HELP # Missing message on an A4 B9
Molemans
C?ID=215708
I have a missing message on my A4 B9 2017.
I have copier my auto-scan below.
Can some one me help troubleshooting this issue.
Thank you.
Sunday,07,January,2018,12:09:51:49819
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4409.4
VIN: WAUENAF42HN007223   License Plate:
Chassis Type: F4-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F 6C
          81 A5 BB BC CA CF D6 D7
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CYMC)       Labels: None
   Part No SW: 8W0 906 259 C    HW: 06L 907 425
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0A2500322326010E34280000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0208W0906259C 001005
   ROD: EV_ECM20TFS0208W0906259C.rod
   VCID: 41DFB8440105E3BF15F-8014
Readiness: 1000 0100
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 8W1 927 155 B    HW: 0CK 927 156 S
   Component: 0CL 20TFSINAR H06 0003
   Revision: --H06---    Serial number: 0000000100
   Coding: 000001
   ASAM Dataset: EV_TCMDL382021 002023
   ROD: EV_TCMDL382021_VW51.rod
   VCID: 3FDBBEBC77F1954F63B-806A
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117051150334000996
Address 03: ABS Brakes (J104)       Labels:. 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0593
   Coding: 18AA409928A20A9815A4489900855292E6259A18021450A812004A4967A459
   Shop #: WSC 61656 001 1048576
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: 47CBA65C2F21DD8FDBB-8012
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0052
   Coding: 140805085548000D10000100800000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 372BD69C5FC1AD0FABB-8062
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000687399
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 15E84AD7000000000001
   Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
   Component: Klima Heck  H34 0050
263424 - Temperature Sensor for Rear Left Seat
          B1113 01 [008] - Electrical Failure
                    Fault Frequency: 13
                    Reset counter: 198
                    Mileage: 31959 km
                    Date: 2017.12.20
                    Time: 11:57:14
                    Voltage terminal 30: 14.63 V
                    Outside air temperature: 19.50 °C
263425 - Temperature Sensor for Rear Right Seat
          B1114 01 [008] - Electrical Failure
                    Fault Frequency: 7
                    Reset counter: 198
                    Mileage: 31959 km
                    Date: 2017.12.20
                    Time: 11:57:51
                    Voltage terminal 30: 14.56 V
525057 - Rear A/C Control Head
          B10AA F0 [008] - Switch Stuck
                    Reset counter: 187
                    Mileage: 32068 km
                    Date: 2017.12.22
                    Time: 17:15:08
                    Voltage terminal 30: 13.08 V
459009 - Databus
          U1121 00 [024] - Missing Message
          Intermittent - Confirmed - Not Tested Since Memory Clear
                    Fault Frequency: 15
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:42
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Coding: 07500363E0081CCD0115871518AC98BB11033D00000000000000000020001A010A690122025505
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 00597D404A8F2AB75A1-8054
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 151009  043 0813
   Serial number: 894353?0401528203101
   Coding: 5BC7F7
   Serial number: 60995248
   Coding: 02005D
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 N    HW: 4M0 941 531 N
   Component: E1 - LDS  H06 0008
   Serial number: 30 08 2015  00082828
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0040
   Serial number: 0000009600335Z08SV02
   Coding: 350000
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20151118105834 00239
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE130101511910378
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 AN    HW: 8W0 947 135
   Component: J528-Dachele  H13 0080
   Serial number: Q00026115
   Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H15 0010
   Serial number: 2615000118889002
9 Faults Found:
65827 - Databus
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:22
                    average_Voltage_terminals: 15.10 V
                    Outside air temperature sensor-Resistance: 2.56 KOhm
                    Outside air temperature sensor-Outside air temperature on CAN: -5.50 °C
                    interior_temperature: 28.50 °C
                    Vehicle speed: 0.00 km/h
66657 - Local Databus 5
          U1506 00 [008] - No Communications
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:25
                    average_Voltage_terminals: 15.20 V
66658 - Local Databus 6
          U1507 00 [008] - No Communications
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:25
66707 - Image processing control module
          U1079 00 [008] - No communication
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:27
66881 - Databus
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:45
                    average_Voltage_terminals: 12.80 V
                    interior_temperature: 29.00 °C
66882 - Databus
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:45
131954 - Vehicle Ride Height Sensor; Rear Right
          B1696 56 [009] - Invalid / Incompatible Configuration
                    Reset counter: 158
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:24
196758 - Databus
                    Reset counter: 196
                    Mileage: 32362 km
                    Date: 2017.12.27
                    Time: 15:35:29
                    Outside air temperature sensor-Outside air temperature on CAN: 1.50 °C
