Results 1 to 4 of 4
Thread: BETA 17.12.0 - HEX-NET keeps wanting to update firmware
    Jan 2016
    Australia
    I have just updated to the latest Beta 17.12.0. I have a HEX-NET and after upgrading to 17.12.0 I went into "program options/test" to re-register my HEX-NET interface and was instructed that "Status: Firmware update required!". My Hex-net was on 0.4401 so I clicked the update link which launched the VCDS Interface Config V2.242 and it successfully updated to CB: 0.4409/ FW 0.254/ CFB: 0.10/ BL: 0.28. I then closed the update tool and went back to options/test and it shows CB: 0.4409.4 with "Status: Firmware Update Required!". So I am now in this update loop as when I am taken back to the interface config tool it says my HEX-NET is "up to date". My HEX-NET won't work as I cannot save my test as "OK" forces the firmware update process.
    Anyone else seen this issue?
    rgds
    A
    You need to switch your HEX-NET onto the beta channel using the config utility. This has been mentioned a few times on here.
  3. Likes Uwe, Eric, Boki Ar liked this post
    Oct 2014
    Arandjelovac, Serbia
  5. Likes Uwe, Eric liked this post
  6. #4
    Jan 2016
    Australia
    cheers. Will do. I suppose I have never had to do this in the past but it makes sense.
