Results 1 to 2 of 2
Thread: Enable Subwoofer Volume Control in MMI for 2017 S3 with B&O Audio
    Nov 2017
    It looks like the option to control the subwoofer volume was missing from some of the 2017 S3 models. I've read conflicting reports on Audiworld forms of some cars with the B&O system having this control and others not. Mine does't, and I was hoping I could enable it with VCDS. Is this possible?
    Auto-scan of my car is here:
    Thursday,16,November,2017,12:58:52:54079
    VCDS Version: 17.8.0.1  HEX-V2 CB: 0.4407.4
    VIN: WAUF1GFF2H1024900   License Plate:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
              55 5F 6C A5 A9 BB BC CF
    VIN: WAUF1GFF2H1024900   Mileage: 9115km-5663miles
    Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 0A1D00122466010E3004
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
       ROD: EV_ECM20TFS0208V0906259K_AU37.rod
       VCID: 48C9A6C0B23EC8B7D3A-801C
       Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H54 4939
       Revision: 06354004    Serial number: TFK01608301919
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021_VW37.rod
       VCID: 53F381AC7B787B6FB68-8006
       Part No SW: 8V0 907 379 B    HW: 8V0 907 379 B
       Component: ESC           H25 0610
       Revision: 00000000    Serial number: 62196000000078
       Coding: 31AA6B7D549B13AD899A0B644191698CD62AC891D0829676184150D482A812
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
       ROD: EV_Brake1UDSContiMK100IPB_035_AU37.rod
       VCID: 43D3B1EC8B18EBEF068-8016
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0415639588
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_002_VW37.rod
       VCID: 3B23C90CF3E8932F4E8-806E
       Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
       Component: AC Automat    H03 0110
       Revision: 20001000    Serial number: 00000001039180
       Coding: 03000014010000001000000000001400
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
       VCID: 40D9BEE09A0EF0F71BA-8014
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: 99880A4800PAG0MUFU03
       Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H34 0236
       Serial number: 02001624000706
       ROD: EV_BCMBOSCH_017_VW27.rod
       VCID: 7EA50018A07A4607296-802A
       Component: WWS371 160625  043 0585
       Serial number:         160706063013
       Coding: 0A47F7
       Serial number: 62220658
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Serial number: 27 06 2016  00001188
       Serial number: 00000000000036269984
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST0015O28400000
       Coding: 101F00
       Part No SW: 5QA 919 294     HW: 5QA 919 294
       Component: PDC 8 KanalH07 0031
       Serial number: 000308418616249
       Coding: 0470155811
       ASAM Dataset: EV_EPHVA18AU3700000 009027
       ROD: EV_EPHVA18AU3700000.rod
       VCID: 094F63C4E9B471BF0C4-805C
       Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
       Component: ACC BOSCH MQB H10 0571
       Coding: B50087C219FFC42474988055000026
       ASAM Dataset: EV_ACCBOSCHVW416 001005
       ROD: EV_ACCBOSCHVW416_001_VW37.rod
       Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
       Component: DAEMPFUNGS-SG H09 0072
       Serial number:       010816012
       ASAM Dataset: EV_AudiMagneRide 002003
       ROD: EV_AudiMagneRide_002_AU37.rod
       Serial number: 003GCR0617M8
       Coding: 9DCCFCC0000000005000001AC24800000065
       Shop #: WSC 46101 001 1048576
       VCID: 47CBA5FCBF20C7CFDA0-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34230167A15091651290
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34230168A15091651527
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001J2UD+
       Coding: 303334
       Subsystem 4 - Part No SW: -----------    HW: 480 001 009 16
       Serial number: 3570000000011A685D1H
       Subsystem 5 - Part No SW: -----------    HW: 480 001 009 16
       Serial number: 3580000000080A685D1O
       Subsystem 6 - Part No SW: -----------    HW: 480 401 409 16
       Serial number: 3510001BB225A8C48535
       Subsystem 7 - Part No SW: -----------    HW: 480 401 409 16
       Serial number: 3520001B5225A8C462F7
       Subsystem 8 - Part No SW: -----------    HW: 480 400 408 16
       Serial number: 3550002A72095062A2F/
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 400 408 16
       Serial number: 3560002A52095064E29$
       Part No SW: 8V0 953 521 KT    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 27071604400332
       Coding: E818
       VCID: 167538B8A80AAE47916-8042
       Part No SW: 8V0 920 890     HW: 8V0 920 890
       Component: FBenUSA       H13 0045
       Coding: 08CD18537F98CF050281E8001800000000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001023
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 7AAD0C08BC526A2715E-802E
       Revision: --------    Serial number: 12091610520857
       Coding: 030100043F085A005B00827CB80B00000001010000000000000000000000
       ROD: EV_GatewConti_013_VW37.rod
       VCID: 7CA10A10B6665417072-8028
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20160909204358 22280
       Serial number: 75410803001609081421
       Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7755
       Serial number: HA1-00012.08.16
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
       VCID: 45D7AFF4852CD5DF28C-8010
       Revision: 00000000    Serial number: 16000154592001
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_004_VW37.rod
       VCID: 3431E230DEB65C578F2-8060
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0410
       Revision: --------
       Coding: 04C002
       ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
       VCID: 392FD304F9D4A13F5C4-806C
       Serial number: 280716EGR2466A
       Coding: 005D1B205C00048000000003
       Coding: 9107
       ROD: EV_SteerAssisMQB_013_VW37.rod
       VCID: 3A2DCC08FCD2AA2755E-806E
       Part No SW: 81A 035 466     HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0100
       Revision: 00000001    Serial number: AUZ8ZAGHX0092E4
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       VCID: 629D546834C282E72DE-8036
       Serial number: 190716EGI13134
       Coding: 005D13205E00048000000003
       VCID: 42DDB4E89402E2E70DE-8016
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0EE2021123200400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E25C018E0FA8607696-806A
       Part No SW: 8V1 035 880     HW: 8V1 035 880
       Component: MU-P-LNS-US   052 0694
       Serial number: A702H0G7514053
       Coding: 017351020000000011220002041A00102F0027E5017001047E
       VCID: 77AB153C8F40774F6A0-8022
       Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
       Component: NAR 2017/2018  --- 0060
       Component: DU High  H49 0014
       Serial number: AUZ8Z9GY207MJS
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
       Component: ControlUnit_H  H85 0855
       Serial number: ALJAL119071600010617
       Component: Gracenote2---  --- 3009
              B11CF 53 [009] - Deactivated
                        Reset counter: 3
                        Mileage: 7334 km
                        Date: 2017.08.01
                        Time: 16:05:36
                        Voltage terminal 30: 14.1 V
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
       Coding: 0273010102002001400040
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 29081612K20568
       Coding: 0403070100000201012223468048490080000E200020
       ROD: EV_MFKBoschMQBB_VW36.rod
       Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
       Serial number: 160825200167
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Revision: J388
       Coding: 000C13204000048000000002
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       Serial number: 020916DHV10819
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
       Revision: --------
       Coding: 04C002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
       VCID: 3635D838C8CA4E47B16-8062
    End----(Elapsed Time: 02:23, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
    May 2017
    Edit : Sorry, missed the sound system module.
    Short answer, not possible with VCDS. You need to re-parameterize the unit and VCDS cannot do it.
