=236885
I can not I do not have the vehicle
mecjp2216
Canada
C?ID=236885
Maybe afternoon auto scan
mecjp2216
Canada
C?ID=236885
Friday,12,January,2018,12:16:18:24102
VCDS Version: 17.8.1.0
VIN: WVWLK73C59E051807   License Plate:
Mileage: 142450km-88514mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 6D 72
VIN: WVWLK73C59E051807   Mileage: 142450km-88514miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 AG    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    3319
   Revision: AAH03---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 05314 000 00000
   VCID: 6FEDE5327EC32A3E78-803A
Readiness: 0110 0101
   Part No SW: 09G 927 750 GP    HW: 09G 927 750 GP
   Component: AQ 250 6F           1391
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 05311 000 00000
   VCID: 0501A79A4C7F006EA2-8050
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000786172180
   Coding: 0000376
   VCID: 2B5531228A5B161E14-807E
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 77FDDD52069362FEA0-8022
   Revision: 00H54000    Serial number: 00000008859461
   Coding: 178C8F0340041A00470000000F000000002A5D435C000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 33652942526B4EDE5C-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 070708 003  0205
   Coding: 00046997
   Shop #: WSC 05124
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__003 VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPKCFJJ4
   Coding: 0012339
   VCID: 7AFBC46635817F96DF-802E
   Subsystem 1 - Serial number: 6333FTS678922418
   Subsystem 2 - Serial number: 6343FTS637052068
   Subsystem 3 - Serial number: 6353ETS67Q94VVNJ
   Subsystem 4 - Serial number: 6363ETS6T0J3VVNJ
   Subsystem 5 - Serial number: 6374CTS68O44VVNJ
   Subsystem 6 - Serial number: 6384CTS6RE64VVNR
   Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507AR
   Coding: 0001112
   VCID: 6DD1FF3A74CFD82E4A-8038
   Part No SW: 3C0 920 871 F    HW: 3C0 920 871 F
   Component: KOMBIINSTRUMENT VD1 2416
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0006305
   VCID: 275DCD1296B3327EF0-8072
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P089170540
   Coding: FD817F06020202002002
   VCID: 2A5B342685A10F16EF-807E
   Part No SW: 3C0 959 433 S    HW: 3C0 959 433 S
   Component:    IMMO         041 0383
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 94770 999 91338
   VCID: 3A7B04667501BF969F-806E
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000752188824
   Coding: 0001205
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.082 0401
   Revision: 1AH02234    Serial number: 00081640514802
   Coding: 0000258
   VCID: 3663105641195BF67B-8062
00003 - Control Module
            012 - Electrical Fault in Circuit - MIL ON
                    Fault Status: 11101100
                    Reset counter: 116
                    (no units): 14.0
                    Voltage: 11.60 V
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 116
                    (no units): 14.0
                    Voltage: 12.40 V
   Component:    KSG PQ46 ELV 041 0472
   Coding: 13900E80D1032E521004141FF08A0F0E087801
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000030788822
   Coding: 0001204
   VCID: 70EFE64E63FD35C661-8024
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000140196
   Coding: 0000057
   VCID: 285FCE2E9BAD3D06F9-807C
   Component: AFS-Steuergeraet    0133
   Coding: 2323457
   VCID: 34672A5E576549E645-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio PM6       019 0037
   Revision: 00019000    Serial number: VWZ5Z7H2257614
   Coding: 0040401
   Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
   Component: J388   TUER-SG HL   0307
   Revision: 42004101    Serial number: 00000000519121
   Coding: 0001168
   VCID: 72EBEC466DF107D697-8026
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 E
   Component: J605  HECKDECKEL    0600
   Revision: 00H27001
   Shop #: WSC 23250 384 715754
   VCID: 306F264EA37D75C621-8064
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0600
   Subsystem 2 - Serial number: 0800H27001001C0183ÿ
   Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
   Component: J389   TUER-SG HR   0307
   Revision: 42004101    Serial number: 00000000543850
   Coding: 0001168
   VCID: 73E5E94212EB0EDE9C-8026
End-------------------------(Elapsed Time: 02:04)--------------------------
Address 44: DTCs cleared
Adaptation Channel 003:
Stored value
  ERROR:
  Security
  access
  required
I think you are going to need to find and fix whatever is causing "00003 - Control Module -- Electrical Fault in Circuit". I suspect that this fault is inside the control module itself.
Probably a bad ground or feed cable down to the rack to module for load of pump + voltage is too low.
Correct it......
Jef
HQ
Fuse SA2, make sure the connections there look good.
Ground point 672 is located at "left front longitudinal member". This looks to be a few inches behind where the left front bumper mounts up, top side.
If the electrical paths for the power/ground of the J500 are good, I would suspect this is a bad rack. Since voltage drop might be of concern, a Load Pro would be handy here:
https://www.amazon.com/Electronic-Specialties-180-LOADpro-Dynamic/dp/B004IKPUL2
mecjp2216
Canada
C?ID=236885
I replace the rack and the problem is solved .......thank you to all of you :thumbs:
Jef
HQ
Feedback!
