Results 1 to 2 of 2
Thread: 2010 A6 Rear View Camera not showing in reverse
    Dec 2017
    Hello all,
    I installed a rear view camera in my 2010 Audi A6 I used the directions posted by iaflyer sometime ago. The module shows the camera is there, but nothing shows in reverse. I travel alot for but will be home for extended period and would to try and wrap this project up. Attached my scan from today.
    Chassis Type: FB-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 4C 4F 52 53 55 56
    5F 62 6C 72
    VIN: WAUFGAFB1AN039914 Mileage: 118690km-73750miles
    Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
    Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0035
    Revision: LB100029 Serial number: 2900L09A288125
    Coding: 000303
    Shop #: WSC 02391 823 56573
    VCID: 392C2521C9572EAF5DF-806C
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0125
    Serial number: 00000000002790759676
    Part No SW: 4E0 035 664 A HW: 4E0 035 664 A
    Component: H-BN-NA H45 0042
    Revision: -------- Serial number: 488J$097520218
    Coding: 010200000002E1EC41000304EF6300030000
    VCID: 221EE24D44C14D776C5-8076
    Subsystem 1 - Part No: 8R0 060 884 F
    Component: NAR 2009/2010 5304
    Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Serial number: 9356KP091109104
    Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F1 919 611 T
    Component: Bedienteil MM H01 0060
    Serial number: 00000001435751
    Subsystem 4 - Part No: 8R0 906 961 A
    Component: CD-Database 1293
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 4F0 910 441 D HW: 4L0 907 441 B
    Component: J772__Rearview 0030
    Revision: --H03--- Serial number: 525PA8-J9422SS
    Coding: 1000304
    Shop #: WSC 02145 785 00200
    VCID: 211CED414DC7566F75F-8074
    After some more reading it appears that I need to go to Address 5F, byte 07-bit 1, to turn the camera function on in the MMI. However when I try to do this with VCDS I get an error message that the coding is out of range.
    Any help would be great thanks
    Oct 2017
    Northwest UK
    Hi
    Please can you post a full autoscan.
    Secondly, out of range error usually refers to a module not having the right/applicable software allowing execution. This can usually be rectified in 2 ways: 1. A software update is available for that module. You can check this on erwin or ask your dealer. 2. You'll need to upgrade the module to a later version.
  3. Likes Uwe liked this post
