Results 1 to 7 of 7
Thread: 01179 - Incorrect Key Programming 000 - - Problem
    Jan 2018
    I bought a 2009 JSW and it came with one key. I ordered a new one from a very reputable non-dealership. I took the key to the dealer to get it programed to the car. They were able to get the key programed, but not program the locks. I called the company I bought it from and talked to them about it. They were very helpful and sent me out two more chipsets and the VAG-COM cable to program it myself. I have attempted several times following the directions exactly. I have un-programmed my original key and programmed it back, so I know its correct. The problem is that I cannot get it programmed either nor with the other chipsets. Any ideas on where to start?
    The main faults are: 2 Faults Found:
    Reset counter: 103
    Mileage: 193729 km
    Time: 11:08:07
    007 - Short to Ground
    Fault Status: 01100111
    Reset counter: 103
    Wednesday,27,December,2017,21:22:00:42304
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(VMWare)
    VCDS Version 17.8.1.0 (x64)
    VIN: 3VWTZ71K39M306841 License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 4F 52 56 62 65 72
    VIN: 3VWTZ71K39M306841 Mileage: 193760km-120396miles
    Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
    Part No SW: 07K 906 055 M HW: 07K 906 055 M
    Component: 2,5l R5/4V G 9971
    Revision: G6H02--- Serial number: VWX7Z0HN24L06P
    Coding: 0000075
    Shop #: WSC 14250 002 1048576
    VCID: 387F40F54BF6CB8669-806D
    Part No SW: 09G 927 750 JE HW: 09G 927 750 JE
    Component: AQ 250 6F 1377
    Revision: 00H76000 Serial number:
    Coding: 0000840
    VCID: 7DF191E124542EAEFA-8029
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 113B400D49220000881302E8921A00413000
    VCID: 74E7B4C5D71E6FE685-8021
    Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
    Component: Climatic PQ35 142 1212
    Revision: 00142032 Serial number: 00000000000000
    VCID: 78FF80F50B760B86A9-802D
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
    Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
    Revision: 00H54000 Serial number: 00000001136266
    Coding: 148D8F2340041000070000001C000000000873075C00012000 0000000000
    VCID: 326B72DDAD8A21D657-8067
    Component: Wischer 251108 021 0501
    Coding: 00038805
    Shop #: WSC 00066
    Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
    Component: SDAR SIRIUS H07 0150
    Revision: 00000000 Serial number: AUZ4Z7H0479380
    Coding: 0000100
    VCID: 336577D9529028DE5C-8067
    Fault Frequency: 26
    Reset counter: 49
    Mileage: 192417 km
    Time: 07:11:56
    Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
    Component: 78 AIRBAG VW8R 034 8000
    Revision: 05034000 Serial number: 003B6M085B9W
    Coding: 0014136
    VCID: 6CD7ACA54F2EB7265D-8039
    Subsystem 2 - Serial number: 6332MSME41332D412
    Subsystem 3 - Serial number: 6342MSME42712F29E
    Subsystem 4 - Serial number: 6351HSME190D0D35B
    Subsystem 5 - Serial number: 6361HSME190D172DE
    Subsystem 6 - Serial number: 63727SME19434D4A8
    Subsystem 7 - Serial number: 63827SME19606366+
    Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
    Component: J0527 052 0111
    Coding: 0001032
    VCID: 020BE21D5DAA515687-8057
    Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
    Component: KOMBIINSTRUMENT 3HL 1222
    Revision: V0003000 Serial number: VWX7Z0HN24L06P
    Coding: 0007203
    Shop #: WSC 12345 067 57207
    VCID: 3C775CE57FCEE7A68D-8069
    Part No SW: 1K0 907 530 R HW: 1K0 907 951
    Component: J533 Gateway H06 5063
    Revision: H06 01 Serial number: 191108F2000116
    Coding: ED807F070003032002
    VCID: 36634ECD41E23DF67B-8063
    Component: IMMO 3HL 1222
    Shop #: WSC 58770 001 1048576
    Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
    Component: J386 TUER-SG FT 1519
    Revision: 72009005 Serial number: 00000769389106
    Coding: 0001205
    VCID: 6FEDBBA97E384C3E78-803B
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 70 2301
    Revision: 00H15000
    VCID: 2A5B6ABD855A6916EF-807F
    Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
    Component: KSG PQ35 RDK 052 0221
    Revision: 00052000 Serial number: 00000000000000
    Coding: 139007885283281B0904058FB0880F0488DCA0
    VCID: 0407E40547BE5F66B5-8051
    Reset counter: 103
    Mileage: 193729 km
    Time: 11:08:07
    Reset counter: 103
    Address 4F: Centr. Electr. II (J533) Labels:. 1K0-907-532.clb
    Part No SW: 1K0 907 532 HW: 1K0 907 951
    Coding: 050B0500
    VCID: 66C3DE8D91C28D760B-8033
    Subsystem 1 - Part No SW: 8R0 959 591 HW: 8R0 959 591
    Component: J245EE16SKB10 H01 0180
    Subsystem 2 - Part No SW: 8R0 959 591 HW: 8R0 959 591
    Component: J394EE16SKB10 H01 0180
    Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
    Component: J387 TUER-SG BT 1519
    Revision: 72009005 Serial number: 08081618263701
    Coding: 0001204
    VCID: 70EFB8D5630653C661-8025
    Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
    Component: Radio DE2 016 0020
    Revision: 00016000 Serial number: VWZ4Z7H2256643
    Coding: 0010400
    VCID: 295995B1805C620EE6-807D
    00856 - Radio Antenna
    00003 - Control Module
    014 - Defective
    Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
    Component: J388 TUER-SG HL 1401
    Revision: 12006001 Serial number: 00000003668396
    Coding: 0001168
    VCID: 76E38ECD01627DF6BB-8023
    Component: RDK 0450
    Coding: 0100101
    Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
    Component: J389 TUER-SG HR 1401
    Revision: 12006001 Serial number: 00000003636253
    Coding: 0001168
    VCID: 77FD83C9066804FEA0-8023
    End-------------------------(Elapsed Time: 02:09)--------------------------
    If you've un-programmed your original fob and re-programmed it again, then VCDS and the car are doing what they are supposed to be doing. That really only leaves the aftermarket fobs as the potential source of the problem, right?
    Jan 2018
    I thought the same and so did the supervisor for where I bought them from. However the other two chipsets he sent me also didn't work. Maybe a bad batch, but having 3 not work seems odd.
    Thanks for registering. We will get your user account flipped to "Verified" so this can be moved to Car Repair Support.
    In the meanwhile it sounds like the aftermarket sourced remote(s) are either wrong or defective. PL24 shows "1K0 959 753 P" so your functional (original) remote should have that part number printed on it. If the aftermarket sourced remotes have VW part numbers on them make sure they are P suffixes.
  5. Likes Uwe liked this post
    Jan 2018
    These are the chips I have. The single is the original.
    I can't help you with that but the part number on the plastic housing is a P suffix so that confirms the parts catalog is correct. Personally, I'd just get a pair of used 1K0 959 753 P remotes and hope both are in good working order.
    Jan 2018
    Thanks. I think that might be only option.
