Results 1 to 8 of 8
Thread: Bentley GT 2007 W12 Oil Pressure Switch 2
    Dec 2015
    South Wales, UK
    Only got the one GT in at the moment so I can't double check on another car.
    Just wondering if the engine oil pressure switch can read 'low' at idle without there being a problem with the engine?
    Instruments Group 1 Block 3.
    On idle it will read low but as soon as you raise the engine revs even slightly it will switch to OK.
    The oil pressure warning does not come on and there are no fault codes stored that are relating to it. No noises/rattles at idle.
    I put a new switch in to be on the safe side but this is reading the same way. <min at idle. OK as soon as revs are raised.
    I haven't changed the oil or filter yet. Just wondering if I'm chasing dragons or not?
    The customer says that the low oil pressure warning did come on two or three times over the period of about a month / 6 weeks. He added a couple of liters of oil ( which I sucked out to bring the level back to normal ) and he thought that had cured it.
    I took it for about a 90 min test drive but no lights, no codes.
    Is this normal? What oil do people prefer or feel gives better oil pressure?
    Thanks in advance guys.
    Seasons greetings and a happy new year to you all.
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by Bentley View Post
    If memory serves, yes that's possible. Check the repair manual for this engine, for the test/replacement procedure for the oil pressure switch. I believe you'll find a documented specific RPM level where the instrument cluster wants to see the high result, and below that, the low result is acceptable. That's from memory, and I don't recall the RPM threshold for my W12, and it might be different for the twin-turbo W12.
    If this engine wants the same oil as my Phaeton W12 (please do double-check this), it'll want a 5w40 oil meeting the VW 502.00 specification. This is a pretty common spec. A 0w40 oil would also be very acceptable, and you can find those meeting 502.00. There are also 0w30 oils that meet 502.00 but I would not run those in an expensive engine that has a history of low oil pressure alarms. I don't have a comprehensive list of brands handy, nor do I know what's available in the UK, but over here, Castrol or Mobil 1 have easy-to-find products in those weights and specifications.
    Silence gives consent.
  3. Likes Uwe liked this post
    Please post an auto-scan......
    Always JPPSG and ref RTFB, further there are no substitution for mechanical tests to be done with a gage & especially when sensors or sumps are in question.
    Low PSI at idle could be an indicator of thinned out oil & with fuel contamination or foaming from over filling all of which are FOD.
    Changing the oil and doing mechanical tests would be the best advice & considering the expense of the car.
    Depending on age and wear or temperature/environment conditions, sometimes a thicker oil is better for a specific region.
    Dec 2015
    South Wales, UK
    Thanks guys for the fast replies,
    The Bentley kit for oil pressure testing is 3k . . . . I am looking for an adaptor for my analogue gauge set.
    The Manual says 1.2 to 1.6 bar at 1000 RPM which it is achieving easily according to the switch. (assuming the only reference I can find to the pressure for the switch which is 1.2 to 1.6 bar is correct) The manual also says that if the oil pressure is under 1.2 bar - replace engine!
    With no warning at idle I assumed that the car is looking at revs and oil pressure switch to decide if there was actually a problem (and hoping that it had not just been disabled).
    It is coming up as oil pressure 2 on VCDS but I have not found another switch listed anywhere.
    The Oil and filter were genuine VW. The switch was genuine from Bentley.
    I will do an oil & filter a full scan and post it later.
    Cheers.
    Dec 2015
    South Wales, UK
    Autoscan. cheers guys.
    The oil pressure warning has not come on, driven it for a few hours.
    Autoscan below.
    Also wanted to say that I've loaded VCDS onto a Samsung Book Windows tablet and it all went very smoothly and worked straight away.
    Easier to handle and transport than my laptop.
    Also the Laptop would not Autoscan. Every maybe 30 seconds or so the Laptop has trouble communicating with the lead / car. I think it may be clashing with the VW supplied diagnostics or interface. It only started to happen after I installed them both.
    Anybody got any thoughts on the reversing camera not communicating?
    Cheers, Paul.
