Results 1 to 7 of 7
Thread: 2008 GTI (Canadian) - TPMS import to USA
    New User
    Dec 2017
    San Diego, USA
    Question 2008 GTI (Canadian) - TPMS import to USA
    My new wife (Canadian) and I are in the middle of a few stressful issues.
    K1 (marriage) immigration to USA for her, 9 month old boy, and trying to import her 2008 Canadian GTI only to find out that TPMS is required.
    From what I gather, her GTI has ABS and ESP. A VIN search at https://vpic.nhtsa.dot.gov/ show that "Active TPMS" is null.
    We are really hoping that the indirect TPMS can be turned on with VCDS, but I'm unsure how to confirm whether it is possible .
    I have an 05 Golf TDI and 93 Eurovan so I have a shop that might be able to help with the VCDS to turn on the TPMS. But I want to be informed and know what I'm talking about, at least slightly.
    Is there a particular model/part number of ABS that would verify that TPMS can be turned on? Or would a full AutoScan and post here allow some benevolent dictator to confirm?
    This car TPMS issue is really stressing my wife out (and me too)... her GTI is in great condition with ridiculously low miles... plus I love driving it too.
    Any advice greatly appreciated!
    New User
    Dec 2017
    San Diego, USA
    My little boy is not and issue... haha. Whoops. That sounded wrong. I'll blame that on lack of sleep.
    Although some ABS modules were capable of supporting TPMS back then, the algorithms in them weren't sophisticated enough to meet all the US regulatory requirements, most likely the requirement that it detect a condition where all the tires are under-inflated equally. So all the US cars that had TPMS back then used a direct system....
    Vru, Estonia
    I would say adding tpms to mk5 is too simple to stress about it.
    Change CCM and add sensors. Do the coding and should be enough.
    Autoscan would be helpful.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  5. Likes Uwe liked this post
    New User
    Dec 2017
    San Diego, USA
    Ughh. Well, Ive got an appt to get an Autoscan and find out more about the ABS tomorrow. Ill post back what I find.
    New User
    Dec 2017
    San Diego, USA
    I wish I felt unstressed about it. From what you are saying, it sounds easy. But I see that there are many different CCMs for MK5s. And is there any concern that a USA spec CCM might cause an issue with a Canadian spec vehicle?
    If you know what part number for the correct CCM or can advise me where/who to ask to spec it, I would be very grateful.
    As for sensors, I see some like this that would presumably work with the CCM. https://www.amazon.com/dp/B009YWG2RA
    I will post Autoscan results tomorrow.
    New User
    Dec 2017
    San Diego, USA
    A bit more info. We used the change noted by BlakH00 in this thread
    Following the change, the TPMS indicator shows on the dash when turning the key before starting.
    Yet, I took the GTI to the dealer, and he said that their scanner isn't picking up on it. I don't know what scanner he is using, and he didn't want to be advising code changes to a customer. Does anybody know if VW dealers typically use an inhouse scan tool and what it is? He did state that in CAN Gateway, Coding/Long, #19, that a checkbox for TPMS should be checked in order for his scanner to see TPMS as active.
    Maybe the procedure (above) I used doesn't check that box. I will investigate, but I thought I'd share.
    Any advise or input greatly appreciated...
    The Scan after change.
    Friday,29,December,2017,11:36:49:49819
    VCDS Version: 17.8.1.0
    VIN: WVWEV71K88W168445   License Plate:
    Mileage: 107460km-66772mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56
    VIN: WVWEV71K88W168445   Mileage: 107460km-66772miles
       Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0GN3N67YR
       Coding: 0403010A18070160
       Shop #: WSC 01279 785 00200
       VCID: 366302674185E6F67B-8062
    008577 - Performance Malfunction in Cooling System
                   P2181 - 008 -  - Intermittent
                        Mileage: 106103 km
                        Time: 02:03:52
                        RPM: 3159 /min
                        Load: 39.6 %
                        Speed: 108.0 km/h
                        Temperature: 75.0C
                        Temperature: 24.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.351 V
       Revision: 00H11001
       Coding: 0004738
       VCID: 73E5FB731277B3DE9C-8026
       Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
       Component: ClimatronicPQ35 130 1212
       Revision: 00130022    Serial number: 00000000000000
       VCID: 78FFCC5F0B11D086A9-802C
       Revision: 00H54000    Serial number: 01000007715840
       Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
       Shop #: WSC 91511 999 72883
       VCID: 71E9F17B686B81CE6E-8024
       Component: Wischer 071107 021  0501
       Coding: 00038805
       Shop #: WSC 91511
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7G0179201
       VCID: 2E532A07B9D5DE3633-807A
                        Fault Frequency: 20
                        Reset counter: 182
                        Mileage: 104495 km
                        Time: 13:35:22
       Component: 6L AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D09VZWB
       Coding: 0013900
       Shop #: WSC 01269 785 00200
       VCID: 6CD7E00F4F496C265D-8038
       Subsystem 1 - Serial number: 6332MSME315748627
       Subsystem 2 - Serial number: 6342MSME31530F087
       Subsystem 3 - Serial number: 6352QSME42232131
       Subsystem 4 - Serial number: 6362QSME446E0A0FV
       Subsystem 5 - Serial number: 63727SME107C4807%
       Subsystem 6 - Serial number: 63827SME0F1F2E61F
       Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
       Component: J0527           036 0070
       Coding: 0002022
       VCID: 75E1C56B1C03ADEEB2-8020
       Part No SW: 1K6 920 874 A    HW: 1K6 920 874 A
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0GN3N67YR
       Coding: 0007303
       Shop #: WSC 19410 444 98964
       VCID: 3169317BA8EBC1CE2E-8064
       Component: J533__Gateway   H15 0180
       Revision:   H15       Serial number: 1400K07A27014F
       Coding: E9811F060013020000
       VCID: 306F347FA3E1C8C621-8064
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T28PM03
       VCID: 7DF1DD4B2433F5AEFA-8028
       Component: IMMO            VDD 1216
       Component: Tuer-SG         006 1207
       Coding: 0001077
       VCID: 387F0C5F4B91108669-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.074 H08 1901
       Shop #: WSC 00000 028 00001
       VCID: 3561056B5C83EDEE72-8060
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Coding: 939006885103281B0904058FB0080A0488BC00
       Shop #: WSC 00000 785 00200
       Coding: 0001076
       VCID: 3979095B709B098E96-806C
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74E7F86F1779B4E685-8020
       Component: Radio PM6       130 0037
       Revision: 00130000    Serial number: VWZ5Z7I2297042
       Coding: 0040401
       Shop #: WSC 39612 828 149130
       VCID: 2959D91B803BB90EE6-807C
                        Reset counter: 33
                        Mileage: 107460 km
                        Time: 11:44:21
    End-------------------------(Elapsed Time: 02:02)--------------------------
