This is a new one for me. My buddy (I'll call him Ed) bought an abandoned 2010 Tiguan from a shop (that he knows the owner). It had a bad engine and a bit of front end damage. He replaced the engine and made the needed repairs. When he went to start the car, it wouldn't. He realized that the ECU was missing, so he contacted the shop. Someone that worked at the shop was trying to make a little money on the side, and long story short, Ed got the supposed original ECU back for the car and installed it. The car is now in SAFE mode and will only run a couple of seconds. I've checked with VCDS and the ECU appears to show the VIN matching the car, so I'm assuming it's the original ECU (this is going to be at the bottom of the post). Error code 005488 - Engine Start Blocked by Immobilizer P1570 - 000 - - MIL ON is showing up. He had two keys for the car and neither one will work. Both state SAFE with the ignition turned on. I researched a bit and it seems some people have had success with resetting the ECU by disconnecting the battery and connecting the cables for awhile. Some, supposedly reteach the key with inserting the key, turning it on (not to ignition) and then removing multiple times. Some state you need to hold the unlock button while doing the process... Anyway, all seems like mysterious voodoo from what I've read. I've tried what I know about VCDS and haven't had any success. Of course, I don't have the SKC number so I can't teach the keys like I have on some other vehicles in the past. Short of him taking the car to a dealer, is there anything else I can do with VCDS to help him out?
Tuesday,09,January,2018,17:18:57:63200
VCDS Version: 17.1.3.0
VIN: WVWMN7AN4AE555477 License Plate: HJJH
Mileage: 163520km-101606mi Repair Order:
Chassis Type: AN (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 65 72
VIN: WVWMN7AN4AE555477 Mileage: 163520km-101606miles
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 906 026 DN HW: 06J 906 026 DA
Component: MED17.5 TFSI 2,0 4668
Revision: AAH07--- Serial number: VWZCZ000000000
Coding: 0423010A19070160
Shop #: WSC 01324 020 00200
VCID: 79F99A75302FB289AE-802C
U1017 - 000 -
Mileage: 163527 km
Date: 2012.06.01
Time: 00:09:45
Temperature: 6.0°C
Temperature: 9.0°C
Absolute Pres.: 1000.0 mbar
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition)
Mileage: 163527 km
Date: 2012.06.01
Time: 00:09:45
Fault Status: 11100000
Mileage: 163527 km
Date: 2012.06.01
Time: 00:09:52
RPM: 705 /min
Load: 41.6 %
Temperature: 6.0°C
Temperature: 9.0°C
Readiness: 1110 0101
Part No SW: 09G 927 750 KN HW: 09G 927 750 KN
Component: AQ 250 6F 1590
Revision: 00H76000 Serial number:
Coding: 0000840
VCID: 071DEC8D76DBD479A8-8052
Reset counter: 40
Mileage: 163527 km
Date: 2011.07.29
Time: 23:47:59
01679 - ABS Wheel Speed Signal; Front Left
013 - Check DTC Memory
Reset counter: 40
Mileage: 163527 km
Date: 2011.07.29
Time: 23:47:59
01681 - ABS Wheel Speed Signal; Rear Left
Fault Status: 00101101
Reset counter: 201
Mileage: 163527 km
Date: 2011.07.29
Time: 23:47:59
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 N HW: 5N0 614 517 N
Component: J104 C2 450 V2 0008
Revision: --H13--- Serial number: 00000002185242
Coding: 0002329
VCID: 39795A7570AF7289EE-806C
9 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 172
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:02:51
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011110
Hex Value: 0x0000
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:02:51
Fault Frequency: 39
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:02:52
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011110
Count: 251
Hex Value: 0x0000
03388 - Engine Control Module - Pressure Information
Fault Frequency: 39
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:02:52
Fault Frequency: 39
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:02:52
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011110
Count: 251
Hex Value: 0x0000
01201 - ABS Pump Supply Voltage
Fault Frequency: 39
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:02:52
00532 - Supply Voltage B+
Reset counter: 176
Mileage: 163527 km
Date: 2012.06.01
Time: 02:41:12
Hex Value: 0x0000
Voltage: 7.75 V
Bin. Bits: 00011110
Count: 112
Hex Value: 0x0000
00576 - Terminal 15
Reset counter: 176
Mileage: 163527 km
Date: 2012.06.01
Time: 02:41:12
Reset counter: 176
Mileage: 163527 km
Date: 2012.06.01
Time: 02:41:12
Part No SW: 1K0 820 047 JS HW: 1K0 820 047 JS
Component: Climatic PQ35 143 1515
Revision: 00143034 Serial number: 00000000000000
VCID: 7EF38969290195B19B-802A
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 C HW: 5K0 937 085 C
Component: BCM PQ35 B++ 008 0019
Revision: BI008001
Coding: 6D580A1B90232EC4808000851000040441015186524D89605C8000000000
VCID: 3365685D92C388D924-8066
Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 17080 012 0203
Serial number: N1955119 °203!
