Results 1 to 10 of 13
Thread: 2012 Audi A8 MMI visible only for a few seconds after screen comes up
    Jan 2018
    I have a similar problem that seems to have many answers, which one is right for me? My MMI only displays for a few seconds after the screen rotates up, then goes dark. If I lower the screen then it will do the same thing again when I raise it. I have the 02259 Information Display fault and Control Head (Front) (J685). I bought the Fiber Optic loops to troubleshoot as the optic tester in VCDS does not seem to work for me. I have bypassed all the units I found in the trunk (Amplifier, Backup Camera and one other not sure what it is) with no change in symptoms. All the displays seem to work, in the cluster, plus I can see the backup camera for those brief few seconds when the screen pops up. I believe I need to replace this unit (J685) is this my first step, and can I test this somehow?
    Please start by posting an Auto-Scan.
    Jan 2018
    Sunday,31,December,2017,17:05:00:30886
    VCDS Version: 17.1.3.0 (x64)
    VIN: WAUAVAFD2CN008675   License Plate:
    Chassis Type: FD (4H0)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 1B 22 28 34 36 3B 42 46
              47 52 53 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
    VIN: WAUAVAFD2CN008675   Mileage: 92818km-57674miles
    Address 01: Engine (------CDRA)       Labels: None
       Part No SW: 4H0 907 560 C    HW: 4H0 907 560
       Component: 4.2l V8/4V    H07 0004
       Revision: N5H07---
       Coding: 0106000A290F0168
       Shop #: WSC 22145 444 13987
       ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
       ROD: EV_ECM42FSI0114H0907560C.rod
       VCID: 2A5BBB454D878F1197-807E
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
       Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 K
       Component: 0BK 42 FSIUSA H08 1001
       Revision: --H08---
       Coding: 000002
       ROD: EV_TCMALX51011_002.rod
       VCID: 01093CE99071AC49E6-8054
    Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
       Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
       Component: ESP PREMIUM   H10 0273
       Coding: 44FEB200227F4D00E200
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremi 005006
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 3169AC296051FCC956-8064
       Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
       Component: BCM2 2.0      H31 0510
       Coding: 0D872000000000000000
       Shop #: WSC 41337 001 1048576
       VCID: 6ED37755B9EFA3310B-803A
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000111128001
    Address 06: Seat Mem. Pass
    Address 08: Auto HVAC
    Address 09: Cent. Elect.
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 10: Park/Steer Assist
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H41 0041
       Revision: --------    Serial number: 003JS00158S6
       Coding: 303143303230303030344A55304C34483053
       VCID: 377D92318E3522F918-8062
       Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
       Serial number: 5850000R11706015V7
       Serial number: 3575HRB405T0IRE24GI/
       Serial number: 3585HRB405H0JR9Q703L
       Serial number: 3515JRB404R0M38E3P7G
       Serial number: 3525JRB404T0M38E9HEO
       Serial number: 3554VRB40550LMIQCPKT
       Serial number: 3564VRB40550LMIQF930
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
       Revision: --------    Serial number: 90815KGB0000S
       Coding: 000434
       VCID: 387F910D8B2B2D8111-806C
       Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
       Component: E221 - MFL  H06 0009
       Serial number: 01 02 2011  11103630
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Part No SW: 4H0 920 920 E    HW: 4H0 920 920 E
       Component: TBenUSA------ H36 0373
       Revision: 32480030    Serial number: 658280711593038
       Coding: 0B660801B300D705020000
       Shop #: WSC 02313 785 00200
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K.rod
       VCID: 275D42715E95B27988-8072
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
       Component: Analoguhr D4  H05 0224
       Serial number: 1110707000150
       Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000198870
       Coding: 00C1034A00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 3467A53D9F43C9E13D-8060
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650927867
       Part No SW: 4H0 907 144 B    HW: 4H0 907 144 B
       Component: DYNAMIKLENK.  H06 0090
       Revision: 51001005    Serial number: --------------
       Coding: 8B0000
       VCID: 275D42715695B27988-8072
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H14 0013
       Serial number: 000807110001018
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
    Address 28: HVAC, Rear (E265)       Labels: None
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Component: Klima Fond    H15 0062
       Coding: 0000000000
       ROD: EV_AirCondiHeck_AU64.rod
    Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
       Part No SW: 4H0 907 553 C    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0096
       Coding: 008004
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2C57BD5D4773912165-8078
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000010262958
       Coding: C0183B0085053201010001010101112131313333203333
       VCID: 356198399C39D0E90A-8060
    Address 3B: Sensor Elect. (J849)       Labels: None
       Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
       Component: SARA 6D red   H02 0015
       Revision: --------    Serial number: EJ1BPA3700FZBM0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D51B0597C69982972-8078
       Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
       Component: TSG FA        H02 0166
       Revision: --------    Serial number: 0000118373747
       Coding: 011F1F205E0062C202000006
       Shop #: WSC 02312 785 00200
       VCID: 4385F6E1C2ED7E59B4-8016
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0155050077
       Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0070
       Serial number: 00000000000000040548
       Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.028  H07 0006
       Serial number:     WOO12681585
