When I am trying to change something in my car, I get a question if I want to use VCDS parameters or settings from the car. In all videos i've seen there is not in any case the same error message.
Because of this error, i have not been so brave to change anything yet.
Is it possible to disable audible warnings but not get rid of the warnings in the info-display, for ex:
1. When i open the door and dont have gear selector in park.
2. the car engine is running and the keyless in in my pocket and i temporarily leave the car, It beeps like a baby and woundering where the key is.
3. Seatbelt warning with only red blinking belt-light but no beep/pling warning.
4. Parking sensors with only indication on display but no beep at all.
Is it possible to disable the aut engage of handbrake when opening a door.
Autoscan
Autoscan
onsdag,13,December,2017,20:18:10:16178
VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 10 x64
VCDS version: AER 17.8.0.1 HEX-NET CB: 0.4409.4
Dataversion: 20170818 DS276.4
www.vcds.se
VIN: WVWZZZ7NZJV008092 Reg.nr:
Chassityp: 7N-VW36 (7N0)
Skanna: 01 02 03 05 08 09 10 13 15 16 17 18 19 25 2B 42 44 46 4C 4F
52 53 55 5F 61 62 69 6C 72
VIN: WVWZZZ7NZJV008092 Mätarställning: 9380km
01-Motor -- Status: OK 0000
02-Automatväxel -- Status: OK 0000
03-Bromselektronik -- Status: Felfunktion 0010
04-Styrposition -- Status: OK 0000
05-Behör.kontroll -- Status: Felfunktion 0010
08-Klimatanläggning -- Status: OK 0000
09-Elektron. elcentral -- Status: Felfunktion 0010
10-park/styr-hjälp -- Status: OK 0000
13-Distansreglering -- Status: OK 0000
15-Krockkuddar -- Status: OK 0000
16-Rattelektronik -- Status: OK 0000
17-Instrument -- Status: OK 0000
18-Extra/p-värmare -- Status: Felfunktion 0010
25-Startspärr -- Status: OK 0000
2B-Styraxellås -- Status: OK 0000
42-Dörrel. förare -- Status: OK 0000
44-Styrservo -- Status: OK 0000
46-Komfortcentral -- Status: OK 0000
4C-Däcktrycksk. II -- Status: OK 0000
4F-Elektr. centralenh. II -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
53-Parkeringsbroms -- Status: OK 0000
55-Helljusområde -- Status: OK 0000
5F-Inform.elektr. 1 -- Status: OK 0000
61-Batteriregl. -- Status: OK 0000
62-Dörr vä. bak -- Status: OK 0000
69-Släpvagnsfunktion -- Status: OK 0000
6C-Back-kamera -- Status: OK 0000
72-Dörr hö bak -- Status: OK 0000
Adress 01: Motor (J623-DFLA) Labels:. AER\04L-907-309-V1.clb
Artikelnr SW: 04L 906 016 HE HW: 04L 907 309 K
Komponent: R4 2,0L EDC H20 1624
Revision: 8AH20---
Kodning: 011D001A047411083000
Verkstad #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01104L906016HE 001003
ROD: EV_ECM20TDI01104L906016HE_001.rod
VCID: 73A633F7DA8A1ADE87-8026
Ingen felkod funnen.
Adress 02: Automatväxel Labels: AER\02E-927-770.clb
Artikelnr SW: 02E 300 066 N HW: 02E 927 770 AT
Komponent: GSG DSG AG6 541 5201
Revision: 06454104 Serienummer: 00001706171457
Kodning: 0000020
Verkstad #: WSC 44551 111 44551
VCID: 240400ABE7E4CD66CE-8070
Adress 03: Bromselektronik (J104) Labels: saknas
Artikelnr SW: 5N0 614 109 CM HW: 5N0 614 109 CM
Komponent: ESC-EBC460iV1 H14 0014
Serienummer: A01J8KZ
Kodning: 12F0449A0920C2740877480922C59043103917F800014884
ASAM Dataset: EV_Brake1ESCEPBTRW 006353
ROD: EV_Brake1ESCEPBTRW_006.rod
VCID: 78BC04DBC3EC7986B2-802C
1 fel funnet:
0763 - Ringtrycksvarning
C102D 00 [136] - -
Fellampa(MIL) tänd - Intermittent fel - Bekräftad - Testad efter att minnet rensats
frysta data:
Felstatus: 00000001
Felprioritet: 4
Felfrekvens: 1
Reset-räknare: 103
Mätarställning: 4855 km
Datum: 2017.10.18
Tid: 22:06:08
Additional_Codes: 11 73 00 0E C0 7F 00 48 02
Felkod: 00 02 FB
Additional2: 00 0A 01 00 05 22 58 00 58 00
Adress 05: Behör.kontroll (J518) Labels:| AER\5K0-959-434.clb
Artikelnr SW: 5K0 959 434 J HW: 5K0 959 434
Komponent: VWKESSYPQ35GP 092 1403
Revision: 00092000 Serienummer: 0447447312
Kodning: 032C0C
Verkstad #: WSC 00020 999 39850
ROD: EV_KESSYPQ35G.rod
VCID: 3C34D8CBB75495A696-8068
1 fel funnet:
1057547 - Antenn 1 i kupén för tillträdes- och startsystem
B1172 13 [008] - avbrott
frysta data:
Felstatus: 00000001
Felprioritet: 4
Felfrekvens: 15
Reset-räknare: 211
Mätarställning: 3580 km
Datum: 2017.09.29
Tid: 16:12:40
Adress 08: Klimatanläggning (J255) Labels:| AER\5K0-907-044.clb
Artikelnr SW: 7N0 907 044 BB HW: 7N0 907 044 BB
Komponent: Clima-Sharan H04 0606
Revision: 00001K06
Kodning: 021010C549
VCID: 71AA39FFA09628CE75-8024
Slave 1:
Subsystem 1 - Artikelnr SW: 7N0 907 049 C HW: 7N0 907 049 C
Komponent: KBT-H 004 0103
Serienummer: 20170710000000124076
Adress 09: Elektron. elcentral (J519) Labels:. AER\1K0-937-08x-09.clb
Artikelnr SW: 5K0 937 086 T HW: 5K0 937 086 T
Komponent: BCM PQ35 M 122 0186
Revision: BC122001
Kodning: 40180A3F8125E1C0408800C09400097403D50008666D2DB2E4848720A2C1
Verkstad #: WSC 00020 790 00000
VCID: 45C2BD2FCC9ED46EF9-8010
Subsystem 1 - Artikelnr SW: 7N1 955 119 B HW: 7N1 955 119 B Labels: AER\1KX-955-119.CLB
Komponent: WWS428 310517 024 0644
Serienummer: 17052603010461
Kodning: 004DBD
Subsystem 2 - Artikelnr SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: AER\5Q0-955-547.CLB
Komponent: RLHS 042 0105
Serienummer: S8Y17M07D04H01M04S17
Kodning: 0228BB
Subsystem 3 - Artikelnr: 7N0 951 172
Komponent: Sensor, DWA 0 005 0502
Kodning: 000000
Subsystem 4 - Artikelnr: 1K0 951 605 F
Komponent: LIN BACKUP HO H01 0008
Kodning: 000000
Adress 10: park/styr-hjälp (J446) Labels:| AER\5Q0-919-294.clb
Artikelnr SW: 1K8 919 472 C HW: 5Q0 919 294 A
Komponent: PARKHILFE 8K H03 0480
Revision: -------- Serienummer: 39361719400912
Kodning: 0031151211
ASAM Dataset: EV_EPHVA18VW364GP00 001007
VCID: 373EC7E78E72B6FE7B-8062
Adress 13: Distansreglering (J428) Labels:| AER\7N0-907-572.clb
Artikelnr SW: 7N0 907 572 C HW: 7N0 907 572
Komponent: ACC Bosch PQx H03 0211
Serienummer: 3006170466A38E
Kodning: 00001900FE0739
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 3620CAE389784FF660-8062
5 Funna fel:
1130 - Sensor för aut. distansreglering
C110B F0 [008] - Begränsad sikt
frysta data:
Felstatus: 00000001
Felprioritet: 9
Felfrekvens: 1
Reset-räknare: 210
Mätarställning: 9105 km
Datum: 2017.12.07
Tid: 16:22:47
Styrdonstemperatur: 12 °C
Spänning klämma 15: 12.3 V
Fordonshastighet: 0.00 m/s
Acceleration: 0.00 m/s²
1132 - Sensor för aut. distansreglering
frysta data:
Felstatus: 00000001
Felprioritet: 9
Felfrekvens: 1
Reset-räknare: 210
Mätarställning: 9098 km
Datum: 2017.12.07
Tid: 15:30:05
Styrdonstemperatur: 16 °C
Spänning klämma 15: 14.6 V
Fordonshastighet: 18.49 m/s
Acceleration: 0.25 m/s²
1131 - Sensor för aut. distansreglering
frysta data:
Felstatus: 00000001
Felprioritet: 9
Felfrekvens: 1
Reset-räknare: 210
Datum: 2017.12.07
Tid: 16:22:47
1542 - Sensor för aut. distansreglering
frysta data:
Felstatus: 00000001
Felprioritet: 4
Felfrekvens: 1
Reset-räknare: 210
Datum: 2017.12.07
Tid: 15:30:05
1545 - Sensor för aut. distansreglering
frysta data:
Felstatus: 00000001
Felprioritet: 4
Felfrekvens: 1
Reset-räknare: 210
Datum: 2017.12.07
Tid: 15:30:05
Adress 15: Krockkuddar (J234) Labels:| AER\5K0-959-655.clb
Artikelnr SW: 7N0 959 655 D HW: 7N0 959 655 D
Komponent: VW10Airbag11M H15 0016
Serienummer: 003PWPDWH0CU
Kodning: 00314D
ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 40CCAC3BDBBCF146CA-8014
krocksensor för sidoairbag på förarsidan:
Subsystem 1 - Artikelnr SW: --- HW: ---
Komponent: S.Sens.Fahr.V --- ---
Serienummer: 3493ETS6054CF8B1D9DF
Kodning: 000000
krocksensor för sidoairbag på passagerarsidan:
Subsystem 2 - Artikelnr SW: --- HW: ---
Komponent: S.Sens.Beif.V --- ---
Serienummer: 3503ETS6084FB791DDDA
Kodning: 000000
krocksensor för sidoairbag bak på förarsidan:
Subsystem 3 - Artikelnr SW: --- HW: ---
Komponent: S.Sens.Fahr.H --- ---
Serienummer: 3513ETS608191801DDDR
Kodning: 000000
Krocksensor för sidoairbag bak: passagerarsidan:
Subsystem 4 - Artikelnr SW: --- HW: ---
Komponent: S.Sens.Beif.H --- ---
Serienummer: 3523ETS6020D3791D9DV
Kodning: 000000
krocksensor för airbag fram på förarsidan:
Subsystem 5 - Artikelnr SW: --- HW: ---
Komponent: F.Sens.Fahr --- ---
Serienummer: 35540TS6009087A1DDDP
Kodning: 000000
Adress 16: Rattelektronik (J527) Labels:| AER\5K0-953-569.clb
Artikelnr SW: 5K0 953 501 EL HW: 5K0 953 569 AN
Komponent: LENKS.MODUL 016 0180
Revision: FF010042 Serienummer: 20170704200076
Kodning: 1112C40008
Styrdon för multifunktionsratt:
Subsystem 1 - Artikelnr SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: AER\3C8-959-537.CLB
Komponent: E221__MFL-TAT H06 0023
Serienummer: 1791707355600882AE1B
Kodning: 2D0000
Adress 17: Instrument (J285) Labels:| AER\5K0-920-xxx-17.clb
Artikelnr SW: 7N0 920 870 Q HW: 7N0 920 870 Q
Komponent: KOMBI H03 1107
Serienummer: 00000000000000
Kodning: 110F010800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
Adress 18: Extra/p-värmare Labels: AER\1K0-815-007.clb
Artikelnr: 7N0 963 272 E
Komponent: Standheizer 044 4941
Revision: 00044000 Serienummer: 09028239000000
Kodning: 0031142
VCID: 373EC7E74672B6FE7B-8062
1 fel funnet:
00664 - Bränslemätare
002 - Undre gräns överskriden - Intermittent fel
frysta data:
Felstatus: 00100010
Felprioritet: 7
Felfrekvens: 7
Reset-räknare: 202
Mätarställning: 7495 km
Tidsindikering: 0
Datum: 2017.11.16
Tid: 19:48:32
Adress 19: CAN Gateway (J533) Labels:. AER\7N0-907-530-V2.clb
Artikelnr SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Komponent: J533 Gateway H56 1682
Revision: H56 Serienummer: 040717F1000517
Kodning: 468022
VCID: 7BB61BD7FADA529EDF-802E
Adress 25: Startspärr (J334) Labels:| AER\5K0-920-xxx-25.clb
Artikelnr SW: 5K0 953 234 HW: 5K0 953 234
Komponent: IMMO H03 1107
Serienummer:
Kodning: 000007
VCID: 6A982E938D40DB1634-803E
Adress 2B: Styraxellås (J764) Labels:| AER\5K0-905-861.clb
Artikelnr SW: 5K0 905 861 D HW: 5K0 905 861 D
Komponent: ELV-PQ35 H22 0240
Revision: 00000000 Serienummer: 17000184209007
