Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: B6 Passat PLA 2.0 retrofit
    Mar 2015
    Australia
    Hi All,
    First post with my shiny new Hex V2 interface
    I'm in the process of trying to finish off what should be a fairly straight forward retrofit - PLA 2.0.
    I've installed the new side sensors front and rear, routed the new wiring and installed the new PLA module.
    I can't for the life of me however get the new front side sensors to work...rears seem OK in that they don't log any faults but I can't actually test them yet.
    Wondering if anyone has had a similar issue or otherwise any ideas as I'm now at a bit of a dead end.
    I have routed new power, ground and signal wires to bypass the existing and new harnesses.
    Confirmed power at the connectors with a multimeter.
    If I disconnect the new front side sensors I get exactly the same open/short to ground error as if they are plugged in.
    If I connect the side front sensor pins to other working sensors, I still have open/short to ground on side front sensors.
    I have tested one of the new sensors in the place of an existing front sensor, and it looks like it works fine.
    The new sensors are part number 1T0919297A.
    I have tried software upgrading the PLA module to 1K8919475E however got the same sensor errors.
    I've quadruple checked the pinouts (front side assist sensors are connected to T18/2 and T18/13)
    At this point the only thing I haven't tried is replacing the PLA module as the only other one I have is the older 8 channel PDC module.
    Autoscan below, its not fully configured for park assist in terms of coding and adaptation of ABS, steering rack etc but I am just trying to get the sensors working firstly for OPS.
    Monday,01,January,2018,13:30:29:58930
    VCDS Version: 17.12.0.1 (x64)  HEX-V2 CB: 0.4411.4
    Data version: 20171213 DS285.1
    VIN: WVWZZZ3CZ9E08   License Plate:
    Mileage: 116040km-72103mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 36 42 44 46 47 52 53
              55 5F 62 65 6C 6D 72
    VIN: WVWZZZ3CZ9E08   Mileage: 116040km-72103miles
    Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 906 032 AM    HW: 03H 906 032 AB
       Component: R3.6-FSI-EU4    F   3488
       Revision: 5GH04---    Serial number: VWZCZ000000000
       Coding: 0000175
       Shop #: WSC 52104 002 1048576
       VCID: 6D87377FB19F9D494484-8038
       Part No SW: 02E 300 012 E    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1903
       Revision: 04844002    Serial number: 00000810231260
       Coding: 0000024
       Shop #: WSC 05311 000 00000
       VCID: 127D4483C861E2B13976-8046
    Address 03: ABS Brakes        Labels: None
       Part No SW: 3AA 698 109 N    HW: 3AA 614 109 AL
       Component: J104   C2 450M VE1F 0042
       Revision: --H07---    Serial number: 00000007379684
       Coding: 0119716
       Shop #: WSC 11111 111 45799
       VCID: 44D1B2DBC295BC01FB6A-8010
       Part No SW: 3AD 907 044 G    HW: 3AD 907 044 G
       Component: Climatronic   H03 0404
       Coding: 0031040004
       Shop #: WSC 12345 123 61029
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 372BD5178FC3E7996EE8-8062
    13701424 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Bordnetz - kein Signal/Kommunikation]
                        Reset counter: 31
                        Mileage: 116043 km
                        Date: 2018.01.01
                        Time: 13:26:18
       Revision: 00H54000    Serial number: 00000009027172
       Coding: 668E8F0700041A00470000001E000000000B79435C400120000000000000
       Shop #: WSC 12345 123 00000
       VCID: 3333E107973B0BB952C0-8066
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 100908 022  0601
       Coding: 00047029
       Shop #: WSC 12345
       Component: RLS     121108 054  0402
       Coding: 00208936
       Shop #: WSC 12345
       Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0480
       Revision: --------    Serial number: 39431711102403
       Coding: 0121167011
       ASAM Dataset: EV_EPHVA2CVW364GP00 001010
       ROD: EV_EPHVA2CVW364GP00_VW36.rod
       VCID: 3B23C927B3EBC3F98A90-806E
    1111572 - Side Front Left Parking Aid Sensor
              B10F6 14 [009] - Open or Short to Ground
                        Reset counter: 31
                        Mileage: 116043 km
                        Date: 2018.01.01
                        Time: 13:26:48
    1112852 - Side Front Right Parking Aid Sensor
              B10FB 14 [009] - Open or Short to Ground
                        Reset counter: 31
                        Mileage: 116043 km
                        Date: 2018.01.01
                        Time: 13:26:48
    13639168 - Databus
              [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                        Reset counter: 31
                        Mileage: 116043 km
                        Date: 2018.01.01
