Hello retrofit has done everything seems fine and working well ( immo,odometer and compenent protection removed) but these units ( instruments / rvc ) has some fault codes is there any way to fix them.
And is there any way to change vc skin to new ones ( big gauge on middle ) and anyway to see laptimer.
Wednesday,27,December,2017,15:41:16:02955
VCDS Version: 17.12.0.1 HEX-NET CB: 0.4411.4
Data version: 20171213 DS285.1
VIN: WAUZZZ8V0GA03xxxx License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
6C A9 BB BC
VIN: WAUZZZ8V0GA03xxxx Mileage: 4905km-3047miles
Address 01: Engine (J623-CJXF) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 0A1D00122466010B3004
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0208V0906259A 001005
ROD: EV_ECM20TFS0205G0906259E.rod
VCID: 3E30DFAEA17C3EDAFDE-806A
Readiness: 1010 0001
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4912
Revision: 06253104 Serial number: TFK01506300855
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 53E69E1A3AFEC3B2220-8006
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61925000000728
Coding: 32F16BA254232A70037C070541C8694CD62A54C0E08296F7184150F48608
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 7AB813BEFDD4D2FA816-802E
Revision: 00021000 Serial number: 0373586315
Coding: 030C0C
VCID: 3A38D3BEBD5412FAC16-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000695967
Coding: 03000014000000011000000000001100
VCID: 3326FE9A9A3EE3B2020-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 47980CB7000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061519604496
Coding: 04151C46C24106FD03844004B31C07A80800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 095A7C72A832C96298C-805C
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150707 042 0580
Serial number: 150711040607
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 24083279
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 04 05 2015 00001296
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY15167185H
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000063138071
Sun Roof:
Subsystem 6 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000FJQYM00000
Coding: 901E00
526359 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 156
Mileage: 4905 km
Date: 2017.12.27
Time: 14:56:21
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39231519400771
Coding: 0000150011
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_EPHVA14AU3700000 002024
ROD: EV_EPHVA14AU3700000_002_VW27.rod
VCID: 3C34D5A6B7602CCAD3A-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 N HW: 5Q0 907 567 N
Component: ACC3 H10 0400
Serial number: 30061503030354
Coding: 003E1301FE0309
ASAM Dataset: EV_ACCBoschMQB 001024
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 46C0B74EF9AC661AB5E-8012
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 130715025
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
VCID: 43C6AE5ACA9E5332920-8016
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 012 0361
Serial number: 003M2R0Y5VYT
Coding: 98CCC000000000005C540000004800000065
VCID: 4BD6867AE2CE9B726A0-801E
Subsystem 1 - Part No SW: ----------- HW: 480 001 507 15
Serial number: 3576700000065BF0851-
Subsystem 2 - Part No SW: ----------- HW: 480 001 807 15
Serial number: 35867000000F3948851$
Subsystem 3 - Part No SW: ----------- HW: 480 401 507 15
Serial number: 3516502B71C52F433133
Subsystem 4 - Part No SW: ----------- HW: 480 401 607 15
Serial number: 3526502C91B7E8E2A2B
Subsystem 5 - Part No SW: ----------- HW: 480 401 706 15
Serial number: 3556502C71B5A872705F
Part No SW: 8V0 953 521 FD HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 10071504221129
Coding: E418
ROD: EV_SMLSKLOMQB_011_AU37.rod
VCID: 014A645290028122C0C-8054
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 HW: 8V0 920 790
Component: FBenRDW H13 0044
Coding: 00AD0A10BF8000081681AE001100000000000000
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_DashBoardFPKAU37X 001023
ROD: EV_DashBoardFPKAU37X.rod
VCID: 79BA0CB2F8D2D9E288C-802C
U1014 00 [009] - -
[ECU incorrectly coded]
Reset counter: 156
Mileage: 4905 km
Date: 2017.12.27
Time: 15:22:47
9582600 - Switch for Instrument Cluster
B1893 13 [009] - Open Circuit
Reset counter: 156
Mileage: 4905 km
Date: 2017.12.27
Time: 15:22:47
16777090 - Databus
[AGA_01 communication error can_error_timeout]
Reset counter: 156
Mileage: 4905 km
Date: 2017.12.27
Time: 15:22:49
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1224
Revision: -------- Serial number: 0003764574
Coding: 030100043F085A005B0002789C0B00000001010000000000000000000000
ROD: EV_GatewLear_013_VW48.rod
VCID: 75A20082D4CABD82EC4-8020
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 03 06 2016 F0009030
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185703001507121039
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Serial number: HA1-00027.05.15
Coding: 0001
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000174934008
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3424FD869F30E48A1BA-8060
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 040715BG311549
Coding: 001C1A204000040000001003
VCID: 41CAA452D082412280C-8014
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8103
VCID: 373ECA8A8E460F923E8-8062
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 270615BFR06939
Coding: 001C12204C00040000001003
VCID: 40CCA156DB88482A8F2-8014
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 01A200002B200200
Shop #: WSC 19021 003 1048576
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FCEA2AAA67637D2F68-806A
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Part No SW: 8V0 035 840 C HW: 8V0 035 840 B
Component: MU-S--ER 042 0461
Serial number: A3E01407150608
Coding: 01730300FF0A000011110001000A00002F0002240100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE_VW37.rod
VCID: 3522C082944AFD822C4-8060
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30C9CP
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: C1000009051500010199
B201A 00 [009] - -
Reset counter: 156
Mileage: 4905 km
Date: 2017.12.27
Time: 14:57:12
Voltage terminal 30: 11.9 V
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: -----------
Component: RVC Compact --- 0231
Coding: 02730101A2002001000040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 393ACCB2B85219E2C8C-806C
10489856 - No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Reset counter: 156
Mileage: 4905 km
Date: 2017.12.27
Time: 15:08:38
passive
13705478 - Databus
[message Parkhilfe_01 not received]
Reset counter: 156
Mileage: 4905 km
Date: 2017.12.27
Time: 15:08:39
passive
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 150630201898
VCID: 7DB218A2ECFAE5C2A44-8028
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 020715BG20098C
Coding: 000C12204000040000001002
Component: TSG HBFS 020 0041
Serial number: 020715BG20111C
End----------(Elapsed Time: 01:50, VBatt start/end: 12.1V/12.1V)-----------
