Results 1 to 10 of 16
Thread: 2000 Jetta Airbag Codes
    Jan 2018
    Hey guys,
    I have a couple airbag codes on my car that I cant get to clear. Any help pointing me in the right direction for what parts to check/change would be greatly appreciated!
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Control Module Part Number: 6Q0 909 605 A
    Component and/or Version: 09 AIRBAG VW5 0003
    Software Coding: 12345
    Work Shop Code: WSC 00066
    VCID: 3522FE480D262AEE72-4B5C
    Fault Codes have been Erased
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
    28-10 - Short to Plus - Intermittent
    32-10 - Resistance Too High - Intermittent
    00589 - Airbag Igniter 1; Passenger Side (N131)
    01217 - Side Airbag Igniter; Driver Side (N199)
    Check control unit for water ingress and clean if needed or replace if all wiring/sensors are in order.
    Check grounds for adequate ability to carry current.
    Nov 2014
    any history for the car accidents airbags replaced etc..
    Jan 2018
    Quote Originally Posted by raf0468 View Post
    no accidents no air bags replaced its a florida car has some rust under the dash looks like from salt in the air
    I have checked all the wiring under the seats and behind the 2 front air bags all looks good
    i swap the sensors from under the front seats and still have the same codes
    thanks
    Jan 2018
    swapped the sensors from under the 2 front seats have the same codes
    which ground wires are you referring to i have check all the obvious wires
    Please observe RTFB for WD and observe JPPSG guide.
    With sporadic codes such as this, I strongly reiterate..... I would seriously inspect the controller internally with a good visual inspection.
  7. #7
    Jan 2018
    which controller are you talking about
  8. #8
    0x15 Air bag
  9. #9
    Jan 2018
    i am sorry sir i don't know what 10x15 air bag means for me to do
  10. #10
    Nov 2014
  11. Likes Uwe liked this post
