Had the VW/Audi 3.0 TDI emission fix (ECR) performed on 11/22/17.
Since the fix was performed, "Address 01: Engine" keeps registering "38161 - ROD - Unknown Error Code"
Example Scan:
Example Scan:
Wednesday,03,January,2018,16:47:55:59648
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 17.8.1.0
VIN: WA1LMAFEXDD****** License Plate: POST FIX CHK ENG
Mileage: 113050km-70246mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 42 46 47 4C 4F 52 55
56 5F 62 69 6C 6D 6F 72
VIN: WA1LMAFEXDD013230 Mileage: 113050km-70246miles
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI FSA H21 0012
Revision: 54H21--- Serial number:
Coding: 2A2A4012253600050000
Shop #: WSC 46818 001 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 224B8EF93526F156A7-8076
- 00 [237]
Mileage: 111891 km
Date: 2017.12.10
Time: 12:23:17
Engine speed: 2184.00 /min
Normed load value: 80.0 %
Vehicle speed: 90 km/h
Coolant temperature: 86 °C
Intake air temperature: 6 °C
Voltage terminal 30: 14.400 V
Outside air temperature: 2.0 °C
Pressure sensor for reducing agent: measured pressure: 5104 hPa
SCR catalytic converter average temperature: 245.1 °C
Sensor for reducing agent tank temperature: temperature: 13.3 °C
Reducing agent pump: activation: 50.00 %
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 002 3399
Coding: 001378
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002.rod
VCID: 7BF5939DF20C609EC4-802E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099441
Shop #: WSC 31414 790 00001
VCID: 346778A157D26FE645-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702049174
Coding: 0000131
VCID: 254195E5EC08066EC2-8070
Subsystem 1 - Part No: 4F0 910 132 J
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0054
01176 - Key
Reset counter: 11
Mileage: 112408 km
Date: 2017.12.21
Time: 09:29:06
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AP
Revision: 00---031 Serial number: 00000030274399
Coding: 0304A036
VCID: 254195E52C08066EC2-8070
Part No SW: 4F0 910 279 AH HW: 4F0 907 279 D
Component: ILM Fahrer H31 0400
Coding: 0039123
VCID: 6FEDB7CD7E740C3E78-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
010 - Open or Short to Plus
Fault Status: 01111010
Reset counter: 240
Mileage: 111672 km
Date: 2017.12.08
Time: 16:28:00
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961306500406
Coding: 25011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 346778A19FD26FE645-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH44 0230
Revision: 08H44000 Serial number: 0038QD0C2WBL
Coding: 0014131
VCID: 2B5563DD8AEC301E14-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME78294A4EX
Subsystem 3 - Serial number: 6342QSME3C2B4344J
Subsystem 4 - Serial number: 6352QSME07243C58I
Subsystem 5 - Serial number: 6362QSME78291C64R
Subsystem 6 - Serial number: 63734SME66284B5AA
Subsystem 7 - Serial number: 63834SME662850680
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H08000 Serial number: 90026130200099
Coding: 0002242
VCID: 285F9CD19B1A1B06F9-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q
Component: KOMBIINSTR. H35 0317
Revision: 00000000 Serial number: VJ450M73E
Coding: 8BD764040100CF05020205
VCID: 428B2E79DD66D156C7-8016
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 R HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0058
Revision: LB600036 Serial number: 3600L132210272
Coding: 00C303
VCID: 3E735A89A99EB5B6A3-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 40060J01544120270835
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Revision: 00---011 Serial number: 00000030274167
Coding: 0000006
VCID: 68DFDCD15B9ADB0639-803C
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000052682777
Coding: 00581300000011110000
VCID: 326B7EB96DC661D657-8066
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000054208788
Coding: 011F07205E40440004
VCID: 489F3C51FB5AFB0619-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01922799520000
Coding: 3570077
VCID: 387F4C914BBA8B8669-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004000 Serial number: 00000000017619
Coding: 030000
VCID: 295999D54010220EE6-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190078359
Coding: 0758477
VCID: 23458BFDE23CF85EAC-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000135975
Coding: 0012001
VCID: 5EB3FA0989DE95B6C3-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000050596381
VCID: 479D3F6DF644F47E10-8012
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 130228-0004-122
Coding: 1147A71010020400
ROD: EV_HeadlRegulBasic.rod
VCID: 428B2E79D566D156C7-8016
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156CO0D7701410
Coding: 020007010000000000
VCID: 244788E12732FF66D5-8070
Part No SW: 4L2 035 746 G HW: 4L2 035 746 A
Component: H-BNT-NA H44 0901
Revision: -------- Serial number: 224C$0D7518585
Coding: 180200060004E3EF410023456F632003140000000100000000
Subsystem 1 - Part No: 8R0 060 884 CS
Component: NAR 2015 1201
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130C-0D2670997
Subsystem 3 - Part No SW: 4L0 919 614 B HW: 4L0 919 614 B
Component: E0380 Bedient H01 0060
Serial number: 00000002097712
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000053459995
Coding: 010E07204040230004
VCID: 46833269F14EED76EB-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000192828906
Coding: 0200000000000000
VCID: 316971B568C05ACE2E-8064
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H07--- Serial number: 525PA8-J3240I0
Coding: 1021201
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD7A0C14F62F7265D-8038
ó
Subsystem 3 - Serial number: RD02.03.13--H57001002G0024ÿ
Subsystem 4 - Serial number: 2G0024ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 131038889-----
Coding: 0003851
VCID: 264392E9910E0D76CB-8072
Component: J_245_EE16_SKB10H14 0220
Component: J_394_EE16_SKB10H14 0220
Component: J_392_EE16_SKB10H14 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000053460106
End-------------------------(Elapsed Time: 04:16)--------------------------
