Results 11 to 20 of 24
Thread: 2018 Audi RS3 Sportback (DAZA Engine)
    Jun 2017
    You can try this until there is an update.
    Copy the redirect file to \Labels\User
    I would very much like to know, if maybe Byte 8 Bit 1 or Bit 2 could be Exhaust flap control unit(s).
    Explanation about Exhaust flap control unit, is in SSP607 and SSP661.
    There is no exhaust flap data if you search for "3816" ?
    @NEtech
    There is another new thing with the Facelift. After a cold-start there is a yellow message "Engine rpm only up to 5500 rpm" (bad translated from german) which is a hint that either the rpm is really limited to 5500 or it's a recommendation as long as the engine is cold.
    No single bit or channel points to this warning message as other people already asked how it could be deactivated
    Could it be the case that some bits in the ECU are responsible for this?
  2. #12
    @NEtech
    The B7 RS4 had a similar message which WAS accompanied by a rev limiter at 7000rpm (normal rev limit was 8250rpm) - IIRC it was hard coded into the engine ECU and could only be changed by a "chip tune", some tuners reduced it to 4000rpm on request - sorry Jack!
  3. #13
    I don't know, probably something internally in one/some of the controllers.
    Have you tested what these Adaptations do ?
    Engine:
    IDE04617-Protective function
    Instrument:
    ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0
  4. #14
    Jun 2017
    Engine:
    Instrument:
    Regarding instrument cluster: I think this whole block only deals with outside temperature warning.
    Regarding engine: Interesting, my adpmap with Release 17.8.1 does not have this channel. I only did the Auto-Scan with the newest beta. I'll have a look...
  5. #15
    Jun 2017
    ;SW:8V0-907-404-E   HW:07K-907-309-E ---  Engine
    ;Component:R5 2.5l TFSI  H22 0003, Coding:12250032242601033600
    ;EV_ECM25TFS0118V0907404E,001003,EV_ECM25TFS0118V0907404E.rod
    ;Saturday,13,January,2018,18:22:31:22578
    ;VCDS Version: Beta 17.12.0 (x64)  Data version: 20171213 DS285.1
    ;VCID: 3B22C691E3E023F98A90-806E
    IDE01945-Engine run-in oil pressure,not active ,1
    IDE02332-Deactivate production mode,00 00 00 ,3
    IDE04158-Activation of start-stop function,active ,1
    IDE06726-Timing deviation after chain replacement: intake bank 1,1.68 ,2
    IDE06728-Timing deviation after chain replacement: exhaust bank 1,0.00 ,2
    IDE06730-Timing deviation after other repairs: intake bank 1,0.00 ,2
    IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 ,2
    IDE06734-Timing deviation: current value intake bank 1,0.00 ,2
    IDE06736-Timing deviation: current value exhaust bank 1,0.00 ,2
    IDE06738-Chain elongation: no. of valid initial values: intake bank 1,2 ,1
    IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,2 ,1
    IDE06742-Chain elongation: initial values valid: intake bank 1,not active ,1
    IDE06744-Chain elongation: initial values valid: exhaust bank 1,not active ,1
    IDE07855-Deactivation of warm travel request,active ,1
    IDE10261-MAS10172-Operating mode selec.-DI operation,not activated ,4
    IDE10261-MAS10174-Operating mode selec.-CNG operation,not activated ,4
    IDE10261-Operating mode selec.-,not activated ,4
    Elapsed Time: 00:04
    Don't ask me why "IDE07855-Deactivation of warm travel request,active" didn't come to my attention. In german it is "IDE07855-Deaktivierung der Warmfahraufforderung,aktiv".
    But this is paradox as "the deactivation is active"....I'll try this tomorrow morning as my car is not cold at the moment
  6. #16
    Jun 2017
    Ok this channel has nothing to do with this yellow hint 5500 rpm thing...
  7. #17
    Dec 2016
    NL
    Are you sure? ‘Warmfahren’ is a really normal term (literal translation ‘driving it warm’) in german and dutch for the warming up phase in which the engine isn’t at operating temperature yet.
    Aufforderung roughly translates to notice or info.
  8. Likes Uwe liked this post
  9. #18
    Jun 2017
    Quote Originally Posted by MasterTommy View Post
    Thanks for explaning my native language.
    Well, as I said it sounds quite paradox as "The deactivation is active" by factory. This should mean that there is no warning. But there is. This 5500 rpm thing.
    Pic: https://cimg4.ibsrv.net/gimg/www.aud...de5cabec74.png
    (I have it in the Virtual Cockpit)
  10. #19
    Dec 2016
    NL
    Well sorry for missing your locale in your profile.
    If its active from the factory, change it to not active, and vice versa. Reset instument panel when applying coding.
    If it doesnt respond, try going through any available settings in the infotainment. Those tend to override any adaptation changes.
  11. #20
    Jun 2017
    I already did change it to "not active" without effect, but didn't restart the unit, I'll try that again.
