Results 1 to 3 of 3
Thread: Xenon and DRL for mk7 Golf 2014 Retrofit
    Verified VCDS User andreizx12's Avatar
    Nov 2015
    Romania
    Hello
    did someone replaced with success the normal headlight with the Xenon and DRL for Golf MK7 2014 ???
    What are the steps ?
    Thnk you
    Andrei
    Jan 2015
    Bosnia and Herzegovina
    yes, replace headlights and bcm and code, if you want to add AFS you need to replace gateway also
    May 2017
    And add control module and leveling sensor to the rear axle
    For MQB I would imagine it's a bigger task due to component protection on GW module, so not completely doable in your garage . On PQ35 (Golf 5/6) it was quite straightforward task.
  4. Likes Uwe liked this post
