Results 1 to 10 of 10
Thread: Help with ABS module coding (MK60EC1)
    Verified VCDS User URS4quattro's Avatar
    Mar 2017
    Suriname
    Hi, I am having a little problem withcoding of a used ABS module on a VW R32. I made a copy of the old coding but when i put that in it rejects it. Jack helped me out before with one on Golf R RHD so Jack if you could be of assitance I would gladly apreciate it. I would like to learn how to properly do it so if anyone has info on how to that is very welcome too.
    Model is a 2008 VW R32 RHD.
    Old module number and coding was: 1K0 907 379 AE, CODING: 136B800D092600FA680C01E9901C0081B500
    Full scan:
    Wednesday,10,January,2018,11:43:21:27662
    VCDS Version: 17.8.1.0 (x64)
    VIN: WVWZZZ1KZ9W040153   License Plate: KELVIN R32
    Mileage: 117550km-73042mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72
    VIN: WVWZZZ1KZ9W040153   Mileage: 117550km-73042miles
    Address 01: Engine        Labels: 022-906-032-BDB.lbl
       Part No SW: 022 906 032 KG    HW: 022 906 032 GP
       Component: R32-DQ-EU4      G   1067
       Revision: 1QH04---    Serial number: VWX7Z0H43NT89R
       Coding: 0000178
       Shop #: WSC 01279 785 00200
       VCID: 5ABA154695737796BF-800E
    Readiness: 0110 1001
       Part No SW: 02E 300 011 CP    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1812
       Revision: 05144002    Serial number: 00001008271205
       Shop #: WSC 04940 001 00001
       VCID: 5FCC24528E5192BEC8-800A
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       VCID: 76E261F6C1AB33F6BB-8022
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 191
                        Count: 3
                        Count: 20992
                        Count: 397
                        Count: 43264
                        Reset counter: 191
                        Count: 3
                        Count: 20992
                        Count: 195
                        Count: 43264
                        Fault Status: 01100101
                        Reset counter: 191
                        Mileage: 117556 km
                        Count: 3
                        Count: 29184
                        Count: 295
                        Count: 43264
       Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       VCID: 6DD04E9A74FDF02E4A-8038
       Revision: 00H54000    Serial number: 00000008535551
       Coding: E68F8F2700041500471400001400000000097B075C000100000000000000
       Shop #: WSC 00000 785 00200
       VCID: 336498E2525966DE5C-8066
       Component: Wischer 100608 021  0501
       Coding: 00038805
       Component: RLS     250711 054  0403
       Coding: 00209069
       Component: 5H AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D0BEXTY
       Coding: 0013640
       Shop #: WSC 01269 785 00200
       VCID: 6CD6439E4FE7F9265D-8038
       Subsystem 1 - Serial number: 6332MSME3D41602FF
       Subsystem 2 - Serial number: 6342MSME3D417764H
       Subsystem 3 - Serial number: 6352QSME73503D5BO
       Subsystem 4 - Serial number: 6362QSME677B457F/
       Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
       Coding: 0012142
       VCID: 04060B3E47771166B5-8050
       Part No SW: 1K6 920 864 B    HW: 1K6 920 864 B
       Component: KOMBIINSTRUMENT VDD 1214
       Revision: V0002000    Serial number: VWX7Z0H43NT89R
       Coding: 0007503
       Shop #: WSC 70050 981 95893
       VCID: 316892EAA84554CE2E-8064
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 140608F2000346
       Coding: ED837F060002020003
       VCID: 3560A6FA5C2D78EE72-8060
                        Reset counter: 191
                        Mileage: 117556 km
                        Time: 11:23:21
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 L
       Component: Haldex 4Motion      0116
       VCID: 3662A1F6412B73F67B-8062
       Component: IMMO            VDD 1214
       Part No SW: 1K0 959 701 AL    HW: 1K0 959 701 AL
       Component: Tuer-SG         006 1204
       Coding: 0000694
       VCID: 78FE6FCE0BBF4586A9-802C
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 141    2301
       Revision: 00H15000
       VCID: 2A5A858685932716EF-807E
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Coding: 819002005103087F2D0484057008DFC6F0FCA0
       VCID: 71E852EA68C514CE6E-8024
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
       Part No SW: 1K0 959 702 AL    HW: 1K0 959 702 AL
       Coding: 0000950
       VCID: 79F86ACA30B55C8ED6-802C
       Part No: 1T0 907 357
       Coding: 0000004
       VCID: 74E65BFE17D721E685-8020
    Address 56: Radio
       Component: Tuer-SG         006 1305
       Coding: 0000144
       Shop #: WSC 01279 785 1012552
       VCID: 387EAFCE4B3F858669-806C
       Coding: 0000144
       VCID: 3978AACA70359C8E96-806C
    End-------------------------(Elapsed Time: 01:57)--------------------------
    Aug 2016
    Switzerland
    136B800D092600FA680C01E9901C0081B500 <--- too short!
    try
    136B800D092600FA680C01E9901C0081B50000
    Quote Originally Posted by URS4quattro View Post
    I'm not sure anyone knows exactly what to do.