                    interior_temperature: 21.00 °C
262146 - Control Module Incorrectly Coded
          U1014 00 [008] - -
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:23:05
                    interior_temperature: 29.50 °C
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 A    HW: 8W0 959 655 A
   Component: Airbag10.44   H64 0086
   Serial number: 003N8000E016
   Coding: BFCCF0C000800000A0000033C24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   Belt Pretensioner left:
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706C0327P01475
   Coding: 80000D
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J150003RHDD0F
   Subsystem 4 - Part No SW: -----------    HW: 442 060 611 15
   Serial number: 3577Y00A31AF3CF4740B
   Subsystem 5 - Part No SW: -----------    HW: 442 060 611 15
   Serial number: 3587Y00AD1AF3CF1E2F$
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 411 15
   Serial number: 3517700B11E0EE95636L
   Subsystem 7 - Part No SW: -----------    HW: 442 0B0 411 15
   Serial number: 3527700AF1E0EE95608Y
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 611 15
   Serial number: 3557500A51DEC3E253DY
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 611 15
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500A31DEC3E3145N
12680704 - No Communication with Control Module for Seat Belt Tensioner; Front Left
          U017E 00 [009] - -
                    Reset counter: 165
                    Mileage: 32760 km
                    Date: 2018.01.06
                    Time: 23:06:13
   Part No SW: 4M0 907 129 GK    HW: 4M0 907 129 GK
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7F5BFEBC3771554F23B-802A
Address 17: Instruments
   Part No SW: 8W6 907 468     HW: 8W6 907 468
   Component: Gateway       H11 2079
   Revision: 3R050039    Serial number: 3983R007716219
   Coding: 0301000100000F4029000000005900104C100007000000000175070E00000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 074B665C6FA11D8F1BB-8052
   Subsystem 1 - Part No SW: 8W0 951 523 H    HW: 8W0 951 523 H
   Component: J453 MFL  H04 0002
   Serial number: 20151110052535 RD118
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 5467628403
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0022
   ASAM Dataset: EV_LCMLeftHELLAAU736 001011
   VCID: 78A915A0125F6277621-802C
   Part No SW: 4M0 959 760     HW: 4M0 959 760
   Component: MEM-FS        008 0015
   Serial number: 00000187089918
   Coding: 005C1B000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
   ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
   VCID: 75B71C94054D1F1F797-8020
9655892 - Motor for Seat Backrest Adjustment
          B1356 54 [041] - Missing Calibration / Basic Setting
                    Reset counter: 146
                    Mileage: 32020 km
                    Date: 2017.12.21
                    Time: 17:58:15
9655380 - Motor for seat height adjustment
          B1354 54 [041] - Missing Calibration / Basic Setting
                    Reset counter: 146
                    Mileage: 32020 km
                    Date: 2017.12.21
                    Time: 17:58:15
458752 - Databus
          U1121 00 [040] - Missing Message
                    Reset counter: 186
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:20
458797 - Databus
                    Reset counter: 186
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:22
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001011
Address 3C: Lane Change (J769)       Labels:* None
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   ROD: EV_RearRadarS1BoschAU736.rod
   VCID: 3431E1904EB746178E9-8060
7 Faults Found:
1192158 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
                    Control Module temperature: 32 °C
                    Voltage terminal 30: 14.90 V
                    Terminal 15 status: OFF
                    Voltage terminal 15: Measured value not available
1192162 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1192210 - Databus
                    Reset counter: 196
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:44
1192062 - Databus
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:23
                    Control Module temperature: 26 °C
                    Voltage terminal 30: 15.20 V
267010 - Databus
                    Fault Frequency: 17
                    Reset counter: 196
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:43
1183745 - Databus
                    Fault Frequency: 16
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:43
                    Voltage terminal 30: 15.10 V
1183965 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:58
                    Voltage terminal 30: 15.00 V
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000176050505
   Coding: 005F1B205E001080000100B2
   VCID: 42DDB7480403F8A70C5-8016
196676 - Door Warning / Enrty Lighting
          B1775 01 [008] - Electrical Failure
                    Reset counter: 184
                    Mileage: 31998 km
                    Date: 2017.12.20
                    Time: 16:31:15
524288 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:47:02
524425 - Databus
                    Reset counter: 187
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:25
196681 - Auto-Dimming Exterior Mirror
          B1317 01 [009] - Electrical Failure
                    Reset counter: 164
                    Mileage: 32425 km
                    Date: 2017.12.29
                    Time: 17:40:06
   Part No SW: 8W0 909 144 D    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0405
   Coding: 09000080008000
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X_002.rod
