jimc
New Member
Hi new to this forum, but can you help me with lost ABS long coding.
I have tried a few code but returns errors.
Scanned as below
Thanks in advance Jim
Scanned as below
Monday,08,January,2018,10:40:00:54050
VCDS Version: 17.8.1.0
VIN: TMBFA25J3C3171946 License Plate:
Mileage: 42510km-26414mi Repair Order:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 09 15 17 19 25 44 56
VIN: TMBFA25J3C3171946 Mileage: 42510km-26414miles
Address 01: Engine (J623-CGPB) Labels:. 03E-906-019-CGP.clb
Part No SW: 03E 906 019 AC HW: 03E 906 019 C
Component: SIMOS11.1 H03 2083
Revision: --H03--- Serial number:
Coding: 00110010000400000000
Shop #: WSC 13765 031 00053
ASAM Dataset: EV_ECM12MPI02103E906019AC 001004
ROD: EV_ECM12MPI02103E906019A.rod
VCID: 65C1B68264B2E46E02-8030
6350 - Cylinder 1
P0301 00 [096] - Misfire Detected
Mileage: 42505 km
Date: 2018.01.03
Time: 16:02:08
Engine speed: 2619.00 /min
Normed load value: 54.9 %
Coolant temperature: 3 °C
Intake air temperature: 2 °C
Voltage terminal 30: 14.523 V
Number of cylinder 1 misfires in drive cycle-Misfires cylinder 1 from engine start to engine stop: 17
Misfire detection: counter in driving cycle-CTR_MIS_TOT_DC: 18
Misfire sum counter: carb A-MIS_SUM_A: 52
Misfire sum counter-Misfires all cylinders per 1000 rpm: 18
6351 - Cylinder 2
P0302 00 [096] - Misfire Detected
Mileage: 42505 km
Date: 2018.01.06
Time: 00:01:20
Engine speed: 1621.00 /min
Normed load value: 25.5 %
Coolant temperature: 9 °C
Intake air temperature: 6 °C
Voltage terminal 30: 14.218 V
Number of cylinder 2 misfires in drive cycle-Misfires cylinder 4 from engine start to engine stop: 13
Misfire detection: counter in driving cycle-CTR_MIS_TOT_DC: 28
Misfire sum counter: carb A-MIS_SUM_A: 0
Misfire sum counter-Misfires all cylinders per 1000 rpm: 28
6352 - Cylinder 3
P0303 00 [096] - Misfire Detected
Mileage: 42505 km
Date: 2018.01.06
Time: 00:01:20
Number of cylinder 3 misfires in drive cycle-Misfires cylinder 3 from engine start to engine stop: 14
6371 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Mileage: 42505 km
Date: 2018.01.06
Time: 00:01:20
Fuel high pressure: actual value-Actual fuel rail pressure: 4977.7 hPa
Sensor control factor: output value-Lambda control value: bank 1: 0.000 %
Charging_activated charcoal filter system_moving_averag val-ACF: load: 0.00000
Target position of EVAP canister valve: 0.0 %
11836 - Cylinder Disabling
P130A 00 [096] - -
Mileage: 42505 km
Date: 2018.01.03
Time: 16:02:09
Engine speed: 776.00 /min
Normed load value: 20.4 %
Coolant temperature: 10 °C
Voltage terminal 30: 13.812 V
Time since engine start: 15 s
Engine torque: 28.78125 Nm
Accelerator pedal travel-Accelerator position: 12.50 %
Ignition angle of current cylinder: actual value-Ignition angle: actual: 2.625 °
Readiness: 0000 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS80.clb
Part No SW: 6R0 907 379 S HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Shop #: WSC 13765 790 00053
VCID: 4E93692E1D04073653-801A
03306 - Coding Not Valid
Reset counter: 187
Mileage: 42516 km
Date: 2018.01.06
Time: 22:56:33
Hex Value: 0x0001
Hex Value: 0x0000
Hex Value: 0x1203
Hex Value: 0x168A
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Reset counter: 187
Mileage: 42516 km
Date: 2018.01.06
Time: 23:07:50
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x1227
Hex Value: 0x147F
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Reset counter: 147
Mileage: 42516 km
Date: 2018.01.06
Time: 23:10:09
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x1213
Hex Value: 0x147E
