Page 7 of 7 FirstFirst ... 567
Results 61 to 70 of 70
Thread: GTI clubsport (3 door) - Kessy retrofit (AU) chasis
  1. #61
    Oct 2017
    Northwest UK
    Ok you'll need to go to the installations list in the CAN Gateway 19 to select those modules.
  2. Likes Uwe liked this post
  3. #62
    Jan 2018
    Kuwait
    Quote Originally Posted by myounus View Post
    this autoscan after adding the modules to the installation list.
    I noticed something:-(
    acc/auth module appears with name (J518) , it should J965 according to golf7 wiring diagram.
    the part # of the kessy module I have 5Q0 959 435 B
    I searched the net , there is also 5Q0 959 435 , 5Q0 959 435 A for VW
    so, are they different (I checked the wiring diagram for a Passat CC , the Acc/auth module is J518
    is that mean that the module I have was installed on Passat ??
    its different ? or can be changed with ODIS ?
    this is the one I bought :
    https://www.ebay.com/itm/AUDI-VW-SEA...53.m2749.l2649
    Wednesday,14,February,2018,22:25:59:35129
    VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4409.4
    VIN: WVWFM2AUXGW246170   License Plate:
    Mileage: 26153km-16250mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 47 52
              55 5F A9
    VIN: WVWFM2AUXGW246170   Mileage: 26153km-16250miles
    Address 01: Engine (J623-CJXE)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 K    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 091D00122464050B2000
       ASAM Dataset: EV_ECM20TFS0205G0906259K 001002
       ROD: EV_ECM20TFS0205G0906259F_VW37.rod
       VCID: 3620C89689CE44F67B-8062
    Readiness: 1010 0001
       Part No SW: 0D9 300 020 K    HW: 02E 927 770 AQ
       Component: DQ250-6V MQB  H53 4904
       Revision: 06253104    Serial number: TFK01601191468
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021_VW37.rod
       VCID: 1D72373A0C38F7AE9A-8048
    10657 - RPM Signal from ECU
              P0726 00 [002] - Implausible Signal
       Revision: 00000000    Serial number: 60246000000551
       Coding: 01FA6BA1542429720778060741C36980D62A94E0608296F7184250B9C288
       VCID: 7AB81CA6FD566096DF-802E
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0420808478
       Coding: 030F0F
       Shop #: WSC 13765 790 12345
       ROD: EV_KessyHellaMQBAB_002_VW37.rod
       VCID: 3B36D9A2B2EC999E84-806E
    65826 - No Basic Setting
              B2010 00 [009] -  -
                        Mileage: 1048574 km
                        Time: 00:00:00
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020014200100001005000012101402
       VCID: 6A982CE68DF6D0162F-803E
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Serial number: 01061602803455
       Coding: 00111A46C20122F34B644000000C07281800000000000000000000000000
       ROD: EV_BCMBOSCH_015_VW37.rod
       VCID: 095A736AA8B07B0EC6-805C
       Component: WWS    160118  043 0551
       Serial number:         160202045705
       Component: RLHS  037 0059
       Serial number: S2Y16M02D08H10M34S06
       Coding: 90A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.403  H03 0004
       Serial number: 0000FST000RK8J200000
       Coding: 181801
       Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0056
       Revision: --------    Serial number: 39291603300852
       Coding: 0001150011
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       VCID: 3D32D7BAACF897AEBA-8068
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 02011604400195
       Coding: 001C1300FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       VCID: 3A38DCA6BDD6A0969F-806E
       Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0120
       Serial number: 29121541350443
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 373EC5928EC4BDFE60-8062
       Serial number: 003F6R1CV8AR
       VCID: 41CAAB4AD000F34EDE-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 902 16
       Serial number: 35767000000E9650291V
       Subsystem 2 - Part No SW: -----------    HW: 480 000 902 16
       Serial number: 3586700000038644881S
       Subsystem 3 - Part No SW: -----------    HW: 480 400 202 16
       Serial number: 3516502B71EDD3E4637W
       Subsystem 4 - Part No SW: -----------    HW: 480 400 202 16
