VCDS Control Module 37 & 54 issues
   #21
Dana
Western PA, USA
That couldn't hurt. Now that you mention it I see my '17 Alltrack had IDE07565-ABS in lower speed range activated.
   #22
my_windmill
Switzerland
C?ID=325542
Tryed to change it but I need an security access.How do I get that?
   #23
my_windmill
Switzerland
C?ID=325542
Dana, could you help me please with this acces code ?
   #24
Dana
Western PA, USA
If you haven't done so already, see if the pop-up balloon (40168) code allows you to change that channel. If that doesn't work I suppose some of the MQB codes in this thread may be worth testing
http://forums.ross-tech.com/showthr...ssue-after-cluster-exchange&p=88737#post88737
... but make sure you don't lock-out the module! If you enter a code that's rejected make sure to enter a known good one (such as 40168) before experimenting with the next code.
my_windmill
Switzerland
C?ID=325542
Thank you Dana.
I tried the codes, and most got accepted but none let me to change that channel :(( "Security access required". I think I will get old, like 100 and more and die in the end and never get that PLA working.:)
   #26
my_windmill
Switzerland
C?ID=325542
Hi boys and gals ;)
I`ve made it. PLA its finally working!!! Its like heaven on earth now After loosing hours and hours of trying to find out the error I found it in the end with some logic and luck I would say because nothing was calculated. So if you really want something dont`t give up! Just keep on going and some day you are going to succeed.
I am going try to explain you how I did it.
In internet(here in ross-tech Forum one car) I found 2 cars(VW Caddy) that are similar(PLA) with mine and after comparing the codings I found some similarities and differences between my car and the other two and then I begun to change some numbers and letters in coding until I got some results.The first thing I done was to change the "59" with "DD" which lead to parking out but not able to park parallel.
Finally I`ve changed the "A" to "B" and its working.
107980 9BB369A 483087D0179 CD84259 378F150 Initial coding/not working
147940 9BB366B 47E287E027A CD822DD 378F1F0 Car 1
107940 9B9362B 484087C0278 C9882DD 378F1F0 Car 2
107980 9BB369B 483087D0179 CD842DD 378F1F0-Accepted only parking out
107980 9BB369B 483087D0179 CD842DD 378F150-Final working/coding
I would like to thank everybody who helped me or at least tried.
Thank you very much! :thanks:
Now I have another project on my " acc radar" and that would be to fix this(see below)
Every help would be appreciated because VW Switzerland (Amag) are so friendly that they`ve asked me 500 Swiss Francs as a deposit in case that VW doesn`t accept it as a warranty The 500 are just for informing VW Germany that something is wrong with my car :cool:. I told them I know already something its not working properly, its popping up on my dashboard everyday.
I think this is my last VW, with this kind of warranty...
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 A HW: 7N0 907 572
Component: ACC Bosch PQx H03 0111
Serial number: 03121577170156
Coding: 00000800FE0339
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ACCBEGVW361 001004
ROD: EV_ACCBEGVW361_SK34.rod
VCID: 3430EC33EEBEDF578E9-8060
1130 - Sensor for Automatic Distance Control
   #27
my_windmill
Switzerland
C?ID=325542
Hi VCDS community
Is it possible to calibrate ACC with VCDS?
Thank you
   #28
Calibration of ACC should be done while checking (and if necessary correcting) wheel/suspension alignment, and it require special targets and measuring equipment.
I think in principle it could probably be done with VCDS, but because the results of doing it incorrectly could be rather dangerous and unpleasant, we have not developed procedures.
