Need to know if I can code the ABS for AWD or if I need to get a different ABS module. Engine is in car and wired. AWD is in and wired. Car drives. Thanks!
Wednesday,10,January,2018,14:04:55:31224
VCDS Version: 17.8.1.0 (x64)
VIN: WVGAV75N49W508982 License Plate:
Mileage: 156250km-97089mi Repair Order: tiguan
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 53 56 62 65 72
VIN: WVGAV75N49W508982 Mileage: 156250km-97089miles
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 KR HW: 022 906 032 GP
Component: R32-DQ-LEV2 G 1098
Revision: 1QH02--- Serial number: VWX7Z0G53NK87G
Coding: 0000178
Shop #: WSC 01279 785 00200
VCID: 65C16BE3AC183E6E02-8030
012313 - Valve for Exhaust Flap 1 (N321)
P3019 - 004 - Open Circuit
Mileage: 156259 km
Time: 15:36:17
RPM: 1299 /min
Load: 38.0 %
Temperature: 15.0°C
Temperature: 17.0°C
Absolute Pres.: 990.0 mbar
Voltage: 9.525 V
000080 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0050 - 004 - Malfunction / Open Circuit - MIL ON
Fault Status: 11100100
Mileage: 156259 km
Time: 15:36:23
RPM: 1159 /min
Load: 41.6 %
Temperature: 15.0°C
Temperature: 17.0°C
Voltage: 13.589 V
001393 - Brake Switch (F)
P0571 - 008 - Implausible Signal
Mileage: 156259 km
Time: 20:43:46
RPM: 772 /min
Load: 37.2 %
Temperature: 27.0°C
Temperature: 18.0°C
Voltage: 13.716 V
006480 - Radiator Fan (V7)
P1950 - 002 - Movement Restricted / Jammed - Intermittent
Mileage: 156259 km
Time: 21:41:04
RPM: 616 /min
Load: 29.8 %
Temperature: 83.0°C
Temperature: 33.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.081 V
Readiness: 0010 0101
Part No SW: 02E 300 011 CC HW: 02E 927 770 AD
Component: GSG DSG 082 1405
Revision: 05108020 Serial number: 00001008181675
Shop #: WSC 04940 001 00001
VCID: 52ABA03FCD96B9D677-8006
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 L HW: 5N0 614 517 L
Component: J104 C2 450 V2 0006
Revision: --H12--- Serial number: 00000001355747
Coding: 0002329
Shop #: WSC 00000 785 00200
VCID: 377DF1AB46347CFE60-8062
Reset counter: 119
Mileage: 156259 km
Time: 20:36:16
Hex Value: 0x0000
Voltage: 11.50 V
Bin. Bits: 00011111
Count: 238
Hex Value: 0x0000
Reset counter: 119
Mileage: 156259 km
Time: 21:41:02
Hex Value: 0x0000
Voltage: 13.00 V
Bin. Bits: 00011111
Count: 215
Hex Value: 0x0000
Reset counter: 119
Hex Value: 0x0000
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 165
Hex Value: 0x0000
Part No SW: 1K0 820 047 JL HW: 1K0 820 047 JL
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 77FD31AB06B4BCFEA0-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000008698745
Coding: 10880FA340041C0047190000140000000008F3475C400104390000000000
Shop #: WSC 01287 785 00200
VCID: 326BC0BFAD5699D657-8066
Subsystem 1 - Part No: 5N1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 150708 012 0203
Coding: 00038805
Shop #: WSC 01287
02604 - Low Vehicle Voltage from Power Steering Control Module
Reset counter: 159
Mileage: 156259 km
Voltage: 12.70 V
Part No SW: 5N0 959 655 B HW: 5N0 959 655 B
Component: J234__200 VW10 HI 1815
Revision: 19013000 Serial number: 0039EPDZ9EC5
Coding: 0012336
VCID: 3C77EE877F125FA68D-8068
Subsystem 1 - Part No: 5N0 959 339 A
Component: BF-Gewichtsens. 001 0004
Subsystem 2 - Serial number: 00000000000UBL
Subsystem 3 - Serial number: 0019.03.080000100000650017ÿ†63
Subsystem 4 - Serial number: 650017ÿ†6333FTS682791598 ÿ†63
Subsystem 5 - Serial number: 91598 ÿ†6343FTS631171638 ÿ†63
Subsystem 6 - Serial number: 71638 ÿ†6353ETS60IKBUVNH ÿ†63
Subsystem 7 - Serial number: BUVNH ÿ†6363ETS6LCPBUVNH ÿ†63
Subsystem 8 - Serial number: BUVNH ÿ†6373JTS6DRI7UVNP ÿ†63
Subsystem 9 - Serial number: 7UVNP ÿ†6383JTS6V7H7UVNH ÿ
Subsystem 10 - Serial number: 7UVNH ÿ
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 159
Mileage: 156259 km
Time: 21:33:59
Part No SW: 1K0 953 549 BF HW: 1K0 953 549 BF
Component: J0527 051 0101
Coding: 0010022
Part No SW: 5N0 920 950 D HW: 5N0 920 950 D
Component: KOMBIINSTRUMENT VDD 1224
Revision: V0003000 Serial number: VWX7Z0H63NN1EE
Coding: 0007204
Shop #: WSC 26149 067 57207
VCID: 306FCAB7A35AABC621-8064
Reset counter: 159
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 190608F2001030
Coding: FD827F070002026002
Shop #: WSC 12345 785 00200
VCID: 3561FBA35C388EEE72-8060
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
VCID: 3663FCAF413E85F67B-8062
Component: IMMO VDD 1224
Shop #: WSC 26149 444 108789
Part No SW: 5N0 959 701 HW: 5N0 959 701
Component: Tuer-SG 006 1205
Coding: 0001205
VCID: 72EB00BF6DD6D9D697-8026
Part No SW: 5N1 909 144 G HW: 5N1 909 148 E
Component: J500__APA-BS KL.096 0401
Revision: 1AH01251 Serial number: 00080660032102
Coding: 0000258
9 Faults Found:
01312 - Powertrain Data Bus
Fault Status: 00101110
Reset counter: 160
RPM: 1500 /min
Speed: 50.0 km/h
(no units): 6.0
Voltage: 11.70 V
00566 - Steering Assistance Operation
Fault Status: 11101000
Reset counter: 118
Mileage: 156259 km
Time: 00:00:29
Hex Value: 0x5301
Hex Value: 0x4301
Hex Value: 0x1B01
Hex Value: 0x5601
Hex Value: 0x4601
Reset counter: 161
(no units): 4.0
Voltage: 11.50 V
Reset counter: 158
Voltage: 5.10 V
Voltage: 10.40 V
Voltage: 10.40 V
Not Occup.
Not Occup.
Reset counter: 161
(no units): 4.0
Voltage: 11.50 V
Reset counter: 158
Mileage: 156259 km
Time: 20:24:11
Voltage: 3.10 V
Voltage: 10.60 V
Voltage: 10.60 V
Not Occup.
Not Occup.
Reset counter: 161
(no units): 4.0
Voltage: 11.50 V
Reset counter: 161
(no units): 4.0
Voltage: 11.50 V
Reset counter: 161
(no units): 4.0
Voltage: 11.40 V
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0222
Revision: 00052000 Serial number: 00000000000000
Coding: 9380078852832C1B1B04058FB0880F0C88DCA0
Shop #: WSC 27387 001 1048576
VCID: 040756674762E766B5-8050
Part No SW: 5N0 959 702 HW: 5N0 959 702
Coding: 0001204
VCID: 73E505BB12CCD0DE9C-8026
Part No SW: 5N0 907 801 B HW: 5N0 907 801 B
Component: J540 EPB3 VW-09384 0005
Revision: H09 Serial number: 00000000101218
Coding: 0000057
VCID: 2E53D4CFB96EBD3633-807A
Reset counter: 158
Voltage: 11.50 V
Count: 76
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
000 - - - MIL ON
Fault Status: 11110000
Reset counter: 116
Mileage: 156259 km
Voltage: 11.60 V
Count: 103
Hex Value: 0x1270
Hex Value: 0x0082
Hex Value: 0x0101
02442 - Function Lamp in Control Head
009 - Open or Short to Ground - MIL ON
Fault Status: 11111001
Reset counter: 118
Voltage: 12.40 V
Count: 81
Hex Value: 0x0871
Hex Value: 0x0088
Hex Value: 0x1010
Reset counter: 158
Voltage: 11.40 V
Count: 96
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
03200 - Switch for Electric Parking Brake (E538)
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11111100
Reset counter: 118
Voltage: 12.40 V
Count: 10
Hex Value: 0x0871
Hex Value: 0x0088
Hex Value: 0x1010
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 017 0021
Revision: 00017000 Serial number: VWZ4Z7H6361526
Coding: 0040401
VCID: 204F3AF7F3BA1B46B1-8074
Part No SW: 5N0 959 703 A HW: 5N0 959 703 A
Component: Tuer-SG 006 1301
Coding: 0001168
Shop #: WSC 01287 785 1012552
Component: RDK 0450
Coding: 0100101
Shop #: WSC 01387 785 00200
00625 - Vehicle Speed Signal
Fault Status: 00111000
Reset counter: 158
Part No SW: 5N0 959 704 A HW: 5N0 959 704 A
Coding: 0001168
End-------------------------(Elapsed Time: 02:14)--------------------------