       Coding: 001F00
       Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
       Component: Dachelektroni  H11 0080
       Serial number: A2011000000000448584
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS010  H05 0005
       Serial number:     WOO1000HPY8
       Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0130
       Revision: CJ007000    Serial number: 00000000033986
       Coding: 030000
       VCID: 1C376D9D1FD361A115-8048
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0166
       Revision: --------    Serial number: 0000118563049
       VCID: 3A7B8B05B5273F91E7-806E
       Revision: --------    Serial number: 00000000117835
       ROD: EV_ParkiBrake_VW51.rod
       Part No SW: 4H0 035 082 B    HW: 4H0 035 082
       Component: Radio U SIRIU H52 0076
       Revision: AB001007    Serial number: 155GR0B7510504
       Coding: 020007010000000001
       VCID: 204F596D33BB4541C9-8074
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
       Part No SW: 4H0 035 746 A    HW: 4H0 035 746
       Component: H-BNT-NA      H48 0380
       Revision: --------    Serial number: 035G 0B7501788
       Coding: 020200000001F1EF45128B0E00000003140001000000000000
       VCID: 26434F75519FAB71B3-8072
       Subsystem 1 - Part No: 8R0 060 884 AD
       Component: NAR 2011  0505
       Subsystem 2 - Part No SW: 4H1 919 600 F    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0064
       Serial number: 00000000045605
       Subsystem 3 - Part No: 8R0 060 961 B
       Component: CD-Database  3371
    02259 - Information Display and Control Head (Front) (J685)
                        Reset counter: 217
                        Mileage: 92818 km
                        Date: 2017.12.31
                        Time: 16:59:41
                        Voltage: 14.50 V
    03787 - Rotation Mechanism for Display Module Front
                003 - Mechanical Failure
                        Reset counter: 217
                        Mileage: 92818 km
                        Date: 2017.12.31
                        Time: 16:59:41
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0162
       Revision: --------    Serial number: 0000118414450
       Coding: 010F1F20400062C202000006
       VCID: 39799409B0213489EE-806C
       Part No SW: 4H0 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0061
       Revision: --H04---    Serial number: 525 PA8J17D3CB
       Coding: 1081002
       VCID: 26434F75919FAB71B3-8072
    Address 6D: Trunk Elect. (----)       Labels: None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 197100260
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3B758E01B21D0699FC-806E
    Address 6F: Centr. Conv. II (J773)       Labels: None
       Part No SW: 4H0 907 412     HW: 4H0 907 412
       Component: ALM           H05 0004
       Revision: --------    Serial number: 000000040791
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63C516616A2D1E5994-8036
       Component: TSG HR        H04 0162
       Revision: --------    Serial number: 0000118413875
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H07 0083
       Revision: 0L0D5012    Serial number: SN110607  0219
       ROD: EV_GSM2x3Mono.rod
       VCID: 2B55BE41427D96196C-807E
    Address 88: Multicont. Seat Driver (J873)       Labels: None
       Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
       Component: IVB           H07 0042
       Serial number: 00001145338002
       Coding: 764FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F6DAA517665EA3940-807A
    Address 89: Multicont. Seat Pass. (J872)       Labels: None
       Serial number: 00001145336801
       Coding: 364FF2
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 00060000031F030000030801424CD8010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FED6A51B6E5AA3900-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70EF692DABDBB5C119-8024
    End-------------------------(Elapsed Time: 05:55)--------------------------
    Based on that scan, this does not seem to be an optical ("MOST") bus problem.
    And 5F does report some faults related to the problem described:
    Jan 2018
    So is the original question valid? Do I need to replace the J685 unit? Is there a way to test this, or do I replace and see if that solves the problem? That seems to be where I'm at. I just don't understand why the screen comes on every time it is raised. Has anyone had similar symptoms? I read all about the MOST ring and even purchased the bypasses, but that didn't change any of the symptoms. Everything works except the display, but the screen does function if only briefly.
  6. #6
    Quote Originally Posted by Stew View Post
    If I had any personal experience that was relevant, I'd happily share it.
  7. #7
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    $5 says it's deploying and turning on as per normal, but there's some little microswitch that's supposed to tell it the screen has fully come out, and that isn't happening. So the display turns back off as it's not supposed to be on when inside the dash.
    I don't know what the cheapest or easiest fix for that would be, but I bet that's the failure mode.
    Silence gives consent.
  8. Likes Uwe, PetrolDave liked this post
  9. #8
    Jan 2018
    Well, I'll see what I can get to this weekend. Maybe when I start to disassemble the dash to pull the unit I'll see something obvious. Even if I need to replace the unit I need to pull it first because I'm not 100% sure on the part number or version if that makes any difference other than some programming. Thanks for the input.
  10. #9
    Dec 2016
    NL
    Check the wiring first. It moves, so a broken or near-broken wire sounds a lot more plausible to me.
  11. #10
    Jan 2018
    Well now its not any better, after spending a better part of the evening pulling out the trim from the dash, I was able to pull the head unit (cd player/sd card reader). The screen is still in the car because of a two wire connection on a ten pin connector doesn't seem to come undone, a youtube video definitely showed that they cut this wire. Anyway in all of my moving around components and wiring now the screen doesn't come on at all. Back at it on Monday.