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Reset counter: 187
Mileage: 42516 km
Date: 2018.01.08
Time: 00:00:01
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x1221
Hex Value: 0x1494
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 086 K HW: 6R7 937 086 K
Component: PQ25 BCM H27 0532
Revision: -3------ Serial number: 1009009700
Coding: 65980B3808010000002008002C2B08800040400F60000000020000000000
VCID: 4B95603AEA16321E34-801E
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3211
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
03302 - Response Closing Status of Passenger's Door
Fault Status: 00111000
Reset counter: 186
Mileage: 42505 km
Date: 2018.01.06
Time: 00:00:39
Reset counter: 186
Mileage: 42505 km
Date: 2018.01.06
Time: 03:50:00
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagT2C H10 0020
Revision: -------- Serial number: 003GX016KP9R
Coding: 003243
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 4A9B653EED6C2B160F-801E
Serial number: 3495RRB405H17NPAJ0D
Serial number: 3505RRB405H17NPAM18T
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5J0 920 901 H HW: 5J0 920 901 H
Component: KOMBI H04 0206
Serial number: 00000010867291
Coding: 410200
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_A01_SK25.rod
VCID: 2C5703A647D815261D-8078
Part No SW: 6N0 909 901 HW: 6R7 937 086 K
Component: GW-K-CAN TP20 H27 0532
Revision: -3------
Coding: 032300
VCID: 70EFD7D6A37031C661-8024
Address 25: Immobilizer (J285) Labels: 5J0-920-xxx-25.clb
Component: IMMO H04 0014
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25.rod
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10140
Shop #: WSC 13765
VCID: 2F6D14AAEACE6E3E38-807A
Part No SW: 5J0 035 161 D HW: 5J0 035 161 D
Component: Radio-SWING 002 0003
Revision: -----05S Serial number: SKZ4Z2M1210447
Coding: 050002000006
Shop #: WSC 80093 222 69422
VCID: 2345E89A2206DA5EAC-8076
00856 - Radio Antenna
Fault Status: 00100111
Fault Frequency: 23
Reset counter: 187
Mileage: 42505 km
Date: 2018.01.06
Time: 00:00:21
End-------------------------(Elapsed Time: 01:45)--------------------------
Address 01: DTCs cleared
Address 03,6R0 907 379 S,recoded (Long Coding),from,000000000000000000000000000000000000,to,410124DB007400B3822E24E600D700800000,(13765/790/00053),
Address 03,6R0 907 379 S,recoded (Long Coding),from,000000000000000000000000000000000000,to,100224DB017000B7082524E480DA00000000,(13765/790/00053),
Address 03,6R0 907 379 S,recoded (Long Coding),from,000000000000000000000000000000000000,to,100224DB017000B7082524E400DA00000000,(13765/790/00053),
Address 03,6R0 907 379 S,recoded (Long Coding),from,000000000000000000000000000000000000,to,110228DB007000B7882514E400DA00400000,(13765/790/00053),
Address 03,6R0 907 379 S,recoded (Long Coding),from,000000000000000000000000000000000000,to,110228DB007000B7882514E400DA004000,(13765/790/00053),
Address 03,6R0 907 379 S,recoded (Long Coding),from,000000000000000000000000000000000000,to,410124DB007400B3822E24E600D700400000,(13765/790/00053),
Address 09: DTCs cleared
Address 03: DTCs cleared
Readiness: 0110 0101
Revision: --------
Reset counter: 147
Mileage: 42516 km
Date: 2018.01.08
Time: 00:51:33
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x1213
Hex Value: 0x1488
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Coding: 030000
Coding: 020000
Coding: 003243
Coding: 410200
Revision: -3------
Coding: 032300
Coding: 10140
Shop #: WSC 13765
Fault Frequency: 23
Reset counter: 187
Mileage: 42505 km
Date: 2018.01.06
Time: 00:00:21
End-------------------------(Elapsed Time: 01:36)--------------------------
