Disable front parking sensors? (2013 Sharan)
myvcds
Sweden
I need to disable the front parking sensors on my MY13 VW Sharan. I have fitted extra driving lamps which trigger the front sensors. Any way I can switch them off through VCDS? I have the VW factory MMS system with both front/rear sensors and back camera. Anyone?
PetrolDave
Westbury, UK
C?ID=1423
We'll need a full Auto-Scan to be able to answer that question, so that we can see what module hardware and firmware is fitted to your Sharan.
myvcds
Sweden
Thanks, I’ll get one off and post it. Cheers
Viking
C?ID=151455
Just run the autoscan, save the result, and then post the complete log. random screen shots of various parts are not what's asked for.
myvcds
Sweden
OK.
I have run the auto-scan in full, but I cannot access the saved file on the cloud - I am trying to fix it, but for now I have collated together the full scan report as screenshots. These are not random this time, but the full log back to back. I hope this can give the information needed.
[/url][/IMG]
[/url][/IMG]
[/url][/IMG]
[/url][/IMG]
[/url][/IMG]
[/url][/IMG]
[/url][/IMG]
:banghead:
When you finish an Auto-Scan, use the [SAVE] button at the bottom.
Then from the top menu [View Saved Files]. Copy & paste text from your browser.
myvcds
Sweden
Here’s the copied link - how can this point a browser anywhere?
Log-WVWZZZ7NZDV026845-auto_3.log
From the main menu in VCDS-Mobile, click [View Saved Files]. This will take you to a page that shows every scan and log file that has been saved locally, on your HEX-NET, and each one is a link, that will open the file in question in your browser.
myvcds
Sweden
Finally, I figured it out. Here it is;
VCDS Mobile 0.4323.0.4
VIN: WVWZZZ7NZDV026845
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 25 2B 2E 37 42 44 46 4C
	 4F 52 53 55 56 61 62 6C 6D 72 BE BF
BE-Sliding Door Left -- Status: Malfunction 0010
BF-Sliding Door Right -- Status: Malfunction 0010
Address 01: Engine  (CFFB J)	Labels: 03L-906-018-CFF.clb
	Part No SW: 03L 906 018 HJ	HW: 03L 907 309 Q
	Component: R4 2,0L EDC   H28 9957
	Revision: 44H28---
	Coding: 001D001A042401080000
	Shop #: WSC 00020 999 00000
	ASAM Dataset: EV_ECM20TDI01103L906018HJ 003010
	ROD: N/A
	VCID: 79B57EE76B18DA243DBD37BFCB-802C
	No ASAM data for: "EV_ECM20TDI01103L906018HJ"
No fault codes found.
Address 02: Auto Trans	Labels: 02E-927-770.lbl
	Part No SW: 02E 300 058 J	HW: 02E927770AL
	Component: GSG DSG AG6     512  3502
	Revision: 05651213	Serial Number: 00001212080920
	Shop #: WSC 00020 000 90108
	VCID: 21057687A308FAE4554D6F9F53-8074
Address 03: ABS Brakes	Labels: 7N0-614-109.clb
	Part No SW: 7N0 614 109 P	HW: 7N0614109P
	Component: J104   C3 450M VD1F  0030
	Revision: --H07---	Serial Number: 00000006217149
	Coding: 0027162
	Shop #: WSC 00020 790 00000
	VCID: 3A37A1EB2E9E893C744780AB16-806F
Address 05: Acc/Start Auth.  (J518)	Labels: 5K0-959-434.clb
	Part No SW: 5K0 959 434 C	HW: 5K0 959 434
	Component: VWKESSYPQ35GP 091 1101
	Revision: 00091000
	Coding: 03100C
	Shop #: WSC 00020 999 39850
	ROD: N/A
	VCID: 352DB2D70780FE4499154B6F57-8060
	No ASAM data for: "EV_KESSYPQ35G"
Address 08: Auto HVAC  (J255)	Labels: 5K0-907-044.clb
	Part No SW: 7N0 907 044 H	HW: 7N0 907 044 H
	Component: Clima-Sharan  H01 0202
	Revision: 00001K03
	Coding: 0210104549
	ROD: N/A
	No ASAM data for: "EV_ClimatronicSharan"
9473393 - ROD - Unknown faultcode
9473649 - ROD - Unknown faultcode
Address 09: Cent. Elect.  (J519)	Labels: 1K0-937-08x-09.clb
	Part No SW: 5K0 937 086 M	HW: 5K0 937 086 M
	Component: BCM PQ35 M    021 0068
	Revision: BC021001
	Coding: 40590A3B8925F3C0508804C07400096443D51408676D2DB2E4848720A2C1
