New Jetta Mark V Sportwagen/ 5 speed
   #41
Tunacan406
C?ID=324267
understood.
   #42
PetrolDave
Westbury, UK
C?ID=1423
Log-NEW JETTA 1.0-3VWTZ71KX9M312054-160060km-99456mi-01.20.18
That's not the scan - that's the filename of the scan - you need to open the file, select all and copy the contents. Then paste it into a post, preferably betwee CODE tags - this is all explained in the link Uwe posted above...
   #43
Tunacan406
C?ID=324267
Saturday,20,January,2018,09:08:07:20071
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4409.4
Dealer/Shop Name: Accurate Garage
Workshop Code: 444 11757 000000
VIN: 3VWTZ71KX9M312054   License Plate: NEW JETTA 1.0
Mileage: 160060km-99456mi   Repair Order: 01.20.18
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 4F 52 56 62 65 72
VIN: 3VWTZ71KX9M312054   Mileage: 160060km-99456miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 N    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9202
   Revision: G6H02---    Serial number: VWX7Z0HD24D0I5
   Coding: 0000071
   Shop #: WSC 06413 444 04864
   VCID: 392FD0FE355D74BF5DF-806C
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 159966 km
                    Time: 03:18:15
                    RPM: 2737 /min
                    Load: 67.4 %
                    Speed: 64.0 km/h
                    Temperature: 84.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 1100
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0120
   Revision: 00H35001
   Coding: 113B400D492300FC880B02E9921D00413000
   Shop #: WSC 27844 001 1048576
   VCID: 76B51BC248C3DBC770D-8022
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 221
                    Mileage: 159966 km
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 51778
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A915FA4ED7ADB7621-802C
   Revision: 00H54000    Serial number: 00000001159632
   Coding: 148D8F2340041500070000001C000000000873075C000120000000000000
   VCID: 323DE7D2E82B87E79C5-8066
   Component: Wischer 171208 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Revision: 00000000    Serial number: AUZ4Z7H0493728
   Coding: 0000100
   VCID: 3333E2D617318EEF973-8066
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 41
                    Mileage: 63620 km
                    Time: 19:44:24
02617 - Satellite Antenna (R170)
                    Reset counter: 219
                    Mileage: 159868 km
                    Time: 21:42:45
                    Reset counter: 219
                    Mileage: 159868 km
                    Time: 21:42:45
02788 - Internal Communications Error
                    Reset counter: 219
                    Mileage: 159868 km
                    Time: 21:42:34
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
   Part No SW: 1K0 909 605 AC    HW: 1K0 909 605 AC
   Component: 0K AIRBAG VW8R  038 8600
   Revision: 07038600    Serial number: 003E7M08045K
   Coding: 0012363
   VCID: 6D8734AE3195181F817-8038
   Subsystem 2 - Serial number: 6332MSME42327A245
   Subsystem 3 - Serial number: 6342MSME43115154$
   Subsystem 4 - Serial number: 6351HSME1A495C02A
   Subsystem 5 - Serial number: 6361HSME1A0A0631%
   Subsystem 6 - Serial number: 63727SME18585246%
   Subsystem 7 - Serial number: 63827SME1A04212F$
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000032
   VCID: 035372160711FE6F473-8056
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0HD24D0I5
   Coding: 0007203
   Shop #: WSC 06413 444 52574
   VCID: 3C21C9EA3A6F4197469-8068
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 211008F1002477
   Coding: E9807F07000303002002
   VCID: 3829D5FA0E576DB7A21-806C
   Component: IMMO            3HL 1222
   Revision: 72009005    Serial number: 00000635189106
   Coding: 0001205
   VCID: 6FBB2EA63B99EA0FB3B-803A
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A0DFFB2C0FBCF27245-807E
   Coding: 139007885283281B0904058FB0880F0488DCA0
   VCID: 0451710A021FF9577E9-8050
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 14
                    Reset counter: 223
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 66954B8218632B47C0D-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
   Revision: 72009005    Serial number: 08102816332704
   Coding: 0001204
   VCID: 70B92DDA26A7F5F7AA1-8024
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2261681
   Coding: 0010400
   VCID: 290F00BEC5FDC43F2DF-807C
00856 - Radio Antenna
            014 - Defective
   Revision: 12006001    Serial number: 00000003684286
   Coding: 0001168
   VCID: 76B51BC244C3DBC770D-8022
   Coding: 0100101
   Revision: 12006001    Serial number: 00000003658547
   Coding: 0001168
   VCID: 77AB16C643C9A2CF6BB-8022
End----------(Elapsed Time: 01:30, VBatt start/end: 14.5V/14.5V)-----------
   #44
Tunacan406
C?ID=324267
had to select all then copy
   #45
Yay...........! /\
That's better!
