Hi. I bought this to service my small fleet of VWs. Sadly, right before Christmas a Drunk Driver came down the street and wrecked my '09 Sportwagen. Now the hunt begins to replace it.
I located a good copy 400 miles away and saw it yesterday. Since I'm new here I thought maybe I could get just a little feedback into the first important scan... A car I want to buy.
I have two other questions,
I've been looking at '09 Sportwagens for a few months and the one I'm interested in has an X in the VIN. No other one does either before or after this chassis number.
The other question is this: Where does one go to find out how many of a particular model was produced in any one model year. I'm looking for 2009 Sportwagens with the 2.5 and a M/T. They are rare and I'd like to know what I'm up against. Not as rare as a VR6 Wagon M/T but those are older. I'd like to be able to find all of this info.
Wednesday,03,January,2018,14:16:55:20071
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4409.4
VIN: 3VWTZ71KX9M312054 License Plate: NEW 4
Mileage: 158870km-98717mi Repair Order: 01.03.18
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 4F 52 56 62 65 72
VIN: 3VWTZ71KX9M312054 Mileage: 158870km-98717miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 N HW: 07K 906 055 M
Component: 2,5l R5/4V G 9202
Revision: G6H02--- Serial number: VWX7Z0HD24D0I5
Coding: 0000071
Shop #: WSC 06413 444 04864
VCID: 392FD0FE355D74BF5DF-806C
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 000 - Implausible Signal - Intermittent
Fault Frequency: 118
Mileage: 156695 km
Time: 20:19:55
RPM: 658 /min
Load: 23.1 %
Speed: 2.0 km/h
Temperature: 84.0°C
Temperature: 30.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.970 V
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Date: 2047.15.31
Time: 31:63:63
Load: 0.0 %
Temperature: 16.0°C
Temperature: 18.0°C
Voltage: 10.160 V
001287 - Idle Control System RPM
P0507 - 000 - Higher than Expected. - Intermittent
Mileage: 158786 km
Time: 23:03:09
RPM: 939 /min
Load: 16.9 %
Temperature: 84.0°C
Temperature: 32.0°C
Voltage: 13.843 V
008583 - Bank 1; System too Lean at Idle
P2187 - 000 - - Intermittent
Mileage: 158770 km
Time: 00:46:38
RPM: 811 /min
Load: 14.9 %
Speed: 14.0 km/h
Temperature: 90.0°C
Temperature: 43.0°C
Voltage: 13.716 V
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 113B400D492300FC880B02E9921D00413000
Shop #: WSC 27844 001 1048576
VCID: 76B51BC248C3DBC770D-8022
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78A915FA4ED7ADB7621-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001159632
Coding: 148D8F2340041500070000001C000000000873075C000120000000000000
Shop #: WSC 00066 000 00000
VCID: 323DE7D2E82B87E79C5-8066
Component: Wischer 171208 021 0501
Coding: 00038805
Shop #: WSC 00066
Revision: 00000000 Serial number: AUZ4Z7H0493728
Coding: 0000100
VCID: 3333E2D617318EEF973-8066
00003 - Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 41
Mileage: 63620 km
Time: 19:44:24
02617 - Satellite Antenna (R170)
Fault Status: 01101011
Reset counter: 203
Mileage: 158866 km
Time: 21:42:23
Reset counter: 203
Mileage: 158866 km
Time: 21:42:23
02788 - Internal Communications Error
Reset counter: 203
Mileage: 158866 km
Time: 21:42:12
Bin. Bits: 00000000
Bin. Bits: 00000001
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 0K AIRBAG VW8R 038 8600
Revision: 07038600 Serial number: 003E7M08045K
Coding: 0012363
VCID: 6D8734AE3195181F817-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME42327A245
Subsystem 3 - Serial number: 6342MSME43115154$
Subsystem 4 - Serial number: 6351HSME1A495C02A
Subsystem 5 - Serial number: 6361HSME1A0A0631%
Subsystem 6 - Serial number: 63727SME18585246%
Subsystem 7 - Serial number: 63827SME1A04212F$
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000032
VCID: 035372160711FE6F473-8056
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0HD24D0I5
Coding: 0007203
Shop #: WSC 06413 444 52574
VCID: 3C21C9EA3A6F4197469-8068
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 T HW: 1K0 907 951
Component: J533 Gateway H06 0071
Revision: H06 01 Serial number: 211008F1002477
Coding: E9807F07000303002002
VCID: 3829D5FA0E576DB7A21-806C
Component: IMMO 3HL 1222
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000635189106
Coding: 0001205
VCID: 6FBB2EA63B99EA0FB3B-803A
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A0DFFB2C0FBCF27245-807E
Coding: 139007885283281B0904058FB0880F0488DCA0
VCID: 0451710A021FF9577E9-8050
Address 4F: Centr. Electr. II (J533) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 050B0500
VCID: 66954B8218632B47C0D-8032
Subsystem 1 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Subsystem 2 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J394EE16SKB10 H01 0180
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08102816332704
Coding: 0001204
VCID: 70B92DDA26A7F5F7AA1-8024
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2261681
Coding: 0010400
VCID: 290F00BEC5FDC43F2DF-807C
00856 - Radio Antenna
014 - Defective
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003684286
Coding: 0001168
VCID: 76B51BC244C3DBC770D-8022
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003658547
Coding: 0001168
VCID: 77AB16C643C9A2CF6BB-8022
Reset counter: 243
Mileage: 158872 km
01554 - Motors for Central Locking; Rear Doors; Lock
Fault Status: 00101100
Reset counter: 243
Mileage: 158872 km
End----(Elapsed Time: 01:31, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
