Results 1 to 6 of 6
Thread: LED bulb error on SEAT Altea XL 2013
    Verified VCDS User Navigatus's Avatar
    Jun 2016
    Veracruz
    My car is built on a PQ35 platform SEAT Altea XL 1.8 TSI DSG Style 2013 year model.
    I have 4 problems
    1. Light sensor - too late switching off lights and switch on lights too early
    2. LED how to access and change bulbs type, any known security access code not works.
    3. low tire pressure alarm, not works on MFI instruments
    4. Low oil level
    1. Light Sensor was working ok. but after change windshield with blue solar strap, now sensor is under this strap, I measured lumens and is about 2.5 times less when below on normal glass which also is with some heat reduction about 30%
    I living in Veracruz where light intensity is high.
    So, lights goes off at 1130 and turn on back 1400-1530
    I think I have to work with this
    http://forums.vwvortex.com/showthrea...-the-7R/page32
    But any security access code none works, and I downloaded manuals for my car. But codes not work, so I can't go into adoption channels.
    2 . Thanks for helping with LED error lights, most gone, part of coding I had to return back as my rear reverse camera stop working, (is connected to power from reverse light also Led now)
    By the way also Would be nice to change light bulb there to LED to clear once for ever problems with led bulb errors (all bulbs changed to Led, except head high / low beam bulbs.
    3. I not have TPSM it's made by ABS module by rotation speed comparation or something like this.
    Before I put my finger in with VCDS it was working ok, was showing alarm on instruments, now we run 3 times with low pressure and none alarms appeared in instruments.
    4. Occurred that car run with low oil none alarms come up, I checking on channels and find been set up level and lower level in Engine, but after investigation I find out that alarm check box not been set up ? From Factory ?!
    I'm urging to resolve problems 1, 2 But I think I can't go any more ahead without access codes.
    By problem no. 2 is possible to set up DRL (LED in fog lights) without position lights?
    Shall post my problem on forum?
    With warm regards from Veracruz
    Robert Pozniak
    Saturday,06,January,2018,17:28:37:40964
    VCDS Version: 17.8.1.0 (x64)
    VIN: VSSBG65P5ER002325   License Plate: xxxxx
    Mileage: 55380km-34411mi   Repair Order: Scan de fallas
    Chassis Type: 5P-SE35 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 56 62 72
    VIN: VSSBG65P5ER002325   Mileage: 55380km-34411miles
    56-Radio -- Status: Sporadic communication error 1000
    Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
       Part No SW: 1P0 907 115 AG    HW: 1P0 907 115 Q
       Component: 1.8l R4/4V TFSI     0030
       Revision: AAH18---    Serial number:
       Coding: 0303000C24070160
       Shop #: WSC 06402 785 00200
       VCID: 70EFA968630317C661-8024
    001089 - EVAP Emission Control Sys
                   P0441 - 000 - Incorrect Flow - Intermittent
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.843 V
       Part No SW: 0AM 300 057 P    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 4532
       Revision: 00043014    Serial number: CU501604036360
       Shop #: WSC 04940 001 00001
       VCID: 3D71405C64D1AAAEBA-8068
       Revision: 00H31001
       Coding: 213F4012092200FC840E02E6901E0041350400
       Shop #: WSC 04941 123 12345
       VCID: 7DF1805CE4516AAEFA-8028
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 207
                        Mileage: 50333 km
                        Date: 2017.07.31
                        Time: 19:48:31
                        Count: 32768
                        Count: 4608
                        Count: 397
                        Count: 49409
                        Count: 255
                        Count: 65280
       Part No SW: 5P0 907 044 T    HW: 5P0 907 044 T
       Component: Climatronic   H19 0909
       Revision: 00001001
       Coding: 0004000002
       ROD: EV_ClimaAutoBasis_SE35.rod
       VCID: 41893CACD029CE4EDE-8014
       Part No SW: 1K0 937 087 AQ    HW: 1K0 937 087 AQ
       Component: BCM PQ35  H+  112 0770
       Revision: AF112770
       Coding: 4C180A38E837B0E0428800809500878447D91111527D8960238068000040
       Shop #: WSC 00495 001 104857
       VCID: 000FF9A893A3074691-8054
       Subsystem 1 - Part No: 5P0 955 119 E  Labels: 1KX-955-119.CLB
       Component: Wischer 13051  26  0611
       Coding: 00DB90
       Subsystem 2 - Part No SW: 1P0 955 559 A    HW: 1P0 955 559 A  Labels: 1P0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 1F542E
       Subsystem 3 - Part No: 5P0 951 177
       Component: Innenraumuebe  001 0102
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 135
                        Reset counter: 2
                        Mileage: 54907 km
                        Date: 2017.12.17
                        Time: 14:33:51
                        Voltage: 12.20 V
                            Term 50 Off
                        Fault Frequency: 120
                        Reset counter: 2
                        Mileage: 54907 km
                        Date: 2017.12.17
                        Time: 14:33:51
                        Voltage: 12.20 V
