- Joined
- Mar 29, 2014
- Messages
- 602
- Reaction score
- 625
- Location
- Wilkes-Barre, PA
- VCDS Serial number
- C?ID=7573
Was the oil cap sucked on? A little hard to pull off?
It should change RPM once removed because you cause an air leak removing it. Question is was it sucked on?
Does the check engine light come on when you turn key on before starting? Bulb check?
Log in to ECU go measuring blocks 032 what are the fuel trims? + or - 5% is good 10% or higher is bad.
Good Luck
Good Luck