                        Time: 13:26:18
    Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
       Part No SW: 3AA 907 567 A    HW: 3AA 907 567
       Component: AC201  RDW A    036 0170
       Revision: 00036000    Serial number: 00000000569541
       Coding: 0010000
       Shop #: WSC 00046 000 00000
       VCID: 3829D62B8E5DE8E167F2-806C
       Part No SW: 5N0 959 655     HW: 5N0 959 655
       Component: J234__00S VW10 HI   1815
       Revision: 19013000    Serial number: 0039BPMPB81T
       Coding: 0012371
       VCID: 7AAD0C23F0D13AF1D106-802E
       Subsystem 1 - Serial number: 6333FTS665962908
       Subsystem 2 - Serial number: 6343FTS632552888
       Subsystem 3 - Serial number: 6353ETS6NTCKVVNR
       Subsystem 4 - Serial number: 6363ETS640PKVVNR
       Part No SW: 3C5 953 501 BM    HW: 5K0 953 569 T
       Revision: FF010041    Serial number: 20160725000799
       Coding: 199AA50003
       VCID: 71BF2B0FA12779A960AC-8024
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0036
       Coding: 830000
    Address 17: Instruments (J285)       Labels:. 3C8-920-xxx-17.clb-SRI1
       Part No SW: 3AA 920 881     HW: 3AA 920 881
       Component: KOMBI         H03 0705
       Coding: 711F01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1682
       Revision:   H56       Serial number: 110114F2000857
       Coding: 462007
       VCID: 7BA30927F3EB03F9CA10-802E
       Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
       Component: Haldex 4Motion      4013
       Coding: 0000005
       Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
       Component:    IMMO         052 0407
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 12345 123 2097151
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
       Component: Sitzverstellung     1101
       Revision: 00005000    Serial number: 00000000000000
       VCID: 2F3BED777B132F593618-807A
       Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1518
       Revision: 71009005    Serial number: 00000691888917
       Coding: 0005047
       VCID: 71BF2B0FADA779A960AC-8024
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 143    3501
       Revision: 00H15000
       VCID: 392FD32FB557F1E998FC-806C
       Component:    KSG PQ47 ELV 052 0638
       Coding: 00900A00D1034E7F000694157008DFCE607801
       Part No SW: 3C0 035 456 F    HW: 3C0 035 456 F
       Component: DSP 10 Kanal        0013
       Revision: 00010000    Serial number: 00000000002780
       VCID: 2313114727DB9B39A2A0-8076
       Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1518
       Revision: 71009005    Serial number: 00000649588929
       Coding: 0005046
       VCID: 72BD2403A8A142B199B6-8026
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000248887
       Coding: 0022157
       Shop #: WSC 05311 000 00001
       Component: AFS-Steuergeraet    0136
       Coding: 2344193
       VCID: 3431E21B92350C814BCA-8060
       Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000035
       Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Coding: 00000035
       Part No SW: 5C0 035 680 E    HW: 5C0 035 680 E
       Component: MU-S-ND-ER    H31 0363
       Serial number: VWZAZ2T5074914
       Coding: 027404080000000011111105440908001F0100D671F087003E
       ROD: EV_MUStd4CTSAT_VW21.rod
       VCID: 231311472B5B9B39A2A0-8076
       Subsystem 1 - Part No SW: 3G0 919 866 BM    HW: -----------
       Component: MRM2 2018  --- 0915
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000699648
       Coding: 0000144
       VCID: 70B92E0BA6AD70A16FA2-8024
       Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0011
       Serial number: 40000000055443
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30_005.rod
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
       Component: VW428 RVC Mid H04 0040
       Coding: 01130608A201000700
       Shop #: WSC 02572 003 1048576
       ASAM Dataset: EV_CamSysRearPANAVW428 002002
       ROD: EV_CamSysRearPANAVW428.rod
       VCID: 3039EE0B6AAD30A12F22-8064
    10489856 - No Basic Setting
              B2010 00 [009] -  -
              [RearView system not calibrated]
                        Reset counter: 31
                        passive
       Part No SW: 3C9 827 383 F    HW: 3C9 827 383 F
       Component: J605  HECKDECKEL    0720
       Revision: 00H27001
       Shop #: WSC 05311 000 08193
       Subsystem 1 - Part No: 3C9 827 384 F
       Component: J756  HECKDECKEL    0720
       Subsystem 2 - Serial number: 0800H27001001B0148˙
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000693593
       Coding: 0000144
    End----(Elapsed Time: 01:53, VBatt start/end: 12.1V/12.1V. VIgn 11.9V)-----
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
    May 2017
    You cannot have the sensors or even wiring connected at all if you don't have suitable PLA module. Either you don't have the wiring at all or you have the wiring + sensors + correct PLA module available.
