Results 11 to 20 of 34
Thread: Winter in USA
    Administrator Andy's Avatar
    The e-tron is plugged in to recharge the 8.8kW battery to allow 16 miles (per EPA) of EV range.
    That's a 12 gauge extension cord that seems to be able to handle the ~1100 watts just fine. Unfortunately, even after running two 20 minute remote HVAC sessions, I still needed to do a bit of scraping:
    The main benefit to remote activation of the HVAC (via phone app) is to warm up the coolant with the Z115 PTC heater so that as soon as I actually get in the car to drive away, warm air comes out of the vents immediately. The eGolf goes one step further by having a heated windshield which the e-tron lacks. BTW, the charge rate through the "stenchin' cord" can't quite keep up with the power consumption of the Z115 so it does diminish range a bit. Still worth it.
  2. Likes jyoung8607, Uwe, NEtech, Eric, Boki Ar liked this post
  3. #12
    Verified VCDS User vreihen's Avatar
    Sep 2014
    The Land of OCC, NY, USA, Earth
    You need to install my "plug-in hybrid" heater into that thing.....
  4. Likes Boki Ar liked this post
  5. #13
    Is yours this one?
    https://www.harborfreight.com/12v-au...ght-60525.html
    The e-tron will turn on the HVAC in a binary fashion, it has whatever settings you last had before shutting off the ignition, so I need to get into the habit of having say, temp and fan on high with vents directed to the windshield. In the summertime, the opposite would apply, choose Max A/C before shutting down.
  6. Likes Uwe, Eric, Boki Ar liked this post
  7. #14
    Quote Originally Posted by Andy View Post
    It strikes me as silly that they have a smart-phone app that lets you turn the HVAC on or off, but not adjust the settings.
  8. Likes Boki Ar, PetrolDave liked this post
  9. #15
    Sep 2014
    I don't know about you, but I would NEVER leave anything purchased at HF plugged in unattended!
    https://www.caframolifestylesolution...ns/true-north/
    Made in Canada, eh, where they know a thing or two about cold weather.....
  10. Likes Uwe, jyoung8607, Boki Ar liked this post
  11. #16
    Quote Originally Posted by vreihen View Post
    I guess if you have an extension cord going to the car anyway....
  12. Likes vreihen, Boki Ar liked this post
  13. #17
    Sep 2014
    Sadly, I can't run the block heater and cab heater on the same long 12/3 cord. When set above stun, the heater above draws 1500 watts by itself. Add another 600 watts or so for the factory block heater, and it's game over even for a 20 amp outlet.
    I gave some serious thought to mounting a marine 30 amp shore power inlet through the front bumper, and then mounting two smart outlets in a two-gang box under the hood so that my home automation system could turn on the block/cab heaters individually as needed. (I only use the block heater at -15 C and colder, and the engine doesn't hesitate to start even at -20 C without the block heater.) I also thought about installing a self-retracting reel behind the bumper so that I could simply pull the cord out and plug it into a house outlet when I arrive home, but the Arctic Leash brand is way over-priced and no way am I going to use an HF retractable reel for that kind of current.....
  14. Likes Uwe, Boki Ar, Andy liked this post
  15. #18
    How about electrifying a winch? Very Alton Brown that way.
  16. Likes vreihen, Boki Ar liked this post
  17. #19
    It strikes me as silly that they have a smart-phone app that lets you turn the HVAC on or off, but not a dust the settings.
    Sadly several of the apps I use have similar gotchas of a really useful missing feature/option, you have to wonder whether some app developers actually try to use the app in real life?
  18. Likes vreihen, Uwe, Boki Ar liked this post
  19. #20
    Sep 2014
    I recently purchased a smart watch band EKG device. The included app did not have a way to save or exit the preferences screen! You don't need Captain Coredump (my alter-ego that embarrasses programmers and their silly mistakes for a living) to spot this one *long* before letting the app ship.....
  20. Likes PetrolDave, Boki Ar liked this post
