Results 1 to 3 of 3
Thread: VW golf mk5 2.0 bkd engine j500 no communication
    New User
    Dec 2017
    Hi guys replaced the abs pump and now traction light is on and yellow steering wheel light is on and steering wheel is heavy scan attached is the abs pump coded wrong thx
    Tuesday,02,January,2018,22:57:20:31334
    VCDS Version: 17.8.1.0
    VIN: WVWZZZ1KZ5W031990   License Plate: FD54 BBV
    Mileage: 173630km-107888mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: WVWZZZ1KZ5W031990   Mileage: 173630km-107888miles
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 016 FM    HW: 028 101 190 3
       Component: R4 2,0L EDC 0000SG  6179
       Revision: 12345678    Serial number: VWZ7Z0D0099082
       Coding: 0000072
       Shop #: WSC 01279 785 00200
       VCID: 73E5A8D912CF4EDE9C-8026
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 000 - Signal too Low - Intermittent
                        RPM: 819 /min
                        Torque: 64.0 Nm
                        Duty Cycle: 96.0 %
                        Bin. Bits: 11000100
                        Mass Air / Rev.: 365.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    Readiness: 1 1 0 0 0
       Revision: 00H11001
       Coding: 0023170
       Part No: 1K0 907 044 AB
       Component: ClimatronicPQ35 066 0404
       VCID: 67DDCC895617B27E30-8032
    00576 - Terminal 15
    00229 - Refrigerant Pressure
    00926 - Terminal 30
       Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
       Component: Bordnetz-SG 1.0 H30 0704
       Revision: 00030000    Serial number: 00000000798685
       Coding: E5890F0600041800001400001400000000
       VCID: 408F371513F9A546D1-8014
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 005  0605
       Coding: 00217125
    00834 - Signal for Activation of Heated Rear Window
                009 - Open or Short to Ground
    01064 - Terminal 58d; Interior Dimming
       Part No SW: 1K0 909 605 D    HW: 1K0 909 605 D
       Component: 02 AIRBAG VW8   022 0600
       Revision: 05022000    Serial number: 0033JD0F5TZ-
       Coding: 0012338
       Shop #: WSC 01268 785 00200
       VCID: 2D517EA1B46B582E0A-8078
       Subsystem 1 - Serial number: 6332MSME12084803
       Subsystem 2 - Serial number: 6342MSME6A767203
       Subsystem 3 - Serial number: 6351HSME5D4E7702
       Subsystem 4 - Serial number: 6361HSME58457A02
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000012
       VCID: 306F67D5A35935C621-8064
       Part No: 1K0 920 961 B
       Component: KOMBIINSTRUMENT VDD 0814
       Coding: 0003403
       Shop #: WSC 00581 210 64475
       VCID: 29598AB18083440EE6-807C
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2600104608041D
       Coding: 3D3F0B40070003
       VCID: 275D8C899697727EF0-8072
                        Reset counter: 165
                        Mileage: 173635 km
                        Time: 14:24:52
       Component: IMMO            VDD 0814
       Shop #: WSC 00999 444 64523
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0148
       Coding: 0000052
       Part No: 1K2 909 144 G
       Component: EPS_ZFLS Kl.3       1301
    02546 - Steering Limit Stop
                        Mileage: 3600 km
                        Temperature: 16.0°C
                        Voltage: 13.10 V
                        Voltage: 12.90 V
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 81C802087F2D8505485FC69010
       VCID: 7BF580F93A9F069EC4-802E
       Subsystem 1 - Part No: 1K0 951 605 A
       Component: LIN BACKUP HORN H01 1201
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    01134 - Alarm Horn (H12)
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 316962D1A8533CCE2E-8064
       Part No: 1K0 035 186 L
       Component: Radio BVX       140 0022
       Coding: 0040402
       Shop #: WSC 00014 210 88527
       VCID: 2F6D64A9BE672A3E38-807A
    00856 - Radio Antenna
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 C
       Component: Tuersteuergeraet 06 0202
       Coding: 0000016
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 C
       Coding: 0000016
       Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
       Revision: 00700000    Serial number:
       VCID: 2C5773A58F7151261D-8078
                014 - Defective
    End-------------------------(Elapsed Time: 02:03)--------------------------
    Strange. The Steering Assist module clearly does communicate, since it shows up in your scan.
    What was the part number and coding of the old ABS module?
    New User
    Dec 2017
    part number is 1KO 907 379 K pre scan attached
    Saturday,30,December,2017,23:35:29:31334
    VIN: WVWZZZ1KZ5W031990   License Plate: FD54BBV
       Coding: 0000072
    Readiness: 0 0 1 1 1
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0023170
       VCID: 3A7B45FD7525FF969F-806E
       Coding: 00065493
       Coding: 00217125
       Coding: 0012338
       Coding: 0000012
       Coding: 0003403
    01176 - Key
       Coding: 0000052
       Coding: 0000052
       Coding: 0040402
       Coding: 0000016
       Coding: 0000016
                014 - Defective
    End-------------------------(Elapsed Time: 02:08)--------------------------
  4. Likes Uwe liked this post
