Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Audi TT mk1 1.8t 225 quattro wandering / surging idle - no codes
    Jan 2017
    Earlier when I clamped "most" of the vacuum lines, apparently I didn't clamp the PCV line. When I clamped the PCV line, there was no surge on engine start and it immediately seems to run like normal.
    The challenge I have now is the same I opened this thread for -- I can't find the right part online to replace that "Y" valve. All the parts I found look significantly more complex.
    My hoses:
    https://ibb.co/bVhC7R
    https://ibb.co/cStkSR(orange fill stick in foreground is what the hard line off the "Y" connects to)
    https://ibb.co/dkcZMm
    https://ibb.co/ga93E6 (bottom left of this pic shows the stuff that's centered in the other pics)
    The top end of the "Y" in the pic is a hard line that connects to the fill tube. That line seems OK as far as I can feel/tell. I believe it's the "Y" valve itself.
  2. #12
    Jan 2017
    Ok .. it was off to the side in the parts diagram..
    http://www.oemepc.com/audi/part_sing.../254631/lang/e
    Part 5 is apparently cancelled, and part 10 doesn't seem to show in the list on the right, but based on what I see, I assume I have to replace the whole assembly.....
    Making headway.
  3. #13
    An FYI:
    If the car was not FOD as aforementioned & for being with modification & deletes, you would of been able to use the trim values/OXS aging to determine a vacuum leak, using the functions of the OBD2 with VCDS.
  4. #14
    Jul 2015
    Canada
    I just looked at three of the aftermarket companies we deal with up here and part #5 06A103221BH is not a problem to get. Maybe have a look at World Pac down there.
    Kevin
  5. Likes Jack@European_Parts liked this post
  6. #15
    Jul 2014
    I might have missed something but I think number eight is the valve you're looking for
  7. #16
    Jul 2015
    Canada
    Quote Originally Posted by ivagp View Post
    Yes, for the valve portion he needs 8 or 10 depending on his application.
  8. #17
    Jan 2017
    Thanks for the feedback guys. I was double checking my diagnostic and ended up ruling out the PCV. I took it to a shop and they identified the defect as the suction pump (06A133751AA). Ordered and it should be in this week.
  9. #18
    Did you learn anything yet?
  10. #19
    Jan 2017
    Well, I'm getting closer to learning my own pain tolerance.
  11. Likes Jack@European_Parts, PetrolDave liked this post
  12. #20
    Thresholds are important for pain and AECD's!