   VCID: 3E25C3B870FB9C4768D-806A
   Part No SW: 8W0 907 064 AC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   016 0307
   Coding: 013400004F100080659FA0002E01000233024000000023502F0400000B04803F001E0001000000
   Shop #: WSC 00008 444 12345
   ASAM Dataset: EV_BCM2HellaAU736 010010
   ROD: EV_BCM2HellaAU736_010.rod
   VCID: 7DA704B43D7D475F317-8028
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1529308BA
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000064209862
   Subsystem 3 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94036540
   Part No SW: 8W0 035 223 B    HW: 8W0 035 223
   Component: MIB2_amp_P_B9 H06 0250
   Revision: 00000001    Serial number: AUZ8ZAFH6004V1U
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
   VCID: 3039ED80BAAF7A37EA1-8064
   Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
   Component: TSG BFS       009 0039
   Serial number: 0000174366789
   Coding: 005F1B205E001080000100B0
524288 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:47:02
524425 - Databus
                    Reset counter: 187
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:25
                    Reset counter: 164
                    Mileage: 32428 km
                    Date: 2017.12.29
                    Time: 17:43:00
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W0 035 880     HW: 8W0 035 880
   Component: MU-P-LNS-US   051 0377
   Serial number: A400K0FB001179
   Coding: 019401020000000053220002041A00102F0002E501700104FE
   VCID: 77AB169C1F416D0F6BB-8022
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 8W0 919 605     HW: 8W0 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9FBJ00703
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 P    HW: 8W0 919 614 P
   Component: ControlUnit_H  H22 0139
   Serial number: C1000022101500020225
   Component: Gracenote2  --- 3007
9 Faults Found:
          B11CF 53 [009] - Deactivated
                    Reset counter: 140
                    Mileage: 31913 km
                    Date: 2017.12.19
                    Time: 12:24:10
                    Voltage terminal 30: 12.4 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
6697 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:57
                    Voltage terminal 30: 15.2 V
6920 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 188
                    Mileage: 32107 km
                    Date: 2017.12.22
                    Time: 20:44:54
                    Voltage terminal 30: 14.9 V
6932 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:30
                    Voltage terminal 30: 15.4 V
6943 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 187
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:24
                    Voltage terminal 30: 15.1 V
7176 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 188
                    Mileage: 32107 km
                    Date: 2017.12.22
                    Time: 20:44:57
                    Voltage terminal 30: 14.8 V
                    BAP-BAP_Function_ID: 02
7188 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:34
                    Voltage terminal 30: 15.3 V
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 140
                    Mileage: 31913 km
                    Date: 2017.12.19
                    Time: 12:33:04
7199 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:50
                    BAP-BAP_Function_ID: 01
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 4M0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0130
   Coding: 0294010102002001000040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
   ROD: EV_CamSysRVRVCPANAMLBEv_004_AU49.rod
   VCID: 72BD2788742308275C5-8026
   Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20151111000657
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 3537DC9445CD5F1FB97-8060
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 8W0 907 217 A    HW: 8W0 907 217
   Component: BVS           H13 0030
   Coding: 0404090100000201022023A2A50000FC00F0C020C000
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3A2DCFA86CD3B067545-806E
   Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
   Component: TSG HFS       009 0039
   Serial number: 0000175896822
   Coding: 004F1B2000001080400000A0
   Component: TSG HBFS      009 0039
   Serial number: 0000176256939
   Part No SW: 4M0 907 594 A    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 208000049100
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004_VW37.rod
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   ROD: EV_RearRadarS2BoschAU736.rod
   VCID: 313FE884B1A5733FE5F-8064
1192158 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1192162 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1183745 - Databus
                    Fault Frequency: 16
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:43
                    Control Module temperature: 18 °C
1183965 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:58
   ROD: EV_LEDModLeftMELCOAU736_AU49.rod
   VCID: 16753B18380BB40790D-8042
0019 - Headlamp Type
          C119F 00 [008] - Implausible
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:43
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:43
End----------(Elapsed Time: 02:23, VBatt start/end: 15.2V/15.2V)-----------
VIN: WAUENAF42HN007223   Mileage: 32761km-20356miles
   Revision: --H13---
   Coding: 000001
                    Fault Frequency: 13
                    Reset counter: 198
                    Mileage: 31959 km
                    Date: 2017.12.20
                    Time: 11:57:14
                    Fault Frequency: 7
                    Reset counter: 198
                    Mileage: 31959 km
