GTI clubsport (3 door) - Kessy retrofit (AU) chasis
   #41
Qassem
Kuwait
C?ID=325382
ordinary key is in cluster but kessy is not and coding kessy key is hard in PQ35 but not yet possible in MQB
Also in kessy the reader coil connected to the cluster, take a look to the wiring diagram in the previous posts (this is a must for the key to work in emergency cases as the key battery died)
Once a kessy key being programmed and the kessy module correctly coded , the transmitter inside the kessy key is also programmed.
I am not quite sure about the procedure, but being able to program an ordinary key is also open the road to kessy key programming
   #42
DGMotors
C?ID=57532
This is not required in the UK. Anyone who is an independent garage can buy the equipment and register for a GEKO access. The only reason only a handful of people actually bother is due to the high cost of a VW approved J533 passthrough and software. It's far cheaper just going to the franchaised dealership. Then there's the ongoing fees etc
This is NOT true, they do carry out security checks in the UK, (I had to send in so many forms and also copy off passports, driving licence's etc to get my Geko access)
   #44
Qassem
Kuwait
C?ID=325382
You are totally right.
I am just posting this because we had a discussion here that MQB kessy keys is impossible to program outside the dealer.
But it seems this give me some hope once I start the retrofit.
   #46
Qassem
Kuwait
C?ID=325382
Dear Friends,
The harness for the KESSY system should arrive tomorrow or after tomorrow, I would like to ask , what coding and adaptation required after installation.
My car is ready for the retrofit, all door panels are removed, also the rear bumper since I was working on blind spot system, it should not take time wiring everything, but I need the adaptations and coding to be ready so I can make sure to save time to start searching for an experienced lock smith who can help with keys and how I can wake up the kessy.
I believe with correct wiring and coding I can use emergency start with my old key until I figure out what to do with programming keys.
Any input from your side guys will help me a lot, specifically whom having experience with such kind of hard retrofitting.
   #47
myounus
Northwest UK
C?ID=321059
Qassem
Before you start please post an autoscan. Did you fit the blind spot radars and side mirrors? Does it work?
   #48
myounus
Northwest UK
C?ID=321059
Oh and make some ad-maps.
   #49
Qassem
Kuwait
C?ID=325382
Qassem
Dear myounus,
I will post an autoscan for sure, regarding the blind spot, yes I fitted it, and it works fine , just the guys recommended to do calibration, and I will ask the dealer to do it.
I will post also an auto scan and admap for the 3C lane change assist module J1068, but not here, in the main thread for the Blind spot retrofitting.
   #51
Qassem
Kuwait
C?ID=325382
Tuesday,13,February,2018,17:52:35:35129
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4409.4
VIN: WVWFM2AUXGW246170   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 32 3C 42 44 47 52 55 5F
          A9
VIN: WVWFM2AUXGW246170   Mileage: 26028km-16173miles
Address 01: Engine (J623-CJXE)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 K    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091D00122464050B2000
   ASAM Dataset: EV_ECM20TFS0205G0906259K 001002
   ROD: EV_ECM20TFS0205G0906259F_VW37.rod
   VCID: 3620C89689CE44F67B-8062
Readiness: 1110 0001
   Part No SW: 0D9 300 020 K    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4904
   Revision: 06253104    Serial number: TFK01601191468
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 1D72373A0C38F7AE9A-8048
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 60246000000551
   Coding: 01FA6BA1542429720778060741C36980D62A94E0608296F7184250B9C288
   VCID: 7AB81CA6FD566096DF-802E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020014200100001005000012101402
   VCID: 6A982CE68DF6D0162F-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061602803455
   Coding: 00101A46C20122F34B644000000C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 095A736AA8B07B0EC6-805C
   Component: WWS    160118  043 0551
   Serial number:         160202045705
   Component: RLHS  037 0059
   Serial number: S2Y16M02D08H10M34S06
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST000RK8J200000
   Coding: 181801
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0056
   Revision: --------    Serial number: 39291603300852
   Coding: 0001150011