	VCID: 3E3FADFB32B6251C486FACFBCA-806B
	Subsystem 1 - 	Part No SW: 7N1-955-119-A	Labels: 1Kx-955-119.clb
	Component: WWS    12111731  0032
	Coding: 004DBD
	Subsystem 2 - 	Part No SW: 7N0-955-559	Labels: 7N0-955-559.clb
	Component: RLFS         021 0024
	Coding: 0280BB
	Subsystem 3 - 	Part No SW: 7N0-951-171-A
	Component: DWA-Sensor 00002 0206
	Subsystem 4 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
01259 - Fuel Pump Relay (J17)
	009 - Open or Short to Ground
Address 10: Park/Steer Assist  (J446)	Labels: 1Q0-919-475.clb
	Part No SW: 7N0 919 475 A	HW: 7N0 919 475
	Component: PARKHILFE 8K  H06 0012
	Revision: --------
	Coding: 308101
	ASAM Dataset: EV_EPHVA18VW4280000 001005
	ROD: N/A
	VCID: 3935BEE72B981A247D3D77BF0B-806C
	No ASAM data for: "EV_EPHVA18VW4280000"
Address 15: Airbags  (J234)	Labels: 5K0-959-655.clb
	Part No SW: 7N0 959 655 C	HW: 7N0 959 655 C
	Component: VW10Airbag00A H11 0014
	Coding: 003041
	ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
	ROD: N/A
	VCID: 3FC1D0FF35BC34144379B9E7D5-806A
	No ASAM data for: "EV_AirbaVW10TS6VW428"
	Subsystem 1 - 	Part No SW: ----
	Component: S.Sens.Fahr.V--- ---
	Serial Number: 3493ETS60010754179DE
	Subsystem 2 - 	Part No SW: ----
	Component: S.Sens.Beif.V--- ---
	Serial Number: 3503ETS609D574717DD
	Subsystem 3 - 	Part No SW: ----
	Component: S.Sens.Fahr.H--- ---
	Serial Number: 3513ETS601A0854179DI
	Subsystem 4 - 	Part No SW: ----
	Component: S.Sens.Beif.H--- ---
	Serial Number: 3523ETS60336247179DG
Address 16: Steering wheel  (J527)	Labels: 5K0-953-569.clb
	Part No SW: 5K0 953 569 AL	HW: 5K0 953 569 AL
	Component: LENKS.MODUL   016 0162
	Revision: --X01---
	Coding: 1102240000
	Shop #: WSC 18438 002 1048576
	ROD: N/A
	VCID: 8247990B86CE19FCEC17980B7E-80D7
	No ASAM data for: "EV_VW360SteerWheelUDS"
Address 17: Instruments  (J285)	Labels: 5K0-920-xxx-17.clb
	Part No SW: 7N0 920 880 C	HW: 7N0 920 880 C
	Component: KOMBI         H06 0505
	Coding: 140F01
	ROD: N/A
	VCID: 33298CCF09F4E074B701357779-8066
	No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
Address 18: Aux. Heat	Labels: 1K0-815-007.clb
	Part No SW: 7N0 963 272 C
	Component: Standheizer     044  4840
	Revision: 00044000	Serial Number: 09024302000000
	Coding: 0031142
	VCID: 352DB2D70780664499154B6F57-8060
00664 - Fuel gauge
01408 - Under-Voltage Shut-Off (fixed Value)
Address 19: CAN Gateway  (J533)	Labels: 7N0-907-530-V2.clb
	Part No SW: 7N0 907 530 AH	HW: 7N0 907 530 AH
	Component: J533  Gateway H50 1634
	Revision:   H50
	Coding: 468002
	VCID: 76AF75DB5A06AD5C509F149BE2-8023
Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
	Part No SW: 5K0 953 234	HW: 5K0 953 234
	Component: IMMO          H06 0505
	Coding: 000007
	ROD: N/A
	VCID: EA97D1AB9EBEE1BC442710EB06-80BF
	No ASAM data for: "EV_Immo_UDS_VDD_RM09"
Address 2B: Steer. Col. Lock  (J764)	Labels: 5K0-905-861.clb
	Part No SW: 5K0 905 861 C	HW: 5K0 905 861 C
	Revision: 00000000
	Coding: 4900000000000000
	ROD: N/A
	VCID: 302383C3F8E2DB6CCAE3125390-8065
	No ASAM data for: "EV_ELVMarquMPVW36X"
Address 2E: Media Player 3  (J650)	Labels: 5N0-035-342.lbl
	Part No SW: 5N0 035 342 F	HW: 5N0 035 342 F
	Component: SG EXT.PLAYER H19 0550
	Revision: A1001003
	Coding: 020100
	VCID: 2A1791ABDE3EB9BC04A7D0EBC6-807F
Address 37: Navigation  (J794)	Labels: 1K0-035-27x-37.clb
	Part No SW: 3C8 035 279 A	HW: 3C8 035 279 A
	Component: RNS315-EU
	Coding: 0400041104000D0000069002
	ROD: N/A
	VCID: 29156EA7DB38AAA40D9DC7FFFB-807C
	No ASAM data for: "EV_RNS315EUV2UDS"
Address 42: Door Elect, Driver  (J386)	Labels: 7N0-959-793.clb
	Part No SW: 7N0 959 793 G	HW: 7N0 959 793 G