Coding: 009795
12 Faults Found:
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 00:14:02
Voltage: 8.40 V
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 00:14:02
Fault Frequency: 13
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 01:03:06
Term 15 Off
Voltage: 7.80 V
00955 - Key 1
Fault Frequency: 13
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 01:03:06
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:21:04
Voltage: 11.80 V
01259 - Fuel Pump Relay (J17)
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:21:04
Reset counter: 216
Mileage: 163527 km
Date: 2012.05.29
Time: 00:02:60
Voltage: 12.20 V
Reset counter: 216
Mileage: 163527 km
Date: 2012.05.29
Time: 00:02:60
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:21:04
Voltage: 11.80 V
Reset counter: 176
Mileage: 163527 km
Date: 2012.05.29
Time: 00:21:04
01516 - Terminal 30; Left
Fault Status: 00101011
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 02:01:42
Term 15 Off
Voltage: 11.40 V
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 02:01:42
Part No SW: 5N0 959 655 K HW: 5N0 959 655 K
Component: J234__200 VW10 HI 1916
Revision: 20013000 Serial number: 003E3PDUEV6A
Coding: 0012336
VCID: 458126850C5706699A-8010
Subsystem 1 - Part No: 5N0 959 339 A
Component: BF-Gewichtsens. 001 0004
Subsystem 2 - Serial number: 00000000004N5X
Subsystem 3 - Serial number: 0015.07.090000100000630104ÿ†63
Subsystem 4 - Serial number: 630104ÿ†6332MTS664362229 ÿ†63
Subsystem 5 - Serial number: 62229 ÿ†6342MTS624402239 ÿ†63
Subsystem 6 - Serial number: 02239 ÿ†6351HTS61K0MV8KR ÿ†63
Subsystem 7 - Serial number: MV8KR ÿ†6361HTS67UVLV8KJ ÿ†63
Subsystem 8 - Serial number: LV8KJ ÿ†63727TS635SR16KR ÿ†63
Subsystem 9 - Serial number: R16KR ÿ†63827TS69M0S16KJ ÿ
Subsystem 10 - Serial number: S16KJ ÿ
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - MIL ON
Fault Frequency: 74
Mileage: 163527 km
Date: 2012.05.29
Time: 00:03:25
02512 - Pressure Sensor for Seat Occupied Recognition (G452)
011 - Open Circuit - MIL ON
Fault Frequency: 74
Mileage: 163527 km
Date: 2012.05.29
Time: 00:03:25
Fault Frequency: 7
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 02:20:47
02511 - Control Module for Seat Occupied Recognition (J706)
014 - Defective - Intermittent - MIL ON
Fault Frequency: 7
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 02:20:47
Part No SW: 1K0 953 549 CM HW: 1K0 953 549 CM
Component: J0527 053 0111
Coding: 0001032
VCID: 7F0D746D2E0B9CB990-802A
Part No SW: 5N0 920 961 HW: 5N0 920 961
Component: KOMBI H05 0206
Coding: 210700
VCID: 6ED3B929B161E5310B-803A
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
Reset counter: 176
Mileage: 163527 km
Date: 2018.01.09
Time: 00:09:23
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0110
Revision: H07 01 Serial number: 030809F1000021
Coding: FD807F07000202006002
VCID: 69D9CA35408F02095E-803C
Fault Status: 00110100
Reset counter: 216
Mileage: 163527 km
Date: 2012.05.29
Time: 00:03:20
Fault Frequency: 7
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 02:24:37
Component: IMMO H05 0206
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [009] - -
Mileage: 163527 km
Date: 2018.01.09
Time: 00:09:49
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Part No SW: 5N0 959 701 B HW: 5N0 959 701 B
Component: Tuer-SG 008 2005
Coding: 0001205
VCID: 34676B4157CD8FE13D-8060
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.162 0703
Revision: 1AH03273 Serial number: 00091670153502
Coding: 0000258
VCID: 3A7B457975A97991E7-FFFE
10 Faults Found:
Fault Frequency: 22
Reset counter: 216
Mileage: 163527 km
Date: 2012.05.29
Time: 00:03:26
RPM: 1500 /min
(no units): 7.0
Voltage: 12.20 V
00566 - Steering Assistance Operation
Fault Frequency: 22
Reset counter: 216
Mileage: 163527 km
Date: 2012.05.29
Time: 00:03:26
01288 - Terminal 30; Steering Assist
Fault Priority: 9
Reset counter: 216
(no units): 2.0
Voltage: 9.50 V
Fault Priority: 9
Reset counter: 216
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 00:01:44
Voltage: 1.40 V
Voltage: 5.00 V
Voltage: 5.00 V
Not Occup.
