Monday,08,January,2018,10:20:09:56355
VCDS Version: 17.8.1.0 (x64)
VIN: WA1LFAFP1FA070223 License Plate: A5Q
Mileage: 82450km-51232mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62
6C 6D 72
VIN: WA1LFAFP1FA070223 Mileage: 82450km-51232miles
Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-CDN.clb
Part No SW: 8R1 907 115 L HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09---
Coding: 6A2A0013242600062000
Shop #: WSC 29643 002 1048576
ASAM Dataset: EV_ECM20TFS0118R1907115L 001006
ROD: EV_ECM20TFS0118R1907115L.rod
VCID: 3E782116A1AB96B6A3-806A
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8R0 927 158 AS HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H19 1002
Revision: --H19---
Coding: 000001
VCID: 0E18B1D6D18B463613-805A
Part No SW: 8R0 907 379 BG HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0030
Coding: 3A1D1801
VCID: 060889F6B1FB0E76AB-8052
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0D854040000000000000
Shop #: WSC 06335 000 00000
VCID: 081487CEBBEF1806D9-805C
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3214000130355010
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 186
Mileage: 61728 km
Date: 2017.01.07
Time: 11:17:40
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01011120140278
Coding: 6481208000
VCID: 77F6F432C61167FEA0-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000936599302
Coding: 26000091803CAFC00000480300003D0D0F1C4608A2090361000008004000030100000034000000
Shop #: WSC 06335 123 12345
VCID: 78F4F70ECB0F6886A9-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 141016 H12 0050
Serial number: 90243014141011144119
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 23407031
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002810140071
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01CD3957
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 7E788757000000000001
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED12T469
Coding: 303634313432383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4C9C7BDEE71734263D-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000LL5G
Serial number: 6334MSME497C4720I
Serial number: 6344MSME4A295600A
Serial number: 6352QSME5D4A1850N
Serial number: 6362QSME304A2C4ER
Serial number: 63732SME444A0854
Serial number: 63832SME444A0A4A3
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NK70009J
Coding: 000017
VCID: 489447CEFB6FD80619-801C
Component: E221 - MFL H03 0003
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 N HW: 8R0 920 981 N
Component: KOMBIINSTR. H35 0564
Revision: 00300000 Serial number: ZD32353CF
Coding: 8BB622000301D705020000
VCID: 458A4EFACC7DC56EE2-8010
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z14A25033F
Coding: 80C303FF00
VCID: 4C9C7BDEEF1734263D-8018
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 5562494803
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000122733479
Coding: 00581B00000000000000
VCID: 428055E6DD53F256C7-8016
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0350867545
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3F865C12A6A19FBEA8-806A
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0350607293
Coding: 010211
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000123750259
Coding: 011D13205E00440004
VCID: 4FA66CD21E010F3E58-801A
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8R0 909 144 J HW: 8R0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0018111498
Coding: 100000000000
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
Revision: 00002001 Serial number: 0350893647
Coding: 0126023A20FA709584B0053200040000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000904288
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000123591559
VCID: 4E9871D6190B063653-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 20000000534706
ROD: EV_ParkiBrake_VW51.rod
VCID: 3A702D06BD83BA969F-806E
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156K20E8090780
Coding: 020007020100000001
VCID: 244CF37E2707DC66D5-8070
Part No SW: 8R1 035 746 G HW: 8R1 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 523F/0F7543923
Coding: 160200060005A1EF51028B5E00000403140000000000000000
Shop #: WSC 49171 001 1048576
VCID: 3B7E2802BAB9839E84-806E
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130K10E3177993
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000002036713
Component: CD-Database 5950
Reset counter: 186
Mileage: 61727 km
Date: 2016.12.19
Time: 13:03:30
Text: KBD_FB8,KBD,M,0,0,5
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000124323368
Coding: 010C13204000240004
VCID: 468849F6F17BCE76EB-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H09--- Serial number: 525PA8-J49A0UF
Coding: 1020010
VCID: 346C033E57E74CE645-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D7A261AA4AD8DAEBA-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000124319189
End-------------------------(Elapsed Time: 03:56)--------------------------