                            Term 50 Off
                        Fault Status: 00101010
                        Fault Frequency: 37
                        Reset counter: 41
                        Mileage: 54920 km
                        Date: 2017.12.18
                        Time: 07:08:26
                        Voltage: 14.10 V
                            Term 50 Off
                        Reset counter: 16
                        Mileage: 55001 km
                        Date: 2017.12.19
                        Time: 14:33:08
                        Voltage: 13.50 V
                            Term 50 Off
                        Fault Frequency: 10
                        Reset counter: 16
                        Mileage: 55001 km
                        Date: 2017.12.19
                        Time: 14:33:13
                        Voltage: 13.80 V
                            Term 50 Off
       Part No SW: 5P0 919 475 B    HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H08 0008
       Revision: --------    Serial number: 36831315701002
       Coding: 000102
       Shop #: WSC 04941 000 00000
       VCID: 3A7B4B40B5FF9D969F-806E
       Component: S7 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD2ZJ3U9
       Coding: 0021303
       Subsystem 1 - Serial number: 6332MSME7A40682FN
       Subsystem 2 - Serial number: 6342MSME7B134538E
       Subsystem 3 - Serial number: 6351HSME2F5A2C3BR
       Subsystem 4 - Serial number: 6361HSME2F5A146EP
       Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
       Revision: FF010042    Serial number: 20130614100470
       Coding: 1892140002
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7EF38750E15771B6E3-802A
       Subsystem 1 - Part No SW: 1P0 959 538 B    HW: 1P0 959 538 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP  H02 0103
       Coding: E30000
       Part No SW: 1P0 920 850 Q    HW: 1P0 920 850 Q
       Component: KOMBI         H01 0809
       Coding: 311B00
       VCID: 3A7B4B40BDFF9D969F-806E
       Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1642
       Revision:   H57       Serial number: 020613F1001539
       Coding: 356202
       Shop #: WSC 18895 002 1048576
       VCID: 79F9944CF079568ED6-802C
    01304 - Radio
                        Fault Frequency: 82
                        Reset counter: 42
                        Mileage: 54907 km
                        Date: 2017.12.17
                        Time: 16:19:40
       Component: IMMO          H01 0809
       VCID: 6ADBBB008DDFED162F-803E
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0505
       Revision: 12110009    Serial number: 0006830923
       Coding: 0010B0
       VCID: 6DD1B01CBC31FA2E4A-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 D    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1501
       Serial number: 00000007801472
       Coding: 000090
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 65     3501
       Revision: 00H22000
       VCID: 3979544C70F9968E96-806C
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0505
       Revision: 14110009    Serial number: 0006847190
       Coding: 0011B0
       VCID: 6ED3B710B137013673-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 704 D    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1501
       Serial number: 00000007802850
       Coding: 000090
    66821 - Position Sensor for Mirror Adjustment
              B11FA 29 [009] - Signal Implausible
                        Reset counter: 221
                        Mileage: 54907 km
                        Date: 2017.12.17
                        Time: 14:16:19
    Address 56: Radio
    End-------------------------(Elapsed Time: 02:21)--------------------------
                    Address 01: Engine       Labels: 06J-907-115-CDA.clb
    Control Module Part Number: 1P0 907 115 AG    HW: 1P0 907 115 Q
      Component and/or Version: 1.8l R4/4V TFSI     0030
               Software Coding: 0303000C24070160
                Work Shop Code: WSC 06402 785 00200
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
                        Fault Frequency: 9
                        Mileage: 55096 km
                        Date: 2017.12.20
                        Time: 14:25:39
                        RPM: 840 /min
                        Load: 14.5 %
                        Temperature: 96.0C
                        Temperature: 45.0C
                        Voltage: 13.843 V
    Address 01: DTCs cleared
                    Address 01: Engine  (1P0 907 115 AG)
    17:33:08 Group 001: General
      720 /min  Engine Speed (G28)
      69.0C  Coolant Temperature (G62)
      0.0 %  Lambda Control Bank 1
      10110110  Basic Setting Requirements
    17:33:08 Group 002: General
      760 /min  Engine Speed (G28)
      21.1 %  Engine Load
      1.28 ms  Injection Timing
      3.08 g/s  Mass Air Flow Sensor (G70)
    17:33:08 Group 026: Ignition (Knock Control Cylinder 1-4)
      0.936 V  Knock Sensor Voltage Cylinder 1
      0.936 V  Knock Sensor Voltage Cylinder 2
      0.780 V  Knock Sensor Voltage Cylinder 3
      0.936 V  Knock Sensor Voltage Cylinder 4
    Jun 2016
    Veracruz
    I done some reserch about sensor and noted from my mobilephone light sensor readings and also when been at home the VCDS channel reading.