    Thursday,11,January,2018,16:25:36:65184
    VCDS Version: 17.8.1.0 (x64)
    VIN: SCBCG43W6AC064272   License Plate: TIM
    Mileage: 84850km-52723mi   Repair Order:
    Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
              37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
    VIN: SCBCG43W6AC064272   Mileage: 84850km-52723miles
    Address 01: Engine (   )       Labels: None
       Part No SW: 07C 906 018 GH    HW: 07C 906 018 HE
       Component: BY - 6.0 L - TT G  6524
       Revision: --H03---    Serial number: VWX3Z0I3875503
       Coding: 0001075
       Shop #: WSC 11111 772 31874
       VCID: 71E9B4E06B57BACE6E-5124
       Part No SW: 09E 927 760 AF    HW: GS1 9.1 1.7
       Component: ZC3J1215  6L W12TT  1215
       Revision: --H04---    Serial number:        0004833
       Coding: 0000111
       Shop #: WSC 00083 790 00000
       VCID: 74E7BDF414458FE685-5140
    Address 03: ABS Brakes        Labels: 3W0-614-511.clb
       Part No SW: 3W0 614 511 H    HW: 3W0 614 511 H
       Component: ESP 8.1 4WD     H01 0650
       Coding: 0002311
       VCID: 34677DF453C5CFE645-8060
       Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
       Component: 74 Kessy            6850
       Revision: 00H22072    Serial number: VWX3Z0I3875503
       Coding: 0422125
       VCID: 2A5B638C81018916EF-807E
    00955 - Key 1
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Fault Frequency: 0
                        Reset counter: 168
                        Date: 2017.07.22
                        Time: 09:18:30
       Part No: 3W0 959 759 E
       Component:    CM Seat Pass.    0023
       Coding: 0000003
       VCID: 4B9506082E3BB01E34-801E
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3W0 035 007 P
       Component:    ZAB COCKPIT      2270
       Coding: 0451237
       VCID: 39794CC073A7328E96-5124
    Address 08: Auto HVAC        Labels: 3W7-907-040.clb
       Part No: 3W7 907 040
       Component: Climatronic BY615   2026
       Coding: 0000111
       VCID: 75E180F0183F96EEB2-8020
    Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
       Part No SW: 3D0 937 049 M    HW: 3D0 937 049 M
       Component: J519                6500
       Revision: -4004---    Serial number: --------------
       Coding: 40020000AB2A11000000000000000000
    Address 11: Engine II        Labels: None
       Coding: 0001075
       VCID: 71E9B4E06B57BACE6E-5140
    Address 15: Airbags        Labels: None
       Part No SW: 3W8 909 601     HW: 3W8 909 601
       Component: 1D Airbag 9.41  H14 0040
       Revision: 91H14004    Serial number: 0039L000F86J
       Coding: 0012612
       VCID: 7BF596C83E1BC09EC4-802E
       Subsystem 1 - Serial number: 63328RB404E2B6E2
       Subsystem 2 - Serial number: 63428RB404E2AD2B
       Subsystem 3 - Serial number: 63528RB404E2A55C
       Subsystem 4 - Serial number: 63628RB404E2AE1D
       Subsystem 5 - Serial number: 63700RB4
       Subsystem 6 - Serial number: 63800RB4
                        Fault Frequency: 7
                        Reset counter: 31
                        Mileage: 84630 km
                        Date: 2017.11.24
                        Time: 08:15:27
       Part No: 7L6 953 549 K
       Component: J527                3601
       Coding: 0000032
       VCID: 479D3A383253547E10-8012
    Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
       Part No SW: 3W0 920 844     HW: 3W0 920 844
       Component: J285 KOMBI-INST.    2226
       Revision: K0H10V42
       Coding: 0007402
       Shop #: WSC 29297 001 1048576
       VCID: 75E180F01C3F96EEB2-8020
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 3W0 920 844
       Component: J533  GW-K-CAN TP20 2226
       Coding: DFF8FF2E9F0E4701
       VCID: 70EFB1E4635DB3C661-8024
                        Fault Frequency: 50
                        Reset counter: 212
                        Mileage: 82794 km
                        Date: 2017.04.11
                        Time: 17:09:50
    Address 34: Level Control        Labels: None
       Part No: 3W8 907 553
       Component: LUFTFDR.-CDC- 3C3V0 7216
       Coding: 0005531
       VCID: 7F0D62D82A03DCBEE8-802A
       Part No: 3W0 959 760 E
       Component:    CM Seat Driver   0023
       Coding: 0000003
       VCID: 43852E28066B785ECC-8016
    Address 37: Navigation        Labels: None
       Part No: 3W0 919 887 P
       Component:    NAVIGATION       2222
       Coding: 0400000
       VCID: 54A71D74F305EFE665-8000
    Address 38: Roof Electronics        Labels: None
       Part No: 3W0 907 135 F