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   VCID: 3D32D7BAACF897AEBA-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 02011604400195
   Coding: 001C1300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A38DCA6BDD6A0969F-806E
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 29121541350443
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 373EC5928EC4BDFE60-8062
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1CV8AR
   VCID: 41CAAB4AD000F34EDE-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 35767000000E9650291V
   Subsystem 2 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 3586700000038644881S
   Subsystem 3 - Part No SW: -----------    HW: 480 400 202 16
   Serial number: 3516502B71EDD3E4637W
   Subsystem 4 - Part No SW: -----------    HW: 480 400 202 16
   Serial number: 3526502B71EDD3E591A
   Subsystem 5 - Part No SW: -----------    HW: 480 400 502 16
   Serial number: 3556502AD1EDD3E150D/
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160204500421
   Coding: 0410
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 3FCEADB2A6F485BEA8-806A
   Part No SW: 5G0 920 756     HW: 5G0 920 756
   Component: KOMBI         302 6420
   Coding: 47AD01083F98000801886A091400000000000000
   VCID: 699A53EA88F0DB0E26-803C
16776980 - Databus
                    Reset counter: 47
                    Mileage: 26028 km
                    Date: 2018.02.13
                    Time: 17:47:45
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 30011610802973
   Coding: 030100043F085900FB00027B9C0F00010001050000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 79BA03AAF8506B8ED6-802C
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29160000048900016026
   Coding: 2DFFFF
   Serial number: 6060799103
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00023.11.15
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 47DEB552FE24CD7E10-8012
   Component: HRE_Master    H11 0071
   Serial number: 0391756389
   Coding: 01031103
   Shop #: WSC 12345 123 12345
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C34DABEB7E29EA68D-8068
   Serial number: 070116EA606676
   Coding: 003F0320D000040100001000
   VCID: 43C6A142CA1CE15ECC-8016
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 393AC3AAB8D0AB8E96-806C
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA01GG51
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI_VW37.rod
   VCID: 6D9227FABC18C72E4A-8038
   Serial number: 080116EA801099
   Coding: 003F0120DC00040100801000
   VCID: 42C8A446D506E856C7-8016
   Coding: 029203000B010200
   VCID: 40CCAE4EDB0AFA46D1-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 2E0000
   Part No SW: 3G0 035 045 B    HW: 3G0 035 045
   Component: MU-H-N-RW     H50 0343
   Serial number: A688A0GB002325
   Coding: 0273000C0000000051110002001828001F0203F401200100DF
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU304VU1
   Subsystem 2 - Part No SW: V03 959 801 ED    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Component: Gracenote2  --- 4008
   Part No SW: 5G0 907 159 E    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0002
   Serial number: 151216201255
   VCID: 302CFE8E6BAA6AC621-8064
End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.3V)-----------
this the autoscan before connecting the kessy , in one hour I will finish and connect , also I will post another autoscan , so you can help me with coding.
Qassem
Kuwait
C?ID=325382
Dear Friends,
After connecting everything according to the wiring diagram (posted in previous posts).
The car wouldn’t start using the push start button, and a steering indicator with exclamation mark appears in the instrument cluster.
I tried to connect the old ignition switch with the electronic one also connected.
The car started using the key but the steering wheel is locked, because of the electronic one is not activated.
Kindly advise , what should I do.
Can code it using VCDS?
Or should I do auto scan while connecting both old Ignition switch and ELV??
I was expecting the car to start with push button, and of course the kessy features will not work (expected).
Please I need your help guys.
   #53
Qassem
Kuwait
C?ID=325382
Guys please ,
At least , how can make the ELV works ??!
Why there is no response ??!
   #55
Qassem
Kuwait
C?ID=325382
The ELV is part of the immobiliser
VCDS can NOT program the immobiliser on MQB cars.
I don’t won’t to program the ELV
I need the coding and the adaptation that can be done, I installed the parts only, what I have to change with VCDS??!
   #56
golfi_vend
Tartu, Estonia
C?ID=195131
Well, i guess Kessy retrofit on mqb is so rare nobody knows exactly.