                    Date: 2017.12.20
                    Time: 11:57:51
                    Reset counter: 187
                    Mileage: 32068 km
                    Date: 2017.12.22
                    Time: 17:15:08
459009 - Databus
                    Fault Frequency: 15
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:42
   Coding: 5BC7F7
   Coding: 02005D
   Light switch:
   Coding: 350000
9 Faults Found:
65827 - Databus
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:22
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:25
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:25
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:27
66881 - Databus
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:45
66882 - Databus
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:45
                    Reset counter: 158
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:24
196758 - Databus
                    Reset counter: 196
                    Mileage: 32362 km
                    Date: 2017.12.27
                    Time: 15:35:29
          U1014 00 [008] - -
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:23:05
   Coding: 80000D
   Occupant Detection:
          U017E 00 [009] - -
                    Reset counter: 165
                    Mileage: 32760 km
                    Date: 2018.01.06
                    Time: 23:06:13
Address 17: Instruments (J285)       Labels:* 8W5-920-xxx-17.clb
   Part No SW: 8W5 920 890 B    HW: 8W5 920 890 B
   Component: FBenUSA       H11 0275
   Coding: 08E751C1288CD705022B79601800000000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736.rod
16776962 - Databus
                    Fault Frequency: 7
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:52
                    Reset counter: 146
                    Mileage: 32020 km
                    Date: 2017.12.21
                    Time: 17:58:15
                    Reset counter: 146
                    Mileage: 32020 km
                    Date: 2017.12.21
                    Time: 17:58:15
458752 - Databus
                    Reset counter: 186
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:20
458797 - Databus
                    Reset counter: 186
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:22
   Revision: --------
   Coding: 0E8002
7 Faults Found:
1192158 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1192162 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1192210 - Databus
                    Reset counter: 196
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:44
1192062 - Databus
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:23
267010 - Databus
                    Fault Frequency: 17
                    Reset counter: 196
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:43
1183745 - Databus
                    Fault Frequency: 16
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:43
1183965 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:58
                    Reset counter: 184
                    Mileage: 31998 km
                    Date: 2017.12.20
                    Time: 16:31:15
524288 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:47:02
524425 - Databus
                    Reset counter: 187
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:25
                    Reset counter: 164
                    Mileage: 32425 km
                    Date: 2017.12.29
                    Time: 17:40:06
524288 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:47:02
524425 - Databus
                    Reset counter: 187
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:25
                    Reset counter: 164
                    Mileage: 32428 km
                    Date: 2017.12.29
                    Time: 17:43:00
9 Faults Found:
                    Reset counter: 140
                    Mileage: 31913 km
                    Date: 2017.12.19
                    Time: 12:24:10
6697 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:57
          U1111 00 [008] - -
                    Reset counter: 188
                    Mileage: 32107 km
                    Date: 2017.12.22
                    Time: 20:44:54
          U1111 00 [008] - -
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:30
          U1111 00 [008] - -
                    Reset counter: 187
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:24
          U1111 00 [008] - -
                    Reset counter: 188
                    Mileage: 32107 km
                    Date: 2017.12.22
                    Time: 20:44:57
          U1111 00 [008] - -
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:34
          U1111 00 [009] - -
                    Reset counter: 140
                    Mileage: 31913 km
                    Date: 2017.12.19
                    Time: 12:33:04
          U1111 00 [008] - -
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:50
   Revision: --------
   Coding: 0E8002
1192158 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1192162 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1183745 - Databus
                    Fault Frequency: 16
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:43
1183965 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:58
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:43
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:43
End----------(Elapsed Time: 02:11, VBatt start/end: 15.1V/15.1V)-----------
Please grab Beta 17.12 from this page. Since you're using a current-generation interface (HEX-NET or HEX-V2), in many cases it will give you additional "tips" with those kinds of faults.
Molemans
C?ID=215708
will do, Thanks.
Molemans
C?ID=215708
here it is;
Monday,08,January,2018,14:32:08:49819
VCDS Version: 17.12.0.1 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20171213 DS285.1
VIN:    License Plate:
VIN:    Mileage: 32879km-20430miles
   Revision: --H13---
   VCID: 41DFB8440105E3B9D04C-8014
   Coding: 000001
   ROD: EV_TCMDL382021_AU48.rod
   VCID: 3FDBBEBC77F19549A6B8-806A
   VCID: 47CBA65C2F21DD891E08-8012
   VCID: 372BD69C5FC1AD096EE8-8062
                    Fault Frequency: 15
                    Reset counter: 207
                    Mileage: 31959 km
                    Date: 2017.12.20
                    Time: 11:57:14
                    Reset counter: 207
                    Mileage: 31959 km
                    Date: 2017.12.20
                    Time: 11:57:51
          U8E6450 F0 [008] - Switch Stuck
                    Reset counter: 206
                    Mileage: 32068 km
                    Date: 2017.12.22
                    Time: 17:15:08
459009 - Databus
                    Fault Frequency: 15
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:42
   VCID: 00597D404A8F2AB19FC2-8054
   Coding: 5BC7F7
   Coding: 02005D
   Light switch:
   Coding: 350000
   Coding: 80000D
   Occupant Detection:
          U017E 00 [009] - -
          [ECU for Pretensioner left no communication]
                    Reset counter: 168
                    Mileage: 32879 km
                    Date: 2018.01.08
                    Time: 14:20:24
   VCID: 7F5BFEBC37715549E638-802A
   VCID: 42DDB7480403F8A1C956-8016
16776962 - Databus
          [Airbag_01 communication error can_error_timeout]
                    Fault Frequency: 7
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:52
   VCID: 074B665C6FA11D89DE88-8052
   VCID: 78A915A0125F6271A772-802C
   ROD: EV_SCMDriveSideCONTIAU736.rod
   VCID: 75B71C94054D1F19BC54-8020
                    Reset counter: 146
                    Mileage: 32020 km
                    Date: 2017.12.21
                    Time: 17:58:15
                    Reset counter: 146
                    Mileage: 32020 km
                    Date: 2017.12.21
                    Time: 17:58:15
458752 - Databus
          [Airbag_01_missing_message]
                    Reset counter: 186
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:20
458797 - Databus
          [PreCrash_02_missing_message]
                    Reset counter: 186
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:22
   Revision: --------
   Coding: 0E8002
   VCID: 3431E1904EB746114BCA-8060
7 Faults Found:
1192158 - Databus
          [databus error value received - SARA_CF_Accel_X_r]
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1192162 - Databus
          [databus error value received - SARA_CF_Omega_Z_r]
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1192210 - Databus
          [databus error value received - ESP_Systemstatus]
                    Reset counter: 196
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:44
1192062 - Databus
          [databus error value received - PH_Systemzustand]
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:23
267010 - Databus
          [FAULT_SLAVE]
                    Fault Frequency: 17
                    Reset counter: 196
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:43
1183745 - Databus
          [databus message missing - SafetyComputer - Airbag]
                    Fault Frequency: 16
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:43
1183965 - Databus
          [databus message missing - SARA]
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:58
   ROD: EV_DCU2DriveSideMAXHCONT.rod
                    Reset counter: 184
                    Mileage: 31998 km
                    Date: 2017.12.20
                    Time: 16:31:15
524288 - Databus
          [Message airbag_01 missing]
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:47:02
524425 - Databus
          [Message PreCrash_02 missing]
                    Reset counter: 187
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:25
          B1317 01 [008] - Electrical Failure
                    Reset counter: 206
                    Mileage: 32425 km
                    Date: 2017.12.29
                    Time: 17:40:06
   VCID: 3E25C3B870FB9C41ADAE-806A
   ROD: EV_BCM2HellaAU736_010_AU49.rod
   VCID: 7DA704B43D7D4759F424-8028
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 3039ED80BAAF7A312F22-8064
   ROD: EV_DCU2PasseSideMAXHCONT.rod
524288 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:47:02
524425 - Databus
                    Reset counter: 187
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:25
                    Reset counter: 206
                    Mileage: 32428 km
                    Date: 2017.12.29
                    Time: 17:43:00
   ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
   VCID: 77AB169C1F416D09AE68-8022
9 Faults Found:
                    Reset counter: 140
                    Mileage: 31913 km