    Your 8ch OPS module does not support PLA side sensors. That is also the reason why you don't see any problems from the rear sensors because your OPS module does not even know they exist. It needs a newer PLA2.0 module minimum for it to even register the new rear side sensors.
    Why have you coded cross traffic alert to the system when you don't have it? You need blind spot radars for that.
  3. Likes Uwe liked this post
    Mar 2015
    Australia
    Sorry if my post was a little confusing...
    I have a PLA 2.0 module.
    It is a Golf 7 module cross-flashed with Passat software:
    I'm not concerned about the cross-traffic error I have not fully coded or set adaptations for PLA yet as I firstly need to have all 12 sensors properly functioning.
    May 2017
    Aa, ok Sorry did not get that.
    Ok then, you have the PDC and PLA buttons also installed? I think those were also required.
    Do you have the wiring diagrams for the sensors?
    Mar 2015
    Australia
    Yes, I have the B7 centre console including the PLA and PDC buttons.
    The buttons work in sense that they engage the relevant functions, but they error out.
    I have checked over the wiring diagrams many many times to try and find a problem with my pinouts but I'm sure they are correct.
    I am using an adapter harness to go from the car's 3x connectors for PDC to the 2x (T18 and T26) required for the 5Q0 PLA module.
    However I have bypassed this adapter harness for the front side park assist sensors (they connect directly into the PLA module) but still I have the same issue.
    I have ordered a new PLA module as it's the only way I could prove that the module itself is not faulty.
    Jan 2018
    Sweden
    Hi
    Are you using Chinese front side sensors.
    I have experienced the same thing on two cars when used upgrading kits from Ali Express.
    Changed only the two longer front side sensors to used original sensor then everything worked.
    First time I also ordered an new PLA unit but it did not help.
    Peter
  8. Likes Dana liked this post
    Mar 2015
    Australia
    Quote Originally Posted by Peter-tech View Post
    Hi
    Peter
    Yes as a matter of fact they are!
    Can I ask you what part number sensors you used to replace them?
    Thank you for sharing your experience
    I have spent so much time going over the same things time and again trying to find the cause...
  10. #8
    May 2017
    I had similar experiences with Aliexpress PLA kit. In my case the PLA button was incorrectly wired.
  11. Likes Dana liked this post
  12. #9
    Jan 2018
    Sweden
    Quote Originally Posted by kamold View Post
    I used as it is stated in the spare part catalogue 1T0919297A.
    That sensor is very common on Audi and can be found on Ebay.
    You can find new ones on Ebay also but I recommend used original sensors. The new on Ebay can be China clone also.
    Peter
  13. Likes Dana liked this post
  14. #10
    Mar 2015
    Australia
    My new PLA module arrived and as suspected it did not resolve the issue.
    Awaiting arrival of some new sensors from Germany which should wrap this up hopefully.
  15. Likes Uwe liked this post