What you need to understand is elv is part of Immobiliser. You can't "code" a key to work with immobilser component. It needs to be matched so car VIN is transfered to that module. Without Vin(and other immo stuff) inside module data, car will never ever start.
   #57
myounus
Northwest UK
C?ID=321059
Send an autoscan and we can take a look at what you've added. The guys are right though it's going to be tough to get the car going.
   #58
Qassem
Kuwait
C?ID=325382
Dear Friends,
I managed to start the car with the old mechanical switch ,while all the kessy component correctly connected (steering wheel indicator is illuminated with a message (steering lock! service vehicle)
this is the Autoscan.
The modules appeared here,
what codding and adaptation I can do with VCDS before locking for immobilizer matching) ??
appreciate your help
Wednesday,14,February,2018,18:30:50:35129
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 47 52
          55 5F A9
VIN: WVWFM2AUXGW246170   Mileage: 26130km-16236miles
05-Acc/Start Auth. -- Status: Not registered 0011
2B-Steer. Col. Lock -- Status: Not registered 0011
   Revision: --H13---
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
          P1734 00 [002] - -
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0420808478
   Coding: 030C0C
   Shop #: WSC 13765 790 12345
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B36D9A2B2EC999E84-806E
65826 - No Basic Setting
          B2010 00 [009] -  -
                    Mileage: 1048574 km
                    Time: 00:00:00
   Revision: 00001K08
   Air quality sensor:
   Coding: 90A8DD
   Sun Roof:
   Coding: 181801
   Coding: 0001150011
   Coding: 0410
          U1014 00 [009] - -
                    Reset counter: 49
                    Mileage: 26130 km
                    Date: 2018.02.13
                    Time: 03:20:30
16776980 - Databus
                    Reset counter: 49
                    Mileage: 26130 km
                    Date: 2018.02.13
                    Time: 03:20:30
   Coding: 2DFFFF
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
                    Reset counter: 49
                    Mileage: 26130 km
                    Date: 2018.02.13
                    Time: 03:20:31
                    Terminal 15: On
   Revision: 00000000    Serial number: 14000171068001
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07029
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 3424F29E9FB256E645-8060
1048836 - Terminal S
          B11A5 12 [009] - Short to Plus
                    Reset counter: 49
                    Mileage: 26130 km
                    Date: 2018.02.13
                    Time: 03:20:30
                    ELV State: 02
                    Information Clamps: 66 20
                    CoCo State: A0 01
                    WFS State: 00 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 6A
                    AD-Value H-bridge: 33
                    Clamp15 flip flop: SSTx: button contacts: 09
                    CAN signals: 00
1048838 - Terminal 15
          B1148 12 [137] - Short to Plus
                    Reset counter: 49
                    Mileage: 26130 km
                    Date: 2018.02.13
                    Time: 03:20:30
                    ELV State: 02
                    CoCo State: A0 01
                    WFS State: 00 06
                    Voltage: 6A
                    CAN signals: 00
1048840 - Terminal 15 Redundancy
          B11D6 12 [137] - Short to Plus
                    Reset counter: 49
                    Mileage: 26130 km
                    Date: 2018.02.13
                    Time: 03:20:30
                    ELV State: 02
                    CoCo State: A0 01
                    WFS State: 00 06
                    Voltage: 6A
                    CAN signals: 00
   Coding: 0001
   Coding: 01031103
   Coding: 8103
   Coding: 2E0000
   Coding: 2E0000
End----------(Elapsed Time: 01:51, VBatt start/end: 13.8V/14.0V)-----------
myounus
Northwest UK
C?ID=321059
Qassem
I'm not clear on what you've added as the gateway is detecting additional modules.
   #60
Qassem
Kuwait
C?ID=325382
Qassem
Hi Dear
Address 05 Acc/start auth
Address 2B steer. Col.lock
Those are the additional modules, or there is another clarification for this message (I mean additional modules)
Ahh , you mean what i added to the gateway installation list?
I didn’t add anything yet.
I need your help , what should I do now