       Serial number: 3526502B71EDD3E591A
       Subsystem 5 - Part No SW: -----------    HW: 480 400 502 16
       Serial number: 3556502AD1EDD3E150D/
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20160204500421
       Coding: 0410
       ROD: EV_SMLSVALEOMQB_VW37.rod
       VCID: 3FCEADB2A6F485BEA8-806A
       Part No SW: 5G0 920 756     HW: 5G0 920 756
       Component: KOMBI         302 6420
       Coding: 47AD01183F98000801886A091400000000000000
       VCID: 699A53EA88F0DB0E26-803C
    16776980 - Databus
                        Reset counter: 49
                        Mileage: 26153 km
                        Date: 2018.02.14
                        Time: 22:02:33
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 30011610802973
       Coding: 030100043F085900FB00027B9C0F00010001050000000000000000000000
       ROD: EV_GatewConti_013_VW37.rod
       VCID: 79BA03AAF8506B8ED6-802C
       Serial number: 29160000048900016026
       Coding: 2DFFFF
       Serial number: 6060799103
       Revision: 00000000    Serial number: 14000171068001
       Coding: 5D00000000000000
       Shop #: WSC 00066 790 07029
       ROD: EV_ELVMarquMQB_004_VW37.rod
       VCID: 3424F29E9FB256E645-8060
    1048836 - Terminal S
              B11A5 12 [009] - Short to Plus
                        Reset counter: 49
                        Mileage: 26153 km
                        Date: 2018.02.14
                        Time: 22:02:34
                        ELV State: 02
                        Information Clamps: 66 20
                        CoCo State: A0 01
                        WFS State: 00 06
                        Vehicle speed: 0.00 km/h
                        Voltage: 68
                        AD-Value H-bridge: 32
                        Clamp15 flip flop: SSTx: button contacts: 09
                        CAN signals: 00
    1048838 - Terminal 15
              B1148 12 [137] - Short to Plus
                        Reset counter: 49
                        Mileage: 26153 km
                        Date: 2018.02.14
                        Time: 22:02:34
                        ELV State: 02
                        CoCo State: A0 01
                        WFS State: 00 06
                        Voltage: 68
                        CAN signals: 00
    1048840 - Terminal 15 Redundancy
              B11D6 12 [137] - Short to Plus
                        Reset counter: 49
                        Mileage: 26153 km
                        Date: 2018.02.14
                        Time: 22:02:34
                        ELV State: 02
                        CoCo State: A0 01
                        WFS State: 00 06
                        Voltage: 68
                        AD-Value H-bridge: 33
                        CAN signals: 00
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
       Component: Quersperre    H52 8042
       Serial number: HA1-00023.11.15
       Coding: 0001
       ASAM Dataset: EV_LockElectHA1VW37X 001007
       ROD: EV_LockElectHA1VW37X.rod
       VCID: 47DEB552FE24CD7E10-8012
       Component: HRE_Master    H11 0071
       Serial number: 0391756389
       Coding: 01031103
       ROD: EV_HREntryHella_VW32.rod
       VCID: 3C34DABEB7E29EA68D-8068
       Lane Change Assistant 2:
       Serial number: 070116EA606676
       Coding: 003F1320D000040100001000
       VCID: 43C6A142CA1CE15ECC-8016
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8103
       ROD: EV_SteerAssisMQB.rod
       VCID: 393AC3AAB8D0AB8E96-806C
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0130
       Revision: 00000001    Serial number: VWZ8Z1FBA01GG51
       Coding: 12000000008AAA8A000000000000
       ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
       ROD: EV_AMPMst11CGen2ALPI_VW37.rod
       VCID: 6D9227FABC18C72E4A-8038
    0512 - Rear Right Treble Speaker
              B1068 13 [009] - Open Circuit
                        Reset counter: 49
                        Mileage: 26153 km
                        Date: 2018.02.14
                        Time: 22:03:39
                        Voltage terminal 30: 11.9 V
    0517 - Rear Left Treble Speaker
              B1066 13 [009] - Open Circuit
                        Reset counter: 49
                        Mileage: 26153 km