    "DAY" DRL lights active
    Half shadow, by sensor sun on side 27-12-2017 at 1545
    5080 - Out-side the car over car glass
    3800 - Inside the car, touching glass on transparent part of glass
    1200 - Inside the car, blue strap at position of car sensor
    In shadow 1510hrs. 06-01-2018
    2930 - Out-side the car over car glass
    2830 - Inside the car, touching glass on transparent part of glass
    676 - ‎ Inside the car, blue strap at position of car sensor
    7 - ‎ VCDS - READING FOR SENSOR
    3821 - Out-side the car over car glass
    3080 - Inside the car, touching glass on transparent part of glass
    950 - ‎ Inside the car, blue strap at position of car sensor
    3018-01-06 1726 hrs.
    2070 - Out-side the car over car glass
    3040 - Inside the car, touching glass on transparent part of glass
    320 - ‎ Inside the car, blue strap at position of car sensor
    Low beam active
    4994 - Out-side the car over car glass
    3500 - Inside the car, touching glass on transparent part of glass
    1003 - Inside the car, blue strap at position of car sensor
    05-01-2018 1650 hrs.
    4010 - Out-side the car over car glass
    2712 - Inside the car, touching glass on transparent part of glass
    810 - Inside the car, blue strap at position of car sensor
    2900 - Out-side the car over car glass
    2800 - Inside the car, touching glass on transparent part of glass
    520 - ‎ Inside the car, blue strap at position of car sensor
    2018-01-06 1645
    6596 - Out-side the car over car glass
    4655 - Inside the car, touching glass on transparent part of glass
    1503 - ‎ Inside the car, blue strap at position of car sensor
    May 2017
    Short answers
    1. Guide you're referring to is for MQB platform. So PQ35 does not have RLS adaptation channels. Instead you modify the subsystem coding in BCM long coding helper. Choose RLS as the subsystem and you can change the coding with long coding helper. There's some settings for light threshold which you can change depending on glass type.
    2. Not possible to do with VCDS. You can change byte 18 with VCDS and with that you might be able to get some of the led bulb issues to disappear. However, if you want to disable cold and warm diagnosis from individual elements in the light setup, you need to edit the BMCs output mapping EEPROM and for that you need different tools.
    3. Sorry did not understand? You changed your ABS coding and now TPMS does not work?
  4. Likes Uwe liked this post
    Jun 2016
    Veracruz
    Helow downtime, my laptop gone, so I been unable to replay,
    No. 3 is already done, hope so error gone, in service they reset all to fabric, but i belive not to my car fabric set up. I'm away of home, so unable to conect and check my car.
    In reference to BMC can you guide me how to do it with mapping EEPROM? This one is a shadow area for me, no idea how I can enter there with VCDS.
    Many thanks for replay.
    Best regards
    Robert
    Dec 2016
    NL
    3. The fault code is ‘lower limit exceeded’. That is not the same as ‘tire pressure too low’. So dont start changing coding because of a misunderstanding. The only module that gives tire pressure too low warnings is 65-tire pressure which you dont have.
    4. Do you even have an oil level sensor? Figure that out first before assuming coding or adaptation is wrong.
    Current:
  7. Likes Uwe liked this post
    May 2017
    Quote Originally Posted by Navigatus View Post
    Best regards
    Robert
    Ok, so that's fine then.
    Sorry, spelling error on my part. I meant BCM = Body Control module or central electronics. You cannot change the EEPROM table with VCDS. You need something else for that. VCPsystem is one tool that people are using. Just google VCP BCM eeprom modification.