    But the short answer is, look for patterns...
    There are some tools available like ESPCalculator/MK60EC1 code generator.
    The most well known ABS unit by far is the MK60EC1, that has been fitted to most of the Golf 5 and Golf 6 based cars for close to 10 years I'd guess. For that, there's quite a lot of knowledge and even some code generators that don't always work very well. I only use them to quickly identify the bytes for the VIN, to be honest.
    Every MK60EC1 has about 20 cars that it should work in, for many markets (VW ROW, Audi ROW, NAR etc etc) so it's becoming almost exponentially complex to calculate the codes.
    Make a huge table, car by car, type by type and list all the characteristics that you think could affect the coding. Chassis, LHD/RHD, engine, gearbox, VIN, TPMS, you name it. And then simply look for patterns. You'll often find some bytes being each others inverse and stuff like that as well.
    What I've done is a PhD in data analysis, and what I did is to make what's called a neural network and feed it a lot of data. You tell them what kind of car, what kind of market, what kind of engine, all the data you can find. And fortunately there is a lot of data that can be found , you simply put "MK60EC1 VCDS" in google and there is your data. Then you devise some kind of clever algorithm to retrieve all the data you need from the autoscans and run the program. Advantage: very cool. Disadvantage: not all info is available from autoscan (i.e. physical stuff like ESP button, brake size). You're also limited by the availability of the data. If you can't find some data about where the car is located, you can't find a byte for it.
    At a certain point you'll end up with a very comprehensive list of 'descriptions' for all the bytes. Put them all together and you have your new code.
    That is more or less the 'cool' way to do it and that's how I devised the first two codes.
    I like this method a lot since it's more interesting and I like a data driven approach more above a trial and error approach.
    There is a much more simpler way that you can try and this is where you make 'clever' people like me looking like an idiot.
    What you do is you simply use the power of google to find your cars twin brother. And then its autoscan. Just put something like
    MK60EC1 "Part No SW: 022 906 032 KG HW: 022 906 032 GP"
    into google and see what pops up.
    There are a few reference scans available, take one with also the most similarities to your car and then simply substitute the VIN bytes. Try. Adjust. Repeat.
    The adjustments, you can make them with whatever knowledge you have from the internet or your own studies.
    This is what makes it both a lot of fun to get it right, yet extremely frustrating since one wrong bit out of the (8x19) bits will cause your code to be rejected.
    So there is not really one trick. Just a lof of small and big tricks. Success not guaranteed.
    Best solution: find yourself a Jack. Jack will usually solve your problems in life.
  3. Likes Uwe liked this post
    WVWZZZ1KZ9W040153
    x
    Vehicle Identification No. WVWZZZ1KZ9W040153
    Model golf r32
    GOLF
    Date of production 03.07.2008
    Year 2009
    Sales type 1K14X7
    Engine Code BUB
    Transmission Code KQA
    Axle drive 6A
    Equipment TK
    Roof color 8E
    Carpet color code
    Exterior color / Paint Code 8E / A7W
    Part No SW
    Component
    : R32-DQ-EU4 G 1067
    Component
    Part No SW
    <<<<<<<<<<<< IDK ( I don't think this is to this car ) 517BE is though
    Component
    Revision
    : 00H31001
    CODING: 136B800D092600FA680C01E9901C0081B500 ( Correct compatible )
    Coding
    x
    OP: please call dealer to double check this part is correct and when I get a chance I will have a look.
    JPPSG Please!
    x
    European Parts Emporium/Performance / Immobilizer Solutions LLC
    Mar 2017
    Suriname
    Thanks for the replies, iichel I tried adding the 00 at the end but stil gets rejected. Jack the problem is that there is no dealer where i live for these cars (Suriname). We have a dealer but they only have acces for comercial cars and don't even want to taek a look at any other because the are not authorised to do so. The donor ABS that is fitted was from a 2010 VW Golf R20. I could not read the coding from there because the car was dismantled.
    Mar 2017
    Suriname
    component number of the old one was ESP MK60EC1 H35 0104
    According to the Etka and Partslink this part is not compatible based on VIN number WVWZZZ1KZ9W040153
    XX <<<<<< RHD TPMS HH 345/310 5K ( decode )
    144B800D092600FAC80C01E9901C0081350000 TRY This
    136B800D092600FAC80C01E9901C0081350000 & This & if anything codes report back & if no good get correct module.
    It is my position that the correct module should be procured.
  9. Likes Uwe liked this post
  10. #8
    Mar 2017
    Suriname
    Thanks Jack, will try and post back with the result
  11. #9
    Mar 2017
    Suriname
    coding was still rejected. I will try to get a hold of the correct module. Thanks for the help till now .
  12. Likes Boki Ar, iichel, Jack@European_Parts liked this post
  13. #10
    Good man........ /\
  14. Likes Boki Ar liked this post