       Component: Dachmodul           0802
       Coding: 0006589
       VCID: 39794CC074A7328E96-806C
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 H
       Component: 1P HSG              0200
       Coding: 0000040
       VCID: 356140F05FBFD6EE72-4AE8
       Subsystem 1 - Part No: 3W8 959 701 J
       Component: Tuersteuergeraet FS 1106
       Subsystem 2 - Part No: 3W8 959 702 J
       Component: Tuersteuergeraet BF 1106
       Subsystem 3 - Part No: 3W8 959 703 D
       Component: Tuersteuergeraet HL 0703
       Subsystem 4 - Part No: 3W8 959 704 D
       Component: Tuersteuergeraet HR 0703
       Subsystem 5 - Component:    HDSG   No Answer
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    6 Faults Found:
    00316 - Bulbs for Rear Illumination
    01816 - Exterior Door Handle Switch in Drivers Door (F272)
    00935 - Electric Window Motor; Rear Right (V27)
    Address 47: Sound System        Labels: None
       Part No: 3W8 035 465
       Component: 08K-AUDIOVERST      4000
       VCID: 79F98CC03427F28ED6-802C
    Address 53: Parking Brake        Labels: 3W0-907-801.clb
       Part No SW: 3W0 907 801 E    HW: 3W0 907 801 E
       Component: EPB  BC7H0270   HC7 0270
       Coding: 0022413
       VCID: 387F49C448AD2B8669-5140
    Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
       Part No: 1C0 959 733 H
       Component: Heckspoiler         0002
       VCID: 306F71E4F0DDF3C621-519A
    Address 57: TV Tuner        Labels: None
       Part No SW: 3D0 919 148     HW: 3D0 919 148
       Component: TV-Tuner            0160
       Revision: R0H16000    Serial number: 91100500622101
       Coding: 0000003
       VCID: 67DDDAB85293747E30-8032
    03214 - Video Signal Y+
                        Fault Status: 00101010
                        Reset counter: 40
    03215 - Video Signal C+
                        Reset counter: 40
    03228 - Video Signal Y-
                        Reset counter: 40
    03229 - Video Signal C-
                        Reset counter: 40
    Address 65: Tire Pressure        Labels: None
       Part No SW: 3W7 907 273 A    HW: 3W7 907 273 A
       Component: J0502 RDK           0004
       Revision: 0004 004    Serial number: 00000700006859
       Coding: 3501E052A5F9A5A5F9A7DA00A7DA00
       VCID: 3E735FDC6D8915B6A3-806A
    Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
       Part No: 3W2 955 023 G
       Component: Wischermodul       9328
       Shop #: WSC 00000 725 65552
       VCID: 3B7556C87E9B009E84-806E
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 D
       Component: Batteriemanagement  2800
       VCID: 24478DB4E3255F66D5-8070
    Address 75: Telematics        Labels: None
       Part No: 3W0 907 722 E
       Component:       TRACKER VTTS  0043
       VCID: 3A7B53CC76A139969F-5058
       Part No SW: 3W0 919 283 D    HW: 3W0 919 283 D
       Component: J446  ST Parkhilfe  0094
       Revision: 11H04001    Serial number: 90030920802081
       Coding: 0101006
    Address 77: Telephone        Labels: None
       Part No SW: 3W0 035 385 AT    HW: 3W0 035 385 AT
       Component: rSAP Bentley        0264
       Revision: 00008000    Serial number: 30900000140307
       Coding: 0031000
       VCID: 071DFA3872D3947ED0-8052
    End-------------------------(Elapsed Time: 07:06)--------------------------
    Address 01: DTCs cleared
    Address 02: DTCs cleared
    Chassis Type: 3W (6N0)
    Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 34 36 37 38 46 47
              53 54 57 65 68 6C 71 76 77
    54-Rear Spoiler -- Status: OK 0000
    68-Wiper Electr. -- Status: OK 0000
    6C-Back-up Cam. -- Status: Cannot be reached 1100
    71-Battery Charger -- Status: OK 0000
       Coding: 0001075
    Readiness: 1110 1001
       Coding: 0000111
       VCID: 74E7BDF414458FE685-5124
       Coding: 0002311
       Coding: 0422125
       Coding: 0000003
       Coding: 0451237
       VCID: 39794CC073A7328E96-5140
       Coding: 0000111
       Coding: 0001075
       Coding: 0012612
       Coding: 0000032
       Revision: K0H10V42
       Coding: 0007402
                        Reset counter: 249
                        Mileage: 84854 km
                        Date: 2018.01.11
                        Time: 16:30:32
       Coding: 0005531
       Coding: 0000003
       Coding: 0400000
       Coding: 0006589
       Coding: 0000040
       Subsystem 5 - Part No: 3W0 909 610 F
       Component: 14 HDSG             1809
       Coding: 0022413
       Coding: 0000003
    Address 6C: Back-up Cam.