Not Occup.
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 00:01:44
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 00:01:44
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 00:01:44
00576 - Terminal 15
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 00:01:44
Reset counter: 216
Mileage: 163527 km
Date: 2012.06.01
Time: 00:01:44
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 5N0 959 702 B HW: 5N0 959 702 B
Coding: 0001204
VCID: 356156455CB796E90A-8060
Part No SW: 5N0 907 801 E HW: 5N0 907 801 E
Component: J540 EPB3 VW-13948 0008
Revision: H10 Serial number: 00000000036638
Coding: 0000057
VCID: 31696255A8DFBAC956-8064
Reset counter: 216
Mileage: 163527 km
Voltage: 11.90 V
Count: 73
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
Reset counter: 216
Mileage: 163527 km
Fault Frequency: 30
Reset counter: 216
Mileage: 163527 km
Voltage: 7.90 V
Count: 52
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
Fault Frequency: 30
Reset counter: 216
Mileage: 163527 km
Reset counter: 216
Mileage: 163527 km
Voltage: 11.90 V
Count: 63
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 018 0021
Revision: 00018000 Serial number: VWZ4Z7H6392390
Coding: 0040401
VCID: 204F9711F3350341C9-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.clb
Part No SW: 5N0 959 703 C HW: 5N0 959 703 C
Component: Tuer-SG 007 2001
Coding: 0001168
Shop #: WSC 01324 020 1012552
VCID: 377D5C4D46BB64F918-8062
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 008 0817
Coding: 018705
02903 - Hard Warning 2
Fault Status: 01100010
Mileage: 163527 km
Date: 2012.05.29
Time: 00:03:45
Text: 3446633282
Pressure: 0.00 bar
Pressure: 2.40 bar
Temperature: 52.4°C
Text: 00
02214 - Tire Pressure Warning
Mileage: 163527 km
Date: 2012.05.29
Time: 00:03:45
02801 - Hard Warning
Mileage: 163527 km
Date: 2012.05.29
Time: 00:41:01
Text: 3446633271
Pressure: 1.70 bar
Pressure: 2.40 bar
Temperature: 8.0°C
Text: A0
02904 - Hard Warning 3
Mileage: 163527 km
Date: 2012.05.29
Time: 00:41:01
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.clb
Part No SW: 5N0 959 704 C HW: 5N0 959 704 C
Coding: 0001168
VCID: 387F5F714BA56B8111-806C
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End-------------------------(Elapsed Time: 02:37)--------------------------
Tuesday,09,January,2018,16:16:03:63200
VCDS Version: Release 17.1.3
Control Module Part Number: 5N0 920 961
Component and/or Version: IMMO H05 0206
Software Coding:
Work Shop Code:
Advanced Identification/FAZIT
Identification: VD1-048
Date: 19.08.09
Manufacturer number: 7392
Test stand number: 5473
Flash Status
Software
OSEK-OS: 03.14.00
HiSpd Net: 01.10.00
Misc.
Hardware number: 5N0 920 961
Workshop System Name: J334
End of Line Equipment Level: ------------------
ASAM Dataset Revision: A03004
Car Info
Chassis Number: WVGAV7AXXAW000446
Immobilizer
Transponder ID (Current val.): C0F82F05
Transponder ID 1: C0F82F05
Transponder ID 2: C0C8BCC5
Transponder ID 3: B91E65AA
VCDS Info:
