Saturday,13,January,2018,20:34:40:49607
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4409.4
VIN: WUAZZZ8K9FA License Plate: MY CAR
Mileage: 54970km-34156mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 22 30 42 44 46 47 52
53 56 5C 5F 62 6C 6D 72
VIN: WUAZZZ8K9FA Mileage: 54970km-34156miles
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 E HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0003
Revision: NAH04---
Coding: 1225003225C6000A2000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560E 001002
ROD: EV_ECM42FSI0118T2907560E.rod
VCID: 3E24CED6D0FBA98768D-806A
Part No SW: 8T0 927 156 J HW: 0B5 927 156 K
Component: 0B5 42 FSIRdW H03 0005
Revision: --H03---
Shop #: WSC 06325 000 00000
ROD: EV_TCMDL501021.rod
VCID: 44D0BC3EBE17C3573E9-8010
Part No SW: 8T0 907 379 G HW: 8T0 907 379 G
Component: ESP8 quattro H09 0010
Coding: 342DEA
VCID: 46D4A63688ABF14720D-8012
Part No SW: 8K0 907 064 KG HW: 8K0 907 064 KG
Component: BCM2 2.0 H15 0711
Coding: 01924040000000000000
VCID: 7F5AF3D297F1608F23B-802A
Subsystem 1 - Part No SW: 8K0 959 754 CH HW: 8K0 959 754 CH
Serial number: 0815000031694002
Serial number: 3215000045160001
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01180320151752
Coding: 4804000000
VCID: 78A818CEB2DF57B7621-802C
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00001031426201
Coding: 0600001100349FF23D8140C3000019094F9DC70A23090201000008004400010200020034000000
Shop #: WSC 06325 123 12345
VCID: 7AAC02C68CD345A7145-802E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110315 H06 0080
Serial number: SWF15033115535
Coding: 00FD11
Component: G397_RLFS H06 0004
Serial number: 20191091
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Serial number: 00000000001603150284
Subsystem 4 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Serial number: AD698C97000000000001
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 C HW: 8K0 907 561 C
Component: ACC3 H11 0100
Coding: 003352
VCID: 323CEAE614237DE79C5-8066
Address 14: Susp. Elect. Labels: None
Part No SW: 8T0 907 376 HW: 8T0 907 376 A
Component: J250 DRC FahrwerH01 0030
Revision: 00000000 Serial number: 00875015797000
Coding: 0000000
Shop #: WSC 06435 000 00000
VCID: 7CA004DE8AE77B97069-8028
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H48 0610
Serial number: 003KFDC6KF7P
Coding: 30534435363030303030554A3052384B3053
VCID: 48C8A80E823FE737D21-801C
Serial number: 6334MSME4F1D005AL
Serial number: 6344MSME4F4C7740R
Serial number: 6352QSME7C570472L
Serial number: 6362QSME354E4B70Q
Serial number: 63732SME044E1566$
Serial number: 63832SME414B2870.
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372OCN000UE
Coding: 0000FF
VCID: 44D0BC3EBE97C3573E9-8010
Part No SW: 8K0 920 983 D HW: 8K0 920 983 D
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 67+5A3K3G
Coding: 33EF1100FF012600010000
VCID: 3634D6F6F84B61C7B0D-8062
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Revision: 1Z120030 Serial number: 3041Z153150177
Coding: 80E3031600
VCID: 4CC0941E96C70B17F69-8018
Serial number: 6313886003
Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
Component: DYNAMIKLENK. H06 0730
Revision: 52001005 Serial number: --------------
Coding: 030000
VCID: 392EDDCAC9558EBF5DF-806C
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H15 0100
Serial number: 000702150001023
VCID: 2F3AE3920791500FF3B-807A
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000121732
VCID: 2D06F99A0D1D221FC17-8078
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H10 0305
Coding: 011C02205C21410001
VCID: 56F47676580B41C750D-8002
Part No SW: 8K0 909 144 P HW: 8K0 909 144 B
Component: RCEPS H41 0510
Revision: 00001000 Serial number: 0027140810
Coding: 010001010001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
Revision: 00002001 Serial number: 0363426957
Coding: 013F0622A0B938948330023280000000
Subsystem 3 - Part No SW: 8K0 959 591 C HW: 8K0 959 591
Component: J245 PS151 H08 0043
Subsystem 4 - Part No SW: 8K0 959 591 C HW: 8K0 959 591
Component: J394 PS240 H08 0043
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813041891606
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H10 0305
Coding: 011C02205E21410001
VCID: 55F6717A450D4ADF597-8000
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 10000000518381
ROD: EV_ParkiBrake_VW51.rod
VCID: 3A2CC2C6CCD385A7545-806E
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109CR0F8024252
Coding: 010103010000000001
VCID: 2B02F78233092C2FDF3-807E
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 60021531800029
Coding: 0032201
VCID: 372ADBF2F34198CFABB-8062
Part No SW: 8R2 035 666 H HW: 8R2 035 666 H
Component: H-BN-EU H48 0897
Revision: -------- Serial number: 515CX0F7516612
Coding: 120101010306A9EF2D80CB5E00000403E40000020000000000
VCID: 3E24CED6D07BA98768D-806A
Subsystem 1 - Part No: 8R0 060 884 CH
Component: EUR 2014 2004
Component: DU7 High H42 0104
Serial number: A130CA0F3301104
Subsystem 3 - Part No SW: 8T0 919 611 M HW: 8T0 919 611 H
Serial number: 00000002167618
Component: CD-Database 5950
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H08 0305
Coding: 010C02204021210001
VCID: 59EE7D4A29156EBF7DF-800C
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-JA1904Y
Coding: 1021007
VCID: 3828D8CEFE5F97B7A21-806C
Part No SW: 8K9 827 851 C HW: 8K9 827 851 C
Component: J605 Master H53 0330
Revision: -------- Serial number: 8K9827851C
Subsystem 1 - Part No SW: 8K9 827 852 C HW: 8K9 827 852 C
Component: J756 Slave H53 0330
Serial number: 8K9827852C
Component: TSG HR H08 0305
End----(Elapsed Time: 02:20, VBatt start/end: 12.1V/11.8V. VIgn 11.8V)-----