       Coding: 0101006
       Coding: 0031000
    End-------------------------(Elapsed Time: 04:45)--------------------------
  7. Likes Uwe liked this post
    Is this scan altered........?
    Coding: 0001075
    xxxxxxxxxxxxxxxxxxxxxxxxxxx <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< where is message?
    Dec 2015
    South Wales, UK
    Hi Jack,
    I haven't altered it!!? Well not deliberately at least
    Just looked at the log as well and it's missing there as well so not a copy and paste error.
    Cheers, Paul.
  10. #8
    Dec 2015
    South Wales, UK
    Disconnected battery to see if camera might wake up. Hasn't helped. ��
    Scan afterwards, then cleared faults, then steering angle sensor set.
    Cleared faults. Engine message is there. Not sure what happened there. perhaps it was me on the new tablet!??
    So all ok except missing camera.
    Cheers.
    Friday,12,January,2018,16:28:20:65184
    VIN: SCBCG43W6AC064272   License Plate: TIM REBOOT
       Coding: 0001075
    006436 - Controller Pin Coding
                   P1924 - 008 - Implausible Signal - Intermittent
                        Raw, Form. N/A: 000 000 000
                        Temperature: 4.0C
                        Temperature: 6.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 11.430 V
       Coding: 0000111
       Coding: 0002311
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0023
                        Hex Value: 0x0186
                        Hex Value: 0x0001
       Coding: 0422125
       Coding: 0000003
       Coding: 0451237
    8 Faults Found:
    00823 - Line-Output; Front Left
    00859 - Line-Output; Front Right
    00385 - Positive Output Audio Channel for Speech/Telephone
    00386 - Negative Output Audio Channel for Speech/Telephone
    00387 - Plus Output Audio Channel for Navigation Announcements
    00388 - Negative Output Audio Channel for Navigation Messages
    00856 - Radio Antenna
                007 - Short to Ground
       Coding: 0000111
       Coding: 0001075
       Coding: 0012612
       Coding: 0000032
       Revision: K0H10V42
       Coding: 0007402
                        Reset counter: 249
                        Mileage: 84854 km
                        Date: 2018.01.11
                        Time: 16:30:32
       Coding: 0005531
                013 - Check DTC Memory
       Coding: 0000003
       Coding: 0400000
       Coding: 0006589
       Coding: 0000040
       VCID: 356140F05FBFD6EE72-4B00
       Coding: 0022413
       VCID: 306F71E4F0DDF3C621-517C
       Coding: 0000003
       Coding: 0101006
       Coding: 0031000
    End-------------------------(Elapsed Time: 04:54)--------------------------
    Address 17: DTCs cleared
    Address 03: DTCs cleared
    Address 05: DTCs cleared
    Address 06: DTCs cleared
    Address 07: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 11: DTCs cleared
    Address 15: DTCs cleared
    Address 16: DTCs cleared
    Address 19: DTCs cleared
    Address 34: DTCs cleared
    Address 36: DTCs cleared
    Address 37: DTCs cleared
    Address 38: DTCs cleared
    Address 46: DTCs cleared
    Address 47: DTCs cleared
    Address 53: DTCs cleared
    Address 54: DTCs cleared
    Address 57: DTCs cleared
    Address 65: DTCs cleared
    Address 68: DTCs cleared
    Address 71: DTCs cleared
    Address 76: DTCs cleared
    Address 77: DTCs cleared
       Coding: 0001075
    Readiness: 1110 1101
       Coding: 0000111
       Coding: 0002311
       Coding: 0422125
       Coding: 0000003
       Coding: 0451237
       Coding: 0000111
       Coding: 0001075
       Coding: 0012612
       Coding: 0000032
       Revision: K0H10V42
       Coding: 0007402
                        Reset counter: 249
                        Mileage: 84854 km
                        Date: 2018.01.12
                        Time: 16:31:43
       Coding: 0005531
       Coding: 0000003
       Coding: 0400000
    No Faults Found
       Coding: 0006589
       Coding: 0000040
       Coding: 0022413
       Coding: 0000003
       Coding: 0101006
       Coding: 0031000
    End-------------------------(Elapsed Time: 06:07)--------------------------
    Control Module Part Number: 3W0 614 511 H    HW: 3W0 614 511 H
      Component and/or Version: ESP 8.1 4WD     H01 0650
               Software Coding: 0002311
                Work Shop Code: WSC 00083 790 00000
    Control Module Part Number: 3W8 907 553
      Component and/or Version: LUFTFDR.-CDC- 3C3V0 7216
               Software Coding: 0005531
    Fault Codes have been Erased
       Coding: 0001075
       Coding: 0001075
       Coding: 0000111
       Coding: 0002311