	Component: TSG FA        H03 0553
	Revision:
	Coding: 01112E209000411011
	VCID: 46CFC51B6A667DDC00BF045B72-8013
Address 44: Steering Assist	Labels: 5N1-909-144.clb
	Part No SW: 5N1 909 144 P	HW: 5N1909148J
	Component: J500__APA-BS KL.325  1202
	Revision: 1BH04737	Serial Number: 00123490061201
	Coding: 0000258
	VCID: 3FC1D0FF35BCAC144379B9E7D5-806A
Address 46: Failed to respond
Address 4F: Centr. Electr. II  (J520)	Labels: 1K0-907-532.clb
	Part No SW: 7N0 907 532	HW: 7N0 907 530 AH
	Component: EZE_2         H50 1634
	Revision:   H50
	Coding: 050B0500
	VCID: EFA1C0BFA55C1C9413594927C5-80BA
	Subsystem 1 - 	Part No SW: 8R0-959-591-A
	Component: J245EE20SKB13H04 0220
	Subsystem 2 - 	Part No SW: 8R0-959-591-A
	Component: J394EE20SKB13H04 0220
Address 52: Door Elect, Pass.  (J387)	Labels: 7N0-959-792.clb
	Part No SW: 7N0 959 792 G	HW: 7N0 959 792 G
	Component: TSG BF        H03 0553
	Revision:
	Coding: 01112C209E00411011
	VCID: 45CDC217576076C409B5FB2F67-8010
Address 53: Parking Brake	Labels: 3AA-907-801.clb
	Part No SW: 3AA 907 801 H	HW: 3AA907801H
	Component: J540 EPB4  VW-86594  0010
	Revision:   H19   	Serial Number: 00000000651905
	Coding: 0024167
	VCID: 362FB5DB1A866D5C901F549B22-8063
Address 55: Xenon Range  (J745)	Labels: 5M0-907-357-V3.clb
	Part No SW: 5M0 907 357 F	HW: 7L6 907 357 C
	Component: AFS-ECU       H04 0111
	Revision: --------
	Coding: 058200000B000200
	ROD: N/A
	VCID: 3731B8DF1D8C0C548B2961872D-8062
	No ASAM data for: "EV_HeadlRegulVWAFSPt"
Address 61: Battery Regul.  (J840)	Labels: 1K0-907-534.clb
	Part No SW: 7N0 907 534	HW: 7N0 907 530 AH
	Component: Batt.regelung H50 1634
	Coding: 030F1859
	VCID: F1A5C6C7B3680A64056D5F5FA3-80A4
	Subsystem 1 - 	Part No SW: 1K0-915-181-H
	Component: J367-BDM     H07 0180
Address 62: Door, Rear Left  (J388)	Labels: 7N0-959-794.clb
	Part No SW: 7N0 959 794 H	HW: 7N0 959 794 H
	Component: TSG HL        H01 0553
	Revision:
	Coding: 01006C200000411001
	VCID: 48D3CB2360726BACF2D31A7348-801D
Address 6C: Back-up Cam.	Labels: 5N0-907-441.clb
	Part No SW: 7N0 907 441	HW: 7N0907441
	Component: J772__Rearview       0020
	Revision: 00H11000	Serial Number: 525 PA8J2Z0370
	Coding: 0020011
	VCID: EE9FDDBBA256959C184F3C3BFA-80BB
Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
	Part No SW: 7N0 959 107 E	HW: 7N0 959 107 A
	Component: HDSG-Modul    H11 0243
	Revision: 41011001
	Coding: 0733334002
	ASAM Dataset: EV_HDSGVW428 201138
	ROD: N/A
	No ASAM data for: "EV_HDSGVW428"
Address 72: Door, Rear Right  (J389)	Labels: 7N0-959-794.clb
	Component: TSG HR        H01 0553
	Revision:
Address BE: Sliding Door Left  (J558)	Labels: 7N0-959-244.clb
	Part No SW: 7N0 959 244 A	HW: 7N0 959 244 A
	Component: Schiebetuer_l 005 2314
	Shop #: WSC 00000 000
	ASAM Dataset: EV_AST A03704
	ROD: N/A
	No ASAM data for: "EV_AST"
041221 - ROD - Unknown faultcode
041222 - ROD - Unknown faultcode
049155 - ROD - Unknown faultcode
Address BF: Sliding Door Right  (J731)	Labels: 7N0-959-244.clb
	Component: Schiebetuer_r 005 2314
	ROD: N/A
myvcds
Sweden
Anyone got any clues if I can disable these damn front sensors???
PetrolDave
Westbury, UK
C?ID=1423
How about looking at the coding/adaptation of [10] Park/Steer Assist to see if there is a coding/adaptation option for rear sensors only?
myvcds
Sweden
Great. Sounds logical - where and how the hell do ’we’ do that?
golfi_vend
Tartu, Estonia
C?ID=195131
You can't disable. You need to buy 4K module with only rear sensors.
myvcds
Sweden
Ok. Is that expensive? Easy to install and configure?
myvcds
Sweden
Guess this is the part?
GENUINE VW AUDI SEAT SKODA OPS CONTROL MODULE 4K REAR 7E0 919 475 T / 7E0919475T