                        Date: 2018.02.14
                        Time: 22:03:39
       Serial number: 080116EA801099
       Coding: 003F1120DC00040100801000
       VCID: 42C8A446D506E856C7-8016
       Coding: 029203000B010200
       VCID: 40CCAE4EDB0AFA46D1-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 3G0 035 045 B    HW: 3G0 035 045
       Component: MU-H-N-RW     H50 0343
       Serial number: A688A0GB002325
       Coding: 0273000C0000000051110002001828001F0203F401200100DF
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9RU304VU1
       Subsystem 2 - Part No SW: V03 959 801 ED    HW: -----------
       Component: ROW 2017/2018  --- 0065
       Component: Gracenote2  --- 4008
       Part No SW: 5G0 907 159 E    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0002
       Serial number: 151216201255
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       VCID: 302CFE8E6BAA6AC621-8064
    End----------(Elapsed Time: 01:51, VBatt start/end: 13.6V/13.6V)-----------
  4. #63
    Jun 2014
    Poland
    Quote Originally Posted by Qassem View Post
    use ETKA to check what parts is recomend to which platform, because you mix passat CC (PQ) with golf 7 (MQB)
    In etka you also have equipment code desctription
    HOT HOT HOT VW Touran 2005 CCS via MFSW HOT HOT HOT
  5. #64
    Oct 2017
    Northwest UK
    Qassem the part number for a Golf on MQB is 5Q0 959 435B which is the control unit for access and start Auth. If the part begins with a 'J' that normally efers to a control module.
  6. #65
    Jan 2018
    Kuwait
    Quote Originally Posted by Spacewalker View Post
    I checked the ETKA before I buy even , and since my car came from germany wolfsburg April 2016 , this part number 5Q0959435B was the latest part number used for MQB Golf.
    I took a picture for the control module (it’s written MQB):
    https://imgur.com/a/WHiiD
    What makes me suspicious is the wiring diagram refers to KESSY module as J965 , and my autoscan shows J518 , I don’t have experience with VCDS , but this may because the module is not coded (no basic settings) !!
  7. #66
    Jan 2018
    Kuwait
    Hi Maysoun is,
    I agree with you totally, itís the correct part number , but why J518 , not J965 as appears in the wiring diagram.
    Is this because the module is not coded yet ?!
  8. #67
    I doubt that coding it is going to change the 'J' number it claims to be. I wouldn't obsess over this discrepancy. Sometimes VW changes these numbers. It has never really made sense to me why they do so, but I suppose the Herr. Dr. Dipl. Ing types in their white lab coats in Germany probably have their reasons, ja?
  9. Likes Qassem liked this post
  10. #68
    Jan 2018
    Kuwait
    Thank you Uwe ,
    Today I will try to find a shop having ODIS and Geko access, I found one yesterday and he asked me to come next Monday so he can take alook , he was clear with me , he said that he did a lot of retrofitting for VW, Audi, Porsche, but he never did a Kessy retrofit,
    So giving that I don’t have that much info to at least guid him using both systems to correctly code it , I decided to look for locksmith specialist so he can confirm to me if he can do it or not.
    As I heard if someone miss with immobilizer , it may cost a lot to gain back the identity of the car (I am not sure of that correct).
  11. #69
    Jan 2018
    Kuwait
    I booked an appointment next Sunday with a specialist Audi & VW shop , who have access to both ODIS and GEKO.
    He will check the connections first then he will code the modules with ODIS then program the new keys.
    It sound good for me , but can you guys confirm that this is the way to do it , I need those guys who did it before or at least help other doing it.
    Is there any other tweaks should be done to the ELV and Kessy especially that they are used (I mean already have data from the old vehicles)??!
  12. #70
    Jan 2018
    Kuwait
    Dear Friends,
    Regarding the last autoscan.
    Can you help me with the steering lock faults.
    Terminal s and terminal 15 short to plus.
    What this means , and how I can fix it.
    Any ideas please.
    Maybe this because I am connecting the mechanical ignition switch also ?!!
    Best regards,