FOD ?
In RED RUM below........
16490/P0106/000262 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
Possible Symptoms
  • Erratic Idle
Possible Causes
  • Wiring and/or Connections from/to Manifold/Barometric Pressure Sensor (G71)/(F96) faulty
  • Leak in Air Intake and/or Exhaust
  • Manifold/Barometric Pressure Sensor (G71)/(F96) faulty
  • Manifold/Barometric Pressure Sensor (G71)/(F96) wrong part installed, see notes.
  • Engine Control Module faulty
Possible Solutions
  • Check Engine Control Module Software Version
    • See Special Notes for Details
  • Check Timing
  • Check Wiring and/or Connections from/to Manifold/Barometric Pressure Sensor (G71)/(F96)
  • Check for Leak in Air Intake and/or Exhaust
  • Check/Replace Manifold/Barometric Pressure Sensor (G71)/(F96)
  • Check/Replace Engine Controle Module
Special Notes
  • On certain smaller Engines we've seen cases where a buggy Engine Control Unit Firmware can cause these fault codes, additionally there are known Problems with the Timing Chain Tensioners which can also result in these fault codes. Please refer to the related TPL/TSB for more instructions.
  • The F96 can be an internal part of the ECM.
2.5L Gasoline specific notes
  • Measuring block 201.3 appears to contain the F96 ECM Baro pressure sensor in the CBTA 2.5L in addition to older MAF equipped 2.5L engines such as the BGP. ST?ID=79232
  • On some 2.5L engines, there can be a Secondary Air Injection (SAI) sensor, G609. This sensor and the MAP sensor can have the same physical shape and be mixed up. MAP sensors will start with part number "03C" and SAI sensors will start with part number "07C".
  • When found in NAR (North American Region) 2011-2013 Jetta, Golf, Passat and New Beetle vehicles with 2.5L engine codes CBTA and CBUA see TSB 01-14-23 -or- TPI 2034012. When applicable, DTCs P050A, P0507 and P0106 are resolved after flash updating the Engine controller.
   #46
Tunacan406
C?ID=324267
I took it to VW. The N80 was failed. I let him change it. They would not cover the ECU flash. I am not up to speed on posting links to pics yet. When I get that sorted I'll show the proof of no coverage. Everything else is good for now.
Monday,22,January,2018,12:30:18:20071
VIN: 3VWTZ71KX9M312054   License Plate: NEW JETTA 1.1
Mileage: 160100km-99481mi   Repair Order: 01.22.18
VIN: 3VWTZ71KX9M312054   Mileage: 160100km-99481miles
   Component: 2,5l R5/4V      G   9971
   Coding: 0000071
   Revision: 00H35001
   Coding: 00038805
   Shop #: WSC 00066
   Coding: 0000100
            014 - Defective
                    Reset counter: 41
                    Mileage: 63620 km
                    Time: 19:44:24
                    Reset counter: 225
                    Mileage: 160088 km
                    Time: 23:26:47
                    Reset counter: 225
                    Mileage: 160088 km
                    Time: 23:26:47
                    Reset counter: 225
                    Mileage: 160088 km
                    Time: 23:26:36
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
   Coding: 0012363
   Coding: 0000032
   Coding: 0007203
   Coding: 0001205
   Revision: 00H15000
   Coding: 050B0500
   Coding: 0001204
   Coding: 0010400
            014 - Defective
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End----------(Elapsed Time: 01:29, VBatt start/end: 12.6V/12.5V)-----------
   #47
I am very interested in seeing.........or hearing about this! :popcorn:
images
Jef
HQ
Can you see this post?
   #49
Tunacan406
C?ID=324267
Here's the bill
Tunacan406
C?ID=324267
rOJSC
