Results 1 to 6 of 6
Thread: Passat B7 2.0TDI NEW Turbo actuator, fault still active!
    Jun 2014
    Latvia
    Hello.
    I have a problem. Came car with following fault:
    uesday,09,January,2018,10:21:39:33393
    VCDS Version: Beta 17.12.0 (x64) Running on Windows 10 x64
    Address 01: Engine Labels: 03L-906-018-CFF.clb
    Control Module Part Number: 03L 906 018 PA HW: 03L 907 309 AE
    Component and/or Version: R4 2,0L EDC H28 2472
    Software Coding: 001D0012043401080000
    Work Shop Code: WSC 00015 115 00000
    ASAM Dataset: EV_ECM20TDI01103L906018PA 003004 (VW46)
    ROD: EV_ECM20TDI01103L906018PA.rod
    VCID: 78F5C627C3513AEAF72-802C
    5249 - Boost Pressure Regulation
    P154F 00 [101] - Malfunction
    Mileage: 215589 km
    Date: 2063.14.30
    Time: 16:40:14
    Engine speed: 1400.00 /min
    Normed load value: 23.5 %
    Coolant temperature: 32 C
    Intake air temperature: 19 C
    Ambient air pressure: 1030 mbar
    Voltage terminal 30: 14.860 V
    Charge air pressure specified value: 1037 hPa
    Charge air pressure: actual value: 974 hPa
    Air mass: actual value (mg/stroke): 479.1 mg/stroke
    EGR Solen.val.: actual value: 100.01 %
    Throttle valve adapter: actual value: 100.07 %
    Charge Pressure Actuator: acknowledgment: 14.03 %
    Mean injection quantity: 6.06 mg/stroke
    Actuator was changed to new but fault still appears.
    It comes active after turbo test - basic settings or when driving.
    Basic settings - N75 adaptation is done several times. Successfully.
    May 2016
    Would appear IMO MAF @ 1400 should be in the above this, maybe above 10GS for conversation, as this is basically reading 0, meaning will not fuel as has no reason too. This engine is under vacuum with no boost at all.
    Jun 2014
    Latvia
    This moment fault came while working on car while turbo test. When driving, conditions are OK.
    Jun 2014
    Latvia
    removed pipeing from intake connection, with all pressures etc correct still the same fault
    Is there an MIL for this?
    Is your actuator set correctly mechanically?
    Is there an obstruction in intake/exhaust causing a deviation which can't be achieved or is turbo charger actually making boost?
    Curse VW for not putting a negative or positive indication to this DTC but stamps indicate the aforementioned.
    Above Magic!
    Jun 2014
    Latvia
    1. Yes, there is MIL and LIMP
    2. Yes, Voltages are correct as in manual
    3. Not that case, tried removing intake connection + new MAP
    4. yes...
    Car went to dealership. I suspect ECU problems as wiring was test-changed.
  7. Likes Jack@European_Parts liked this post
