Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Retrofit from Discover pro MIB1 to MIB2 on GOLF MK7
    Oct 2017
    Italy
    Hi all guys !!!
    Foreword ... the car I'm talking about is a golf mk7.
    I took the retrofit from Discover PRO MIB1 to Discover PRO MIB2 by purchasing an unlocked MIB2 version 3G0 035 043 D.
    Now I can see the sport monitor but I have a problem.
    The oil and water temperatures always remain at 0, even if they are correctly marked on the dashboard.
    Ideas on how to solve?
    Thank you.
    Posting an Auto-Scan would help please.
  3. Likes Uwe liked this post
    Oct 2017
    Italy
    In the coming days I will post an autoscan but I have no errors related to that ... I have already checked.
    Quote Originally Posted by Riddick20 View Post
    It's not just errors that we look for, it's also coding and hardware/firmware versions - all of which matter.
  6. Likes Uwe liked this post
    Oct 2017
    Italy
    ok I will!!!
    thanks for now !!!
    Oct 2017
    Italy
    I'm still here to ask for your help ...
    I mounted:
    mib 2.5 (golf facelift)
    latest version of golf gateway 7
    latest version of bcm for golf 7
    but in the sport monitor the oil and water temperatures always remain at 0.
    and in the offroad menu, oil and water pressure gauges do not appear.
    now I do not know what to think ... do not tell me that all this information is managed by the instrument panel (tacho) which is the only thing that I have not changed ...
    We're still waiting for you to post an Auto-Scan ...
  10. Likes Uwe liked this post
  11. #8
    Oct 2017
    Italy
    Saturday,17,February,2018,09:31:55:49498
    VCDS Version: 18.2.0.3
    Workshop Code: 011 01357 000200
    VIN: WVWZZZAUZEW144891   License Plate:
    Mileage: 17170km-10668mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 32 42 44 47 52 55 5F A9
    VIN: WVWZZZAUZEW144891   Mileage: 17170km-10668miles
    47-Sound System -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0007
       Revision: --H13---
       Coding: 091900122424050B2000
       ASAM Dataset: EV_ECM20TFS0215G0906259 001011
       ROD: EV_ECM20TFS0215G0906259.rod
       VCID: 6BD25F9F8244AA1CDD-803E
    17169 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [167] - -
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:24
                        Engine speed: 710.00 /min
                        Normed load value: 7.5 %
                        Coolant temperature: 105 C
                        Intake air temperature: 80 C
                        Voltage terminal 30: 13.203 V
                        ACC variants (coding): CCS
                        CCS Switch: CCS operating unit
                        Cruise control switch actuation-Main switch: not activated
                        Cruise control switch actuation-Setting: not activated
                        Cruise control switch actuation-Activation: not activated
                        Cruise control switch actuation-Status: OK
                        Cruise control switch actuation-Accelerate: not activated
                        Cruise control switch actuation-Decelerate: not activated
                        Cruise control switch actuation-Cancel: not activated
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Coding: plausible
                        Cruise control switch actuation-Limit function: not selected
                        Cruise control switch actuation-Limit button: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        Cruise control switch actuation-Large increment: not activated
                        Cruise control switch actuation-Control component verified: Yes
                        ACC variants: ACC
                        Engine: operating status: IS
    Readiness: 1110 0001
       Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
       Component: ESC           H31 0472
       Revision: 00000000    Serial number: 626830000007B8
       Coding: 01FA6BA154242970037F060941C46980D62A94C0608296F700400079C009
       VCID: 071A032FBEEC6E7C59-8052
       Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
       Component: Climatronic   080 Z052
       Revision: 00001K07
       Coding: 00020004200100011005004000101000
       VCID: 73E247FFDA7472DC15-8026
       Air quality sensor:
       Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
       Component: BCM MQBAB H   H24 0175
       Serial number: 01061703800247
       Coding: 00000A46C24122FB4BE4400000080708100A000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 040014238FDA45643C-8050
       Component: WWS    130926  042 0551
       Serial number:         130927225315
       Component: RLFS  024 0042
       Serial number: Y13M09D28H19M20S59S1
       Coding: 06A8DD
    558100 - Databus
                        Reset counter: 9
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:22
       Component: AirbagVW20    014 0385
       Serial number: 003F6R00ZNE.