                    Date: 2017.12.19
                    Time: 12:24:10
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:57
          U1111 00 [008] - -
          [Interior light (0x08) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 188
                    Mileage: 32107 km
                    Date: 2017.12.22
                    Time: 20:44:54
          U1111 00 [008] - -
          [Garage door opener (0x14) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:30
          U1111 00 [008] - -
          [Reversible belt tensioner (0x1F) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 187
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:35:24
          U1111 00 [008] - -
          [Interior light (0x08) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 188
                    Mileage: 32107 km
                    Date: 2017.12.22
                    Time: 20:44:57
          U1111 00 [008] - -
          [Garage door opener (0x14) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:18:34
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 140
                    Mileage: 31913 km
                    Date: 2017.12.19
                    Time: 12:33:04
          U1111 00 [008] - -
          [Reversible belt tensioner (0x1F) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:50
   ROD: EV_CamSysRVRVCPANAMLBEv_004.rod
   VCID: 72BD27887423082199B6-8026
   ROD: EV_GSMWaehlZFAU736_VW53.rod
   VCID: 3537DC9445CD5F197CD4-8060
   ROD: EV_BVSMLBevKOSTAAU736.rod
   VCID: 3A2DCFA86CD3B0619186-806E
1123601 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 206
                    Mileage: 32783 km
                    Date: 2018.01.07
                    Time: 15:22:32
                    Control Module temperature: 33 °C
                    Voltage terminal 15: 15.10 V
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   ROD: EV_SunRoofCONTIAU736_004.rod
   Revision: --------
   Coding: 0E8002
   VCID: 313FE884B1A57339202C-8064
1192158 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1192162 - Databus
                    Reset counter: 196
                    Mileage: 32022 km
                    Date: 2017.12.22
                    Time: 10:01:09
1183745 - Databus
                    Fault Frequency: 16
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:43
1183965 - Databus
                    Reset counter: 187
                    Mileage: 31998 km
                    Date: 2017.12.21
                    Time: 09:46:58
   VCID: 16753B18380BB401551E-8042
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:43
                    Reset counter: 198
                    Mileage: 32471 km
                    Date: 2017.12.30
                    Time: 21:20:43
End----------(Elapsed Time: 02:11, VBatt start/end: 15.2V/15.2V)-----------
OK, we now see that much of that points at the airbag module, and that module is unhappy about a lack of comms with the Control Module for Seat Belt Tensioner; Front Left...
I would fix that first, then clear fault codes and see what comes back.
Molemans
C?ID=215708
Thanks for clarifying this error.
the front seatbelt tensioner was replaced with a used one.
I will perform a visual inspection of those 3 connectors at the tensioner.
Molemans
C?ID=215708
Thanks to Ross-Tech team help,
I resolved the "missing message" by performing these steps:
1-removed the driver (left) B pillar Trim
2-disconnected the seatbelt tensioner white terminal t5
3-checked for voltage between terminals 30 (-Battery) and 31 (-Battery)
4-found no voltage on terminal 30.
5- followed the wiring diagram and found a ST1 (10amp) fuse that was blown.
6-replaced it and cleared the missing message
below is the auto scan with just one issue
Tuesday,09,January,2018,20:23:52:49819
VIN:    License Plate:
Mileage: 32922km-20456mi   Repair Order:
VIN:     Mileage: 32922km-20456miles
   Revision: --H13---
Readiness: 1010 0101
   Coding: 000001
   Coding: 5BC7F7
   Coding: 02005D
   Light switch:
   Coding: 350000
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705C0218Q00881
   Coding: 80000D
   Coding: 80000D
   Occupant Detection:
                    Reset counter: 169
                    Mileage: 32922 km
                    Date: 2018.01.09
                    Time: 16:00:03
   Revision: --------
   Coding: 0E8002
          U1111 00 [009] - -
                    Reset counter: 169
                    Mileage: 32922 km
                    Date: 2018.01.09
                    Time: 16:00:08
   Revision: --------
   Coding: 0E8002
End----------(Elapsed Time: 02:04, VBatt start/end: 15.1V/15.0V)-----------
                    Reset counter: 169
                    Mileage: 32922 km
                    Date: 2018.01.09
                    Time: 16:00:03
Any idea how:
1/ perform a seat height calibration?
2/ Address 5F: Information Electr. (J794)
U1111 00 [009] - -
knowing the drive select is not available.
Thank you again
Molemans
C?ID=215708
any suggestions?