Kodning: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 312AF9FF601668CE35-8064
Adress 42: Dörrel. förare (J386) Labels:. AER\7N0-959-793.clb
Artikelnr SW: 7N0 959 793 H HW: 7N0 959 793 F
Komponent: TSG FA H05 0561
Revision: Serienummer: 0000263870920
Kodning: 011006208000411011
VCID: 47DEB727F692C67E0B-8012
Adress 44: Styrservo Labels: AER\5N1-909-144.clb
Artikelnr SW: 5N1 909 144 S HW: 5N1 909 148 K
Komponent: J500__APA-BS KL.325 1501
Revision: 1BH04741 Serienummer: 00171650017801
Kodning: 0000258
VCID: 42C8A6331DB0E356DC-8016
Adress 4C: Däcktrycksk. II
Kan ej nås
Adress 4F: Elektr. centralenh. II (J520) Labels:. AER\1K0-907-532.clb
Artikelnr SW: 7N0 907 532 HW: 7N0 907 530 AN
Komponent: EZE_2 H56 1682
Kodning: 050B0500
VCID: 6FAE3F87BEA23E3E63-803A
Subsystem 1 - Artikelnr SW: 7N0 959 591 B HW: 7N0 959 591 B
Komponent: J245EE04SKB03 H04 0090
Serienummer: 0123456789ABCDEFGHIJ
Subsystem 2 - Artikelnr SW: 7N0 959 591 B HW: 7N0 959 591 B
Komponent: J394EE04SKB03 H04 0090
Adress 52: Dörrelektr. pass. (J387) Labels:. AER\7N0-959-792.clb
Artikelnr SW: 7N0 959 792 H HW: 7N0 959 792 F
Komponent: TSG BF H05 0561
Revision: Serienummer: 0000266484432
Kodning: 011004208000411011
VCID: 46C0BA23F198DF76F0-8012
Adress 53: Parkeringsbroms
Kan ej nås
Adress 55: Helljusområde (J745) Labels:. AER\5M0-907-357-V3.clb
Artikelnr SW: 5M0 907 357 F HW: 7L6 907 357 C
Komponent: AFS-ECU H05 0111
Revision: -------- Serienummer: --------------
Kodning: 058200000B000200
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
Subsystem 1 - Artikelnr SW: 1T0 941 329 HW: 1T0 941 329 Labels: AER\3D0-941-329.CLB
Komponent: LeiMo links H06 0011
Kodning: 360000
Subsystem 2 - Artikelnr SW: 1T0 941 329 HW: 1T0 941 329 Labels: AER\3D0-941-329.CLB
Komponent: LeiMo rechts H06 0011
Kodning: 360000
Adress 5F: Inform.elektr. 1 (J794) Labels:* saknas
Artikelnr SW: 5K7 035 200 L HW: 5K7 035 200 L
Komponent: MU-S--ER H41 0449
Serienummer: VWZAZ2T5295603
Kodning: 02240800FF0000001111000100080A001F0100C40020010003
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 2D12E58F7C2E0C2E11-8078
Adress 61: Batteriregl. (J840) Labels:. AER\1K0-907-534.clb
Artikelnr SW: 7N0 907 534 HW: 7N0 907 530 AN
Komponent: Batt.regelung H56 1682
Kodning: 330F1873
VCID: 71AA39FFA89628CE75-8024
Subsystem 1 - Artikelnr SW: 1K0 915 181 L HW: 1K0 915 181 L
Komponent: J367-BDM H07 0270
Serienummer: 34184549405831521005
Adress 62: Dörr vä. bak (J388) Labels:. AER\7N0-959-794.clb
Artikelnr SW: 7N0 959 794 K HW: 7N0 959 794 G
Komponent: TSG HL H06 0561
Revision: Serienummer: 0000266490058
Kodning: 010004200000411001
VCID: 4BD68B17EAFA221E2F-801E
Adress 69: Släpvagnsfunktion (J345) Labels:. AER\7N0-907-383.clb
Artikelnr SW: 7N0 907 383 A HW: 7N0 907 383
Komponent: Anhaenger H12 0130
Revision: 3I001001 Serienummer: 00000440794465
Kodning: 410C040003000000
VCID: 3424F0EB97045DE65E-8060
Adress 6C: Back-kamera (J772) Labels:| AER\5Q0-907-441.clb
Artikelnr SW: 7N0 907 441 B HW: 7N0 907 441 B
Komponent: VW428 RVC Mid H04 0040
Kodning: 012408012301000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 302CFCFB6B1C61C63A-8064
Adress 72: Dörr hö bak (J389) Labels:. AER\7N0-959-794.clb
Komponent: TSG HR H06 0561
Revision: Serienummer: 0000266489894
Slut--------(Förfluten tid: 02:11, Vbatt start/stopp: 12.0V/12.0V)---------
