Results 1 to 5 of 5
Thread: Hex-V2 adaptation error.
    Dec 2017
    Hi i got a Hex-V2 for Christmas, I had some registration issues and Uwe got that straighten out and i'm so happy for that. I started messing around with my new VCDS this morning ran a full scan and had no issues there. I wanted to check my glow plug adaptation as i'm getting a very short glow time even at 0 degrees i go into engine hit 10 for adaptation and enter group 12 as that should be glow plugs and i get error. So i started to scroll up and down and i only get channel one and one other channel. If i go into measuring blocks i can get things like engine temp, idle speed and all the info i want. I do have an aftermarket radio installed and i am using a can-bus radio harness this was the only code found in the full scan. Am i doing something wrong or is my radio harness screwing me i no longer have the stock radio it burned out and unplugging the aftermarket head unit makes no difference.
    We'll need a full Auto-Scan to be able to help you - without knowing what car you have and what modules are fitted it's not possible to answer your question properly.
  3. Likes Uwe, Eric liked this post
    Dec 2017
    Thanks i hope i am posting this right.
    Tuesday,26,December,2017,10:53:26:23744
    VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4409.4
    VIN: WVWSP61J13W253098   License Plate:
    Mileage: 210930km-131065mi   Repair Order: john tdi scan 2
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: WVWSP61J13W253098   Mileage: 210930km-131065miles
    Address 01: Engine        Labels: 038-906-012-AGR.clb
       Part No: 038 906 012 GN
       Component: 1,9l R4 EDC G000SG  4308
       Coding: 00002
       Shop #: WSC 01317
       VCID: 629D54709D5A7D172C5-4B1E
       WVWSP61J13W253098     VWZ7Z0B6047882
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 L
       Component: ABS FRONT MK60      0101
       Coding: 0004097
       Shop #: WSC 01317 785 00200
       VCID: 3333E1347720A49F973-5184
       Part No: 1C0 909 605 F
       Component: 03 AIRBAG VW61 0202 0001
       Coding: 12339
       Shop #: WSC 01266
       VCID: 270B0564B6F8D83F3BB-513C
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
                29-10 - Short to Ground - Intermittent
                32-10 - Resistance Too High - Intermittent
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 A
       Component: Lenkradelektronik   0004
       Coding: 00118
       Shop #: WSC 01317
       VCID: 2F3BED449E08807FF3B-5216
       Part No: 1J0 920 906 L
       Component: KOMBI+WEGFAHRSP VDO V11
       Coding: 07232
       VCID: 313FEB3C883C968FE5F-513C
    01304 - Radio
                49-00 - No Communications
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 01317
       VCID: 70B92E3843B6DF87AA1-513C
    01304 - Radio
       Part No: 1C0 959 799 C
       Component: 8A Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 01317
       VCID: 372BD524665848BFABB-4B1E
       Component: 8A Tőrsteuer.FS KLO 0004
       Component: 8A Tőrsteuer.BF KLO 0004
       Component: 8A Tőrsteuer.HL KLO 0004
       Component: 8A Tőrsteuer.HR KLO 0004
    01141 - Luggage Compartment Unlocking Switch (E165)
    00912 - Window Regulator Switch; Front Left (E40)
    00943 - Heated Exterior Mirror; Driver Side (Z4)
                35-10 -  -  - Intermittent
    End----------(Elapsed Time: 04:57, VBatt start/end: 14.0V/14.3V)-----------
    Try a Login with 12233 before going to the Adaptation function.
  6. Likes Eric liked this post
    Dec 2017
    That did the trick thank you so much for the amazing customer service.
  8. Likes Uwe liked this post