       VCID: 418EDD37D048904C57-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 109 13
       Serial number: 35767000000A1A759D0/
       Subsystem 2 - Part No SW: -----------    HW: 480 001 009 13
       Serial number: 35867000000ED8409D04
       Subsystem 3 - Part No SW: -----------    HW: 480 402 709 13
       Serial number: 3516502AD1118A543091
       Subsystem 4 - Part No SW: -----------    HW: 480 402 709 13
       Serial number: 3526502AD1118A557255
       Subsystem 5 - Part No SW: -----------    HW: 480 402 509 13
       Serial number: 3556502C31142C83511-
    9440027 - Driver's side; side-airbag igniter
              B100B 1B [137] - Resistance Too High
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:23
    9439771 - Front Passenger's Side Airbag Igniter
              B100A 1B [137] - Resistance Too High
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:23
    9447189 - Seat Occupied Sensor; Passenger's Side
              B1027 15 [137] - Open or Short to Plus
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:24
    9629972 - Indicator Lamp for Passenger Airbag Enabled
              B12F1 14 [137] - Open or Short to Ground
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:24
    9442836 - Front Passenger's Airbag Disabled Indicator Lamp
              B1016 14 [137] - Open or Short to Ground
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:24
       Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
       Revision: --------    Serial number: 24091304220220
       Coding: 0400
       ROD: EV_SMLSKLOMQB_013_AU37.rod
       VCID: 75E679E7D4006CEC3B-8020
       Part No SW: 5G6 920 870     HW: 5G6 920 870
       Component: KOMBI         314 2210
       Coding: 03AD09002B80000C04087E00040000
       VCID: 6CD05C83874AAD24D4-8038
       Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1265
       Revision: --------    Serial number: 0005526889
       Coding: 030100042B085900EF00066B080F00010001000000000000000000000000
       ROD: EV_GatewLear_013_VW37.rod
       VCID: 7CF06CC3F72A3DA444-8028
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H06 0101
       Serial number: 27130002010240093502
       Coding: 2A0000
       Serial number: 7070981403
    131695 - Digital sound System control module
              U106A 00 [009] - No Communication
                        Reset counter: 9
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:23
                        Supply voltage: Terminal 30: 13.0 V
                        Terminal 15: On
    1025 - invalid data record
              B2005 00 [009] -  -
                        Reset counter: 9
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:23
                        Supply voltage: Terminal 30: 13.1 V
                        Terminal 15: On
    1029 - invalid data record
              B2005 00 [009] -  -
                        Reset counter: 9
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:23
                        Terminal 15: On
    1036 - invalid data record
              B2005 00 [009] -  -
                        Reset counter: 9
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:23
                        Terminal 15: On
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
       Component: Quersperre    H52 8038
       Serial number: HA1-00013.09.13
       Coding: 0001
       ASAM Dataset: EV_LockElectHA1VW37X 001001
       ROD: EV_LockElectHA1VW37X.rod
       VCID: 479AC32FFE6CAE7C99-8012
       Serial number: 050215BB301568
       Coding: 003F0320D000040000001000
       VCID: 428CD23BD54E8B544E-8016
       Serial number: 00000000000002846731
       Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
       Component: EPS_MQB_ZFLS  502 5011
       Coding: 0101
       ASAM Dataset: EV_SteerAssisMQB 009026
       ROD: EV_SteerAssisMQB_009_VW37.rod
       VCID: 336287FF9AF432DCD5-8066
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H30 0150
       Revision: 00000001    Serial number: VWZ8Z1GBA02UBX/
       Coding: 12000000008AAA8A000000000000
       ASAM Dataset: EV_AMPMst11CGen2ALPI 001002
       ROD: EV_AMPMst11CGen2ALPI.rod
       VCID: 6DD65187BC50A42CC3-8038
       Serial number: 29081406070299
       Coding: 003F0120DE00040000801000
       Serial number: 00000000000002832675
       Coding: 090000
       Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0080
       Coding: 029A01000B010200
       VCID: 3D76A1C7ACB0F4AC33-8068
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 043 D    HW: 5G0 035 043
       Component: MU-H-N-EU     H40 0407
       Serial number: A457I0D7506385
       Coding: 027300010000000011110002000800031F0203B40100010057
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 1F4A7B4F067C86BC01-804A
       Component: ABT_High  H42 0022
       Serial number: VWZ8Z9N2300ZJA
       Subsystem 2 - Part No SW: V03 959 801 BG    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Component: Gracenote  --- 1008
    7202 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 9
                        Mileage: 17170 km
                        Date: 2018.02.17
                        Time: 09:23:27
                        Voltage terminal 30: 13.5 V
                        BAP-BAP_Function_ID: 02
       Part No SW: 5G0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0011
       Serial number: 130725200355
    End-------------------------(Elapsed Time: 04:07)--------------------------
  12. #9
    Mar 2014
    Europe
    Had a similar issue with Octavia RS 5E MY2015 with the same engine.
    The Performance monitor started to show real values after the engine ECU was flashed to newer version.
    Original was 5G0 906 259 H13 S010, updated with 5G0 906 259 C H13 S002, less than 4 minutes using O//-E.
  13. #10
    Dec 2016
    NL
    Also, there are a lot of adaptation channels related to can bus networks in that unit. If you post an adaptation channel map, we might even spot some obvious errors in there.
    Current:
